View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Can't get into REVERSE HELPP!!
- Cheapest place to Buy NGK wires/plugs?
- engine block thread size?
- My intro and My Irish White EM1 (project)
- 2000 si piston rings
- 200 si piston rings
- need help fixing dents on my fenders
- Advice on locating a B18c B18c5 motor dealer.
- Mushy clutch
- AP1 cluster in 99-00 ek
- Front bumper
- ECU wiring project gone bad?
- b18c1 ek swap mount?
- CODE 9 DRIVING ME CRAZY!!!
- My RHD 96 hatch
- oxygen sensor differences by year?
- wont stay running
- Valve Keeper Install/Removal
- B20b no oil to front cam...
- What sensors are a MUST?
- noise at startup
- South African Hondas...
- 96 - 99/00 front end conversion
- rear drum brake to disc brake help plz
- Newby needs headlight help
- 16x7 205/50/r16 too big for 2000 civic coupe?
- b18b1 wont start after rebuild.
- interior pics??
- What WHP am I looking with these mods?
- d15b vtec OBDII into non-vtec OBDII civic using p2p ecu
- motor mount question.
- tranny seal leak causing my clutch to slip
- header
- NO VTEC jdm motor jdm ecu look
- B18B FPR VS. B16A FPR
- Fried Climate control/G751 location?
- Tein Coilover collars broke
- ECU MYSTERY!!!
- Causes for injectors not spraying?
- ek a/c problem. compressor wont come on.
- 97 dx electrical problems.
- cranshaft pulley bolt unbelievably hard to get off.
- exhaut question
- Is 15x7 et +38 too wide for front on my EG hatch?
- 93 Honda Civic Emissions Failure
- suspension torque specs
- ECU pins
- First Car
- are the rear drum brakes supposed to drag slightly?
- ek3 & ek5
- Radiator Fan Problem
- H22 swap question
- skunk2 pro 3 cam advance and retard
- any shops? out in the lOs Angeles area?
- Another D16Z6 VTEC question - wiring
- P2J-J11 and 3 stage vtec
- a/c in 00 civic with gsr swap...HELP!!!
- heater goes in and out when on
- Fuel pump not priming.
- Does anyone have experience with AEM CAM gears?
- New swap, car won't start
- Rear defrost issue
- Overheating problem, over flow empty
- gear problems
- 1997 Honda Civic EX EK B18A1 Q's
- EG 5 Speed Conversion Question
- no fuel pressure
- RUNNING B16 AS LS VTEC ?
- Orange hose connected to fuel pump.
- Back In The Day Circa 99 Mugen EG6
- b18c1 into 97 ek
- Alternator problem ?????????
- What is the order to remove/assemble a D16's head bolts??? Nothing in FAQ
- EK hatch latch problem???
- need help both doors stuck
- RHD and LHD (not the type of thread you think)
- newbie....
- iac valve questions
- Sideskirt painting conflictions
- ITR Front Swaybar - Worth The Money?
- shake on take off
- Blox lower control arm bushing
- Ignition Rotor Stuck?
- Air conditioning
- d15b timing..
- 94 Civic Clutch Issue
- 97 HB - Window off track
- does v tec work if knock sensor dont work
- four door exhaust on coupe length
- 99 honda civic ex with jdm d15b swap
- wiring harness help
- valve to piston clearance question.
- rear sway bar
- P2T ECU to run GSR
- Goin from obd2a to obd2b
- OBD2 B16A2 in EG injectors not firing
- New to imports
- LCA bolt? 10x80?
- DSM 450s without resistor box? No tranny ground?
- dc2 front sway bar on eg hatch with ex lower control arms???
- thinking of running acetone if my car dont pass emissions
- Searching for hydro to cable conversion kit, need heeelp !!!
- will eg suspension parts work on ek
- S2k harness needed
- Car doesn't start.. After a whole night of perfect driving.
- 99 SI Instrument Cluster lighting
- Wheel websites? (sorry if this has been covered a million times)
- ECU help, p72 identification
- HELP! Intake Made Loud Noise At 7000RPM
- A/C Swap Setup *** Plz Help
- bought a shell! build questions
- blowin ecu fuses???
- 92-95 Civic Vtec Wiring Trouble
- 99.9% done, except for 2 problems...
- What is this sensor on brakes
- CKP Sensor CEL CODE 4!! PLEASE HELP! PLEASEE
- Where should I buy a CAT for my 95 EX?
- real type r?
- Coilovers or Lowering Springs help me decide?
- Wobbly shifter on my 98 EK Hatch
- so i pulled my b20vtc to go lsvtc
- Need Help swapped a d16y8 on 96 honda del sol (stock d16y7)
- "DEL SOL TRANSTOP PROBLEM GEARS BROKE GOT NEW 1'S BUT NOW DONT KNO HOW 2 RESET"
- i need some help with my brakes
- A/C Idle Bounce + Stops Getting Cold, Bogging/Hesitation
- H22 axles pop out
- need bushing type thing for shifter???
- tinted my tailights (pic inside)
- 94 del dol stripped bolt issue/clutch swap
- Cruising to East Coast Honda Meet
- rear turn signal went out
- Throttle body size
- What APC coilovers on a civic look like
- honda civic
- UPDATE***more info on possible hg problem-Need Help!!
- THOSE WHO HAVE INSTALLED EXTENDED WHEEL STUDS HELP!
- stock muffler + 2.5 custom piping + high flow cat = rasp?
- Quick question...What color does transmission fluid burn?
- Just picked up a em1!!!
- How to connect AIT
- Ek with gsr blue smoke high rpms
- 1994 Civic Sedan original sales brochure
- DIY: JDM Auto Climate Control on USDM Civic
- New Member, Need Some Help, New To The Honda Seen. Possibly Blown Head Gasket.
- Car continuously overheats, keep adding water! Help?
- 95 CIVIC WITH B16 SWAP HELP
- bad rear toe on passenger side
- Del Sol Owners/Club Members
- possible to put vtec on non vtec D16?
- Brake question//??
- brake pad questions!!!!!?????
- Quick question about Fuction&Form Type 1 coilover adjustment
- d15b s300 help
- How to tell if my b series tranny is ls or b16
- b16a Wont start
- Motor change what's best?
- D16Z6 MANUAL LONGBLOCK IN AUTO VEHICLE
- B18C1 on EG, CEL confusion
- Where can i order input shaft bearing (ISB)?
- Putting Vtec on stock B20...
- Y7 Block/Y8 head swap. Mini me or Frankenstein?
- Blower motor wont go off after key is pulled out, defrost light wont go off nor vent
- b series swap question; wiring
- Need help: 93 vx won't start
- Timing Belt Cover
- I have a clutch problem... PLEASE HELP
- 1999 Civic LX D16Y7 bone stock cold start issues
- need opinions thinkin bout tradeing cars
- Resistor box question to wiring harness!!!!! Need help please
- DoEz ANy1 knOw
- EK with banded steelies!!
- non vtec to vtec ek question
- Missing Engine ground
- 92-00 Civic Mirror Compatibility
- Honda wiring questions.
- 95 Civic Ex B18b Swap...Running Hot
- 94 civic
- Coolant problem.
- B18c type r with b16 exhaust manifold!!!!
- Exhaust pipe Help
- help! eg fog light wire fried up need help!!
- When signaling, steering wheel vibrates
- Camshaft Duration Measuring Doubts
- ACT or Exedy??
- aftermarket motor mounts
- one piece headers or two piece??
- civic o2 sensor
- LS trans...?
- How to drain coolant...
- Can Anyone Identify This Head?
- water cover metal to metal.. no gasket?
- '98 Honda Civic, need help troubleshooting
- where is the best place to buy Distributors
- Need some info on suspension conversion on a 96 Ek Hatch
- Good place for cheap wheel bearings?
- 92 Civic failed smog after timing adjustment
- evap wires not connected
- Car making rubbing noise after tranny install
- b16a2 build
- My compression results
- vtec is not working!!!
- once a headgasket goes, roughly how long till the engine will go?
- Question about radiator in 5th gen coupe
- What to replace before reinstalling head?
- d you need a resonator to pass pa inspection?
- b20z into eg help.
- LSD for auto tranny
- standard/auto d15 questions
- 94 coupe turbo help
- Sir double din into DX hatchback, help?
- D16Z6 Idle Surge at Start
- del sol exhaust question
- seal for the master brake cylinder
- H22a/f22 rear bracket question
- Help me choose a radiator.
- Fit? 4door DC sunroof fit a 2 door eg coupe?
- Skunk2 Upper Front and rear strut bars help
- ABS and Polyurethane lip difference
- help with etching on window
- HELP with exhaust and rear sway bar!
- AC compressor question
- New member from NYC
- Help! I need to solve an Erratic Idle with my 95 B18B1 swap into 98 Civic
- I need major help with my cooling system.
- rear disc conversion from eg to eg help
- Help me choose a camber kit!
- need help with kill switch
- AC Intermittent in 1997 Civic
- iacv 3 wire plug to 2 wire plug
- Smokey Z6
- D16y7 loom/harness ok to use on b18c1?
- universal oil drain plug problem. total newbie needs help
- Miracle Story!
- Major Oil Leak
- B18C vs B18/B20
- Dumb dome light question
- Do canadian EK's come with black interior???
- New civic, bad suspension, cold idle, and sticky gas pedal
- You're Gonna be SO JEALOUS 100% SURE OF IT!!!
- NEED help with mini me swap!!
- car is bogging when im flooring it
- Anyone with an NRG short hub on an EG
- EG w/ b18 injector help
- just blew a fuse
- Is my TPS done?
- p28 auto/manual identification
- i need help for a b18c1
- Honda Canada Parts search?
- a/c troubleshooting
- d16 compression?
