View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b16 into ek help
- Need Transmission Help
- 93 CIVIC 4DR WANT TO PUT A MOONROOF IN MY LX MAKE IT EX STATUS
- b18c mount help
- h22 axle problem
- swapping a b18c from my EH to my EG2,, couple questions
- Looking for 96-97 del sol VTEC (B16A2) ECU
- Help vibrating when turning right
- Gsr in 98 civic exhaust problem.
- 95 Del Sol, feels like running on 3 cylinders? (Video inside)
- Solid CEL and SRS light - wont start (B20 EX)
- GSR Leather seats in a EM1 Question:
- What's Up
- Need help repin odb2 to obd1
- What swaybars to use.......
- HELP!!! throttle issue!!!
- EK AC question??
- Civic with mini-me swap wont start
- swap help b16 into my ej1
- EJ1 rear Disk Conversion Questions
- sparked(while replacing ignition switch) acting weird
- Hi Flow cat
- ignition switch replacement ??how to???HELP PLSSS
- 9 months later and I burnt the same valve again
- manual steering rack into a ek
- jumper harness question
- Will a 4Dr floor harness work? Power door swap
- Wiring Harness woes....
- I've got a coolant problem with my em1
- NEED info or advice PLEASE!!!!!!
- Adding check engine light to race car.
- Anodized washers..where to get them??
- D16z6 build.
- Electrical prolems!!! My turn signals keep...
- I hate exhaust.
- Vaccum Leak Troubleshoot help?
- new shifter bushings, new problems
- drivers side mirror replacement
- ef and eg axels
- URGENT! B16A2 Compression: motor for sale
- turns over but wont start
- H brace or sway bar
- 93 del sol...bad idle???
- AC bracket torque spec???
- 99 em1 speed sensor issues?
- what is the stock piping size for eg?
- Fuel/Bogging/Misfire
- big puddle, limp mode
- Why is tranny fluid leaking out of my differential
- Quick question about Del Sol Seats
- NEED your help bogging problems
- 94 integra cluster in 95 hatch
- Help with partially stripped fuel line
- crank but won't turn over
- b16a2 fuel injectors
- 94 Hatch ls swap confusion
- 92 si sunroof problem
- Is there a fuel pump reset button on Civics?
- ls swap??? or mod z6?
- Fake ASR braces, be careful
- Trouble Getting USDM Blinker Sockets into JDM Headlights
- Are ABS calipers/knuckles different from non-ABS?
- Lowering The Car Which coilovers Best For 1999 HatchDX.
- D15b + y8 head mini me swap
- wideband
- b16 help - please someone help me with the solution
- swap finished... issue time
- anyone order em1 password jdm fenders ?
- ek gsr STARTS but then DIES
- Steering Problem
- No CEL with ignition on. Help!
- Is there a B Series Torque mount Bracket without ac?
- What were all the differences between trims from 96-2000 civics?
- CEL is on, weird idle
- I think you should know that ...
- Air Lift Air Suspension Kits for the Del Sol ???
- question???
- Megan Racing Rear Upper and Front Upper Brace
- Differences Between HONDATA S200 VS S300?
- How many OHM'S can a 96 civic fuel sender resist?
- Swapping B18c1 into 98 Civic EX 4door.
- mishimoto radiator question
- thinking about buying a obx intake manifold
- Si floor harness in a hatch?
- ECU Code 7? tried new TPS and service manual on adj.
- I need help with b16a3 into ek hatch
- Need help with b20b swap
- Doing a wire tuck, is this an ABS plug?
- Valve cover stud part #
- d16y8 trouble
- Vote:Turbo or All Motor? what you got???
- Fast Idle Valve Assembly
- Newbish transmission fluid change questions...
- REPLACE THE FUEL PUMP?
- Power steering for b18cR swap
- 95 Ej1 w/B18B1 Swap PS Help....
- My ek sounds different
- header B.A.R. question
- interior colors
- fog light question
- b16a2 into 93 civic
- Will Kosei K1 TS 14x6 clear DC2 calipers?
- 99 EM1....O2 sensor.
- CT: 2000 Ek w/Z6 help__?? -_-
- all motor project
- Still have code 10, eg z6
- Complicated EK electrical problem?
- rack and pinion boot repair
- exhuast question
- 98 Civic EX Overheating issue, changed radiator and thermotstat
- 98 civic lx wired idle and flashing lights
- Replacement of front wheel hub/bearing eg
- PLEASE SOMEONE HELP ME OUT HERE
- which b16?
- Trailing Arm Bushings on a eg
- Auto ECU Chipping question
- EK EX Knuckles compatible with DC Knuckles?
- Help with P28 replacement
- Blew my d16z6 block
- Steering wheel off center
- Electrical problem 97 hx
- 1992 Civic LX 4dr
- Couple of things I noticed that may need replacement
- Guess my poor HP! #2
- Well... what a $hitty weekend
- need help!!!
- Picked up a new swap?
- GSR swap in my future?
- My engine check light just turned on
- Civic Shifting issues
- What Intake?
- Problems with belt. need help
- help! rsx rear seat in ek hatch
- Vtec Not Working
- oil buring/smoke under acceleration
- Imported Civic 92 HB
- Welcome Sakura
- 2.5"-3" exhaust
- How to secure an armrest in an EK
- Swap JDM B18C-R into EG6 Si
- temp guage?
- Shift Linkage Question
- Wanna clear up issues for me?
- ls-vtec whp question
- What else do I need for a 96 HB Power Door Conversion?
- Bureau of Automotive Repair B16A2 EG8
- Lost kyokugen lugnut lock, wtf do i do?!
- new i need help...
- Hello-New here....
- CAMBER kit problem..
- My engine doesnt spark!
- Requesting ECM Mounting Picture (Please...)
- Driver side tire blew on my EM1
- Emission Test Question about switching a 96 ek to auto to manual In IL
- Hydro to cable trans...how hard will the swap be
- 96 civic hatch problems help please
- b20 vtec question
- d16z6 swap. Hesitation at 1500 rpm
- How can you tell how many miles a civic has on it?
- Auto to manual swap, to B-series
- My hatch, and what ive been doing lately
- Temp gauge runs hot but car makes no heat...... HELP
- Emissions people help!
- EG hatch temp gauge not working Car smoking
- Ls/Vtec
- Y8 Breaking up at low R's after swap
- big brake kit for del sol question??????
- What tranmission to use
- OBD2 B20z enigne, into OBD1 93 Eg
- When to do Timing belt on a 98 civic ?
- blox sway bar install
- Lookin for a D16y8 for a 95 eg.
- B16 axle help
- No VTEC on non VTEC engine
- Remove head?
- brake problem, no fluid to one caliber help!
- Manual Door to Power Door
- i've got some bearing questions?
- B18c1 GSR moroso oil pan
- Engine Reaches Tempeture, Misfires
- replaced tank, now im not getting fuel.
- a/c or no a/c on eg?
- Help with EG and rims
- FMU Help Pleaasee!!
- Help!D series mounts
- 59300 camshaft ignition timing help
- please help with mini me swap
- grinding noise when i turn left
- cant find any turbo manifold that work with a/c and p/s for my 2000 Si
- 92 hatch with hydro trans.. Cable trans going in motor mount help needed..
- d16z6 vs d15b intake manifold
- Front LCAs
- help tps broke. how to replace.
- 2000 EM1
- difference between d16y7 auto and manual?
- d16z6 with 250,000 miles, i want to make it feel like it had 100,000 miles
- unique 2000 si starting issue
- d16y8 into 92 vx won't start need emergency help
- Misfire Under Acceleration, Poor Acceleration
- which o2 sensor for b16a in civic>?
- B20b Auto to Manual Conversion Help
- Civic SE ?
- *EBP EM1 Picture Thread*
- 97 civic lx sedan pooper door lock drivers door
- car powers on
- CONVERSION AND A SWAP?
- dash harness plug/connector help
- how to mount jdm flare PICS PROVIDED
- Spoiler Fitment?
- d16y8 into eg distributor problem please help!!!
- 1992 Civic low beam light and buzzer problem pls help
- PLEASE Help mini me swap info
- electrical question
- I'm looking to convert my Honda dx door to power doors
- eg throttle cable????
- My 95 Ex Coupe Build Thread
- Short Ram Intakes
- another surging idle question
- D series mounts(help me)!!
- 99 civic wont crank, and fuel pump doesnt engage
- OBDIIB to OBDI Harness Required?
- Bumper Question.
- is my axel shot? what should i do please help!!!!!
- Fix it or get a new Car?
- Are 1992-2000 Civic REAR mounts the same??
- AC HELP!
- A few suspension questions.
- eg benen b-pillar in a 99 ek?!?!?
- please help a noob
- Really Odd Brake/Idle Problem
- Help identify to wires under dash in 97 hatch
- How to install a genuine Mugen Wing on a Del Sol ?
- Guess my HP!! I'm too poor to Dyno it:[ help me out
- Leaking on passenger side floor
- New B18b swap in my eg what to do??
- d16 timing belt on d15?
- not having credit sucks!! motor swap loan not approved..
- auto to manual B18C1 swap question
- B20/VTEC, what timing belt to use? Need quick answer
- Need Advise on Injector size ls-vtec??
- auto trans shifting @ 6500
- Can EK axles fit my EG?
- Engine Temp needle not working!
- ek gas tank
- Weather Stripping Question?
- Crap fuel economy
- 1997 Honda Civic EX Help
- Someone plz help with my koniY/GC!!
- !!!!!!!!! Stolen Hatch Omaha Area
- If your EG (or whatever) gets jacked, here's how to NOT get screwed by insurance...
