View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Idle @ 4000 rpm
- Thermal 3 4 sale or trade
- Fuel Line Question
- Perch cutting, need help!!
- Baretta 2 Way LCD Pager/ Car Alarm Keyless Entry
- My gf just bought a auto. green 93 del sol, help shed some light on it please.
- what is wrong with this thing??????
- b16 cel codes
- At what mileage did your D16 spin a bearing?
- saving more gas
- vavle springs
- ROCKINGHAM PARK, NH MEET PICS *56k, die*
- Need some guidance.........2000 Civic Si
- A/C Compressor
- rod knock....what do i replace?
- Will password JDM 3 point strut bars work with tein flex with edfc?
- 170mm Hks Hi Power Exhaust
- 1990 Integra GS brakes onto EK?
- Heater Fan & High Beam Intermittent Failure. Help!
- S-AFC Wiring diagram for a 92-95 GSR Civic
- question for people with jdm swaps
- heater cable replacement
- Other options than Greddy 31v intercooler kit?
- eBrake button
- quick question about buying an engine
- i just got my first car!!!
- Im bleedin.....
- How to Do 1993 Del Sol Si SOHC VTEC VALVE ADJUSTMENT????
- Is this smart
- My power door locks stopped working.
- traded hatch for ek with sohc turbo. good trade?
- d16a6 into a 97 civic
- ??????? STRUT BAR ???????
- how to tell cylinder is tdc??
- Exhaust for B16B
- Del Sol OEM Replacement Parts
- steering wheel question
- OEM fenders??
- Tranny problem need help guys thanks
- Rear disc brake swap questions for my eg hatch
- Attempted theft
- 97 Civic LX - pass side rear door electrical
- help on diy on doing engine swap in 95 civic
- CEL doesnt work?
- Purchasing a Civic - Need Advice
- Type R tranny on b18c1
- Search down.... Do D-Series Torque Mounts for EG Fit B Series
- B16A or B18C?
- some quick questions...
- How to tell if Speed Sensor is bad? Just bought car and odometer is flaking out...
- How long is the search gonna be disabled?
- will exhast mani from 99dx fit 97cx?
- Where is the turn signal relay located on a 98 civic?
- foam filter vs k&n
- suspension problems out of an h22 hatch
- 1993 Honda Del Sol AfterMarket Catback Exhaust, Front /Rear Lip Fitment???
- some questions after d16z6 swap
- Trade Carbon Hoods????
- idle problems when cold engine.....
- oil flood
- where can I buy a ram horn for my intake
- EG side peices
- Brakes dont work
- Electrical connector for front headlight problem
- car wont start?
- my car is running 2 slow
- Intercooler on an ek..?
- Chipping the d16 ecu
- Roll Cage for del Sol
- Air/Fuel Ratio Gauge install
- will a 93 civic dx 1.5 distributor fit a 93 1.6 vtec motor
- Head swap (upgrading to vtec)
- Cam question Mini-me
- suspension fit?
- turn signal woes!!! plz help
- 97ex intake fit on 92dx?
- Greddy turbo kit
- 2 questions...honda emblem and fuel cutoff switch
- Need torque specs for d15b7 bolts
- Would this be worth it?
- Car acting weird on freeway
- Where to find
- Problem with Knock sensor
- wat springs for 95 eg hatch?
- memory fab. S68 s58
- Project Update: Turbo Built B17 - fire'n her up this week!
- All Motor Now And Boost Later?
- Need help. Intake Air Temp sensor N/A on my new B18?
- how much does your 96+ civic wieght?
- wtf is up with my car??????????????
- Skunk2 throttle body? tps? throttle cable?
- computer code Po135 sensor heater need help
- replaced clutch master cylinder, now two weeks later clutch pedal feels different
- Search is down... Need some guidelines for Master Cyl. replacement on my '95 Coupe
- cheapest swap?
- I NEED YOUR MINI ME PICS!!!
- Civic Radio: Antitheft Code?
- KYB AGX, need help quickly, possibly got shipped the wrong shocks
- can i use D/F/H crank/engine pulley on a b16a2 ? ?
- Viion amber corners question
- eg hatch back seats
- TOW HOOKS
- header heat sheild?
- I read the how to's at the top but no pics(brake swap)
- need help deciding on what to do
- doing a DIY exhaust, how much piping do i need?
- b16a or b18c1
- Fluid Error
- 2000eksi
- ej1 turbo minime 9psi 14b
- help on installing a fuel pump on a EK!!! ASAP
- how do i change a fuel tank and lines from carb to a injection unit ?
- JDM b16a in EK4 (oil Seeping out between)
- Are The JDM 96-98 Civic Type R...........
- d16z6 spark plug wires on a d15b7?
- Removing Heat Sheild
- '99 EK engine swap ( B16A or B16C )
- How do you replace an antenna?
- Is there a 2.5" exhaust that is quiet?
- o2 sensor
- typer 4x114 brake conversion question? search is/was down
- For sale-Greddy Turbo Kit!
- Clutch Engaged/Start Sensor Problems?
- C pillar on EK
- o2 heater simulator ?? Can it be done ?
- Questions that need answers...
- 99-00 vertical doors
- Body Kits
- wtf???? pwo ecu problems
- 1992 hatch v-tech wiring
- Civic hatch
- handling. ek hatch vs ek coupe
- questions on how to setup a turbo for stock b16a
- where to get smsp header ???
- STOLEN CAR FROM COUNTY USC HOSPITAL: Charcoal EG Civic Hatch
- Pro-Eg or pro-ek?
- HELP ME PLEASE!!
- 99 civic hx to obd1
- what year is this b16a block?
- Carfax question.
- Alternator or battery problems, please help
- Which header/exhaust/intake?
- Folding mirrors from a DC2
- REMOVING 98 EK SRS STEERING WHEEL
- Using gsr lca's
- Plug n Play?
- single cam transmission swap ?s searched
- starter problem
- Looking for some pics
- Cam specs and tunning
- Need to add knock sensor
- track results of my GSR
- When do vtech come in
- 98 hatch d16y7 swap to a b18b1
- whats up with That???
- low dust performance brake pads
- swap question...
- D15Z1 intake manifold problem
- question about b16 power
- Popping hood
- It is safe to use Stock d16z6 cam in a D16y8?
- Check engine light after installing intake, searched forever and havent found any anwsers please hel
- Sway bar on ek rear disc conversion?
- broken ignition
- 95 Civic Ex Coupe
- motor swap... need some help
- B18C1 bog. Help.
- hesitation and vacuum leak 92 hatch
- B16A low compression
- dash lights don't work
- Car only starts in the shade.. need help!!!
- HELP!!!steering wheel hub problems
- Help me start my car having Ignition Problems! I DID USE ARCHIVES BUT NO HELP.
- car don't start: no spark, tach dosen't work and not the distributor
- onsoku coilovers any good?
- what bulbs are used for jdm headlights?
- Ground motor to chasis with Switch to Starter Battery Cable?
- ek hatchback what is the lightest you have got them down to
- USDM Si vs. CADM SiR Parts Compatibility
- H22 in civic
- oem fogs fit-eg>ek
- 92 jdm d15b
- would a d-serie timing tensioner fit on a b serie block ?
- cluster question: simply replacing one guage
- heater core CEL
- B16 in Sandrail? wire harness issue
- loser hp due to ks?
- window handel wont come off on ek
- JDM Paint codes
- LOW idle problem :: 2000 Civic LX
- vibration in steering wheel
- what is this?
- brake conversion
- little help
- Do i need these part for 5 lug onto 99-00 ek?
- to Micro polish or not to Micro polish?
- Can anyone in Socal help me out????
- steel braided fuel lines
- Which head studs?
- Are parts on 99-00 SI B16 and 93-97 Del Sol B16 interchangeable ?
- PCV Valve for B16 is .... $$ 21.00 !!!!!! WTF
- best honda engine??
- AF w/ B20 VTEC or EF, EG, EK W/ k24?????
- '00 SI B16 into '00 DX HB, Secondary O2 sensor wiring
- edelbrock turbo kit
- HOW to fix up an ek?
- rear disc trailing arm question
- How much is this del sol worth??
- Oil Relocation Opinions....
- Can't Figure out a noise in my transmission
- going for 100% stock and..
- OBD 1 -> OBD 2 jumper harness? MD emission crises!
- DOHC swap to a 97 civic vtec?
- Boston New Civic Ride and Drive Today???
- MPG on your swapped hatch
- what shoud i do
- headlight question
- DC SPORT civic si 99-01 header on gsr??????????
- EM1 owners
- integra door handles on a civic
- whats a good idle rpm for me
- need some info for motor
- B16 hatch....CEL flashes onces every 2 secs forever and it isn't IAT...Mainrelay..ABS??
- help, 2 weeks of searching and no luck
- Starting Trouble
- Does anyone have two MAP SENSORS?
- Need info
- EG Cluster w/ 140mph speedo?
- Good painters and junkyards in the Atlanta/Chattanooga area
- rear bracket (not mount) is it needed??
- civic vs. integra
- Wiring harness???
- Stock Brakes seem mushy/weak
- Will H.I.D's fit on my projector headlights?
- AEM cam gear, usable or not?
- Need some advice for my dead civic
- Idle hunt Q
- D16Z6 oil cooler?
- Suspension Question
- HELP! Sparkplug wire pops out! Oil on spark plug!
- Start up and die....
- i was followed in OXNARD CA
- Cant find header post
- Need quick torque spec misplaced my helms
- window visors?
- New Car Buying rims.
- Questions regarding clutch and d16y7 swap
- best way to clean my engine bay while motor is out?
- idle wierd CEL
- Are GSR gauge cluster needles interchangeable with 92-95 EX gauge clusters?
