View Full Version : Honda Civic / Del Sol (1992 - 2000)
- speedo
- B16 Code 20 Help
- EP3 Seats into a Del Sol
- weight diff between del sol & hatch
- just a quick ?
- new to fourm & hondas
- 1993 Civic DX wont start
- EG 92-95 civic Helms manual
- Anyone know a good place in the Bay Area to fix a mount?
- Steering Concern....?
- gas tank question ??????
- Boging Motor
- b18c1 in a 93 eg - idle high
- 3" kteller exhaust on EG hatch?
- Integra dash in EK
- looking for parts supplier using worldpac around boston
- INTEGRA DASH INTO 94 HATCH
- oil pressure gauge install
- install air fuel ratio gauge
- misfiring, stalling and a bright cel whats the problem?
- B18c A/C parts...
- fuel line problem!!!!!
- what kind of brake system does a 95 civic coupe have?
- has anyone switched to integra front calipers?
- what would you do if
- 205/50R/15
- transmission bearings
- Front disk Integra swap Issues
- Front license plate
- EX sway bar... Factory of Aftermarket?
- Where is the cheapest place I can get lowering springs/ coilovers for my 93 civic coupe?
- need help finding a part...
- How hard is it to swap a dashboard on a 93 civic coupe ex?
- what the heck is this noise...?
- Do i Need a complete Swap???
- difference in d16a and d16z6, which is better
- D16Z6 VS B18C1
- Distributer rotor screw help
- just a quick suspension question
- Modded Civic
- 99-00 OEM Foglight Question
- k20 type-s motor into em1 legal?
- 98-98 -2- 99-00 Tails
- 92-94 Honda Civic Hatch C-Pilar Bar install...Help
- two main relay part numbers, which do I want?
- Clunking/Popping noise
- grr... front end smacked the ground... speedbump!
- short canister exhaust?!?!
- Weird noise from under dash at certain RPM...
- turbo kit
- tires question
- WILL A GSR p72 Intake manifold BOLT ONTO MY 93 CIVIC EX D16Z6??
- has my radio crapped out ?
- b16a2 in 96 ek hatch
- 1997 Honda Civic alarm.. factory?
- Can a Full 96 Integra Suspension and Braking System Work On My 97 4dr Civic?
- When is trial period over?
- leak from vtec selenoid?
- B20 with GSR Head
- D16 Hydro/Cable Dilemma, Need help/suggestions...
- Trunk domelight
- eg wit stock B16
- del sol bumber (front)
- what rad hose to use with my set up (thanks)
- 93 civic 4dr with b18a want to keep power steering need help???
- Has anyone tried this Del Sol tutorial?
- i have a 93dx and want to put a d16z6 in it....
- considerign i cant start a new topic there, maybe someoen will move this.
- is this a good deal on a block???
- installed civic type r pistons in b18b motor
- working on obd2 to obd1 conversion on boosted y8, have some questions
- Just got done using Mothers Clay Bar
- b16 Injector wont close.and other things! pls help. Searched.
- camber question
- EG corner lights
- Getting a replacement key
- Ihelp me please!
- Parts needed for a Y8 intake mani on Y7 block/head?
- what clutchs fit?
- oem side marker.. what the diffence?
- fuel capacity
- d15b8 with a d16z6 head can it be done?
- idle fluctuation in low compression b16 is it natural
- C/F M3 mirrors
- My VTEC ran away! Need Help! [Pictures]
- JDM ITR Cluster In EK. NO ODOMETER...SEARCHED!!!!
- COLD START PROBLEM
- thread pitch
- Can I remove this?
- ANY 1 KNOW HOW TO TAKE OFF REAR QUARTER PANEL
- Uninstalling V-AFC
- EJ1 B18C1 Give me suggestions (I Read the JDM BIBLE DAILY)
- Scratches on my car
- cam and flywheel
- Needed: Alternator and Bracket for a 1993 Civic DX 1.5 Liter
- Oil leak need help asap gotta drive it 300 miles in 5 days
- A few B16A SiR II Questions
- heat=fluctuting idle?
- bump
- 92-95 eg coupe....
- 92-95 hatchback back wheel well rust
- this motor illegal?
- can i use this?
- timing belt?
- Ignition question...
- High RPM Hesitation in my 93 Civic EX..
- changed oil, only 2 litres came out?
- hey ROCHESTER people! Check this out!
- spark plug wires
- oil leaking into cyclinder
- B20 into a 97 Sedan
- 1994 honda civic hatchback CX
- Header intechangeability
- can i use\hack a d-serise dizzy on to a obd1 B16 ??
- valve lash specs d15b7
- Will rotors from a 96-98 HX fit on a 92-95 CX?
- For sale: 85 GT-S with 04' S2000-F22 engine
- Movement
- H22a or B18c in a EK
- Exhausts and Hatches... Got a question!
- who's using tien basic dampers?
- c-west front and rear bumpers vs stock bumpers with type r lips on civic ek
- Clutch Problems!! Plz Help
- Difference bewteen the map sensor being mounted firewall mounted or the throttle body?
- h22 in my eg!
- how to get hoses off the engine?
- Body Shops
- IACV 3wire to 2 wire
- I just bought a 93 civic... start problem
- d16y7 to d16y8 head swap....question about knock sensor
- Stuck Bold, new idea... JB WELD... good plan?
- konig rims help.. reply please
- Dash swap Question
- How To: Gas shock hood strut, junkyard setup
- 1st Annual Pacific Northwest Type-R's and Tight Cars BBQ
- car overheating
- 92 CIVIC HACH WITH A 95 INTEGRA DASH AND WIRING HELP
- would not having the gasket on the tps cause a vacume leak?
- Ep3 Seats in a 00 civic ex?
- installed my poor mans type r a week ago and no more oil.piston rings?smoking.
- Remote Unlock wont work
- D16 parts on D15b?
- What water temps do you guys run?
- Does ELD engine code give a CEL??
- slicks with no LSD... still able to pull good 60's?
- Apexi WS Exhaust Questions
- my doors wont lock!! help me
- Another Overheating Issue!!! Give me some insight
- all o2 sensors created equal?
- 94-01 Integra intake on 97 Civic
- i switched positive and negative on my battery, now my car won't start!
- all about civic egs
- HELP ! CANT EVEN REVERSE or GO UP HILLS !!!
- Honda Sport Springs
- help with b16..
- car shuts off when turning steering wheel
- What rack do I need?
- Dizzy rotor button
- Exhaust
- WA Drivers: I need a really good Driving Defense lawyer
- Did LX 4-Doors Come with Rear Disc?
- Parts for a tune up
- non power to power conversion?
- OBD1 PR3 ECU chipping any different than OBD1 P28/P30/P72 chipping?
- Solve my braking problem!!!!
- Do ecu's go bad, anyone had one? if so let me know
- Flowmaster vs. Greddy exhaust 98 civic
- b16 swap into 96 civic.......wiring help needed
- is anyone running omni suspension?
- Exhaust 98 civic 2d
- Can you fix the newer style main relay for the EG chassis?
- Eg6 with Ef8 dash & AP1 cauge cluster.
- Will manifold fit?
- Transmission problem
- rpm tachometer gauge
- Inline Pro turbo kit on B16a question?
- How hard is it to install speapers in a 93 civic coupe?
- HEY HEY I GOT A EJ (DERICE PROECT)
- 03 civic fuel filter on 93 civic...
- rubbing noise when backing up
- starting problem
- '99 civic dx auto gears?
- NEED HELP....Alternator went out..now codes are on and sensors are bad..b16A
- HOW DO YOU DO: PICS
- Thinking about throwing a d15b7 tranny onto my d16z6... benefits? downfalls?
- Good deal for EG?
- engine bogging out
- did i fubar my headlights?
- Question Hydrolock
- 2 simple questions about removing caliper
- Problem with emissions... :( :(
- '99 civic d16y8 ignition timing???
- ECU retarding timing?!?!?!?!?!?!?
- Hey guys im new and had a question (searched)
- pics of OEM B20 headgasket request!!
- New 2006 Civic More Powerful?
- Paint job in socal
- knock sensor cel...no vtec?
- Short Ram Intake vs Full Intake?
- DISC BRAKE CONVERSION
- Gas tank help
- which mud flaps, Ek sides on EG?
- reverting back to stock exhaust?
- Problems with headlights, extended them to hide in fender, now the dont work!
- 99-00 Front end Conversion
- Mirror Switch
- camber kit adjustments for daily driving.
- Engine Light Still... On?
- 93 Si hatchback, attempting to add keyless entry
- Sales Honda Civic White Face Gauge Cluster ! !
- ES torque mount inserts: sold individually???
- Prop Valve question; yes i searched.
- what is need to put vtec head on d16y7?
- teg dash in 99 civic
- VC stud broke. Help!
- need help please.
- possible engine rust?
- 1.5 power output???
- What Kit is This?
- looking for civic hatch
- My Exhaust Sux
- EBP-Si: Email me I want to buy your stuff
- vtec not engaging in my d16z6. No codes, need help.
- Cherry Bomb's Quiet ? ...
- gsr timing belt on b16
- switch kill
- knocking sounds when turning?
- quick fender question *SEARCHED*
- Few weird problems with the sol..
- si OR TYPE S?
- power steering pump brackets which are interchangeable
- valve lash adjustment
- power door lock problem - manual locking doesn't work
- What will fix this?
- I NEED A FREAKEN
- searched.. high flow cat
- help with Brightstar HID
- Orange plug behind gauge cluster
- need help taking apart 3 piece rims!!
- Can you compress hatch struts by hand? EG hatch
- swapping a b16a OBD0 into 93 Eg Hatch-VX, parts list?
- gathers...
- i want to know a typical setup of an civic EG hatchback.
- Looking for AC system for a 94 Civic DX
- Exhaust under gas tank question ?
- Auto-Manual conversion EK9 ( shift linkage )
- Valve tapping/ticking under acceleration after timing belt change, HELP!
- jdm obd1 gsr tb vs usdm obd1 gsr tb???
- MY NEW ek Ride
