View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Cat Convertor Help
- Cost of roll cages
- Is 2 1/4 to 3inch too big?
- need help to remove ebrake lines
- probs after install 16"
- built motor and forgot little thingy PLEASE HELP
- 95 cx won't start
- HELP! Rear view Mirror!!!
- Radiator fitment issues!!! Need help
- power locks doesnt' work after power windows/lock conversion
- code 43, fuel supply system, what does it mean?
- How often are you supposed to change your fluids?
- Omni Clutch Master review w/ pics
- b16 cel
- Swap A/C Help
- MY SPEEDOMETER IS NOT WORKING
- Ebrake Cable is locking rear drum - how do I get the drum cap off?
- Rear section fitment question
- Acceleration Problem
- wanted axle back apexi n1 for 2000 civic si
- Questions regarding replacing RF axle assembly in 95 Coupe EX - And part source?
- How do you shorten the brake booster pushrod length?
- AC COMPRESSOR
- I NEED MY A/C TO WORK
- axle question
- Stuttering on takeoff
- 99-00 si side skirts on an eg
- high beam dash light
- 6061 T-6 aluminum ebay
- HELP! How do you install FOGLIGHTS on 99-00 CIVICS?
- Does anyone know....
- HELP me unplug this bastard!!!
- help with mini-me swap (y8 head on D16y7)
- STR seals?
- CX Vs. DX in Weight!!!!!! It's me again!
- Chicago Service Request: Clutch Replacement
- Who Wants To See My Transmission?
- gsr swap in eg hatch
- How much Oil in a D15b7?
- OIL HELP! need answer ASAp!!!
- uberdata p2e
- MY RIDE
- removing si front bumper
- starter problem
- 93 Del Sol ABS brakes?
- Anyone have good luck with aftermarket headlights - fit, quality etc. 96-98 civic
- Rims/Rubber for my EG hatch
- recomended fuel for d16y8
- white smoke
- I think I may have the wrong ECU...
- CUSCO Cage for EK, Where to get?
- Posting in the Classifieds
- question on the JDMSHIT Spoon replica duckbill
- B16a / b18b wiring question.
- Quick and easy... what is gas tank capacity 92-95 civic HB's
- Aftermarket Radio Question
- 94 hatch tach 1200 rpm off??? wtf?
- Civic starting question
- I just did the DIY on baking headlight....
- <~~~OBD II 02 SENSOR~~~>
- B16 Turbo Questions
- will a 99 civic si clutch cylinder fit into my 95 ex?
- Getting Knocksensor code 23....any help please?
- Water leak
- Does anyone make LED tailights for a 93 hatch ??
- h22 into a 99 civic? can it be done??
- D16y7 Turbo, A FEW QUESTIONS!!!
- megan racing exhaust fitment???
- installing a new Rad, got some questions
- Trubo setup... am i missing anything?
- Hey I'm new to the import cars so I got ?s
- b16a swap shift linkage
- Car Lowered
- 95 coupe carpet question...
- spoon throttle body
- what mounts for a b18c in my 99 ek?
- 92 hatch eg e-brake ?????????
- Code 22 - VTEC Oil Pressure, & Can't rev past 6500RPM P72 OBD2 H22 in 96 EK
- My damn aftermarket headlight housing fogs up, help!
- Want EX tach on my DX
- low oil pressure!!?? HELP!!
- ctr steering wheel???
- O2 sensor or new engine?
- Dumb question yes I know.. but I can't think
- Going back to stock, now rough idle, throwing a cel, and no VTEC? HELP!
- toda spec c vs. jun type 3 HELP!!
- A/C Wont Shut Off..!!!
- will a b20 A/c Bracket have the clearnace on b18b in EG?
- B16 Question
- ...Questions, Need Help, Tire and Rim Sizing Opinions?
- going to a junkyard.. How to Identify 85-87 CRX aluminum drums?
- WHAT CENTER CONSOLE IS THIS?????
- sup peoples, new to honda-tech here, need some wisdom/advice
- p72-1 & p72-2???
- infamous exhaust rattle (oh yeah, i've searched)
- b16a on LS tranny???!
- All you smart honda guys PLEASE HELP HELP!!!
- Those with Depo Fogs...Relay got Wet (95 EX)
- Final Ration 4.7 clutch plate
- Need some info on trans mount bolts in my EG
- Spoon N1 Racing Silencer fitment...
- Help w/ Fuses
- its about to rain and my window is screwed... how can i fix this ???
- swap guide
- Order Of Spark Plug Wires To Distributor
- Finally I'M back!!! Need help overheating, What radiator to use????
- lighten my coupe
- WHAT PARTS ARE NEEDED TO INSTALL A B20 INTO A 95 EX COUPE
- Need help.. EDM EG Headlamp Wiring
- HELP! Throwing code 67!
- help with removing bolts!
- noob question (dont worry i searched)
- B16a2 Help
- Brake lines for Legend Calipers on EG?
- help with brakes
- one pice front end on 92-95
- Civic Balljoint Boot
- Idle Surging When A/C Is Turned On
- GM syncromesh part number(please help)
- problems running p30's
- dash light problem in hatch
- SI seats into ek?????
- 99 dash/interior in a 95?
- TPS Wiring help- y8 manifold
- No Heat
- torque converter 0-60 time difference
- What axles for B16A in a 94 VX with Y21 LSD tranny? Yes searched, too many different answers
- Spoon Sport Radiator Cap (DID SEARCH)
- d16y8 swap overheating. did search, need some input.
- what is the difference btw a 92-95 head SI and EX?
- WHAT MOTOR MOUNTS TO USE???? HELP ME ASAP
- squeeky brakes or bearing?
- Need Help, Just rebuilt trans, now cant get it in gear!!
- Tech Questions: Radio Code
- CEL: 9 CYP - cylinder sensor
- New EG hatch Member
- itr motor in vx
- failed smog and have a quick question now
- HMMMMM, just encountered a problem...
- o2 sensor
- Installing gauges...question about dash removal...
- Stolen Black SI in Alpharetta, Ga
- Difference between Si Lip and Type R Lip for 99-00 civic?
- My oil filter is stuck, need help
- integra ITR 5lug hubs in civic knuckles?
- 92 Hatch with LS/Vtec
- what would you pay for a 1997 civic type r?
- Can anyone tell me what color paint this is on this car and is it original?
- 96-00 JDM teg frount on 91-95 EG hatch
- Tranny problem...clutch?
- code 73 74 same time
- how to change shoes
- integ shell
- Honda Wheel Well Rust Solution
- some help with my gauge cluster anyone
- a/c compressor not turning on????
- obd identification from shock tower plugs...?
- throw out bearing sqealing
- Difference between EX / DX / Regular
- pulley question
- ?'s on b18a1 into EH2
- HEAD UNIT INSTALLATION PROBLEMS
- CV Joints? Axles?
- EG radiator for auto vs manual... whats the difference?
- Flapping under the hood (timing belt?) on 98 ex. Help!
- Need little help with iacv on poor mans r!!
- WTB: Looking for Del Sol or Civic HX 14 Rims.
- P2E & P2F Wiring harnesses?
- So I blew another single cam, in so-cal...
- wiper relay install
- A2 or H22
- accident.....how much will it cost?
- Y7 distributor work on a Y8???
- how many quarts?
- 92-95 civic hatch si mufflers and Del sol si mufflers
- Where to buy Brand new JDM honda parts?
- LEAKING Sol
- B16 question....
- What is the rice-world coming to?
- Problem: VAFC Install into 98 Civic EX.
- sponsors in the performance dep.
- Beefing up grounds. need locations, guages
- Should I trade my EG for a 94 integra RS?
- boosting a b18a1 motor?
- does anyone know where to get an obd2 p30?
- Car won't start... don't know what's going on... used to run fine
- FUCKING THIEVES IN CENTRAL JERSEY
- td04h oil line fitting size 'searched'
- 95 honda civic
- 94 integra dash conversion
- Does any1 have a 00civic coupe rear bumper?
- Stock 99-00 Si intake arm diameter?
- bulb size for 93 civic ex coupe trunk ?
- GSR Intake Manifold questions (Skunk2, Edelbrock?)
- Fuel Filter ?
- Apexi Power Intake owners, how to clean filter?
- Civic runs like crap after about 20min of driving. Why?
- Headstuds
- B16A (JDM) cams vs B18C (JDM GSR) cams
- anybody in here ride with...
- Tach cuts in and out..? wtf
- Need Help>>Sunroof Question
- Automatic and Manual P06 ECU's, differences???
- which exhaust gasket can i use?
- Turbo Si 00.. which ECU i need
- TRADE!!!!Tanabe Racing Medalion Exhaust 99-00 Civic SI or EX TRADE!!!!!!
- SEARCHED: 96-98 Headlight Fitment
- V-tech Help
- vibration at 3500 rpm, 1997 Civic HX
- b16'd EK exhaust options
- heat from ebrake handle area ?
- headlights quit working need help soon!
- Going from NO armrest to ITR armrest in a EG???
- Code 41 Primary Oxygen Sensor Heater Integra LS OBD2 Jumped to OBD1
- Si Engine question
- Melted my ground vtec solenoid wire??????????
- automatic to manuel
- JDM CTR honda H badge question
- B18b dizzy on b16a2?!?!
- 96 Ek, alternator wont charge...
- Weird clutch activity after highway driving!
- question about steering ratio on ek civic (searched)
- direct replacement muffler for a 98 lx?
- Rear Deck Rattles
- 92 civic
- Y7/Y8 block timing question
- remove intake manifold when changing gasket?
- Did a search anywhere to buy eg Kevlar spoon lip?
- Air Conditioner problem?
- GSR TB on y8 motor
- Alternator installation?
- Skunk 2 Pro Series Coilover Kit
- do i have a bad heater core or what? please help
- Sedan Headlight ?
- IS THIS CONSOLE A DIRECT PLUG AND PLAY FOR MY EKHATCH?
- fuel injectors
- silver sir spotted on el camino/millbrae
- Broke My s21 Tranny case!!!
- airbag question
- What shops are reputable for an engine installation in Vegas?
- Does the UK verion of the 1.8VTI supports ODB-II or prehaps ODB-I
- 5zigen exhaust
- Runnin realll rich
- DC2 suspension on a EG6?
- Extended wheel lugs
- throwing code 41 (o2 sensor heater) even when sensor unplugged. wtf?
- GSR shiftlinkage? in EK sorry if repeate...just a quick ???
- Wondering if this looks right.
- H22 into EK
- P1456 wtf code 90 sux
