- JDM parking pole install eg
- d15 with b16 tranny
- d15b oil filter?
- LS Swap into EK
- Have Question about Rear Bumper of '98 Civic Sedan
- WTB: 1996-1998 Civic Fender: driver's side
- weird missing problem!!
- Civic 96-98 HID Retrofits
- car is backfireing?
- help with d16z6 sputtering and stalling left and right
- A/C Help
- 1996 CIVIC SWAP HELP!!!!
- short shifter help
- VIN Number.....
- 1996 Del sol Si w/94 GSR swap Air conditioning question
- Exhaust Flange Question
- IAT code 10
- Auto to manual swap question
- How u get rid of the sqeeks in a del sol?
- 16y8 or b16a
- Painting Side Mirrors
- Anyone running LSD Motorsports Flywheel
- knocking sound.
- Breaking my back on my skunk2 coilovers on my 99 si...
- b18c1 gsr vs b18c5 type r
- LABOR FOR LSV!!
- EK lights
- i only posted here to sell stuff.....
- anyplac where i can get new door panels
- TYPE R CAMS CAMSHAFTS ITR B18C5 for my b18 LS is this a good setup?
- 92-95 civic exhaust
- Eg coupe w/ gsr motor
- itr header on b16a
- question...HID better on Projector ?? or STOC Headlight???
- EK 98 dx simple question
- OO CIVIC SI QUESTIONS
- 99-00 power window ect conversion Without floor harness..
- HELP ALTERNATOR BOLT BROKE!
- A couple assorted questions.
- paint settle time
- rod knock? vid w/ sound...
- ebay turbos kits???
- O2 code Problem 00 si
- Can someone please....
- Is it hard to install a a/c system in my 96 civic?
- replacing a hand break?
- what is this noise?!?!?!??!??!!?
- replacing mirror. and sunroof
- oil pan gasket 98 ex? HARD TO REPLACE?
- Perch Levels
- "spun bearing"? please help
- Brake clearance
- Does ls intake manifold bolt up to gsr head? Loss of power?
- EM1 rear lca question
- short shifter
- injectors
- looking for a good shop, can you help me anyone?
- need feedback...b16a2
- Does this need to be connected to something?
- 00 EK hatch rear brake noise issue
- NEED HELP ON MY STRUTS
- d16z6 compression?
- QUESTION PLEASE HELP. =]
- Swap question???
- Questions about the RSR exhaust?
- ???B-series vs K-series???
- 92 Civic LX swap
- ZENN lowering springs
- helms for b20 hatch..
- What front lip to buy for my 99 civic hb
- Anyone Got Any Pics on putting on JDM fog lights?
- wire tuck for an ek?
- Head Gasket Howto?
- exhaust question
- Doing an Automatic swap into a 1997 DelSol...What transmission?
- WHICH HEAD IS BETTER
- 6 puck clutch
- i have a question on front tie rods!
- Clutch fork ball socket
- IM BACK WOOOOOOOOOOOO .....goldfish....
- Air Idle Control Valve
- Ek with B18c wanting a/c...do i need the del sol tensionor?
- help with d16 to b18 dizzy wiring
- Engine Mount Bushing Removal
- Clutch problem
- please help !!!!! changing fuel injector
- Will EG Hatch Axleback Exhaust fit EK Hatch?
- Starter replacement time?
- what crank pulley same for d16y8
- 94 VTi
- LS BLOCK FOR A LSV!! Help!!!
- d16z6 Fuel Injectors VS d15b7 Injectors
- what size is the jdm ek rear emblem ?
- singing engine
- PWJDM/GReddy Cooling Plate, really works?
- ls longblock
- 5 Speed Conversion wiring- lil help please(don't say search!)
- 75k miles
- 2000 B18c5 into 96 dx wiring harness question
- how to adjust timing with out a timing light
- KMS Engine Development
- 99 Civic EX coupe ECU
- Ordering Brake Cables...
- yellow H3's on 95 oem fogs
- Swaping a Z6 into my 1996 Dx Hatch EK
- ITR MC In ek(abs)
- headlights: positive signal or grounded?
- 92-95 eg carbon fiber rear hatch... any one know where i can get one?
- Apex'i Neo vs apexi v-afc vtec controller
- nrg/personal set up help
- whats the difference between saturated and peak and hold injectors?
- S2000 cluster in Ek
- Lower rad supports
- P06 VTEC Conversion?
- Nos Fuel Pump
- wrecked crx picked up ek hatch what parts are transferable?
- how can I tell if an engine is built?
- Hatchback VX rims
- question for those who have done auto to manual on 92-95 civic
- please help me with transmission issue
- n00b question
- eg dash question
- window problem
- iat and turboed car!!!!!!!!!!
- High Volume oil pump
- Whats the best motor to put in a 98 civic
- d-series oil pump
- difference b/n 4 and 5 lugs
- is this a bracket? i need a part number!
- Exhaust manifold
- P28 on a non vtec?
- radiator support
- upgrading to BLOX IM on my 98 gsr coupe..do i need a throttle cable too?
- pass side del sol seat on driver side EK?
- cars cutting out
- B16A2 SiR II OBD2 vs. B16A2 SiR II
- Civic Gauge Cluster
- Help identify "clunk" noise up front
- Just finish Doing a D15B swap.. fuel pump not ON!!!
- steering wheel
- Axle seals are broken?
- tein basic vs. ksports vs. skunk2
- Slight hesitation when trying to take off
- Squealing from passenger side wheel/suspension area - need ideas for what to check
- Cold Starts?
- Picking up a 1992 VX
- How to take dash dezel off?
- suggestions on cheap axles for sohc ek hatchy?
- del sol rear wheel bearing
- OBD1 Wiring help!
- h22 vtec engagement at 5900rpm way to late?
- What would you rather buy...used koni sports for brand new kyb agx for a 95 civic coupe?
- skunk 2 stage 1 cam D16Y8
- some advice
- obd2b-obd2a question???? PLEASE HELP
- Ami resetting Ecu correctly? Help!
- Question on JDM aluminum A/C mount
- y7/y8 problem, NO VTAK! oil jet? =(
- Oh Crap! My vitara's wont are too small for my z6 :(
- Will a rack & pinion from a 95 Civic Coupe fit my 95 Del Sol
- ASR subframe brace
- opinion needed: OEM bumper w/ fog light or C-west front and rear bumper
- p28...auto or manual?
- will dc2 rack and pinion fit my 97 ek hatch...
- Cel help
- Fuel Problem???
- new ebay short ram
- sparco seat brackets?
- gsr swap
- 93 sol performence
- dc2 steering column question
- What the expletive is a cf whale penis intake? hahaha!
- 99-00 J's Racing front lip?
- swap problem
- 97 ek hatch, where to get tie rod ends??? not a power steering rack, where u buy ends?
- TICKING SOUNDS COMING FROM MY HEAD
- B20 into an EG using and obd1 LS distributor with a stock eg harness. anyone have the pinout
- Fried ECU!
- B18 block with B16 head: will it blow up?
- fucking thieves
- important information
- Need pinout for obd1 LS Distributor for obd1 stock eg harness with two connectors
- opinions on a d16z6 high comp build?
- Muffler SIZE question
- Best place to cut AEM CAI to convert to short ram intake
- VTEC Problem (HELP)..!!
- throttle body
- how to custom body kits
- i need a little help with vtec
- RS*R ExMag for the del Sol
- megan exhaust on a del sol
- Battery Ground corrosion
- Buzz sound from evo 2 exhaust
- how much oil in b20?
- octane booster?
- To all who say Eby shifters DONT snap!
- AEM V2 vs Regular Cold air intake for B18
- Help...plugs and hoses...swap related& pics included
- annoying problem!
- GSR brake/supension swap
- need to replace vtec solenoid gasket for b series
- Revised version of will this fit and operate
- Personal Hub
- Whining/Whistling From under the hood?!
- n00b question - SOHC vs. B16A2?!
- cat. converter
- integra clutch line work with civic with b18c?
- B18C-R ITR LOSING POWER IN EG6 SWAP
- 92-95 Civic Audio Console Installation Instructure
- +45mm offset fit under Del Sol
- 92 Civic CX HB with vtec swap
- check this out.....
- help me fix my ek please?
- jdm d15b vtec p08 rebuild questions
- B18C1 with B16 Head...
- Swap help
- ok, this is for you mugen guys!
- ALL HONDA MODELS BRAKE ROTOR SIZES
- heat question
- fuel pressure regulator
- AEM VS. injen cold air intake
- Automatic LS swap question
- Can you tell me if this engine has VTEC?
- Odd Coolant Leak-- Question??
- 1996 Civic DX transmission question
- J's racing intake duct on drivers side????
- header question
- LS engine in my 2000 ek hatch wiring harness question:
- 99-00 front end conversion
- GSR injectors????
- 93 hatch
- PIC REQUEST...
- Does any real "mirror" paint exist? chrome-like...
- help N E 1
- ctr or itr
- apparently these dont exist....any help?
- itr header, can i use this test pipe?..
- Maine State Inspection (battery relocation)
- clutch hardlines
- Del Sol Side markers
- Exhaust fitment question (pic intensive)
- map sensor....
- front end suspension parts?
- radiator question
- Which is better chassis? EG or EK when modded?
- can anyone help me out w/ suprcharger knowledge?
- Turbo for a JDM D15B.. will it fit?
- d15b1
- wiring from hellllll!!!!!!!!!!?!??!
- 2000 Civic Swap W/ 92-96 H22A1
