View Full Version : Honda Civic / Del Sol (1992 - 2000)
- side skirts
- insurance rate for a bad driver..
- b16a sir2 problems please help
- 92-95 Front Bumper Side Vents
- questions about gsr
- performance tester
- ACT vs EXEDY clutch
- EK hatch swap! Emissions???
- Looking to buy/price OBD1 B16a ecu....
- WRX??
- Just noticed this, auto tranny and 5spd tranny's use different O2 sensors? y?
- put in new turbo, now I'm ready for more time shaving.
- Rims
- what mounts are compatible with a b16 in 92-95 hatch
- D-Series guys....i need help
- really sloppy,loose steering?
- Any Washington State Auctions?
- GSR Dash Install...Anyone ever done a how-to?
- knocking noise on cold start
- Hatchback Overdose!!
- D15b
- how much do you think my car is worth?
- What to do with my EK?
- where to buy aem shortram for my 00 civic dx hb.
- overboard for my street car
- power streeing removel from eg question
- pix request and application advice on CTR rebar
- Trailing arm question for Gsr to civic rear brake converison
- anyone else hate the rota centercaps?
- 1/4 mile times-d16-I/H/E...?
- Wheel well molding
- mini me??
- weight
- sohc vtec in 96 hatch dx question
- I need a pw0 ecu in cali today. Where could I get one?
- Engine Swap
- HELP HELP HELP... Removing INDIGLO GUAGE COVERS OFF STOCK GUAGES>>HELP
- Suspension Techniques + Need reinforcement?
- CTR Door wiring.. help
- Engine Seized????
- need help on foglight harness (civic 95 4dr)
- Possible Busted O2 Sensor?
- coupe piping to a sedan
- Looking for machine shop IN SO cal
- what color is your clutch masters PP?
- question for NJ heads
- ATTN 92 -95 civic COUPEs
- odd d15 question...
- yo my shit just got distroyed
- Engine in hatch with a twist.......(Has anyone ever done this)
- Perodic non starting when hot - '92 Civic DX
- Denji Projectors
- Civic sputtering before 4 grand
- 95 del sol to 95 civic shift linkage
- front grill
- silencer exhaust in the civic
- autometer oil pressure guage noise
- timing belt question
- lettle burn out
- Best Bang 4 Buck Clutch Kit?
- Camber kit + Azenis = AHHHH
- SOHC Online
- white EG stolen in West LA, pls help
- Took body kit off, time for a paint job
- itr header bracket?
- best tranny
- 1998 Mini me conversion ecu questionS
- what do you guys do to prevent your coilovers from rusting
- 99-00ek drivers and passager fenders needed!!!!
- wheel off aligned?
- Sites that sell d16's?
- going to japan....what should i get?
- bought a ek si gauge cluster need some help
- roll cage
- Safety
- zeal function basics or b2's
- poll: zeal function basics or tein ss?
- Where did you guys get your zeal coilovers?
- tein flex, ss, or zeal b2?
- to all eg with d16z6 & tranny guys
- SRS Light?
- How long do stock springs last? Ride height for an EG hatch w/ or w/o modded susp?
- tps problem???
- Electric power steering
- crazy idle problem
- CHIPPED ECU?
- EG Civic and DC Integra Passenger Airbag same?
- shock replacement with aftermarket springs
- Ran at theTrack 2day. timeslips inside...
- Finally installed my B&M Short Shifter
- Check Engine light on in a 2000 Civic Hatchback DX
- tranny questions!!!
- post pics of black si's with rota c10's...
- oversteer?
- SAFC2 wiring help
- new times in the ej2 ;)........
- Ricer flyby's lol *vids*
- Neuspeed lowering springs!(searched...)
- CEL keeps coming on..
- Deciding wheather to go with a LS or B16??
- 99-00 front end conversion materials needed!
- GSR intake manifold question in EG
- ? about Si Motors
- AutoTransmission fluid change?
- Si vs DX
- Itr seats in Ek.
- >?? ON THE EG6 PUSH POCKET
- differences in suspension for various models
- fast blinkers
- Where to get stock or close to stock carpet for trunk?
- rsx seats fit in an eg?
- where to get a sunroof installed into a EG CX?
- d16 timing belt tensioning question.
- GSR Gas Tank in Civic?
- radio area dash section swapable?
- KYB AGX Struts
- Wiring the resistor box for an H22a Swap?
- civic Si gauge face....
- Red EG or Green?!@#?!?
- Anyone here have a Toda Flywheel?
- ek door locks
- Need Dimensions of Optional Audio in EG civic
- my lastest kill!!!
- EK 3 point strut bar
- d16z6 into 94 civic dx... starter wont crank.
- People with del sols seats in their coupe!!!!!
- Dizy from DX, working my B18B
- Brake conversion
- EK or EG..what do you prefer?
- d16z6 cam questions...
- Question regarding GSR tranny on my LS (EH2)
- Rota Slipstreams (black or gunmetal w/ polished lip)
- EK HATCH OR CRX???
- Keep it or not
- H22 in a Del Sol????
- z6 valve cover on a y8?
- ground control coilovers any bad experiences
- civic question
- lower control arm bushing
- ECU's in Hong Kong
- something i picked up today
- Spring or Font strut problems
- integra tires on 93 hatch?
- What offset on rims??
- High Flow Cat off of EBAY
- Stock Motor?
- RED CF FENDERS (fiberimages)
- Crower valve train for my LS, worth it?
- Put a new motor in my 97 LX (stock motor) won't start
- vtec oil pressure switch
- suspension set up ?
- what service manuel to buy 4 00 si
- Pics of my newly installed CF duckbill (JDMShit)
- d16z6 in a dx eg hatch
- RWD Turbo Delsol
- selling my eg
- Weird CEL issue?
- has anyone bought from www.racingworks.com
- 1/4 times are in!!!
- D16y8 turbo kit
- hazard lights on my eg
- ~~help~~coolant leak on d16
- Problems bad IACV could cause?
- wiring 1-wire o2 to 4-wire?
- Quickie: D16Y8 Camshaft in D16Z6 Head?
- New Shoes for the 4 door
- 92 automatic LX(4dr) radiator? stolen....
- NEED HELP FAST: Pulling engine, can't seperate tranny!
- How in the hell did I do this to my diff???
- Shocks for 02 Civic?
- Women's cleavage!!!!!!!!!!
- any good web sites?
- EG w/ GSR swap price
- sites to get b20 motor!!!!!!!
- Key Interlock Fix - Instead of leaving gear selector switch under console-
- d15b2 in civic lx
- What is the engine designation for the 96+ Civic HX?
- WTT hatch for del sol
- How do i wire in gauges.
- Spark Knock / high compression motors question...
- 1.7 crank
- JRSC from a 99-00 EX onto a 97 EX?
- To do or not to do...
- suckin down gas like a mustang
- quick question
- goin to track 2day, any last min tips!!!!!!1
- Custom intake Possible hp gain's?
- Quick Question - Please reply! EuroVTi and Exhaust.
- Some good layovers?
- Help on this cluster...
- is there a way to add a tach gauge cluster in a civic dx/cx?
- What should i get next?
- ctr engine swap!
- Turbo D16z6?
- EK gate
- greddy kit with AC and PS
- Who has a 96-00 civic with a turbo h22a?
- Top-Fuel Distributors in US?
- Suspension for my 96' civic
- pics of 96-98 jdm ctr lip
- 5speed rad in a auto
- engines?
- Can Honda of America get Japanese parts?
- type-r lip question
- tranny from a 92-95 civic work in a 2000??
- Does VTEC have a safe mode??
- 95 civic with b16a2 swap throttle cable help? hose
- DOES anybody knows WHAT KINDA of lips is this??
- Will 88 civic springs fit a 92 hatch?
- GC coils quick question
- cable reel
- just ran over a brick in the road! and messed up my rim, got a few Q's...
- Need Urgent Auto Tranny Help Please
- hey bauley civic i have a Question about you video?
- hey Bauleycivic i need some z6 info!
- Spark Plugs for d16z6?
- I need new engine what u recamend?
- Please Help!!!!! Need question answered Quick!!!!
- Can you remove paint from cf hood?
- hydraulic/cable transmission
- Clutch issues or something else?
- Mini-me problem - Why do I have to keep refilling coolant.....
- Help diagnose strange rattle from passenger side rear
- car bogs at high rpms full throttle HELP!!!!!!!!!!!!!!!!!!!!!
- ????? b20 already VTEC from factory???? look here
- D16Z6 questions
- My new Type R lip..
- how can i disable the Key interlock?
- 2001 civic question
- Si question...
- Looking for a good guide on opening up a SOHC tranny
- Drum question
- my eg lights... whats wrong...?
- Anybody else have door panel vibration noise??
- Anyone with a RsR with a bottle rack noise ?
- Kill Switch 95 civic
- shifter ?? b-series to d-series
- Interior Setup?
- does the type R LSD...
- 99 EK offset???
- Spoon carbon fiber spoiler
- Testing Waters: What cxb18c1 worth? (56k beware)
- MY NEW EG 20 hours in my hands
- Need help quick-Skunk2 manifold install on sohc vtec!!!
- z10 engineering front traction bar
- EH3 stock piping size
- My H22 del Sol
- exhaust leak.. help!
- SRR rear tie bar with ITR sway???
- yes or no?
