Crank pulley bolt is kicking my....
95 civic dx hatch with a jdm b20b, so here's what's up, I need to change my timing belt, it was rubbing against something and now it's all frayed. Upon further investigation, I found out the little key that holds the pulley to the crank is missing (disintegrated, pulled a sneaky on me, idk man!) so I can't use the crank pulley tool. I heated the bolt, half a can of pb blaster, impact gun that is over qualified to take the bolt off, and i did the screw driver in the flywheel and breaker bar trick.....no luck. I'm out of ideas, so now I turn to you guys, help me out!
Re: Crank pulley bolt is kicking my....
Blue point AT500A, it took off the bolt multiple times for my d15, and the b20 once when I first got the engine (timing belt, water pump, tensioner)
I just stuck a screwdriver in between the flywheel teeth and used the breaker bar to try to muscle it out, didn't work out, obvi. I'm letting some more pb blaster soak in right now untill i figure something else out
Why can't you use the tool??
I don't understand why you can't becuase the woodruff key isn't there. I had no problem using mine.
It's been known to take over 1100lbs of break away torque to get them off, or, breaker bar with 6-8 feet of a cheater pipe..
BUT, you'll need to use the crank pulley tool.
I fought mine for 2 days, and said **** it, and limped it to my friends shop.
the pulley spins freely, since there's no key in there, I'm like 98% sure it wouldn't work, plus i don't know anyone that has one and F**K waiting a week for it in the mail. The only way I'll be able to get it to the shop is if I get it towed, and that seems kinda silly, I'm sure I can get it off, I did it before.
It only won't work if you try to use the Honda hex tool that works by holding the crank pulley in place. Without the metal key, the pulley can turn independently of the crankshaft.
Do they make another tool that doesn't need the pulley? I doubt it, ugh, I'm so close to just drilling it out, worst case scenario I have to get a new crank? that's like a LAST LAST LAST ditch effort though, hahahaha.
I to have done it several times, got to my car and bam. Hit a freaking wall.
I wouldn't have it towed, unles you have access to a truck and trailor, if not that would just be expensive.
I was told to use this stuff called Areokroil. The shop I went to used it... It is a little on the expensive side though.
Yes soak with a lot of PB Blaster overnight. How long is your breaker bar? I needed to extend my 24" breaker bar with a 4' piece of galvanized pipe to get enough leverage to remove the bolt. You may need a 6' extension.
Homedepot, or something. Hopefully, you can buy it and just return it. We had to buy a
6' pipe for my friend's, and we were able to return it after using it.
true, i'm about to do that, i'm using a 18" breaker bar and a 2 floor bar for my floor jack and i just keep breaking screwdrivers. any tips for the screw driver half of it?
Good question. I haven't heard that it is a problem. But you could probably lower such risk by filling cylinder 1 with rope when the piston is positioned a little before TDC1. This way, the valves should be closed or nearly closed when force is applied. In addition, nylon rope is somewhat malleable, which should help to distribute the force over more surface than just the valves.
If your crank pulley is moving freely because the the woodruff key is missing, you may have a bigger problem after you are able to remove the pulley. Most of the time when the key is missing, it already have been worn down by the constant rotation of the crank against the pulley. This is evident by the rubbing and fraying of the timing belt. You may have a damaged keyway on the crank for the woodruff key.
Also, I had a similar problem on my son's car. He said the engine was making some strange noise while he was on the way to school. I found the crank pulley bolt was a little loose and it damaged the pulley, crank, and timing gear. The crank damage wasn't too severe since I was able to use new key with some modification. The crank bolt came off pretty easy but the timing gear was a pain.
Andddddd, the bolt rounded on me. So now way? Drill it out, replace the crank? It's a 2000 b20b, can I replace the crank from any b series engine? If so I might just pull one from the junk yard tonight.
i usually just drop the pan, wedge a piece of wood between the crank and the side of the block then go to town with a breaker bar.
Do you think there may be enough room to get a Bolt-Out socket over it?
That's great and all, BUT THE BOLT IS ROUNDED, it has no grip. Can I drill it out and not damage the threads of the crank? Or should I use a bolt extractor kit? I'm thinking of just saying F**K it and replacing the whole crank with a junkyard one, bad idea, i know, but i'm a broke college student.
