View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b20z ek swap issues w/ axles...
- Help, new swap but O2 code
- OEM 00 Si steering wheel
- v-tec in a d15b??
- Problem with LS swap in my 93 Si Hatch
- ex dash cluster in a dx?
- Help, Half stripped ignition coil screws
- H22 Into Eg Hatch, How Hard? New to Eggs
- quick ? about acuraautomotiveparts...
- price estimate for an EG, need a quick answer
- smog check
- b18a in to 96 civic
- good springs/shocks for 94 hatchback
- new gauges?
- help with diagram
- A/C Parts
- just a quick question.....
- 1991 Civic HB DX
- EJ Sites??
- ENGINE/IDLE PROBLEM
- SUPER ENGINE SWAP
- Pricing on a eg hatch, too high, what should I offer?
- Pics of the Eg and friends......
- WTB: Stock 2002 Civic EX Valve Cover
- titanium retainers
- Koni shocks knocking noise
- 02 sensor problems
- Need info on the d15b SOHC Vtec engine
- question about clutch assembling.
- PLZ post pics of your EG9 4dr civics??
- civic a/c
- how to install sir jdm cluster in 4 door civic ?
- Ideal ECU in b16a SirII
- '96 Civic coupe wiring
- For Shocks...Will rear LCA from 96-00 civic Fit 95 Civic Hatchback Dx??
- comptech 7lbs aluminum flywheel... first impressions
- headlight ?
- D16Y8 Vtech
- Sway Bar Q's
- installing coilovers
- DTC: po132 primary o2 high volts.... does anyone know why? anyone?
- 2000 Civic SI question, Please help!
- why dont Discovery channel have a HONDA build off?
- need a part for a 97 civic ex coupe
- anyhone got some black door panels you wanna sell?
- 1/4 times for jdm b18c-R in a 95 civic ex coupe
- Civic Intake and Exhaust
- question about 92-95 Si hatches. and factory options
- What Size Magnaflow muffler should i get?
- 98 spec itr b18c on a 94 eg coupe
- Heads Will Roll.... (venting)
- Changing to synthetic oil
- how to make home made shift light
- some help and some opinions please...
- roll cage in my del sol
- EP3 Seats in EG
- Honda Ex Break Questions..
- need to know an aproximate price
- air/fuel gauge installed, but it stops reading. bad o2 sensor?
- Brake light in cluster stays on faintly when parking brake is down
- "close" spring rates (searched)
- How much for my car??
- Energy suspension bushings for 94 LX w/ GSR suspension
- Which of the two Shells is Lighter: 94-01 integra or 99-00 civic ?
- only for competition purposes decal
- p0132 primary o2 high voltage.. why?! its new brand new
- Does this go here?
- 2000 Civic LX how to fix the air-condition?
- will this blow up my engine?
- Need 97-00 ex automatic opinions
- No Oil Light
- stock 92 hatchback rims would fit my 00 si?
- doing auto to manual swap tomorrow anything else i need to know
- What Should I Do To My 95 Civic Ex
- Civic Coupe '04.. few questions
- I'm The New Guy!
- cheap engine swap sites?
- How's your experience with WheelNext?
- Mileage out of BFG Drag Radials?
- HELP ME PICK MY CAR
- DIY HOW TO BOOST CARS!!!!!!!!!
- ls throttle body going onto a y8 mani...
- upgraded srs, is it safe
- anybody got pics of an eg hatch with full itr interior??
- Y8 AEM Cam Gear on Z6...
- GSR swap in... but codes 03/20... I checked all connections... all good.. now what???
- i never changed any engines?
- K24 / 20 Dyno chart Dynojet 5thgenjon car
- TOTALDJM.com
- ENJO?
- Quick questions about SI rear disk rotors...
- where can i buy mugen rnr center caps
- Help me decide
- 04 Civic EX, Exhaust bolt breakage. Need help.
- Omnipower Pre-load
- Another brake swap question
- J's Racing
- Just did a front brake conversion and now i got a question
- help! tps setting
- making a b18a1 with b16a1 head swap ! help
- Are there shops out there that can fix chipped glass?
- Sold my hatch today. Sad day for me (not tech related)
- where to tap for oil, turbo d15
- FUSE panel help!
- Cut teg springs + agx on eg coupe please help!!!
- A safe NOS shot for B16
- Honda Civic Recharge
- please help with wiring
- did the si.....
- wtb: 96-97 del sol front bumper
- car wouldn't start...why?
- I NEED HELP NOW!!!!! CAR WILL NOT START
- can someone run a car fax report
- HELP: DE-charged my air conditioning...?? 2000 Civic Si
- Need help on solving audio wire problem
- 10,000 RPM B16A
- need help: looking at itr cams
- Passenger vent blowing mist/condensation?
- EG, models & there diffeent sway bars
- fuel needle
- motor mount question please help
- clutch won't fully engage, help!
- help me plz
- For Honda owners
- Anyone Recognise This Climate Control Unit Ever Being In A EK Civic ?
- for those with tokicos illuminas...
- Mugen Headgasket in...quality?
- f22 in ej7
- got some gs-r blades and si rims for sale
- headlight problem need help!
- which wire to connect solenoid to Spoon???
- '93 ex hatch, tach cluster swap?
- Clutch? Motor? Rebuild?
- Will this manual tranny work
- need an ECU harness for an EG
- need pic of 99-00 si driverside main mount bracket
- help! - airbag serial # matching?? catch thieves??
- constant CEL on....grrrrr
- power window problem
- 3rd brake light
- B18c1 engine swap problem
- Spark plug gapping experiences?
- ::::code 21::::
- how to: removing a/c clutch on 96 civic dx (i searched)
- BAR...? how do i go through with making my z6 swap legal....?
- removed srs brain, can i just plug back in?
- My electrical system is all screwed up... Please help me out.
- Will GSR axles fit on a 99-00 Civic SI?
- Got a motor mount problem
- 95 civic...y8 bottom end, z6 head...help with my swap
- D series stock exhaust manifolds Interchangability
- Car dies when I step on the clutch...Help!!!!!! I'm out of Ideas
- where to buy a JDM civic hatch
- kyb agx settings
- Help quick----speedo problem.
- Greddy SP exhaust axleback what material???
- help with cable to hydro swap
- kteller setup question
- 94sisol
- Water temp readings
- Any help will be greatly appreciated!!! Cylinder head Question
- 99 ek sedan folding mirrors, power adjustment
- speedometer doesnt work
- cusco roll bar on 99 ex coupe
- engine noise at low rpm
- IAT CODE 10
- Lowered car and now....
- Drivers seat problem
- 6 speed
- What is best exhaust for my EG???????????????/
- headlight wiring
- purge cut solenoid valve, do i need it??
- im a beginner
- civic rails into integ seats?
- What should i offer?
- 140k Tune Up?
- Installing a 99 y8 IM onto a z6...things i need to know?
- Are the y8s and z6 intake manifold parts interchangeable?
- CEL Prob!!!
- temperature gauge
- best exhaust for turbo.. i have Apexi but want stock... what should i do ..
- WTB Old HKS Sport Exhaust for EG
- Lean Air Fuel Sensor
- Weak Driver Side engine mounts on 96-00 Civics?
- gauge, the temperature needle is stuck not goin up or down. help!!
- Squeeky Noise Coming From Wheel When Turning
- Bent Hood Hinges
- can I use a cx throwout bearing on a y8, and visa versa?
- ckf problem
- ES sport muffler where should i buy it at???
- What ECU is this? 37820 - p30 - 901
- GAUGE oil temp needle is not moving anymore. helpppp
- I have no clue what to look for in an Exhaust....
- What do you think about my GSR head????
- H22A EH2 clutch problems
- Coolant inside Interior?!
- Using a non-vtec dizzy on vtec engine?
- Anyone have a pic of...OEM JDM duckbill?
- 94 civic hb cx ticking/rattling
- will 99-00 si cat-back fit my 98 ex
- VSS help
- testing waters: 94 ex (low mileage)
- im going to swap my stock fuel pump out for a walbro 255 (need help)
- got fuel and sprak but engine still doesn't start up
- Do you think $8500 is a good deal for the following.....
- how to remove the power antenna in EG del sol?
- Mini Me help!
- Looking for Custom-Show car type Civics for TV Commercial July 15 & 16th In Los Angeles
- Lost Heat....
- PLEASE help, my h22 hatch only 15.2
- turbo boost gage
- Anyone in DFW get there hatch stolen lately?
- water temp gauge install on a D16Y8
- P0135 Error Code
- question on msd stuff
- CAN I DO THIS?
- My Wrecked Civic
- newbee with some1999 civic EX 2-door questions
- what muffler looks all most stock
- CEL 20 Do OBDII cars have an ELD?????
- Apex'i N1 cat back for a sol?
- Dyno time or wideband?
- 2001 D17 in a '94 Hatch?
- vtec engaugement
- problem adjusting timing...
- Speedometer/odometer don't work for first ten minutes, then begin working...
- b16a2 powered ek civic hatch
- B series Tranny Rebuild
- Wax/polish question
- any one has pix of an eg w/ jdm itr front coversion???
- Turbo Exhaust, 2000 civic si
- Clutch cover plate and rear engine stiffener are interchangeable on B-series?
- exhaust help
- Alignment Quick Questions in relation to handeling
- D series block building
- NEED HELP NO SPARK! 1996 Civic DX NO SPARK!
- itr or ctr brake booster
- 98 civic head gasket is bad
- my jdm eg6
- synthetic oil...
- is there anyone that has a engine fron jdm
- OMFG PLEASE HELP!!!! Lower Rear LCA - broken bolts and rusted into bushing!!
- How to tell your ECU Condition?
- need a car 92-95 civic(black or silver coupe) (any color si)
- dont you love waking up to see...
- want to see pic of del sol
- distributors from autozone??
- OBD Emissions call back
- TDC Problem
