View Full Version : Honda Civic / Del Sol (1992 - 2000)
- is this guy legit?
- oh damn, i think i'm F***ed
- My civic wont pass emissions
- do i have to mod if......
- D16 I/M Question
- STOCK FRONT BUMPER CUT MARKS!!...help
- EG6 SEAT RAILS
- D16z6 Engine Block
- bad vibration in steering wheel. need help.
- HELP!! b18b with tpye r trany into a 95 civic cx?
- POST UR 96-2000 BLACK CIVICS WITH WHITE RIMS
- ***FRONT END CONVERSION***
- EG6 Type-R PEDALS
- obd1 GSR into 94 hatch. KNOCK SENSOR? 2 other sensors unknown?
- Car wont crank
- new paint
- OBD0 B16 - What Rotor n Cap Do I Buy? TEG LS DOESNT FIT!!! STRANDED!
- hello
- D16A9 in the US???
- Exaust (D16Y7)
- The most newb question ever..
- Convert rear drums to disk - searched
- turbo oil lines...
- What was Honda thinking? (pics)
- my cars crapped up!!!!
- Checking out B18B
- hydrolocked? or flooded exhaust?
- tie rods?
- bucket seat screws and bolts?
- trans problem?
- 5 lug em1
- test pipe issue plz help
- How to depin?
- skunk 2 shocks?
- Del Sol side marker location
- JDM no Vtec Pressure Switch?
- firing order 1999 honda civic si
- what does GSR stand for
- will this b diffrent
- Honda Part Number
- Circuit 8 Center Caps
- Center Caps
- Where can I find...
- ls vtec bearings
- 23mm itr
- swap help
- Dizzy harness
- 95 civic auto to manual question.
- Help with my 99 civic ex
- neighbor blew my turbo
- MPH gauge going crazy..
- MPH gauge swinging up and down....
- Skunk2 Manifold
- Seized Drums on 93 DX
- Ac causing rough idle
- Doing my first Swap
- Weird shifting problems?
- Wrecked my car!! Need advice on how serious this is.
- SAFMS
- WTB Civic Shell -- - Need SHELL ASAP
- Do you use aftermarket pedals?
- bottom alternator bolt......
- need help with my hatch..
- where to get cheap mounts and axles for a GSR swap into a 1998 civic!
- How many quarts of motor oil for B16A 2nd gen
- cooling fan
- DA struts/springs on 95 civic...possible?
- Cluster problems while installing
- bent rim fix?
- new tranny making loud whinding noise??
- H series A/C bracket for SOHC A/C Compressor!?!
- obd2 harness with obd1 motor and disdributor, how to hardwire?
- WHat full synthetic oil do you use
- please help. ::p75 on 97ex harness, and engine question::
- clutch slave cylinder help
- exhaust - should i get a new one? + new pics of ride
- DIY ambers
- B16 ecu on single V?
- JDM Side Marker help!!!!
- what does a longblock mean??
- engine harness differences between auto and manual tranny D15 non vtec engine
- steering column ?
- new intake manifold gasket
- whats my ecu
- cv axles????
- How do I install this bolt (pics)
- ST sway bar
- Stupid header , help!.
- jdm eg foglights. i dont know shit about wiring stuff and i need help
- Wich HID for this car?
- ****help with a/c console controls*****
- Code 9 after swap,turbo,obdI conversion.
- Stock final drive on y8 tranny?
- new updated pics
- Cant get into gear!!
- 98 Ex Sedan powerlocks
- Car Feels Sluggish - New Brake Setup Sticking Maybe?
- Car is running too lean..HELP
- compression
- b16 help
- EG Fog Light Switch with a Defroster Harness attached HELP ON WIRE CODING!
- tinted taillights
- 99 civic lx vtec?
- fititng jackson racing thermostat ?
- dx cx si
- short ram intake or CAI
- ac has gone crazy HELP
- Y80 Problems
- A/C not working, Dont know why
- Civic ek Keyless entry problem
- IDLEING ISSUES
- help plz, B16b preparing, tuning and adding turbo
- temperature gauge not working
- supercharger question plase help!
- CHECK ENGINE LIGHT please help !!!!
- Wiring on VSS
- IACV & ECU RE-pin
- VTEC kickpoint
- Possible New Honda Owner
- wondering about pherable.net
- vtec button??
- b16a jdm swap into vx
- TRANNY PROBLEMS
- Ebay spoiler question
- Interior Swap, is it worth it!?
- 97 civic ferio
- changing throtle cable out on eg to a gsr one.
- gearbox oil
- DOHC Vtec
- would 91 crx springs shocks & struts fit 93 civic hatch si?
- Engine Build Help: A6 Block With Z6 Head Turbo
- need springs
- Smoking EG
- need help with a/c
- How do i turn off the Speed governor on a 1997 honda civic ex if there is one?
- H Brace??
- crazy suspension?
- ??? about the civic hatch vx....n...si
- ENDLINKS WONT FIT ON MY FUNCTION 7 LCAs!!!
- compression
- Throttle Cable Question
- aftermarket power windows?
- Need help
- help removing axle
- Question about replacing ECU/ECM (computer brain)...
- 92 hatch wheel bearing
- 2000 honda civic si tranny problem x2
- RSX rear seat on EG hatch?
- MINI-ME OR D16Y8??
- B16A2 81,5mm piston?
- ignitor or main relay??
- B16B redline...searched.
- how much whp do i need...
- KYB???? (need help)
- irratic Idle and bogging down, I think vacuum line issue
- Please help Knocking sound **VIDEO INSIDE**
- got code 1,41,43, what to do from here???????
- FINAL DRIVE KIT,B16A2.
- looking for Jdm parts!!!
- H22 ek9 swap problems!!! help
- cel code 45
- stroker kits??
- want to do a swap
- eg linkage???
- Anyone got an EG hatch they wanna sell?
- (17 x 7.5) Takata Green Volk Racing TE37 Wheels
- jdm rear fog light??????????
- Manual swap using auto ecu?
- flywheel question
- EK hatch Power Door Locks ?????
- REALLY Slow Starts, Misfiring Idle - Whats The Problem
- Where is the oil pressure sensor for d16?
- Buying a car with signs of rust?
- Sorry to post in here but emails not being responded
- mugen valve cover
- H&R sport OE, sport, limited, race
- Engine and Inner fender splash shield...important?
- Bumper pole install
- d13 to d15b swap
- Air conditioner Question
- Help With Swap..
- Holy crap, I am experiencing an ELECTRICAL NITEMARE
- JDM B16a Hatch - which axles?
- Second Gen b16aw/ lsd complete swap in a 94 eg hatch. What axles do i need? what kind of car?
- D16Y8 Intake Manifold On D16Y7 motor
- apexi Ws
- I need to make my exhaust shut up!!! too loud
- Vtech/Air fuel controller
- b18c into 1998 civic ex with a d16y8! what will i need to make a swap?
- help with my B16a2!!!
- No Fuel, No Spark
- Legit Hondata Gasket
- intake manifold for an ek4
- DIY: shift light
- Mudflap/ Mudguard question..
- 92 LX 4 door - 2003 D17 vtec
- can't get last nut off intake manifold
- 1994 civic vx beiing swapped with 01 gsr.
- Front bumper
- car security (kill switch)
- Someone help me w/ this ignition problem!!
- Problems Mini-Me swap, need serious Help. (Long read..)
- EG power door conversion
- Huge problem :( Can't replace rear engine mount due to Auto to Manual conversion
- Need a Bracket fast if anyone has one
- h22a civic ~ f22 a/c compressor bracket ~
- Driving EG 4 door with OEM lip onto ramps
- steps to put a teg dash in a 93 civic hatch? help me.
- obd2 to obd1 injector harness?
- part# for bumper clips
- installed ac and now car overheats
- Ac belt tension question
- How much for Timing belt and Water pump replacement?
- front end conversion
- some feedbacks for the noobie
- Still have blue smoke after $1100 worth of work
- Question - OEM Civic Si Fogs
- stock throttle body size? 2.5"? HELP!!!111
- vafc/ Is there is difference between gens.
- WERE IS THE CRANK SENSOR LOCATED IN A B16
- NEED HELP WITH B16
- 99 HATCH: how to remove front crossmember??
- idle problem...
- how much is a eg
- ZC ECU Compatibility ?
- How to fix a seized front license plate bolt on front bumper for 95 hatch--with pics--
- advantage/disavantage plug power steering rack??
- will this work...
- ??? tranny question???
- Sparco Fighter side mountable?
- Shifting is mushy??
- Del SOl cooling issue!!
- fan not working, checked usual stuff
- tps sensor question
- H22 into del sol questions...
- body parts
- harness question
- 2001 auto tranny in a 1998
- gear lude
- instructions of how to replace the dizzy rotor?
- Oil pan removal?
- eagle rods/ je pistons
- Need new brakes for my ek... any suggestions?
- New to Import Tuning World and has questions
- extremely frustrated ... vibration in steering wheel with proper alignment and wheels balanced
- Harmonic Balancer question
- Sidemarkers Leaking/Fogging up
- 1993 ex with a d16y8, and the stock 5sp tranny, reverse lights not coming on
- climate control not lighting up
- transmision
