View Full Version : Honda Civic / Del Sol (1992 - 2000)
- integra brakes on 00 civic
- D15Z1 o2 sensor?
- d16 to b swap
- my whip and spring info!
- 97 EK4DR !!
- 95 EX Runs like a lawnmower! help
- my speedo dont work
- VX vs DX Crankshaft Pulley
- 98 EJ8 idle drop with A/C turned on even at 1
- Will 99 Civic SI Cruise Actuator fit 96 EX?
- hondata questions PLEASE HELP!!!
- shifting issue, assistance appreciated!
- d15 all A/C components fits d16y7 civic 94 coupe...???
- door won't open on 1998 Honda Civic Cxi
- Dyno Runs. How much?
- need your help ASAP!!
- How much you guys think?
- Behind steering wheel slanted
- code #6 water temp. sensor
- 96-98 DX Auto Harness modification. STARTING SWAP TOMORROW!
- *sohc guru's needed d15b help *ek*
- Turning to Honda-Tech for help please!
- 95 civic ex sterio problems
- My new to me daily....
- del sol engine swap trouble
- AC issue
- Air Compressor Problem
- Windshield wiper witch broken
- motor revs slowly, timing is good and no CEL
- Another, How much is my Car Worth? Bar'd Eg SI
- Help with engine swap PLZ :)
- '92 VX starter not getting power!?
- JDMCARBOY lowering springs any good?
- Is del Sol Si same as VTEC?
- Separate Wire for Tach to work
- b16a1 head gasket set fits all b16a?
- vtec solenoid leak fix experience share
- How would you know if it's eg5 or eg6?
- EG fog lights
- Check Engine Light issues
- Help with codes 14, 65, and 22. PLEASE HELP
- Help my Del Sol :( Starting Problem
- Need to replace leaking transmission oil seal for driver-side axle
- Cluster Lights, Turn Signals, Radio On Same Circuit Normal?
- y8 boost project..
- Brake Booster Vaccum leak problem!! Need some help
- TN:93 civic hatch failed HC passed CO
- cutting the webbing out of the trunk
- d series build!!
- I need hellpp!!!
- rywire good or bad?
- D15b plug an play or ???
- New to the land of ek's.
- 92 2dr throttle trouble
- Help! Fuel pump not priming!
- head stud
- help with vtec decal placement
- coupe trunk light
- Del Sol onwers chime in and tell me what this is??
- TPS problem!
- Question On Installing Alarm In 96 Civic
- p0420
- 1 PSI Supercharger DIY
- D16Z6 Engine harness please help!!
- IF YOU BOUGHT AN ENERGY SUSPENSION Master Kit...
- d15b cam?
- removing bumper/rust repair
- RHD Conversion Help
- help i got no spark tried everything!!!!
- Modded Seat Rail Question
- Where can I get a flywheel cover?
- dc5 exhaust to fit ek hatch
- does integra dc post mount fit ek?
- left my hood up in the rain... is my ram intake dead?
- donor car
- B18C with P54 A/C bracket, which belt?
- electrical problem?
- rain got inside engine?
- mini me d15z1 vtec
- Thermoswitch or Fan Switch Wiring
- Should i buy a hatch?
- Clutch Master Cylinder
- need help guys b16a turbo vs ???
- P0108
- Engine gunk back up in the radiator helpp PLZZZ
- How To Change Shift Boot in 00 Coupe
- h22 in an eg civic?
- My New Forward Facing Divided Housing Turbo Manifold
- which lug nuts to use?
- Transmission rattling sound
- How much is to much for an EM1?
- input shaft bearing going out, how long can i wait
- random dead o2?
- civic 4/2 door headlights
- b16a idling problem into 95 civic Hatch
- B16A bad lma's, how soon should I replace them?
- Bumper Support kinda loose....
- washer pump failure
- MAP/TPS sensor ?
- Need Help with 96 del sol si !!!!
- Power Window Help
- ? for a friend auto-5spd eg
- 1993 del sol si, current setup, what upgrades to do?
- New Civic owner - just introducing myself
- Del Sol and Bluetooth: Built-in or External Mic?
- Which cluster would you prefer?
- HELLO world of HONDA
- kinda new to honda tech
- Can RSX clusters fit in eks?
- Hello. I'm new to Honda Tech
- Found a clean 95 Hatchback. Is it worth $3000?
- WEIRD PULLING/VIBRATION @ HIGH SPEEDS H22-T
- Cluster lights, wipers wont work at all! any suggestions?
- Intermittent hard steering problem
- B.A.R.'d question
- 95 eg with a Ls turbo question
- Civic runs rough
- 93 civic dash switch question
- Timing Marks and Misfire
- Power Windows/Locks/Mirror conversion
- Wreck and Rebirth. EK Squad, here I come ;)
- gas gauge help.
- del sol engine swap troble
- Simulating a 2 wire O2 sensor off a JDM b16a
- needing guidance.... and ideas for b16a2..!!!!!1
- flux idle..
- Which Intake Combo for B16?
- H22 into eg innovative mount problem.
- new o2 sensor - running like poo
- has the best way to take off a rotted out bumper bracket..
- EG tail light ?
- Replacing locks in a 96 civic
- Fuel pressure issue? Out of ideas.
- 95 ej1 d16z6 build
- Where to buy these clips?
- What is this connector on my harness?
- car wont start warm
- shifter keeps popping down
- '97 Civic A/C compressor clutch slipping
- b18cR into eg6 help
- i have 2 questions speed -sensor-/-egr valve-
- Half shaft prob
- EK drivers side motor mount. any alternatives?
- Need front end help!!!
- Spoiler Template or Spoiler diagram for 96-00 Coupe Wing
- i need help with ek hatch with b20z6
- is d16z6 and b16a1 wiring same?
- coner light problem
- CEL Question
- ???WHAT AXLE DO I NEED?????
- em1 oil issues!
- d15b2/z6 mini me questions? worth it?
- Feel's tuned EG SiR2
- Is This Worth Getting For 200?
- Build Thread - 95 Civic Coupe Project Budget/Daily Driver
- Swapping rear LCAs DIY?
- ek 02 sensor help
- Clock/radio 12v battery constant?
- squeeky clutch pedal
- Secondary o2 question
- BREAK IN MILES.... fact or fiction?
- HELP: del sol door light on (on the guage)
- What exhaust system should I get?
- b16 smoking problem
- ::Installing Authentic 99-00 Ek Mugen Lip::
- Brake warning light stays on?
- b series clutch problem
- 97 Civic LX Sedan Power Window Issue
- setting dead timing.
- how do i know if my clutch is still good?
- need help geting my A/C bolted up...HELP PLEASE!
- SRI humming
- Blower Motor Question
- A/C and power steering ?
- which intake should i grab?
- motor wont start problem!!
- speedo reading off
- Rear disk conversion help
- Hondata s200 "cel" How to scan for a code
- Cruise Control cable delete
- Having Trouble Starting
- are 92-95 ex and dx knuckles interchangeable?
- Hello, new member! Need help looking for 99-00 spoiler mounting hardware.
- front window tint strip
- Is my power lock module toast? Video Inside
- Buddy Club Digital Meter Water Temp Gauge
- New to the world of Honda: 1993 Del Sol S
- header pipe - gasket?
- Good Street Pads for Wilwoods
- Tahitian Green vs. Aztec Green ????
- 99 civic starting issues
- Stock 1994 Civic CX Engine Has Died
- Civic ej1 Suspension Setup
- headlights dont work need help plz
- 1997 Honda Civic Ex, Misfire and EGR blockage
- New Guy with a 97
- whats needed to put ac in a eg h22
- blox lca bushing removal help
- New Ek9
- rust issue killing my project
- any good car meets around???!!
- drivetrain clunking during braking and when going over bumps
- how painfull is this swap 91 ls into a 96 civc?
- no clutch pressure. 94 eg d16z6
- White Smoke? Help!
- what are some of my options when it comes to different seats in my EG?
- torque bracket question
- Rebuilding my y8/b7
- Feels like vtec in my non-vtec...
- possible electrical problem?
- 95 EX Throttle cable P/N
- Engine missing when its cold???
- need imput
- Random Beeeeeepppppp
- GSR/S80 LH trans output seal replacement?
- B16A2 TRANSMISSION BRACKET
- 96 civic lx with idling problem
- Reconstruction Help(Crashed EG)
- y7 to y8 im swap
- ek dash and si cluster into 92-95 civic coupe...
- wiring harness help
- 92 civic d15b7 headgasket repair
- engine choices for my ek
- idle sensor wiring..
- oil light ?
- 96-98' ctr headlight/grill
- I think I'm stupid and fuked my car up... lol
- rear lip
- whats your opinion on how much my car is worth? pics and story inside
- Help with 99 civic ls swap.
- 05 civic cluster in ek. temp questions.
- Does a "quiet" exhaust with 3" tip exist??
- Which Radiator Hoses for EG with B18C Swap?
- Valve Adjustment
- B16 OR GSR TURBO??
- wierd starting problem..help please
- turboing my car what else do i need?
- clutch ?
- del sol brake lights are stuck on...
- Frying ecu's
- window keeps going off track such a pita
- rear disc
- 96 civic hatch sway bar question
- 2000 white Honda Civic Hatch For Sale
- Radiator for B18C swap
- D16z6 ? d16y8
- fuse boxes not labeled on 95 del sol vtech
- Removing a Turbo Kit?
- turbo B18 civic hesitation at 5500rpm
