View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Newbiw to Ek's , Old Skool EF'r
- VTEC WIRING FOR 93dx
- Where is the map sensor?
- b20 turbo or na built?
- 92-95 Civic Si Hatches: How much does your weigh?
- 92 civic where to get a complete chassis harness
- dpfi to mpfi
- JDM ITR Momo Non-SRS steering wheel question?
- Exhaust Question....
- Can a Jdm B16II obd1 wiring harness work in a Usdm obd1 car???????
- Safe Rev Limit? (searched)
- no speedo!!
- Anyone know the stock piping diameter on 00 si???
- compatibility questions...general.
- Will a obd1 wiring harness fit into a obd2a chassis
- PROBLEM!! IAB WIRE UP?? different explanations all over h-t! SOMEONE HELP!
- contemplating whether to go with Kteller's piping on 00 si.
- YELLOW FOGLIGHTS LEGAL?
- Where to find??? Authentic Mugen Body kit for Del Sol
- Quick Release Hubs and Locks ....
- will a leaking oil pan gasket cause this?
- CTR intake cam installed on 00 si.
- turn signal light???
- gsr iac interchangable??
- CEL CODE 61
- Cluster went out.. RPM doesn't work.. Help.. checked fuses, wires. HELP!
- Cabin filter for civics before 01
- Cannot pull codes out of my car, Check Engine Light Codes
- ek question
- where to get civic 96-98 4-door seat covers??
- obd1 engine harness into a obd2 chassis???
- Anyone have this?
- clipping an ex
- my vx civics gauge cluster wot work
- Question about fog switch
- Have a B16 with a greddy turbo kit. Runing lean what do I do?
- b16 bearing torque specs
- 93 Civic EX w/ B16a Swap... (SEARCHED ALREADY!)
- Zero MPH on Interstate
- got a Q need an A
- air/fuel gauge
- Poor Mans Type R......with CTR pistons.
- dash instrument cluster fuse size?
- HELP... 92 civic dx 4dr Tie-Rod question
- Progress Suspension Camber Kit
- My new ride...
- LSD
- Does anybody make a Thin D16z6 headgasket?
- stroked d16???can it be done???
- CEL Definitions
- help with my eg wont start !!!!!!
- Whirring noise from tranny???
- Help code P0420
- JDM B16 Help!!!!!!!!!!
- Is this a good exhaust setup?
- Stupid gas gauge question...
- Is TD42U distributor for 95 Si?
- a anonimous question
- WTF getting manual door panels off
- My compression on the D16z6
- what starter do i need to get for my sir-II b16?
- whats the voltage and amps to the starter singnal wire?
- honda exhaust pictures
- Tranny/Clutch Grinding?
- passenger door needed
- what wheels do u recommend
- obd1 harness, obd2 dist\alt need wiring info.
- Civic si 2001
- Anyone good with HVAC on 92-95 Civics?
- Good Sound without the weight !
- B16 Valve Adjustment
- 02 sensor wires?
- reset the srs light ..help
- rear CRV seat in EK hatch?
- FS 92 civic Vx w/j-spec H22
- local mechanics
- removing e-brake boot/handle from eg
- Need Help with 99 built ls motor
- Everyone who has had car stolen answer please!!!
- General Question
- Idle looping problem, idle jumps 1k to 2k back down and up.. Already searched
- will a 96DX manual rack fit a 99ex?
- selling car but smog is getting me
- HELP with my weird problem
- Motor Questions (damage of blown seals) need some info
- b18c eg swap ac belt
- new Rack & Penion ??
- LS mesh tire size help!
- Mud Flaps?????
- FS: 93 Civic B20 Vtec Turbo (325 Dyno Wheel HP)
- Code 63 - Secondary oxygen sensor
- how different are 96-98 hoods compared to 99-00 hoods?
- *HELP ME* Why Cant I Setup My Timing Belt!!! *SOHC*
- 97 ek engine problem
- exhaust pop when shifting?
- rear disk brakes on a ek?
- how hard??
- stolen dx
- my girlfriend won't be impressed if i have to push start my car
- Sputtering Problems
- Engine Ligth, no power at all.
- Megan Racing Upper Strut Bar
- Brake help
- wiring harness question
- does the testpipe and resonator bolt on together?
- camber help !!
- does the testpipe replace the resonator? thx
- MEETINGS/SHOWS
- d16y5 head
- DEFI Link tachometer wire picture please
- Question: Re-sueding steering wheel??
- A/C question
- another n00b checking in
- Ecu P2t?
- About How....URRRT
- no oil pressure.
- under dash fuse box schematic for d16y8??
- What Motor Does This...
- got a new oem bumper. help pls
- Finding adapters
- SiR gauge clusters / eBay
- RHD Eg6 Owners or RHD converted Cars! HELP ME!
- In need of a few parts
- My mechanic said my rear motor mount broke/fell which part do I most like need?
- What do you think this hatchback is worth?
- Ek door question
- Coil Overs with stock struts
- Ported Intake manifold now my car is running wierd
- Trans codes
- Tach revs at idle...
- engine shakes bad after swapping to 6 puck clutch
- LOOK! OVERHEATING!!! HELP!!!!
- teg radiator in EG *SEARCHED*
- p05 convertion kit to p28
- 94 DELSOL CAR WONT START HELP ASAP
- Need clutch help! No presure
- Who wants to be nice and help a noob out?
- D16Z6 replacing D16Y8... HELP
- Ek Sidemarker worked, but not anymore
- 92 Civic A/C question
- he guys, I NEED HELP! overheating!
- POLL: rear lower tie bars for eg
- brake setup question.
- Center Console Fits of EG/EJ
- what chip?jun /mugen/spoon/vision/jdmshit chip?
- h22 help with exaust
- 99 spec climate control assembly, QUESTION
- turbo for si
- Black dash
- EG optional audio console
- Will 96-00 Civic Stock Wing Fit 92-95 Civic?
- my car doesnt blow.....
- want to do a mild build on my z6 help!!
- Clutch and Flywheel advice - D series
- ls swap in eg...which cat and radiator hose do i use?
- 99-00 civic auto to manual swap
- IDENTIFY eg carbon fiber lip
- 95 coupe front bumper to 95 sedan. would it be better if i change the corner lights?
- WILL SOMEONE PLEASE HELP ME THIS ONE!!!!!!!
- Rear disc conversion 95 EX?
- 1999 civic si
- Rubbing type noise in front left tire....part cracked/loose w/ grease leaking PICTURE
- Best repair manual for 96 civic
- Which Motor should I choose?
- spoon gauge please watch out.
- Oil in spark plug hole?
- Jazzproparts.com
- motor question
- inconsistant car?
- HELP ME WIATH MY DEL SLO!
- why deltagates suck (as if you didnt know already)
- Rocker Arms???
- Axle question
- gauge cluster swap , what about the mileage ?
- password cf intake in a d16y8 auto
- my ac stop working
- EG Question....
- Need to find a cheap windshield place in southern cali
- power window conversion on a 93 hatch
- Directional Lights
- exhaust resonator
- No Help
- b18c1 ignitor into a b16a2 dizzy.
- Help!!
- Clear del Sol Targa Top?
- timing belt
- emissions problem need help asap
- Looking for 92-95 VX
- New to site/ Universal O2 sensor swap/ Light still on
- did you lose the use of your horn with the MOMO steering hub?
- need ideas
- 96 Civic EX with B16A2 swap, i need a OBD2a to OBD2b Jumper Harness Right? What kind to use?
- track time or ek
- turbo weird idling prob
- jdm edm ukdm parts ?? were to find them
- custom interior pics
- Titanium exhaust
- ITR Rack
- rear-trailing arms for sale will fit civic-crx
- rsr exmag
- *P30 ECU REDLINING TOO LOW AND NO VTEC*
- What kind of OEM wheels could I get for a DX?
- big difference between type s swap and k20 type r?
- ATTENTION THIEVES:
- speaker?
- Left fender
- What Seats Will Fit my 00 Civic ex sedan
- Smog Legal swaps for 00 Civic
- Which ac compressor?
- Problem!
- 93 civic ex oil leak*** ????help
- any mufflers for eg.........
- 2.5 inch exhaust
- located in seattle, WA. know a good performance shop?
- R there any 96-00 Civic Coupe sites?
- No, I'm not joking: I'm kind of stumped.
- Help: While trying to swap ecu's some wires came out of the harness.. Code 21
- idle funny cleaned iac????
- new to the game
- Car is dead, Blowing Fuse!
- Highest flowing, quietest exhaust?
- Civic si Speedometer
- problem with idle
- catback
- cam ?
- Are 2dr EJ doors the same as the 4dr front doors?
- Auto ZC
- Replaced psngr side axle seal, now car makes thumping noise
- SAMCO HOSE QUESTION????
- how do i check my main relay and neutral safety switch with my multimeter
- Dude Check Me Out!!
- Bubbles from heat in vinyl on door panel
- quick question, easy answer?
- funny noise
- 92 cx????'s
- HOW THE !@#$: pillar bar in 96 coupe
- EG6 gathers speakers
- to build or not to build?? b16a
- What are the damper braces and what do they do?
- Exedy stage 1 clutch kit?
- HELP!!!! Coolant is not circulating in my D16Z6 .
- Installed GSR front brakes, and alignment is way off on passenger side now. Need Help!!
- headers and intake help!!
- Which wire to tap in EG for intrument lights?
- 2nd gear trouble!!anyone?
- problem with b16a Sir2 swap
- Jdm headlight info????
- DX manual tranny vs EX manual tranny
- buying ek, wut should i look for?
- b16 swap into 96 civic.......idle problems???
