View Full Version : Honda Civic / Del Sol (1992 - 2000)
- magnaflow catback + rear lip??
- blew motor (huge hole in oil pan)
- F#CKIKNG THEIVES!!!!!!
- question about cam gear tuning
- B16A2 head on a JDM B16 BLOCK passing smog?
- clock resets and die?
- Rising rate fuel pressure regulator VS 1:1 Fuel pressure regulator in boost - rrfpr vs fpr
- stock tire size for 97 ex.
- Clutch wont fully disengage - HELP!
- Building up my del sol, lots of pictures and updates
- headlights & adjustment
- first trip to the track
- WTF Starter not going in?
- Trasmission/Clutch Experts.. Need Help & Advice!
- Help getting my exhaust back to semi stock.
- Is there an OEM plug that fits this hole?
- Si bumper
- huge problems, any one help please.
- rhd eg
- ITR usdm front seat fit in EJ?
- use an auto ecu?
- 92-00 EG//EJ//EK Hood question [searched]
- FOLD-IN ELECTRIC MIRRORS
- Help on H22 Civic.
- header question...?
- Hybrid-Tech.
- Car starting problems..
- OEM 6 disc cd changer
- paint code ?
- Install Tweeters on Non-Tweeters
- NRG 4 pt. H brace install for EG
- question on fitment
- check out my new EK hatch
- Jumped a curb, need help - any body work knowledge is wanted :( :( :( :( Plz plz plz help + header
- motor for a decent price???? where????
- How to pull CEL's
- jdm EG doors to USDM wiring
- paint code help 96 civic RED dx or spray can
- Help 92 EG with Sohc Vtec-E
- eg radio wire harness
- EG: Teg brake swap...e-brake cable's
- NEED HELP b20 block, sir-g head, type r tranny..etc EG
- QUICK MSD WIRE QUESTION
- need help
- Relay help.......(foglights no workie)
- car startup
- Nrg Quick release hub with Oem type r steering wheel
- gsr plus b16 tranny???
- is this a misfire or something else...
- with the help of all of HT
- Type R Engine
- Lower spring, which one goes front and which ones goes to rear
- Starters interchangeable on d16a6?
- help with HID wiring!
- PLEASE READ HELP NEEDED!!
- civic trannyprobs
- 92 Civic Alternator Removal
- Honda Civic Si
- 4 wire obd1 O2 sensor question?? HELP
- Coolant temp. sensor (code 6)
- :CLUNK: noise from exhaust/pipes?
- inline fuel pump doesnt Wine anymore!!!!
- shifter
- How long can I go with out changing Timing Belt?
- GSR Head Problems
- starting problems
- Coolant spiting out of downpipe
- ITR into EG pls help me clear a few things up
- A/C Compressor NOT turning on - checked fuses
- EK Rear Hatch Tint
- Joey Mod - Headlights
- both back doors locked/ handles inoperable
- OIL PAN HELP
- srs cable reel
- BUMP?
- automatic fuel door cover !?
- Fuel pump not working!
- New clutch, aligning tranny back up...
- ***SHOW ME SOME SICK ASS EK'S***
- engine code help
- honda gauge face
- motor swap questions
- wheel well question
- Stock Rods with boost?
- Torque specs on head gasket
- engine shut off at light!
- Shaving the head
- the difference between spark plugs
- aluminum lower control arms QUALITY?
- Grounding pts
- man this video is brutal.
- RUNNIG STRAIGHT HEADERS............
- Dash lights cut out when i hit bumps, wtf?
- welding
- password jdm
- check/replace thermostat
- Tanabe exhaust?
- Quick ECU question...
- D16y8 and z6 Identify and Timing Belt Question...
- CONVERSION
- I need a pic asap
- zc turbo boost ???
- TIMMING QUESTION??????
- winter and anti freeze
- need some photoshop help.... rims onto car
- eg side moldings question
- purpose of fog lights
- B16, what is this part called?
- Is this JDM or USDM
- Great place to buy tires?
- Which polyurethane motor mount insert kit for a B in an EG?
- B Series Header Install
- Weird Noises
- car iddling problem need some help!
- Y8 manifold
- Gauge Cluster/ Fuel Acting up
- 94 SI STOCK VALUE
- Spark Plugs = Done For?
- h22 swap in eg throwin code
- usdm b16/b18c swap in a 99 hatch
- New guy questions
- For Sale 3 inch Thermal Exhaust for 99 2000 Civic SI
- SIDE MARKER HELP
- EG freeze plugs
- Torque Specs on arp studs for d16z6
- Map Sensor Problem. Can't find anything within the 988 results.
- vtec question
- 92 Civic dx hatch cluster problems...speedo
- most comfortable front seats that will fit in a 1994 civic Si hatch
- 97+ Prelude' seat rail fit on 94 Civic?
- Which cam gear for my swap
- my rear end sounds like its falling apart
- BAD NEWS MOTOR MOUNT BROKE OIL ALL OVER
- whats the best spark plugs and leads??
- Nitrous Bottle Question
- b16 or b18
- noob: how to HID EG headlights??
- how do i post picture on this site????
- [Searched!] EG Si/EX lip fit Sedan?
- Integra rear seats in 96-00 coupe.
- my coupe is haunted.
- shifter?
- HELP! Temperature problem
- Changin Tranny oil?
- adjusting fuel pressure
- Q for guys with H22 swaps...boosted h22 swaps especially
- What kind of headers should I get???
- looking for HATCH
- need info on k20A2
- MOTOR MOUNTS
- timing?
- what motor should i build???
- sohc motor
- can't get this castle nut on!
- 99 si fog light?
- '02 - '05 Civic Si seats in an EG? anyone done it?
- 99-00 civic radio console
- ITR 2.5 inch catalytic converter on my civic si?
- car shaking when I get on it
- Need help B18C Hatch!!
- KSport Control Pro Or Tein Flex ?
- 96' - 00- climate control Question
- Crazy Idol Problems
- Best brake pads for street/strip dual driving
- Fastbrakes 11'' rotor for brake swaps
- heat gun or blow dryer?
- ? about rear sway bar mounting hardware
- Want your opinions on my Intake/Header/Cat/Exhaust setup
- wiring my vss need someone to comfirm my research
- Integra wiper blades on my hatch
- srs light
- JDM HONDA PARTS & OTHERS (DEL SOL MOSTLY)
- Sorry but I cant post in classifieds...Hatch for sale in Florida
- ONE simple stereo install question?
- Apexi Filter, kit or filter?
- optional console thread
- Just got my second honda!
- 17" Rims on 2000 Hatchback
- just got the jdm foglights :)
- someone help please
- what is the most important thing
- should i empty out my power steering fluid to get more control
- instrument/guage cluster wont light up
- Can someone explain something to me about VTEC?
- how much oil
- JDM D15B Swap List.
- 96-98 civic foglights install help
- Warped head and symptoms to look for
- *******side markers********!!!!!!!!!!!!!!! help asap
- PROBLEM WITH A/C IN A 92 CIVIC
- ls rear swaybar on 92 cx hits exhaustb
- keepin it simple.......draggin 209 !!!
- are itb's safe to run on a 100% stock block
- Parts....
- Quick question on rear sway bar.
- exhaust and intake... give input and what u think..
- Oil filter guys chime in
- JDM ZC
- Quality obd2 scan tool
- Rebuilt NSX calipers
- Need JDM Parts
- one headlight dimmer than other
- $200 For a lock and Key complete set on a Del Sol okay price?
- possible leak coming from roof???
- ls in eg hatch cant pass emissions
- Speedometer stopped working, help please!
- Any way to get around buying a jumper
- D series trans
- t3/t4 turbo adapter flange
- Trying to Resurrect my '94 EX Pt.I ... it won't start!
- the dream build.. your ideas please
- difference in Auto B16 and Manual B16
- ac what should i do
- Speedo stopped working, alternator bad?
- Looking to replace my factory engine mounts
- ITR/integra suspension on EG coupe
- Eg headlights
- ls vtec question please need help!
- why is there a hole in my cat?
- b16a running rich
- quick eclipse GS question
- cmi raceway
- would a code cause speedo not to work?
- paint remover Help!!!!!!
- obd 0 b16
- Which intake should i get for my swapped hatch...
- suspesion?? need help
- whats the spark plug firing order
- main relay
- Door panel help with a '92 CX?
- GRUVYTUNE?
- EG hatch exhaust 70mm
- Cost of sideskirts and lip getting painted?
- 92-95 ex lip to 96 civic?
- Thin moldings for EK four door. Where the hell......???
- DUDES!!! CIVIC TYPE R INFO IS OUTTTTTT!!!!!
- '96 Civic throws code 41 - Primary Oxygen Sensor Heater
- Newb Questions - 95' Del Sol Suspension
- 94 Civic Si with SRS light on
- anyone kno the Size/Offset of these ssr type-c's?? pic inside
- What can reright hondata
- 4point harnesses into a del sol
- need fuse diagram for honda civic hbcx 95
- where to find the Glass targa top for del sol???
- which intake??
- Loud squeak sound when car turns on
- DECENT SUSPENSION
- >>Wiring, connectors, confusion, etc. HELP!
- Lowering:best compromise?
