View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I need a intake and header
- Gas Tank Swap
- help with spring pin (aka bitch pin)
- b20 mount question
- Apexi N1 silencer
- Weekend fun car to daily driver?
- Help i think i blew my motor
- just picked up my SI from getting its new b18 installed...
- *ALERT* n00b question about d16y7
- header fitment???
- EK Side Skirt Install
- Header Rattle
- EK Air duct...
- Requesting info on Honda TSB 00-006 Rear Suspension Clunk
- SMOG!!!!
- Rear Strut Bar that Requires NO Cutting?
- rsx seats in 99 civic
- Recommended Aid For Old Ass Tranny?
- fuel pump kill switch..splicing yellow wire with green stripe right???
- Best Bulbs?
- JDM parts source?
- searched: 88 crx lowering spring
- Eg climate control
- Front Sway Bar Install Help
- Problem with rear seat removal
- Whining noise when decelerating
- Best camshaft
- tranmission oil change
- ALISO VIEJO CA, white Ek turbo coupe STOLEN!!!!!! 2-11-05
- 96-00 civic hx is defective in lawsuit with honda
- Question about buying a civic hatch
- shaved bodyline
- Vtec plug for 96 EX harness
- Front-end damage of my EG
- GSR on EG....
- are this JDM?
- a/c question on jdm swap
- would a 92 da stearing wheel fit the EG?
- ENOUGH WITH THE 2006 CIVIC SI PICTURES
- how to bleed the air out of cooling system ?
- cams question?????
- 94-95 accord sohc vtec 2.2 into 92 dx hatch?
- Stolen 1997 white civic coupe in Long Beach
- where to buy a honda engine in the UK
- WooHoo!! Just Ran At The Track!!
- What are some good cam gears?
- 99 civic wont start at all???help
- 99 ex civic stock, need o2, what one?
- how much do slicks help?
- D-motor Mods
- Fuel Gauge On SIR II cluster EG6
- what do you think
- Tranny question
- head removal links
- ANYONE HERE HAVE 96-00 CIVIC EX W/ JACKSON RACING SUPERCHARGER & BOOST UPGRADE PULLEY?
- Adding Cruise Control on an EK
- Apex-i N1 fitment on EK hatch...help!
- 92-95 FOGLIGHTS 4 DOOR CIVIC JDM YELLOW!
- auto to manual swap?
- 99 si dash in 97 cx with 96-98 ex cabin harness
- I need HELP!!! Where can I find this hose....?(96-00EX)
- sport springs on 98 civic
- my list of problems
- Parting out my civic. not much but some stuff..
- driveway, car makes noises
- HeLP!!! H22 swap in del sol wont start
- what does it mean when..
- 01 Accord Keyless Remote Work on 99 civic SI?@@@@@@
- Tired of getting screwed on headlights…
- what's up guys i m new to the team
- 2000 civic EX swap distro wiring problem
- B18a swap into my 93 del sol. about mounts...
- question about gsr axles
- best swap 98 civic dx?
- integra brakes with 14" rims
- Pistons
- What All Parts Will I Need To Do A Integra Front End Converstion?
- D15b in 93 Lx 4d...
- Two-way evap valve
- """H Brace On a H22 Civic"""
- Engine Swap,I searched
- Are D series Dizzy internal interchangable? Rebuilding
- need help fast srs light is on
- oil inside muffler?
- fake mugen body kit with out aux. holes
- what do you think about these rims?
- 97 integra cd player on a oem eg harness?
- CVT 98 hx tranny question thanks :-]
- gsr dash
- gsr motor mount ?
- How much power is it pushing?
- just bought front and rear disc conversion from passwordjdm.com
- JDMshit.com Question???
- Radiator fan isn't spinning.
- What is redline on a stock civic cx
- ac k series swap
- 1996-2000 gear ratios?
- What do I need: Swapping D16y8 into a 92 CX hatch HELP
- Who owns adjustable shocks....are your running bumpstops or not?
- d16y8 wiring harness question
- strut bars?
- Crappy tint job?
- Rebuild question, about pistons, rods, and block gaurd.
- b17a in 97 hatch
- Axle problem. GSR in 95 del sol S
- 626 s0 cali - any good alignment shop?
- b20 swap problems
- scam alert......
- 92 EG Hatch exhaust on 95 integra.
- Anyone know where I can get my other car "SMOGGED" in San Diego??
- Nasty smelling smoke coming out back end
- I need some one who knows D series motors in north fl to help me!
- Sponsorship Opportunity.
- D15z1 head(vtec-e) + D16z6 components? will it work?
- Exhaust for Del Sol
- Code 41 + limp mode= searched
- searched i suck cam plug replace
- D-series Exhaust manifolds.....
- Brake Bleeding.
- vtec wiring and cooling ques.
- yokohoma yk240 vs. falken ziex 512
- are obd1 and obd2 iacv the same??
- 01 Civic Factory radio-Aux in?
- chatter in tranny area
- Humming/whining noise !! is it the bearing? what is it?? Help
- Need Help On Power Window On EG6
- Looking for An Eg
- D17 tranny?
- ? on ecu's for a gsr swap
- hub question
- engine swap-enigine running like crap????
- Intake Manifold Question:
- Sliders,brackets,side mounts to use with buddyclub seat in eg?
- Need some help, my rpm bouncers up and down.
- is this a 97 cx engine harness?
- CEL 43??? Anyone else have this problem?
- Miles per gallon...doesn't seem right??
- b7 wit y8 head help!
- y5 block w/z6 head for a daily driver. what do you think??
- does cai void warranty?
- Broken back
- Manual steering rack in a 94 civic ex with power - need some help
- will this gauge cluster fit in 99 si
- Tranny housing cracked & leaking oil, is clutch fine?
- i have a ? about a civic exhaust
- Tire question?
- (searched) EK (non Si/SiR) brake onto EG? Will they bolt on?
- Heat/Guage question
- Is this a good buy
- Mounts for the engine and tranny
- CTR 5-lug
- EM1 weather stripping
- Help!! my temp Gauge goes all the way down when Vtec is on...
- a/c and power sterring removal y or n.
- good deal or not
- Ijust need some techinical info for bragging
- I've got a K20A or a F20C engine, which civic should i put it in?
- H22 SWAP INFO
- Another vandalism, quick question about paint!!
- How much you think this car is worth buying for
- Clutch bearing
- front bumper removal, air bag!
- help me on an engine swap
- turn signals
- muffler question
- Please Help.. i think i messed up my eg civic!!!
- what are the differences on these
- bolt broke off in head.help please.
- 93 civic hatch
- Window weld to repair trailing arm bushings? or suspension stress?
- Compression Help
- My 95 Civic CX Project
- help me im trying to swap my d16y7 for a b18b1
- Question about the AC mount.
- f22b 94-95 accord motor into 92 dx?
- which one will run better..
- GSR steering wheel with EG airbag?
- What you got 2 do 2 make Ek side Skirts Fit A a EG Hatch......
- EP3 rear seats
- Just picked up a stock EBP EM1, reasonably rare find...
- seatbelt question
- CX header exhaust vs chikara header and kteller exhaust
- FITV, I think thats my problem
- Bouncing Temp needle?
- casper shield for H.I.D's
- front end conversion DIY anywhere?!?!?!?
- jdm lights
- Civic Suspension problem!!!
- Bye Bye EG8........Another one bites the dust.
- /////\\\\\/////RADIATO SUPPORT (somone help me) /////\\\\\/////
- BAULEYCIVIC
- Replaced the dizzy, and i cant get timing to advance past 14 tdc ! help!
- EG instrument cluster lights not working...
- oil leak from valve cover
- exhaust manifold coating
- Anyone put a deck in the CD player spot?
- Does EK front seat fit EG?
- 1999 Civic Hatch for $5k a deal? (Vote)
- HOW LONG WILL IT BE................???????????
- gsr fuel pump in civic hatch
- suspension question?
- MSD Coil Connections
- REQUEST DC2 CONVERSION ON A EK HB!!!
- ok, h-t.... help me decide my next step with my eh2!
- are the integra and eg glove box support rails the same?
- wire harness
- 1992 Civic Front Brake Upgrade...stock Calipers??? (HELP)
- quick insurance question
- 99-00 si dash harness and 96-00 civic hacth dx
- swapping brakes without trailing arm
- 95 b18c1 into eg. wiring help please!
- 00 Civic Green Plug in Front of ECU.. need wiring help
- Guage cluster question
- Bumper is sag issue!! URGHHH!
- ATTN: VEGAS EG STOLEN 2/8/2005
- 1991 civic dx
- Gel coat bumper?
- PLEASE LOOK!! I really need to fix it.
- Opinion those with mechanic or racing background legit answer...
- dash swap wiring problem...help!
- AXLE ??
- skunk2 valve spring.....can you install them upside down????????
- 99 Si brakes on a EG
- Where can I buy a carbon fiber trunk for my 97 dx hatchback
- who wants a 96-98 airwalker/bys kit?
- Whats your thoughts?
- Fuel injectors
- new to tha game
- Need an exhaust, and some other advice
- window rolls up too far!!!!!!!!!!!!
- DIY GRILL!!
- hey im new
- Tranny shop in WA
- does anyone know what color and what the paint code is on this red?
- Which one's a KNOCKOFF alarm and which one's the REAL DEAL?
- CIVIC HEADER INFO
- will my 18's fit????
- 3rd gear grind (not tranny problem?)
- 15x7 Wheels Won't Fit My Si
- distributor/plug wire question..help?
- new member, new civic, NEED HELP!
- H22a turbo on a EG6
- Help, tps wiring..
- ignition question on 99 EX
- eg dash removal question
- how loud is the EVO2?
- another 'how much would you pay for this' thread.
- where Can i Get this Cf Spoon Hood at
- delsol b16a2 grinding noise from the rear(might be the tranny)
- Lack of Power
