View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Dose a 97 Dx Come with Power Steering and how would i take this vinyl off ?
- car wont stay runnin
- HIDs Messing up my alternator
- b18c swap axles
- What sensor does this plug into
- ecu problem!! help needed
- wiring issue please help!!!!
- My speedometer is trippin!!!!!!
- when i did the oil change to my ferio i put a lil bit more
- 97 civic h22 swap
- Car has been sitting for a while
- Obd2 b16 into 93 ex coupe- help needed!
- weird TPS ECT sensor voltage drop causing issues
- recent swap: gas needle doesnt mark right?
- My b16a2 swap has a rough idle problem (solved)
- 95 civic DX B18 Swap: Burning smell
- Cold start problems
- putting rear discs on my ek, full bleed or just rear wheels?
- Z6 Not starting...details inside
- HX And EX Suspension Difference Question.
- EK - D to turbo B swap, advise pls
- What Front End should i do
- Ports must not match? b18b1/d15b7
- HELP: I have a 2000 civic si blowing all cold air and no heat..
- How do I install a 99-00 climate control panel into my 96 Ex?
- Idle Problems with New Intake manifold
- EJ8 front end swaps
- What are the best mods for the b16a2 to make it come alive?
- Jerks at constant speed after skunk2 throttle body installation
- MiniMe swap vtec (y5 block y8 head) with Y7 ECU - Safe to rev past 5K rpm?
- 95 coupe swap (in one night by myself)
- EJ1 power windows - driver side pops out of track/pass side tilts & wobbles badly
- 94 civic/jdm d15b - starter won't crank
- 96 and up rear mud flap question
- 00 Civic Si crazy vibration when in gear letting go of clutch
- Verify sunroof switch location
- '96 Civic, loud whine on cold starts... PS Pump?
- z6 Head Setup, pros and cons help!
- 98 Civic LX - Header and cold air intake worth installing?
- Torque for 94 Civic inner and outer tie rods?
- symptoms of faulty main relay?
- 99 civic ex/si
- eg hatch b16a - Input needed on my build project
- 99 Civic Si/turbo b16a2 misfires in 1st and 2nd when cold
- Reverse is gone in my Ls-swapped eg
- 92 eg8 d16z6 swap - VTEC won't engage
- 95 civic shakes above 60 mph
- Anyone have a review on Function & Form?
- eg cx hatch - I fried my p05 ecu, so could I use a p06?
- Del Sol/b18b/greddy sp2 catback - Would a header & test pipe make it too loud?
- eg hatch - What do I need for a gsr swap?
- 3 point strut bar? Ebay vs Password JDM
- >POLL for EG HATCH/ SKUNK2 SINGLE BEND OR DUAL BEND SHORT SHIFTER
- Engine code 6 won't go away!! Need help!!
- My EG not starting fuel/electric problem
- New Axles and Now Vibration Under Acceleration (PLEASE HELP!!)
- Grinding/whining coming from distributor...
- driving to chicago
- How would a vibrant muffler on a stock b piping exhaust sound?
- Master cylinder wires and wiper wires
- Need help with B16 Motor swap in 92 Civic EX Coupe
- B18A1 into 95 civic - What intake should I use?
- Canadian Civic - Is the clutch line to the master cylinder M12x1.0 or M12x1.5?
- HeAtEr PROBLEMS.. help 95 civic dx
- f20b oem part numbers
- 2.5 in resonator on 2.25 in piping?
- Are there any oil heaters that can run off 12v DC?
- Is my civic eg main relay the same as an obd1 integra?
- Skunk 2 shifter worth it?? Single or Dual bend
- 2000 Civic EX Trunk Latch Issue
- 94 EG/Turbo GSR has a vacuum leak and idles at 2500 rpm
- 93 SI hatch - power window/lock conversion
- 1994 Civic died and wont start after running fine all day.
- ctr cams in ls/vtec, possible wrong valve adjustment?
- po420 and no power, it dies out
- 93 Si - Rear caliper stuck out
- del sol/D16Z6 sputtering air sound
- Will an em1 gauge cluster fit in an ej1?
- ek gsr swap - runs great when cold but like $#?! when warm
- how to stop/unplug windshield wipers on 92 honda civic
- Crank Position Sensor for jdm d15b
- how do i remove map sensor ona d16y8
- 99 Civic HX with bad auto transmission - What are compatible replacements?
- plug and play swap that went to poop
- helppp me
- Vtec issue
- 93 del sol fender
- Mnaual Power Steering Fluid Change
- 92 Civic Si/stock D16Z6 getting bad MPGs
- Stinky exhaust & rough in gears
- AEBS "Typhoon" Intake Manifold
- what all do i need to swap a 91 ls into my 95 hatch
- engine bay main plugs pinout
- radio was stolen, all connectors cut
- P06 B18C1 swapped EG Shift light always on
- Heater problems... HELP honda 95 civic dx
- Question on brake upgrade for '99 Si
- Civic Si oil on plugs
- d15b7/z6 mini me timing
- 94 Civic EX - CEL switched with brake light in cluster
- Need Help! swapped a Ls/vtec in ek, car wont start
- post your del sol pictures
- 96 civic ex into si
- my fuel pump or my fuel pump relay?
- 93 civic - My worst gas mileage ever
- hollowed cat or high flow cat?
- Anyone have ideas for a Bezel for my EJ1w/ S2k cluster???
- 93 civic h/b antenna mast wont go down...
- Ls into my 99 ex dizzy question..
- help needed.. ac compressor bracket?
- HELP With putting carburated eg fuel injected
- black friday 2010, what do u add to your car proucts collection?
- p28 or p72 ecu on a b16a2 ?
- Mil-spec harness issues!!!
- Stock GSR D brackets on ASR question!?!
- gsr headgasket...???
- Hard start when cold - b18c1 turboed/tuned REALLY NEED HELP
- Need Help: Dash lights turn off when High Beams are on
- NEED HELP!!!!!!
- Battery light dimm at idle only 13.5 volts WTF
- 98 ex wipers will not park
- 99 Civic d16y7 - cracked header, misfiring, and throwing CEL code P0420
- Del sol D15b7 engine bog and idle issue
- 92-95 Civic TPS Connector
- my del sol si was stolen
- type R swapped del sol - codes 7 and 9
- Weird Battery issue (Noob move) did i fried my cables?
- 98 ex coup with 95 1.8
- CEL turns on then turns off after i start the car again
- QUESTION! trading my 5 lug for a 4 lug..
- Skunk2 ProSeries manifold and throttle body. Problem with cable
- 97 dx cranks but wont start
- 93 Civic ex/D15b7/5-speed - Need help swapping in my b18b1 need help
- Where do I buy parts while visiting Japan?
- Aftermarket 92-95 IM on a d16y8
- 94 Civic sedan - Want opinions on what motor to swap
- 00' Civic Backup light problem (Switch/bulb ok)
- 00si swapping ob2a gsr
- eg hatch swap
- DO 00 EK9 TYPE R POWER FOLDING MIRRORS FIT A 00 EJ6 FOUR DOOR?
- D15B7 CV Axle Length Problem
- Ls vtec has spark and pump primes but only starts with starter fluid
- Parts to salvage from 1993 EX to put in 1994 Del Sol?
- Del Sol front on Ek
- 01 GSR in 97 Civic 2dr bogging/breaking up with anything more than partial throttle.
- DTC 4. HELP ME!!!
- crankshaft/ timing belt question
- 95 Del Sol - Sloppy shifter...
- Fuel Problem
- B18B into EG - mounts, bracket(s), and axles
- Will d15b8 exhaust manifold work on a d16y7?
- 94 Civic EX molding's
- Yakima roof rack help for Ek sedan - What kind of clips do I need?
- 1998 Civic CX 2 of 3 brake lights not working
- 96 Civic/jdm d15b with d16z6 head and y8 intake manifold - fluctuating idle
- Can an igniter (ICM) go bad without throwing a CEL?
- Accord side skirt on an eg?
- idle and clicking problems.
- stanley lights question
- 92 Civic DX dash lights go on and off when headlights are on
- Brake booster for 93 civic cx
- 98 civic ex
- 00 Civic/D16Y7 Burning Oil but Compression Is Good
- Will a d16y8 benefit from b18 tb?
- HELP PLZ ASAP
- Spark Plug Gap Question 93 Del Sol Si Stock Motor
- 94 civic coupe ex has no power at 4k rpm! Anyone i need help!
- What is the "built-in noise condenser" in the ICM?
- Need diagram for EK non-vtec engine harness
- 94 Ej1, B18B2 swap, reverse lights inop
- 93 honda civic si hydrolocked
- HELP! "CAI" for a EK
- ej1 with b20 won't start
- Are these ITR cams? (pics)
- eg oil light help.....
- PLEASE HELP!! EK HATCH WITH B16 ENGINE TICK
- Soft Clutch (Clutch slave/mc prob?)
- How to remove fender flare?
- GSR tranny problems!!!
- Hondata heatsheild gasket fits weird on my d16 IM[PICS]
- Civic Overheatting Problems?
- ***Power steering question!?!?!***
- Winter is near and my civic doesn't start good
- Buddy Club Short Shifter.
- Breather/Recirculation box block off
- b20 swap in eg coupe
- eletrical problem
- New clutch, pedal grabs high
- Climate control switch question
- 95 civic ex crank but no fire
- Koni yellow/tein s tech ride height on EJ6
- 93 del sol si d16z6 stock -- Need help with failed emissions
- GSR tranny gear problems?
- EP3 steering wheel fit on EK?
- 00 Civic DX - Questions about 99-00 rear disk conversion?
- b18c1/gsr tranny - questions about the clutch fork
- 93 Civic coupe/D16Z6 in CA - Want to do a B-series swap
- 95 Civic sedan/D16Z6 swap will not rev past 3000
- ls swap question
- 93 Del Sol SI AT project car issues
- Alternator Working/Whats the Problem?
- NEED HELP MY CAR WONT START (I SEARCHED)
- Bride Seat Rail Help!?
- 6-8pt del sol roll bar
- installing rear side panels into 99 coupe
- how to tell if exhaust is clogging....
- Need help finding design specifications for Ignition Coil
- Hard to get into gear (1st & 2nd)
- Problem with dash lights.
- YS1 leakage
- d15b7 Timing Belt Issue?
- 96 Ek hatch/JDM Type R motor/b16 trans - Axle fitment question
- Help with steering noise needed
- EG civic with 00' SI rims tire question
- car acts like its out of gas then jerks into normal acceleration?
- 93 Civic hatch - dome light and lights-on chime won't work after rewiring cluster
- Which 5th gens had tape on side moldings which ones clipped on?
- Clutch question
- Is that a hood visor on this eg9 (pic)? Where can I get it?
- dc2 gsr 2 door sunroof into 98 civic ex?
- 97 Civic HB DX TPS and MAP sensor wire colors
- 94 Civic EX Coupe
- Idles high but goes down if I rev it.. please help?
- overheating at stop and go traffic
- 95 civic ex MPG too low
- D16Z6 CUTTING OFF
- 92 civic sedan b18c
- What MPG are you getting?
- [Help] Crank but no Start, need some Input on my results
- 96 Honda Civic DX A/c Install Help
- eg gas tanks
- d15b intake mani vac line question
- 92 hatchback/B16 swap - starter won't crank
- mini me IACV 2-3 wire trouble need help
- 96 Civic/B16 - need help with alternator
- Switching to power door locks and windows in a 97 dx?
- k20 or b18
- Which short shifter???
- Losing Power and MPG - 93 Civic Lx Sedan
- HELP! 94 civic ex turns over but wont start
- 97 civic hx - hazard switch powers on the car? (solved)
- Wired in IAB/KS: Throws CEL(new KS)
- Bride Seats Install Help!!!
- APR Strut Bar (With Pics)
- 93 Civic LX, can anyone identify this part and if it has an o-ring?
- Solution to Civic LX cracked exhaust manifold
- CEL startup and wont turn off till 2 minutes
- headlight promblem
- b18b1 heat problems
