View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 97' hatch auto to manual switch
- rpm gauge going nutz whats happening?
- d16y7 pcm
- Missed a shift
- TURN OFF ABS?
- swapping zc into 97 hatch?
- 16's or 17's, Which is better?
- Green Eg hatch - My new car.
- fuel cap that holds the fuel hose on the fuel rail, tiny screw on the cap?
- CTR CF bezel
- Cut out today...
- Good deal?
- Whats wrong w/my JDM D15B Vtec?
- need help!
- Hamp filters
- Oil dipstick WTH
- Main Seal question
- CTR LIP ON STOCK 96 USDM EK HATCH
- LOOSE CALIPER HELP
- pulling back sensation when off throttle in gear.
- lip kit question
- running a little hot maybe?
- Energy Shifter bushings- What ones to get 98 coupe, with b series swap!
- spoon n1 muffler.
- noob questions...
- COMPLETELY HONDA ILLITERATE SWAP WANTEr
- eg brake question
- alright so my car is obd2 and the ecu is obd1 HELP !!!!!
- searched.. gsr sway 93 si
- d15b7 throttle body with my d16z6 skunk2 I/M will this work?
- Need some quick help
- Connector/sensor help?? OBD0 LS into OBD2 EM1; LS/VTEC
- valve adjustment
- are these dsm clips / will obd1 ls injectors work with them
- h22a problem
- Ignition control module
- civic si or eclipse gst opinion
- Cheap Cracker Repair?
- Ej9 from Italy
- head opinions
- block ??
- problem with poor mans R
- motor
- D15B7 MAP sensor
- gsr smoke
- is this right?
- suspension on '00 EX ques
- witch one!?!?!
- 1998 Civic Steering popping question
- did a big oops today at work
- 99-200 4door door handle swap
- 96-98 DX coupe compared to EX coupe, what makes it 200 pounds lighter?
- What CV Joints Do I Need????????
- Tranny making noises!
- vtec wont hit
- jdm side marker help!!!!
- please help, weird idle, yes i searched, no answers,
- 96-98 EK4 Clock
- dizzy question
- smoke
- b18b into a 95 cx hatch
- ebay turbo kits pics
- idle role need info
- Question h22a with atlantis head
- Is My 93 civic cx A/c Compatible?
- HELP-- noise in my transmisson
- TONY FUCHS RACING
- Need Help on Mistery Plug
- gauge cluster HELP!
- another d question
- Where can I use 1.5L engine?
- will z6,y8,y7 rocker arm and cam fit d15b7?
- OEM eg 92-95 clear corners with amber inside VS oem full clear corner lights ??? eg6 sir
- MiniMe swap on the horizon, but is my block or old head dying?
- rear swing arm...
- Junkyard d-stroker
- Hitting Rev Limiter and question about Compression Test
- IACV Wiring Diagram
- How much of a diff between em1 and fit manual setup?
- ECU timing advance???
- remove a/c
- Where to get QSD H2B kit?
- how to remove headlamps on ek civic?
- ------DOES SOMEBODY WANT TO HELP ME WITH MY PROJECT H22A IN A EG-------
- 99-00 civic wont run right, plz help
- first 2 cylinders...plz help
- gsr tranny prob question.
- itr rear seats into a 96 ek hatch
- a/c bogging problem help
- need help???????????
- hard brakes after steering and ignition swap
- 98 civic dx rear leaking..
- d16 vtec?
- Hard shifting into gears...already searched
- D-Series Axle Length Differences?
- Easiest Way to install wire locks?
- e-break relocation
- 96-98 civic coupe doors fit hatchback?
- clicking axels?
- check these out
- Where to post?
- how to take off cap on dash
- getting EG bolts loosened
- Hasport EGH2 and DSS 2.9 axles
- 99-00 si rear disc conversion questions!
- Driver Window wont roll up??
- speedo problem
- VIN verification
- Overheating problem
- O2 Sensor Extension
- Integra Mirrors on EG
- time attack
- What is this harness on passenger side near headlight? 92-95 Pic inside!
- low fuel light?
- B16A3 Swap / Tuneing in general
- Need some help with vibration...
- Anyone running turbo+p/s+a/c?
- D16z6 head on D15b
- Spring/Shock removal
- OEM Fuel regular looks rusty from outside
- b20 vs b16 swaps in ek
- my fuel guage
- gsr into A EM1
- Manual Window Regulator Problem
- Turbo manifold for D series engine
- aem nitrous wiring 00 civic
- 4 door eg hood.....
- The hole on chassis frame for oem stock air box
- FUEL PRESSURE REGULATOR
- ek rear seat problem
- aebs or skunk2 throttle body
- Over the fart noise. Reccommend me a nice well muffled muffler for EG hatch
- EG EK ??
- b16a2 trade for b18c1 bottom block w/ b16 head!!
- Cheap Chip claiming enhanced performance...
- plz anyplz help on suspension prob..
- Help!!! need help with my 96 civic ex
- Will interior from 97 civic coupe fit EK Hatch????
- Exaggerating Speedometer.
- will my d series skunk2 intake manifold fit d16z6 head & my d15b7 throttle body?
- Check engine caused idle to rise at 2500 rpm,help
- k20 in eg
- 95 EG Civic interior is really warm
- 97 EK foglight question
- trade slips for buddy club knocks?
- BEARING QUESTION
- Rod Knock? Complete teardown, can't find the problem
- WTB: EK between 7k-10k
- NEVER underestimate the power of a B16.. lol help!
- diff between manual and auto distributors?
- Swap questions
- Throwout bearing bad or clutch/flywheel/pressure plate are cracked ?
- rides like crap!!!
- shocks going out
- intake manifold swap - sohc 1.6 on sohc 1.5
- PLEASE HELP ME!!! HUB QUESTION
- factory service manuel
- A/c condensor fans eg and ek similar??
- Cutting a coil off my springs
- Ground control Coilovers rates , need some input
- engine wont run right
- is it a type r tranny?
- need help wit wheels
- strokin a d
- oil??
- hood release cable
- IACV for 97 Civic
- after rhd conversion rear window wont roll down on my sol
- what is the name of this del sol rear bumper ..
- Passengers side power window?
- What clutch to get(d16y7)
- ase prep
- Short Shifter Bushing ?
- side mounted intercooler
- getting rid of my power steering....
- race
- Rear disc brake conversion vol.101
- ecu problem??
- question about air intake
- corrosion inside my distributor
- valve srpings?
- Brake Pad squeal lube
- Weight reduction...
- Vtec Wont Turn on an starting Issues
- Radio Flashing
- b20v b16 head
- 97 civic ex motor problems. has me cornfuzeled....help
- Can PR3 and P30 ECUs be OBDI?
- clutch problem
- key tumbler !!!
- eg o2 vs ek02
- caR STAlls under load
- I think I need a new fan for my AC condensor
- Picking up My B18C tommorrow....Check?
- CAR WILL NOT STAY ON. IM BOUT TO SHOOT THE CAR :UPSET:
- H2B or Stay GSR?
- just wondering wat ppl thought bout this. is it good? would i need any other parts?
- 97honda civic stalling
- b20 header question
- compression test and timing question.. need help please!
- Del Sol 94' Body Kit?
- want to get new driver and passenger side floor mats, dark grey, which part #?
- who has BENT a clutch release fork???
- Best Sound from my Stock engine
- Current ECU P30, I also have a P72 which ECU is best?
- missing relay-need help to purchase online..for 96-00 civic
- Help with 2nd Oxygen sensor.
- Help with Engine Component
- NEED HELP!!! 97 DX Exhaust Manifold question and C.E.L.
- Help With the Bumper !!!!
- 00 conversion headlights
- 1992 Honda Civic 1.5 Liter Hard Start.
- this is a question bout sohc and dohc rear bolts
- Windshield wiper problem, HELP
- accessories tripping CEL
- vtec not working need help asap
- 301 cam on a D15B7
- replacement mounts question
- im looking for a clean ek or eg hatch shell. cash in hand.
- CTR EK9 ecu problem
- hand brake question ???
- OBX exhaust tip
- REALLY weird revlimiter problem
- RE - OXYGEN SENSOR! HELP!
- need some help
- Fuel Problem...
- Legit Engine retailers (ex. hmotors) help
- anyone knows this bumper?
- Help - Nasty popping sound (h22 swap)
- Blow off valve
- Tail light problem
- HELP PLEASE!!! ROTOR PROBLEM
- Trailing Arm Bushings?!?!?
- Honda Parts Help Needed
- tps problems
- A/C belt trippin
- window is laggy.
- Question about aplication on sparkplug wires?
- administrator help
- Need help with MAP
- Driving impressions: 11.1" brakes to 11.8" brakes
- built a motor, having some problems, please read
- civic EK Harness Question
- OBD1 B16A into 98 Civic DX......Need some confirmation lol
- Help with Civic '93 SI VTECH !!!!
- Del Sol Track Car?
- Oem vs. Aftermarket
- Gap in between hood and grill,help greatly appriciated
- Exhaust question
