View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 97=> 99 civic dash conversion
- OBD2 GSR Into a OBD2 97 Civic IAB Help.
- Raditor Hose Dripping problems
- my gas needle is being retarded...help!
- How much power can OEM clutch handle?
- ecu chip put in backwards?
- 1997 Civic Ex Belt Change Question
- Noob question?
- Temperature gauge question
- JDM EG6 Gauge Cluster Problems, HELP PLEASE!!!
- Rough idle but stop when heat is on
- Fluidyne Rad and Stock rad fan
- Open Header Bad for car?
- need help with exhaust piping
- Is this a good reason why my car would consume alot of gas
- ns2 sparco wheels?
- Engine coolant sensor 1994 civic ex
- May 3, 2009 AUTO SHOW
- Reverse Light Wiring
- Control Arm Question
- 97 honda civic nitrous - $3500 gooD DEAL?
- What color code is this?
- worn suspension bushings
- ecu question
- Oem Seat Swap Questions 00 civic ex coupe
- how much out of b18b
- trying to find the right ecu
- What's the best battery for my EJ8
- b18b1 ECU wiring Question.
- d15b7 gas mileage problem?
- Intake manifold fuel rail spacers??
- Need help with shop to rebuild b16 nashville tn area
- wore out ground control?
- eg guage cluster
- ej1 guage faces
- Does anybody make a cross bar like godspeed but it goes from front to rear???
- How much out of a D series
- where does this go?? pic inside
- Canister control valve help...
- ~~~1999 Honda Civic SI 5,500~~~~
- FD2 seats into an em1
- Has anyone every P&P intake piping some
- IACV info needed
- Jumper Harness question
- Are GSR & Si differential bearings the same?
- Need new Axles for my Del Sol HELP!!
- what kind of ecu do i have
- B16A2 Coolant Diagram
- del sol seat problem!! help!!
- VTEC Trouble
- Del sol fog light question
- f22b tranny troubles
- OEM or nonOEM bumper?
- obd0 - obd1
- sand paper????????
- What qualifies as a full tune up?
- D16z6. Low Comp. Pistons, horrible mpg. Whats wrong?
- Ej1 auto to manual swap help please !
- Failing emissions HC too high
- CRV cluster in EK
- Removed alarm and car won't start. Please help!!!
- Wind Deflector Removal, need advice
- Anyone willing to trade bottom ends
- New Here Hello All
- Turning Off Alarm
- d16z16 trans issue
- gas mileage still sucks d16z6
- hey i need some help 96-98 civic
- HELP!! : RPM drops then rises back to normal whenever i step on gas!
- Horrible Idle Problems
- S2000 seats in EM1 (PLEASE HELP)
- dohc zc into 92 civic HELP PLEASE
- using d16y7 harness on b16a2?
- EG driverside window hard to roll up and down
- B series RSR exhaust with K20a2?
- DA integra seats in EG coupe?
- any meets in vegas?
- Does 92-95 Civic Coupe Seatbelts fit Hatch?
- 94 civic ex
- racing shell f/s
- 94 Honda Civic LX Sound at startup - ABS? Also, light issues, more...
- tokico Illumina with ground control
- can't Choose Which seat will LOOk Better
- Need p72 ECU!!!
- d16y7 into a eg hatch, which harness?
- Pic Request: 96 and up civic with Rota Track R
- Fuse 15 problem 97 civic lx keeps blowing
- DIY-Alignment
- Exhaust Question...Advice needed (Pics)
- 96-00 fuel pump relay.?
- Sedan, or Coupe
- Wheel Spacers for EG
- Help... Engine Dies while Driving then starts again...
- Shifter bushing compatibility question...
- b series swap need help
- t3/t4 or gt35?
- New HT member, Just saying hi.
- Will the drivers seat from a 97 honda civic lx fit a 92 Civic Hatchback
- parking brake replacement
- throttle body gasket question
- d15b vtec
- undecided
- Omni Valve Springs and Retainers
- Engine help!
- Pulstar plugs Fake or Real gains?
- Cat Converter And Exhaust Question
- 07 Si Seats in my 95
- 1997 del sol fog lights
- Jdm Ek9 Wing VS Ebay Ek9 Wing
- where can i find this header
- New to HT - what to do now...
- Good Turbo Kit?
- GSR Transmission
- door locks
- 97 ek hatch b16 block/gsr head no vtec
- 12 volt wires to tap into?
- IACV & timing belt
- rod knock?
- Is it my clutch?!?!
- 93 honda del sol oil in spark plugs
- new civic owner, need opinions
- Automatic upgrades....help
- Does 95 Ex Steering Column fit Del sol?
- Replacing rubber under EG hatch doors
- EK seats in EG??
- opinion on internals d16y8
- wats the fastest swap 2 do with turbo?
- B18B worth swapping?
- Installed new rad and now problems!
- Couple B series questions
- how to install traction bar
- do i need to change piston and piston rings before install turbo?
- wheels still spins while in gear?
- Overheating nightmare!
- h22a swap in 98 civic
- What disk-brake rear triling arms will fit on a 93 civic?
- Should I get 96-97 (obd1) or 98+obd2 what's better
- b18b swap...
- fuel gauge not working?
- dc sports header...please help!
- Engine light came on in my 98 civic cx and the code was
- 00 Civic hatch with an EM1 harness, LS swap 02 sensor questions
- 1997 and tranny feels weird.
- PS Pump in GSR Swap
- 00 si tranny bell house problem
- Will a Civic 99-00 bumper fit the 98 model?
- anyone got a rear tranny/ motor mount under warranty?
- check engine light on?
- how do i empty my antifrezze
- Thrush turbo vs. ES Tuning muffler
- injector wiring help!!
- Car won't start sometimes
- motor harness
- cant find oem thread sizes, please help need a new fuel feed line
- Transmission Smell!! need HELP!!!
- Pulsating lights and eratic speedometer.
- advance auto axles?
- JDM recaro seats
- Oil inside where the sparkplug Wires and sparkplugs go help fix.... plz
- 97 EX Condensation on windshield / coolant ?
- No start after insane wiring headache
- clutch sinks to the floor
- Fuel pump question
- wierd problem! with videos, HALP PLEASE!
- d16z6 idle adjustment - no screw to adjust?
- Quick Turbo question
- Quick Question K2 Motors
- keeping power steerin and ac in b swap
- b16 starting problem when cold
- d15 same as d16 flywheel?
- Bad pressure plate ot TOB
- mini me head question
- J's racing CF lip?
- Car won't go into gear....
- wheel stuck to knuckle.
- NRG Thin Quick Release Q's?
- $1000 on wheels and tires...What should I get?
- GSR SEcondary butterflies need help/opinions quick!
- fuel pump or relay!?!
- Changed trailing arm bushings and now my car wont align
- oil feed line
- replacing motor 93 civic
- Whats Up Honda-Tech I'm New!
- Speed sensor problem!!
- 95 civic:B16a boost build...how to get it to 350+whp
- Need info on how to build b20 on boost
- New member Eg6 sir-s owner
- ok car wont run after 2500 rpm
- Fuses blowing and no marker lights
- civic rear quarter panel rust
- Timing belt ???'s y8 head/z6 block Help meh out
- heter motor and defroster problem
- What the f*ck.. 28mpg???
- F1 Racing Clutch on ebay- Good or Bad?
- Thermostat or temp sensor??
- Brake question
- D16z6 cam questions
- 97 Civic, crankshaft pulley fell off to side
- Windshield Washer lines, clips, and window cowls
- Timing noob
- Hanging cigarette lighter problem 96 ex coupe
- hydro tranny
- EG Disk conversion help
- 93Si exhaust?
- Eg exterior question
- Td-44u
- worth swapping a zc?
- Airwalker bumper take away support?
- honda motor swap need help
- aem cold air intake
- Starter Question
- over heating
- Looking for NAPA Part# for del Sol Radiator Dual Core Radiator
- New car (to me)
- can i use ek9 linkage with dc2 short shifter?
- How do you clean/flush out a radiator?
- apex safc 2
- obd0 ls into eg
- JDM DC RHD CLIP for a EJ COUPE
- 92 civic dx with ls/vtec swap
- asr rear swaybar
- Where does this part go? Pic inside
- 1997 Civic DX Coupe Hybrid Help
- h23a1, In a del sol.
- 93 civic with 94 integra disc rear brakes
- Temp Gauge 2/3's up WTF???
- Pistons hit'n the head!!!
- question about jdm type r motor help!!!!
- 95 Gsr with a Type R head!
- Headersworth it on d16y5?
- Should I take out my a/c?
- Mirror Question
- Air ride on my sol??
- h22 or lsv? For hatch.
- turbo dat d
- Port and Polish question...
- Do i need eg axels or ITR axels for swap??
- idling problems with 99 si
- rpm surge
- 93 civic LX tansmission
- help mayb axel problem
- honda civic si
- stuck valve?
- Found this on YouTube, thought I'd share it with H-T...
- Re- Usable gasket.
- really low low idle no check engine
- temp sensor?
- burning oil issues
- SLOW B16A2 oil issues.
- Oem clutch or f1 racing clutch
