View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16Y7 ?
- 94 Honda Civic Lower Control Arm change.
- 99 civic intermittant electrical to car, all fuses good
- Throwout bearing?
- EM1/EJ8 Coupe slammed on racelands? anyone running that setup?
- ac problems
- 00 Civic Hx bogging during idle
- 92 Civic VX- doesn't start most of the time
- B-Series Post Mount Identification..
- No Speedomter or odometer,
- 2000 civic ex trouble shifting
- Rear Strut Bar Opinion
- 98 civic sunroof stuck
- Help!!!! Is test pipe a direct bolt on!?
- Coolant temp switch/sensor question
- My 1998 EK Hatchback project
- Rear Sway Bar???
- noise while driving
- JDM ECU 37820-P07-901 --> would this be an auto ECU?
- long way from home and needing some help
- Weird electrical/static/flapping bag sound from engine?
- Wide radiator in a 98 Civic?
- Does Civic Have ANY Power In 5th Gear?
- Help Setting Civic TPS (Throttle Position Sensor) can't find balance
- lowering springs
- Upcoming 92 hatch build
- Coolant issues on 2000 civic dx
- Wiring swap help
- JDM B16 Sol kind of "boggy"
- seeking insight on what to do.
- A Different Kind of Honda Build
- Can/How to start a car that was stolen?
- Question about wire tuck
- Jumper harness
- code 9(#1CPS) after taking obd1 dizzy apart
- r12 to r134a retrofit fittings hit the hood
- Lower Control arm bushings? confusion
- Engine feels like its choking
- 93 eg no power?
- 96 civic ex help
- No reverse light
- rhd eg wiring help needed
- 99 civic si Air Conditioning
- D15 Exhaust Header question
- 96-00 Civic opening the hood from outside of the car?
- 94 Civic EX Blower Motor Resistor
- Would you pay this much for this del sol?
- Recaro ATR front seats on Civic Ek
- 1999 honda civic ex trunk leak
- Low RPM surging
- B16 knock sensor- Not the usual question.
- 92 civic front end squeaks in steering/suspension
- Powerwindow problems + blowing fuses
- B18a1 in eg ecu help
- Rear T-bracket help
- D16Z6 head on a D15B7 block?
- D15b7 Is giving me hell!
- 93 civic d16 automatic can't read codes high idle and won't rev over 3500
- "Typical" Idle RPM Question from Newb
- MPGuino Install in My 95 Del Sol Si
- Wheel hub questions
- Wheel Bearing
- Which muffler would be the better fit?
- Please Help - Civic Vi RS 1999 CVT to Manual Transmission Conversion
- 94 civic hatch headlight to bumper gap
- Please Help! Oil spraying out of my black box on ctr block
- Honda ATF DW-1 VS ATF- Z1?
- '94 Civic - More distributor nightmares
- bisimoto dyno sheet
- Civic experts please please please help.
- Newbie here. Engine Idle Question
- weight reduction Q
- 96 civic ex sunroof and dash lights not functioning
- Interchangeable components
- Honda Civic 99 Check Engine Alert
- Engine swap legality
- Car won't start after timing belt change
- 94 dx sedan Temp Gauge Issues.
- 96 civic dx b16a2 ecu
- Honda civic b18b1 upgrades?
- 96-97 DC2 Integra TypeR Momo Steering wheel
- Rear Lip
- possible blown head gasket but still good compression?
- Distributor bolt sizes
- Vtec head for ZC SOHC?
- Rewire Themro JDM D15B in OBD1 ???
- AWESOME SITE FOR FINDING PARTS
- another cooling issue. stumped!
- ScanGauge E to a non OBDII 98 Civic EX
- 1
- Oil leak from under distributor.
- B16B
- Eg carbon roof cap
- 98 civic d16y7/y8 Bogging
- Rare JDM sources
- 2000 DX Y8 IM Swap
- ej tranny swap
- A6 cam into b7 quick question
- b20vtec running low and idling rough when warm
- D16z6 Squealing noise coming from crank pulley area
- trans question
- parts
- Broke bolt rear right
- Stuck in park
- Driveshaft help
- ecu issues
- 00 Civic Speedometer issues
- Junkyard compressor: 1992 civic Compatible years & makes?
- Oil on Spark Plugs
- Distributor cap overheats
- Came across this on EBAY 0 Mile civic engines.
- Help! - D16Y8 starting issue
- 94 SI Hatchy Power Window stuck
- Can an intake manifold leak can cause a TPS malfunction?
- remote start problems
- Low rattle from underneath 94 Civic when accelerating
- 92 vx cable reel/clock spring
- motor mounts
- white smoke codes random misfire and misfire cyl 4
- intermitant no start, has fuel and spark. at a loss
- What ECU do I need?
- 97 civic dx y7 P0420 CEL
- Always Use Genuine Honda Parts
- DIY Ep3 side skirt retrofit onto EG
- knocking sound from flywheel area in gear
- Will a shifter for a 96-98 civic hit my 93 civic?
- 97 DX, weird engine noise, not sure
- 98 honda civic ex - need O2 sensor replaced?
- Rough start
- 98 civic, metal bar in the way of replacing rear O2 sensor
- D-series advice
- Question about swapping current mini me z6 head to fully built y8 head
- the best shocks for being slammed
- LTB ICM for EG
- start issue
- Side Markers/Repeaters Information
- Auto Trans Civic gear shifter not precise with "clicks"
- EVAP Charcoal Canister Fumes Smell Gas Fuel
- How do iRetain power steer in my 99 ek with jdm b18c type r
- Turn signal switch question
- Help with 2000 Honda Civic DX Check Engine Codes Please !!
- JIS Screwdriver
- fuse 15 blown
- 94 civic ex performance build.
- 3 Optima Yellow Top Batteries Dead: Need help finding short!
- D16z6 HELP!(Video included)(91 CRX Si)
- 500 K on these plugs . . . Bottom end next?
- vibrations
- dgk's '97 EJ9 build thread
- 96 civic CEL 41 problem
- Missing Brake Pad Retaining Clips
- lotek shocks
- B7 manifold to z6 quick question
- 95 eg sedan build
- Bushing replacement id? help?
- Transmission Pulled. Questions
- Damn P0420 code!!!
- stumped! 99 ex intermittent stall while driving
- General Advice Y7/Y8 Build
- suggestions
- 96 civic ex misfiring
- Need new motor mounts, what to get?
- car revs to 4000rpm after installing aftermarket throttle body and intake manifold
- Heistation
- 92 eg hatch cx question
- road noise-civic
- Can I remove the stock seat rails?
- Skunk2 intake fuel rail studs stripped?
- oil light question
- 93 civic jumped time, won't start
- Some tricks to removing fuel filter
- dual filament/beam hid
- retired
- Questions About A JDM EG6 SiR
- Reasonable price for brake parts for my EG?
- 1992 civic 1.5lt hard starting.
- 93 Civic CEL 'ELD Code 20'
- Del sol awd plz help need some info plz
- 1995 civic si - no start/ no crank issue - help needed
- D16Y7 to D16Z6 Head swap.
- 92 95 civic hatch power door conversion help!!
- Boomslang harness & SAFC in 1998 DX Civic
- S2000 Brake booster/mc on EG?
- Obd1 dizzy to a obd2a car please help
- Do I need an ECT sensor?
- 99 civic si running rich
- 92 civic shifting trouble
- D16Y8 oil leak help!
- Where to find ARC or ARC style splitters?
- EG with brand new brakes, squeaking?
- 98 Civic LX Door Lock/Keyless entry woes
- Got a new civic, Need help.
- Worn piston rings enough to cause idle problem?
- Brake Issue
- Wheel Stud Removal Issue...
- Odd problem with 98 Civic Dx
- Installing relay for city lights and side markers on ek?
- need help with identifying these
- What dizzy do I need?
- Harness connector pn, tps screw size?
- 94 civic randomly loses throttle response.
- d16y8 d16z6 parts change
- would it be worth replacing an D16Z6 for a JDM D15B VTEC
- Wanting to tap del Sol VSS and Injector Signals
- QM3 P28 ECU repair and cel
- Skunk2 intake manifold w/z6
- Rough low idle/Engine rattle video update.
- D16Y7 to D16Z6 mini me swap
- Connector Pins/Terminals
- 93 Civic D16Z6 low idle
- 97 gsr into 97 ej8. Need harness help.
- Knock sensor gone/Missing ? 4.99 fix RIGHT HERE
- 93 honda del sol clutch pedal question
- d16z6 coolant bypass for aftermarket throttle body help! with description
- Aftermarket D15 head gaskets with reinforced hot spot?
- speedometer jumping during high idle??
- '94 Civic - Removing ignition coil rusted screws
- Spun Bearing on 93 Coupe, need opinions
- 2000 Civic Random Loud whining noise
- Diagnostic Trouble Code P1359
- Need expertise before buying this B16 Del Sol
- 97 CX HATCH MISS FIRING IN THIRD
- making crossmember bars for 96 civic coupe??
- 1994 Honda civic Hatch Eg low compression issues
- Need SiR Blades and Lip for Ej2!!
- Grinding and Shaking when Driving at Slow Speeds- 1999 Civic LX
- New throttle body ecu problem
- EG Ground Control coilovers on EK?
- tuning/break in
- push start using cruise control button??? help
- Bogging and bucking- 92 civic vx
- Need help car not starting!
- My em1 dies when clutch is pushed in?
- EBP EM1 WHEEL SUGGESTIONS ?!??! EVERYONE WELCOME
- Mystery part? *pic*
- Refinishing OEM Alloy Wheels (Paint or PC)
- Fuel pump not priming
- 93 si gsr cluster and dieing issue
- Ek4 Sedan won't start (EU Model)
- Clutch Issue - 00' Civic EX
- 94 civic ex aftermarket throttle body
- Fuel gauge
- 1993 Del Sol Manual?
- Slow to crank when warm , advice needed
- Adding power to a D15B7
- 93 civic wont pass smog
- rad fan issue
