View Full Version : Honda Civic / Del Sol (1992 - 2000)
- slower @ WOT
- POP NOISE On take off HELP!
- 99 SI exhaust fitment
- superchip
- Urgent, Just got screwed on a car!!
- 2 1/16" TACHS
- D16Z6 w/ 200k miles turbo?
- Stoid Racing - Dallas, TX
- brake light help.
- eg lip fit for del sol?
- SHORT SHIFTERS!!!!!
- sputtering problem
- black CAI for 94-2001 GSR motor...
- How much could i get for my car?
- LCA replacement camber or toe problem???
- question about after market lca's?
- help with the weather strip for the window
- Trouble with a new keyless remote
- b18c into EJ civic... a/c?!?!
- cruise control help
- Help me, I swapped my d16 block and head for a d16z6.
- *SOHC* retard my timing and i think it pulls a little bit better on the highend!
- Re-installing AC. What should i replace. Please help.
- I want to see a REAL JDM EG Civic
- Help with Drag slicks for 94 Honda Civic Hatchback
- single cam hx owners, quick tricks
- went to the track yesterday... now the car sounds quieter???
- Skunk 2 intake manifold
- anywhere to buy BRAND NEW eg6 headlights?
- different tire sizes?
- JDM B16 Cams? Automatic Vs. Manual. Vtec Problem!
- thread pitch for engine bolts?
- Reading Plugs [HELP]
- a/c into EG
- Short Shifter and Synchros??
- Snapped my Stage 4 CM puck!
- i need help NOW!! Please Overheating
- what do you need for a complete home made turbo kit?
- looking for an affordable civic to turn into a tuner.
- homemade rear diffusor? eg hatch
- Kumho Ecsta 711 Tires. Any good???
- Tweeter Placement?
- Front strut bar debate, NOT WHAT KINDA BAR BULLCRAP/POLL!!!!@!!!!!!!!!!
- 99-00 AC SCHEMATIC DIGRAM NEEDED !!!!!!!!!!!!!!!!!!!!!!!!!!!
- Engine overheating need help finding problem
- good deal?
- Code 20, Eletrical Load Detector
- someone had a diy wrapping door armrests. where'd it go?
- new rear suspension and arms help.
- Roof Tie Bar: Does it help?
- Buying for a swapped car.
- How does bump-starting work?
- Failed smog...some help please....
- part or parts of car, that you hate changing the most....
- is there a difference in reliability between ground control with koni adapters or groundcontrol koni
- Damn Car: Gauge Prob 94 civic dx
- Tint Removal
- 2000 civic si question
- Still need help with ECU/CEL comes on'92civic w/97gsr
- B16 times
- ahhh what do i need to do foro this code
- Need to add external input to 2004 Civic LX stock stereo
- USDM Civic Si CAT
- question: 91 crx si rear discs into 92 civic vx?
- problem in my 94 coupe
- Check out this 480 hp Ek hatch
- ITR tranny!!
- D series LSD Tranny (JDM)
- spoon spoiler
- Fixed the problem-stupid v-afc
- coolant bleed
- NEED HELP.....DRUM TO DISK 93 HATCH ....92 INTEGRA BACK DISKS...
- FAL Fan almost killed m y engine
- Need your assistances plz
- is 96 civic hx intake the same as 99-00 SI intake?
- tranny removal question
- whirling noise...
- Lower control arm bolts
- Exhaust question - O2 sensor placement
- civic pulls to the right
- Avid racing motor mounts ek good or bad ?
- hx wheels
- Need opinions on Tanabe exhausts?
- brake line question
- Damn You Window Trim!
- Need Help-'97 Civic LX
- getting gasoline from exhaust
- del Sol WOES......
- Please explain ECU's for my DOHC with Hondata
- Little hybrid question for my 94 hatch
- Running too rich? Minor backfiring & gas coming out of the exhaust?
- Climate control bulb (searched but with no luck)
- Hondata Install and Tuning in San Diego?
- installing 4-1 header on 03 civic ex????
- what's a good exhaust system to get?
- gsr tranny leak??????
- any experience w/ Holley FPR?.......
- Valve Cover Gasket?
- Question for guys that have gauges on the A pillar?
- Possible hp from a 97 dx hb ????????????????
- Cheap mods?
- TDC Problems??
- AC experts, I need some help
- REVIEW::: comptech sport springs mated to kyb agx
- yet another AC question RE: compressor relay wires/electrical
- ANYONE KNOW THE CHASSIS CODE FOR THE 04 civic vp,dx,lx,ex
- Sir brake booster Q?!?
- starter problems?
- Got the rice bug - what's next? Advice anyone?
- hey SOHC guys, need some tranny advice
- Scratchy sound when i accelerate..
- A/C compressor is possessed
- Gear ratios
- intake imporvements....
- Best Snow tires?
- What year best for h22?
- Car Starts and Stops after replacing Rotor
- oil in spark plug holes...
- t 3 turbo question
- timing belt rubbing??? eg b18c
- 2 different kind of templates, which one is the right one?
- checking spark
- b18c w/ skunk2 IM in a eg
- Exhaust question.
- another reason to hate crimps
- where to find?
- brake question
- brake upgrade question... ek/gsr
- civic 95 DX Non-vtec sparkplugs
- Compression Test Results...
- Needed conformation before I order from a site NaganoJapanese.com
- noticeable handling difference if I install Rear Sway Bar on Civic EX ?
- What's needed to put a 94 gsr front sway on a 92 cx hatch
- Ideal ECU/Harness for SIRII
- Troubleshooting on my hatch
- which ecu for 93 del sol z6?
- Nice EK for sale
- NEUSPEED sport on 99 SI
- Another Trial User
- ahhh problem with oilpress and water temp gauge install
- Anybody have some ideas for cool interior mods?
- what size k&n ait filter for stock jdm eg6 airbox
- brake smell?
- 92-95 JDM EG6 Folding Mirrors, Folding when turning On/OFF car
- Question about Z6 dizzy
- Integra leather seat swap question...
- where can i get the jdm rear hatch trunk option?
- Neuspeed Sport spring question
- Difference in EX/SI
- B18b1 swap code 41
- Rod & Block #'s to order bearings from Honda - HELP!
- ECU Question
- Toda ITB's (searched)
- del sol side skirt problem?
- dizzy questions
- clutch question
- Gauges on your pillar?
- Ok are there any people with TODA cam gears?
- need some info on chipped ecu's (spoon,mugen,skunk2,jun)
- d16y8 intake manifold on y7 head
- quick question
- Higway crusing rpms and MPG
- knocking noise?
- Eg exhaust question
- V-Tech ?
- strippin the back interior need help!
- why is my rev limiter low
- Am I getting a good deal??
- Can I keep A/C?
- oh no...stupid me!
- distributor buying?
- ****need quick answer.... auto to manual... 97 ex.****
- Suspension Questions
- ls vtec what do i do next???
- What is the best tranny option for a GSR?? in an EG
- 96 civic
- I am getting a check engine light and the code is( catalyst sys. efficiency below threshold
- HELP!! did they sell me the wrong spark plugs
- GOOP Automotive Glue for my Civic pedals
- 94-01 Integra Side Skirt on a 93 Civic Coupe
- my SRS light stays lit on my 92-95 EX Coupe
- :SEARCHED: I need some advise "engine swap"
- I know this isnt the right forum but i need a p28 5speed ecu and stock obd1 gsr or b16 injectors
- 93 Del Sol Si Clutch Replacement
- Rear suspension/brake question. need help/ identify ! ASAP !! ** no 56K **
- ? for people with automatics
- car runs but goes nowhere (towed back from track)
- 95 ex d16z6 tranny swap help.
- B16a2 head porting...
- OEM Throttle Body Question (B16A2)
- header bolt snapped off
- HandBrake Irresponsive. Need Tips.
- Wheel Painting Q: Aircraft Stripper? Safe on tires?
- Want more speed!!!!!
- Accident stress on a motor?
- RSX muffler on a EG
- integra seats in a del sol
- any know where the best place to get k20 mounts for a eg
- another dating site.lol
- have a question about obd2 cars?
- problem w/ passenger headlight
- eg b16a swap o2 sensor deosn't work
- Speaker Problem.
- WHAT NEXT? couple q's on a SOHC build/clean-up..
- J-Spec anyone heard of them before?
- vx hatch with a 00 gsr swap in it. which catback should i get? any 1 got pics of theres?
- HELP! b-pipe broke by the resonator
- Power steering problem
- error code 22
- Installing Teins w/ ES bushings.....
- Bent valves in a B16A2...
- owners of civics thats between the years of 97-00 read this
- Do JDM ECUs communicate with OBD2 scantools?
- Tranmission Problems
- Plastic Window Tab
- Horrable/weird camber wear on 97 coupe
- d16y8 intake manifold swap, what gasket?
- coupe/hatch front bumper on sedan?
- WTT for Si Rims
- y1 LSD tranny into a EG
- Suspension(LCA, Shock, etc)
- Help:My new slave cylinder wont hold pressure for the clutch pedal to work
- need help, Dx to Z6 question
- Toda Stroker kit
- Honda overpricing on Foglights installation on a civic '04 si?
- Mods stress on d16y8 motor?
- audio console colors
- Chicagoland - Bent rims.
- Want to upgrade stock brakes...
- car just got stolen..philly, pa area
- Cutting Side Moldings?
- Suspension question on del sol?
- Vtec engagement problem (99 si)
- Anyone know the specs on the Del Sols models?
- why dont usdm 92-95 clusters have a gas light?
- Crazy problem with wiring
- What's times are expected out of a EK Coupe With a JDM GSR Swap
- 1 wire to 4 wire o2 (cx to dohc o2 sensor rewire)
- need help on swap for a eg2
- need"t" & intake manifold body for 97 dx hb
- Help with jdm gsr swap into CX hatch
- cold air intake instal???
- P28 speed wire = what color wire? (RSM)
- OBD1 GSR SWAP in CX Hatch
- just got home from MIR(1/4 times)
- Stock FPR Leak!! Help!
- hey fellas new member....i just got a new car!
- Where to get roll cage in chicago land area
- Got a question.
- 4pt. roll cage
