View Full Version : Honda Civic / Del Sol (1992 - 2000)
- delsol vtec differential/gears gone?
- Power to manual steering rack
- Suspension question?
- looking for a legit place to get a low mileage jdm engine
- This sounds like a dumb Idea
- tenabe exhaust
- 92-95 EG hatch
- 93 Del Sol Si speedometer not working/reading correctly
- Ignorant Exhaust Question
- I/h/e d15b7 Emissions fail! Help!!
- need help going to REF soon!!!!!
- How to do a "burnout"?
- Eg steering rack play
- Obd2 harness pluging into Obd1 Dizzy
- Need help with Ac in b series Ek
- shift fork? blown trans? b18c
- vtec engagement problems
- s2k wheel into 96 cx horn not working
- '92 DX: starts then dies; dies while driving
- Check engine light
- Car Won't Start, Checked a few things, what else should I look at?
- NEED HELP ASAP!!!!! Clutch issue?
- does anyone make aftermarket rhd civic mats?
- Rod knock or bent valve?
- compression test on used engine.
- Stuttering, loss of power, sounds like WRX, only when cold.
- noob need some advice
- B16a water pump.
- what should my car run???
- D Series Oil Pickup fitments?
- Removing aftermarket shift knob
- Few questions, SOHC Zex camshaft...
- 99 civic si to obd1?
- Need Help finding ground wires through out 95 civic hatch
- anyone know what size???
- Budget project car/DD
- Anyone have a picture of the IAB solenoid on a obd1 GSR????
- Glovebox swap?
- Bseries axles work on Dseries swap?
- What do you think of these compression test results?
- Del Sol Door Handle!
- D16y7 Intake Manifold Swap HELP!!!
- DISTRIBUTOR QUESTION!!!
- bad valve cover gasket causing NO START???
- Can you swap obd0 to obd1
- need help finding auto to manual thread
- 99 ex D16ya to 96-98 ls
- D-Series rebuilt head break inn question.
- CAMBER KIT! EK
- where to purchase jdm d16y swap
- HELP:: Bent piece inside OIL PAN. car starting to seem clogged? Picture inside
- eg hatch mini build
- Are eg civic coupe headlights different than sedan?
- Clutch or tranny? Cant tell what broke
- Pulling out my D16z6
- new to the honda world
- My car wont go past Vtec
- painting seats with krylon?
- 96 Civic Dx 98 H22 Swap Question
- Fuel pump not priming...
- NEWBIE :-)
- NRG Type-R Replica Seats
- intermitting spark need a guru on this 1!!!!!
- Correct Throttle Body?
- duz my hatch run??
- Cam troubles b16a2
- so i feel dumb
- B16 Yonaka mounts
- Wiring an amp. 95 civic.
- d16y8 Billet mounts??
- 92 cx civic rotor placement?
- 1999 Civic Si, 96 spec ITR swap Idle/fuel issues
- needing a jump every other time but battery is strong!?!?!?
- what should my car run in the 1/4
- suspension question?
- nice driving at mosport
- hi guys im new
- Gsr into 99-00 si
- Help with Del Sol gas tank
- d16zc rebuild and i have a problem
- Spark plug stripped...
- H22A4 into DelSol axle problem
- Will EG interior door handles fit a Del Sol?
- few questions regarding ls turbo build
- help!!!!!!!!
- 1996 Civic drive ability problem
- EG lower ball joint
- Mismatched spark plugs?
- SRS airbag light on
- Im new to hondatech, just have a quick question?
- anyone have a bbp header 4 2 1
- Welding on D16 Z6 intake manifold???
- New B18C EJ6 owner.. pics inside
- Password Jdm Whale Penis?
- rebuilt head break in?
- 92-95 4 door with coupe/hatch front bumper?
- New 94 civic eg coupe Owner
- how much to rebuild trans??
- 95 gsr swaped hatch no start IMPUT PLEASE THANKS
- SOHC valve cover ?
- EG hatch weight reduction question
- midori ej8+wire tuck from el salvador
- help with turbo. what to look for when buyin a used one.
- PWJDM Fenders
- Civic ex
- Popping noise from exhaust..missfire? Please help!
- Car not starting
- obd1 h22a into 00 civic hatch dx problems
- Where to buy 92-95 civic hatch roof ???
- Strange overheating problem a 98 Civic Ex
- ek lowering problems
- Pics of COUPES!!! Where they at?
- flush offset
- Automatic EX Cluster In A DX Manual
- civic si 00 engine harness
- Stock Del Sol Floor Mats
- Quick Q - 95 EJ2 w/ 95 B18B1, AC belt??
- Leather seats in my EM1
- Valve Cover Question
- civic seat swapping.
- top rear strut nuts froze, help!
- 95 eg caliper
- Hassport Mounts?
- What is a MSD External Coil For?
- what swap should i do
- snapped bolt on Water Pump! Help!
- Innovative mounts for ek
- Fittin an EK hood in the back of an EK?
- Name of these OEM rims?
- Timing Help?
- Water Pump installation problem! Has anyone done this, suggetions?
- EBAY spoon style exhaust
- ways to connect sidemoldings. help.
- would it be worth to save and get a b16
- em1 gauge cluster removal
- D16z6 to a d15 block
- Would this be a good deal?
- hose connection
- Honda Civic Clock Light
- cuts out
- SOMEONE F-ING KEYED MY CAR
- Got a Question?
- Need help,What code is this?
- how do u swap seat rail?
- 57 TRIM OR 60
- Need help with 1999 Honda Civic engine and transmission problem
- itr brakes on a em help!
- jdm b18c gsr obd2a p72 013 ecu when does vtec and iab engage
- header 2.25'' or 2.5''
- problem with headlights ..
- rims for del sol
- "new to the shop"
- gauge cluster in a 94 civic hb
- 00 SI rb16a2 engine removal help
- Ek motor mount bolt size
- Sunroof question.
- machine shop
- LOL at another Endyne PCV thread. Easy ??
- comp vs. crower camshaft
- help please
- HELP: Oil on tranny and block??
- no o2 sensor on b18 ls help!!!
- my eg is dying...
- Aebs Intake Manifold
- How much would a Eg Ek shell cost?
- Is usdm popular in japan?
- ?'s LOW RPMS? amps jummping. 98 civic expert advice PLEASE
- I gutted my interior
- New Guy Here! 94 Eg8 sedan.
- deciding on shocks
- If You Like Lil Wayne...
- held does any one know what cel code is this. video
- How much does a b16 swap cost?
- steering wheel????
- What motor will bolt up to a d16z6 tranny
- eg ek front end
- 94 civic died while driving help!
- Name that noise, win $10!
- need help deciding what motors and trans is best for the money
- pic request - EK's rocking Rota Grid Drifts
- Compression test...now car wont start / No spark
- suggest midori help
- Brakes
- My car wont do nothing....NOTHING
- how much to fix 3rd gear synchro?
- quic question about factory immobilizer
- 96 Civic Automatic - Only Reverse No matter what gear indicator says
- D15b2 on 1994 civic dx
- Car noises
- idling???/
- 99-00 climate control conversion question
- manual door to power doors?
- car not getting spark need help asap!!!!
- D16y8 manifold on d16z6?
- vtec green plug?
- turn signals dont work but hazard lights do
- car jerks to the left
- Swapping my d16 into a gsr shell
- Check Engine light code 21
- EG door panel swap
- Help ASAP.. Thanx
- Car wont stay on unless You "HOLD" key in turn on position
- Oil seals on Transmission..help
- idling issues on my b16a swap
- Faulty MAP Sensor = Limp Mode?
- Dash Vent Removal Question, Please help
- New EK owner
- Main and head bolts thread size
- EG Hatch OEM side skirt installation?
- Need some help mild restore on hatch dash
- Coil Over Question. HELPPP
- Looking for a hatch, but only finding A/T
- why would you upgrade to a steering wheel with no airbag??
- Are gsr/b18c1 sleeves steel
- workshop manual b18b4?
- POST YOUR CLEAN EG AND EK HATCH!
- 1997 motor swap
- tps problem question
- obd1 gsr in ej8...code 20-ELECTRICAL LOAD DETECTOR
- Need help b16a2 swap in my '00 hatch
- new here, 95 del sol
- will EJ DX calipers fit on EG EX/Si spindles?
- jdm itr catback vs ek9 catback
- Loud weird sound on my EM1 while driving
- JDM SiR Cluster issues regarding cracking?
- A few videos of my H22-EG6 from local autocross events in 2009
- header question
- eg h22a(well read in this topic motor is already in) questions i need some quick help
- ideas for modding a b18 non v-tech
- heater not working
- JDM ITR O2 sensor fustration
- Head Stud Removal
- Need Alternator? another model work?
- Civic lights pulsing and speedometer not working
- Road racing eg
- HELP! TERMOSTAT OR WATER PUMP PROBLEM?
- i'm new here, here is my 93 del sol si
- Civic EG - B engine swap
- WTB d16z6/y8 built head
- Del Sol worth road racing?
- which block i should get need help
- Need some help ASAP!!
- 97 ek single v obd1
- Blown Head Gasket
- 2000 civic si-no power when accelerating?? wheel bearing ? too
- how do u get the clear plastic cover off of a gauge cluster?
- little help wit the gsr turbo setup..!
- STILL overheating
- Persephone is Dead
- cluster light questions
