View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Lowering my car.
- obd1 auto p72 ecu help
- p30 vs p61?
- GOING TO REFF FRIDAY 3-26-2010
- Ac not switching over to cool from heat
- 96 Civic EX GSR Swap Sputtering...
- what models had ABS? (serial #s?)
- Fuse Panel Wiring EG
- !!!!b16a and y1 lsd tranny, starter questions please help ASAP!!!!!!!!
- Honda Civic DX to SI conversion
- 96-98 sedan seat options/interchangability
- trying to build my b20b block...please help
- do i need iab for gsr swap?
- Headliner question
- need help
- 93 civic w/ b16a3 swap and speedo does not work
- del sol suspension components
- automatic axles same as manual?
- driving around / vtec afterburn smell ?
- 75 psi on my fuel line??
- will a b series starter fit a d series motor? they are both manual
- del sol wheels
- im baaackkk :D
- New proud owner of a 99 FBP EM1
- Need help With my 92 Honda civic hatch
- Rough Ride...
- starter question
- 94 shifter linkage
- ECU got wet while driving, spark but no fuel
- 3 piece wing for a 98 civic
- New power window channels/rubbers
- anyone get a diagram for 92-95 civic tcs
- hasport mounts
- MY DEL SOL !!BUILD!! aka Sonic
- sohc vtec dizzy queston
- Clutch not shifting
- 2000 DX hatchback - Help me pimp it on a budget :)
- foglights on dolphin nose Del sol
- 97 CIVIC HELP ME PLZ
- K SWAp NOOB
- Exhaust Fumes entering cabin 92-95 civic
- Oil Light/Pressure
- Radiator problems
- Headlight conversion!!! 96-98 HEADLIGHTS TO 99-00 HEADLIGHTS EK.
- hesitation while driving
- 1998 Civic EX annoying beeps in key position 1
- hid in my ek fog lights
- Ls vtec part numbers?
- No 4th or 5th gear with hydro B16 tranny
- Where to Buy Kevlar lip?
- Fuel mileage questio (WAY too good)
- B16a2 Fuel Pressure Regulator??????
- ASR Subframe Brace Install PIC PLEASE
- Crx with D16z6 swap wont rev past 4k
- 1995 honda civic hb.. work in progress.. LMK how i'm doing and what needs work..
- Clutch Converstion
- Help with power windows/lock conversion
- KN/AEM dryflow/S&B factory type filter
- need help with speedometer
- b16 HYDRO TRANNY PROBLEMS HELPPPPP
- Del Sol: Whats in the hump??
- shaking front end
- GSR pedal assembly interchangeable with EJ?
- map sensor wiring q
- cracked exhaust manifold?
- p28 chiped d15z1
- swap transportation problem/ question
- Suspension issue, can't figure it out. Help?
- Dead spot in steering 92 civic hatch
- ♦drivers side motor mount question this dosen't look right!♦
- Help car isn't staying on!!!!!!!
- 94 civic si cant pop my hood
- wire tuck question.
- Another car wont start thread :x
- Hello there...long time lurker, new member with questions.
- Water leak :(
- battery is good but car has no power help!
- what flywheel should i use
- Where am i leaking from ???
- How come these are different?
- How do you change square fog light bulbs?
- D16/D15B(OBDII) Injector Voltage
- JDM Gathers twin-pod speaker variations
- axle keeps popping out must help!!
- PLEASE HELP MOTOR PROBLEMS!!!!!!!!!!!!!!
- New Exhaust = OBDII troubles :(
- Changing water pump/timing belt
- fuel problem? sputtering?
- A few 93 civic ex questions
- What kind of T mount do i need for a EJ8
- Need Oem part number
- 97 civic lx idle screwed up again...
- 99-00 ek9 conversion Question?
- Blue Smoke at Random 92 b8/z6
- loose gas pedal
- Quick question
- problem...
- 96 spec-r B18c vs K20 type S what to choose???
- Si grinding
- Color code anyone???
- harrisburg pa lock your shit up
- D15B Hesitates when revving
- stock front upper camber arm
- d15b swap ecu needed for start?
- Need HELP..Car Hesitates at 1000-1500 RPM
- Ep3 steering wheel into Em1 will cruise control work
- need help!
- XTD clutcn on sohc
- My 99 hatch.
- Ignition switch need replacing?
- Anyone know the location of keyless entry system on 00 civic ex
- Anyone have p0135?
- My EJ2 Build Thread
- PROJECT: EG6---> LS VTEC
- HELP! where do these go?
- Fuel Pump Fuse
- Need some help with my A/c.....
- FMU question
- HELP no power to car, no lights, no sounds
- What's your experience with redrilled wheels?
- Electric driver window not rolling up properly - 93 Civic LX
- Ground Wire Behind Cluster ??? HELP
- squeeky noise from hell!!
- Plastic SRI?
- running lights
- clutch issues
- First every project, Valve cover paint!
- traction bars in EGs
- obd1 b16a and y1 lsd, vss
- Just looking for some suggestions on swap
- Turbo B16A3 hitting 7200 rev limit
- Is my Idle ok?
- Good deal?
- I want to REDO my suspension
- need lug nut for volk cv-pro wheel
- confused on b.a.r rules.
- How to remove this door trim piece from a 95 civic???
- Am I screwed?
- do oem 4 disk brake will do? or is better to do the GSR brake swap on a EG?
- Diamond Japanese Auto??
- ??? B-series shift linkage from a crx will it work in a 92-95 civic w/ b-series
- Just Blew Motor, Need Rebuild Help/Info
- blox, omni, buddy club, front camber kits
- Swapping instrument cluster
- Civic brake up grade
- MY CUSTOM EG TYPE R CLONE CLUSTER.DONT JOCK.
- that was some impact...
- post your innovative way of weight reduction on a 92-95 hatch
- Turboing a standard 1.6 engine (information wanted ASAP)
- will 99 civic si back seats feat ek hatch?
- Lil Things That make Big Differences
- Power Steering boot rip?
- Del Sol toy hauler?!
- Ripped CV boot
- B18c GSR skunk2 intake Question
- b20 vtec build and question
- ecu question
- Spark Plug Gap (not a normal question)
- iac? on 2000 ex
- Need Some Exhuast Help
- CEL problems
- misfire issue
- need help with civic
- Recovering factory seat
- what do i need to swap B18C5 on a del sol?
- Is this worth the $$$$?
- Car wont start
- 15x8 on civic
- Help removing gas pedal
- ARP head studs pattern...Please help
- Can someone tell me what this button is...
- 93 Turbo Hatch
- D15B7 has very low compression, but its very consistent?
- Slight Missfire under boost
- intake QUESTION!!
- RPM needle tweaking out???
- SINKING PEDAL!
- weird problem with 92 sedan help asap
- GSR Knuckle and brake upgrade
- is my key worn out?
- RSR GT2 exhaust
- newbie here point me in the right direction
- What do you guys use as pedal covers?
- 96 EX sound after header install?
- wiresets... preformance vs replacment
- anyone know where to find 1/24 size model cars
- Mounting Mugen Style front lip on an eg hatch
- Charcoal Can Question?
- How many Mounts for EG swap??
- Axle questions for you H22 eg owners!!! HELP!
- Engine switch
- Ej1 civic and DC integra parts interchangeable?
- 99 Civic EX
- clutch problems
- civic 99 hatch back misfireing
- TROUBLESHOOTING ENGINE PROBLEM
- d15b7 with d16y8 block
- Code 67/P0420: How can you tell if it's a bad cat converter or bad o2 sensor?
- 99-00 Grilles ... Si mesh insert w/ 00 CX grille bezel?
- Help with timing belt
- JDM EK4 SIR Headlight Question.
- d15b7 to d15b no start plug question
- Help: Trans
- air pocket in cooling system
- Power trunk release "option button" part #?
- Newb here..
- Help with Bad Idle problem Please
- Help with Honda Access Window Visors for Eg Hatch
- Seat Rail For My Yonaka Seats
- taking glass part of cluster .
- Mini-ME!! D16z6head/Y7 block.. questions
- JDM GSR or JDM H22
- boost on automatic transmition comment pls
- How Do I change a Dizzy on a d16y8 motor ?
- can you indentify this rim for me?
- D16y8 crank help
- Changed valves now have some ?'s
- 96 civic dx coupe coilover help
- rebuild tips.
- Loud knocking sound from engine
- pistons and rods Question
- b16 tranny bolt questions need help by early tomorrow morning
- NEED INFO ON SEAT RAIL BRACKETS USING YONAKA SEATS ON A 95Eg
- Vtec problem help!
- head unit woes
- 92-95 civic starter cut relay
- 1993 Si Auto-X/DD Build Suggestions?
- why does my jdm b18c bog in vtec
- Anyone have pics of pinouts on d16y8 ecu
- WANT parts for my DSERIES...have HONDA 400ex to trade?!?!
- B20 swap into EG help!!
- The situation --99 ls motor in a 1994 civic ex
- total n00b question - vin on block
- Vtec solenoid obd1 obd2 differance
- wibble wobble...steering?
- screw boost, i made my mind up ;)
- password JDM yay or nay??
- VX rear diffuser....from factory
- Radiator Cap= OVERHEATING ISSUE?
- Oil in coolent resevoir-Y8- help!
- 93 o2 sensor
- another tire question
- Windsheild washer wiring
- [FAQ} DIY: Lexus IS300/ES300 fog lights retrofitted into EG
- Its my ECU dead?
- is this a clutch problem...
- cel light on but reads 0 codes
- brake conversion Q
- tire size question
- high pressure PS line... welded?
