View Full Version : Honda Civic / Del Sol (1992 - 2000)
- GSR swapped Eg weird overheating issue
- '97 Civic DX - D16Y7 to D16Z6 Swap Help Needed
- Honda civic roof problem
- 96 civic ex won't idle right
- b20 block & b16a head
- 1995 civic auto wont shift into 3rd or 4th gear
- ZC engine & S20 trans
- Help with OBD location
- brake swap question
- Pictures: Any insight into this trunk leak?
- No problem using old sealed manual transmission fluid?
- EG hatch project, needing advice on b16 head.
- Automatic transmission switch over
- Hasport cable to hydro bleeding problem
- Labor of love em1 resto build
- D16Y8 Air Intake humming sound
- HELP! Quick question while my intake is off
- Suddenly lost compression after driving a week with a swapped z6/y7 mini me
- 1997 CX not starting
- Gen5-6 Sleeper Hatch
- seat belts
- Y8 swap help
- No heat
- p0505 bucking surging gas smell.
- Helppp
- **95 civic seat rails**
- clutch behaviour
- oil pump failure?
- Alignment Problems Persist After Replacing Almost All Alignment Parts
- Removing AC and PS
- Need help again, cranks wont start ...
- ap1 cluster swap on eg speedo inop
- Good idea to replace old water pump with 58,000 kms on it?
- How hard is it to insert a wire through this tube in door hinge
- Flat towing for $100 or less [advice needed]
- P75 ecu running a d16z6.
- EG no key need to move
- B20b4 h8gh compression motor
- D16Z9 valve springs in D16Z6?
- K-Series EG6 Sedan?
- Domani trunk conversion inner tail light issue
- 1998 civic ex dy8 stalling
- Crackshaft Pulley Bolt Torque Spec (New Style)
- '95 civic fuel pump on/off switch?
- 95 del sol with d15b idle and acceleration hesitations.
- Soft pedal. Lost
- 97 d16y7 del sol wont start
- Creaking/ squeaking noise from front right suspension
- d16y7 rough idle, hesitation, stumbling
- d16y4 block with d16y6 head
- Erratic idle and stall
- 98 DX honda civic with a B20 swap CEL
- Difficulty flushing brake fluid
- 98 civic wiring diagram to test range sensor circuit anyone?
- 00 ex auto to manual engine swap
- 95 Civic LCA Pivot bolt Won't Tighten
- tokico struts vs nuespeed struts?
- H22a1 94 civic eg tie rods
- my 1998 honda civic is leaking coolant from the bottom of the radiator.
- 98 HX cel p1361 Help!
- B16A Si-R II (170HP) What is this Noise?
- Does anyone know where to buy this retainer clip?
- 1997 honda civic
- Eg civic b16a2 conversion advice
- tune up on b16b engine
- moog ball joint grease nipple hits CV casing
- Wiring help
- civic 96 b20b rpm issue
- Help diagnosing an odd sound.
- 95 civic for resto.... suggestions?
- 2000 Civic 1.5i Vtec (MB3) OBD Conectors
- 1999 civic injector issue.
- 98 civic cx hatch ls/vtec
- transmission
- Problems putting LCAs back on
- Rebuilding jdm b16a gen 2
- 1995 Honda Civic LX Air Intake system?
- 1996 honda civic lx roof rack?
- 97 civic ex new alternator but regulator fails
- Rebuild advice
- D16y7 Auto to Manual swap help
- Automatic b20b4 all wheel drive
- 96 Honda Del Sol H22A4 Swapped: Transmission help
- OBD2A plug-in
- 92 Civic CX Dash Lights/Taillights out
- Ignition Barrel and Door Lock Help
- Engine stall, idle issue
- 94 Civic EX d16z6 2 door coupe - Doesn't Rev past 4000 rpm
- Ask for details D16A7
- 98 Honda Civic
- 1997 Civic Misfire
- Clutch pedal problem help!!
- 95 Civic - Extension Rod Spring Pin Replacement
- Knocking coming from inside my motor
- Door leaks a little water
- Can anyone help with p0705 trans code?
- Best Recommendations for 2000 Civic si
- eg hatch headliner alternatives???
- catch can question
- 95 civic Auto with d15b7
- D16z6 Turbo Build
- Engine Shuts Off While Driving?
- 2000 honda civic ecu problems
- Should I get a short shifter?
- Swapped 98 EX auto to manual with a D16Z6
- d16y8 swap runs terrible
- EK wheel stud sizes
- Secondary O2 Sensor questions
- What model number is a factory ac compressor
- 1994 Honda EH
- Honda Civic DX 1997 Hand Brake
- 95 civic synthetic oil
- 2000 Honda civic ignitions switch?
- I'm back in an EG.
- d16y8 swapped into 98 dx no start, stater making noise
- Civic after running fine for months
- b20b - obd1 or 2?
- EG Sir & Sir II
- Radiator support
- 99 Civic D16Y7 Cranks But Doesnt Start.
- Loud knocking noise under car
- Swap help
- How do I replace the following and what part(s), do I need?
- 97 civic, h22a swap, chipped p28-no start no, fuel pressure.
- Type R 5 Lug conversion Ej1
- Not exactly sure which harness i need
- Power Lag - Oil related
- cant find obd connector
- Code 11 Myth Busted JDM ECU
- Honda Ecu Reset civic obd2 JDM
- Fuel main relay possible issues
- d17a2 swap (97 civic lx)
- Del Sol Rear Window Motor Repair?
- having problem. need help!
- 94 hatchback Eg with h22a1 swap looking for advise
- $300 ex coupe with p0705 code
- Coolant leak near engine coolant temperature (ECT) sensor
- Wondering what this plug goes to?
- Broke valve cover bolts
- driver's seat fix
- Replace Honda del sol taillight assembly
- EG hatch B18c Turbo IAT sensor issue
- engine sway
- Engine Cranks but no Spark
- 93 eg b18c1 swap... why is it rich at idle and fine at cruising?
- timing issues?
- d16y7 & y8 question
- B16a2 head rebuild
- D16y7 in D15b7
- Obd2a to obd2b dizzy
- Genuine Honda??
- Rough idle
- 96 hatch won't start.
- only starts if I pop the clutch
- Wiring a odb1 vtec to odb2a P2E ecu
- transmission problem
- Neuspeed suspension
- My Honda Civic 95 ex won't start
- Buying 1999 EX, Things to look for?
- Honda engine sluggish acceleration
- 92-95 Civic Fuel Sending Unit OR Meter Unit Assy., Fuel
- 93 honda civic ex
- Suspension Play
- Power loss/Rough Starts Mystery
- Help Finding Part For Mounting Bracket Ignition Key Cylinder
- needing insight for my jdm sohc? zc
- Blown Headgasket or fan problem?
- I need help with tps
- Exhaust for a 96 hatchback
- Coolant leak
- '92 Civic Si Steering Rack Boots Issue
- d16y7 idle surges.
- Anybody know what B16 head this is?
- 99 civic si no power
- 1994 del sol s 1.5 quick mount struts
- D15 to d16z6 swap..
- VIP EJ8 Seats
- Looking for suggestions: 99 ek sedan refresh
- anyone have a how to guide on removing del sol door without pulling the fender?
- Del Sol dash cover removal
- Dream car with to many miles! Need Advice !
- 2000 honda civic tailight/license plate fuse keeps blowing
- Em1 Worth 20 years from Now?
- I need of help urgently
- Timing d15b7 plz help
- coolant line routing for d16
- Need to Lower My Seat in My EM1
- Finally got my First Civic!
- Best place For pre painted Bumper?
- no start
- can use the right hand car transmision and engine for the left hand cars??
- B16 Weird Accelerated Startup, FITV and IACV
- oem bearings worth it?
- Po6 or p28/chipped or not
- Swapping y8 into 98 civic dx
- Looking for answers to what probably seem like stupid questions.
- Lookin for Info on Boosting my D16Z6
- Low RPMs bogs/hesitation/die
- 2000 acura EL does not start after winter storage!
- Clutch release bearing
- True monowiper DIY for Del Sol
- Discontinued Part locator help
- Gushing hose under distibutor. HELP!!!
- Del sol swap
- tons of white smoke, runs like sh**
- Civic randomly dies
- Del Sol VTEC Traction Control Possible?
- Torque Specs
- EG Civic Wiring
- Burping Radiator
- 1997 Honda Civic LX Wont Start.
- Stuck Distributor Cap..
- Hitachi vs TEC Distributor
- 96-00 Front suspension differences
- D16Y8 EG bogging and dying
- double din convertion
- B20b Swapped 97 Civic Sedan 4k Idle issue
- Help diagnosing starting issue
- CA smog check normal Nox values?
- Zc block with y7 head help
- Driver Side floor harness help
- Weird Behavior
- Loose Fuel Injector Clips
- quick turn signal wiring question (solved)
- ECU no codes given.. stumped
- Bleeding clutch and clutch still won't come all the way up
- ECU problem civic genio 1993 p27
- 2000 SiR stalling issue but now gotten worse
- loud 'skimming' noise
- Ignition coil location 1999 Civic Sedan
- Can't figure out detonation
- Civic 93 Gas wont prime until CEL light goes off
- Quick question about IMA sensor.
- ... freaking suspension
- New dizzy yet NO SPARK! Need HELP!! SO Stumped!
- Heavy Single Clutch Slow 1-2 Shift
- Sons firsr car.
- How to verify that I purchased genuine 99-00 Civic Si harness?
- Advise to build a beast.
- Finding a 12v ignition switched power source but with a specific condition.
- Front defroster problem
- codes and trans
- 1997 Honda Civic ex with odometer problems
- B16 swap no spark
- 93 Del Sol - No A/C - Plenty of freon
- alternator not charging
- 1997 Honda Civic coupe with power windows
- Ignition timing d16y7
- water pump
