View Full Version : Honda Civic / Del Sol (1992 - 2000)
- koni yellows and tokico illuminas
- tech question
- help with p28 ecu!!!
- Questions on mini me
- ek CTR headlight install..remove bumper?
- will vtec work if tach is not working?
- lca bushing on a 99 ex
- V2 Coilovers
- A/C question
- ZEX sohc help! muffled knocking noise coming from engine
- climate controls are out
- where did you get your CF Hood?
- Hid lights for EG
- Possible transmission problem.
- Beauty and the Beast
- spoon stroker kit
- quick suspension question, ek fit on a eg?
- Apexi WS for 371 bucks, anyplace have better prices? for 96 EX
- Which Endlinks for ITR LCAs, Beaks ITR Sway Kit - in EG hatch?
- long armrest
- DEPO Foglights -Wiring harness help
- Seatbelt indicator light EG
- IACV questions
- Picture(s) of Thermal R&D 3" on hatch?
- headlight adjust..what the..
- Diff. Replacement
- Dumping old brake fluid and coolant...
- weird clacking in engine...HELP!!!!!!!!!
- comptech header problem....
- ls(140) or jdm d15(130 hp)?
- what year teg are these seats out of
- Can alternator go bad practically overnight ~ (after a motor swap)?
- stock GSR muffler better than stock EX muffler?
- Specific questions: Searched: Pics: integra dash
- Will a B18a work in an EG
- buying a '99EX coupe
- aftermarket Short Shifter jdm real titanium knob
- anyone install an aftermarket fuel level gauge????
- JDM EK Sidemarkers
- 96 CX brake/suspension upgrade suggestions...
- Tranny leak?
- CEL code 6 Primary o2 sensor question
- Differences in 1.6L D-series blocks....
- JDM D Series Question???
- installed d16 skunk2 manifold(2 pics)
- turbo b16, getting a check engine light
- Weird brake noise!!
- Legal questions about trading a car with some one in NY
- Radiator capacity for 95 civic Dx 1.5 liter
- installing zex right now.. need help bad...
- eg carbon fiber doors
- ITR suspension
- k&n drop in filter for sir airbox?
- HELP- Need motor info/help!
- Noisy cams?
- civic si bumper fix question
- buzzing noise coming from passegnger side airbag?
- asking big favor, can someone run a carfax for me, please...thanks!
- T1-r resontaed test pipe/race cat ?'s
- asap! kumho supra or falken ziex?
- need help asap!!!
- Y8 intake manifold on y7 Fuel pres. regulator
- Why do different Honda dealers charge different prices on my oil filters ect..
- strut bars
- Project B20/VTEC motor complete
- *****4-wire o2, how do I wire it?******
- SMOKED
- AC BELT HELP!!!!!!!!!!!!!
- spring install question
- Suspension Squeaking.
- track/drag analysis needed
- stock fuel pressure regulator
- 1998 Civic Motor Squeaking Noise
- Speaking of theives.
- Pivot tach seems WAY off
- turn signals don't work
- fan fuse number?
- Are the oem 92-95 fogs very bright?
- Top speed of a 94 del sol si?
- honda-tech?
- CTR armrest?
- OEM foglight installation
- Tokico Illumina Coilover kit / Is it worth it?
- help find thread for this car...
- F20C in a Civic? Can it be done?
- wat gauges??
- Gunk coated header...
- Ok is the B20/vtec goin to give me problems in the future
- Can someone please help me????
- Guages Autometer
- JDM GSR in Ek 1/4 times?????
- Do I need a resistor box????
- fabbing INTEGRA door panels for my hatch...
- del sol B16A engine swap.... advice...
- where to buy d16 online?
- check out my hatch i bought ....$350
- d16z6 vlave cover
- ....ghetto riggin a LED light to tell me when to shift.
- d15 rods?
- questions, buying a car with obd1 to obd2 engine ....
- exhaust ?
- civic coupe questions
- Taillight Question for 4 door owners
- 92 Civic DX is dead
- KYB AGX problem. need help!
- BAR sticker with b20?
- ECU link to a peronnal computeur on board??
- tein S springs
- I HATE THIEVES
- ============>USDM b16a2 EG h/b owners<=============
- 00 EX help...
- washer placement on TEIN SS
- Template for gauge cluster?
- hks turbo timer type 1. accuracy questions
- can i use a b16 vtec solenoid on my d16y8
- APEXI Vtec Controller
- rear bearing/hub
- Looking for aftermarket axels
- harness extender
- PRICE ON CAM INSTALL WITH AIR INTAKE MANIFOLD ALL SKUNK2
- Idle problem while AC is on...
- ...keys stuck in ignition...
- Horn Replacement.
- 4 Lug JDM ITR WHEELS
- OT. Minneapolis HB GUY !?!?
- coolant question
- itr swap in eg hatch...1/4 mile times
- 97 civic with 00' b16a2 why doesnt the fan work and the gauges ?
- Anyone from NJ, or the area, going to Englishtown?
- it it normal for a b series motor to guzzle coolant?
- Tenzo seat rails????
- going 2.5" exhaust, what do i need to get?
- steering rack for EK!!!
- Code 9 or 90
- New to these parts...
- 00 civic ex engine probs
- has anybody ever dealt with this co. for swaps?
- The old... and THE NEW :) Can you say CLEAN sol si??
- will a P72 ECU run an ls motor?
- Paulll's Turbo Clean
- Questions About Civic VX
- HeLp!!!!!
- Who else in here has K-fever?
- Tom the Moderator
- CAN some1 ID this PART????
- Question about ARC splitters
- vtec light, some questions...
- my 93 civic cx hatchback front lip HELP
- Possible change of plans. (pics)
- GSR Swap EG, Driver Side Mount ?
- 99-00 Civic Si CV assemblies interchangability?
- p30 woes... won't rev past 4000 w/ mugen xh4 chip...
- Its alive......
- swap question
- Question about ls swap
- what rims are these?
- Paint code for "Samurai Gold Metallic"
- what's the point of......?
- will a 92 dx distributor work on a d15b??
- How do you completely disarm the alarm system for a Civic?
- New Greddy SP2 exhaust
- Easy - Timing Belt Question
- All EK hoods the same?? HB/coupe=4dr???
- OMG my Baby
- vtec wiring on a d16z6
- Are Honda Vehicle Speed Sensors interchangeable?
- 4 wheel disc with no abs?
- LSVTECTURBOZEXHONDADATABILT
- excessive engine vibration from AC?
- question about the neuspeed front strut bar, and strut bars in general, for civics
- SRR sohc cam gear , good or bad??????????
- Throttle Cable Problem
- flywheel weight for 99-00 b16a2?
- A day on the dyno
- Anyone have Pics of a Tsudo exhaust on their car?
- changing out d16y5 with cvt help please
- cigarette lighter in 93 cx hb?
- Si Guages (92-95) Need help, having shorts...
- THE NEW SMOG LAWS/Machines!!!
- y8 swap on a y7 block help! Minime vtec!
- TDC SENSOR
- need help taking my speedo off..
- SUSPENSION COMPONENTS
- jdm type r header
- eg interior light help!!
- Are these good deals??
- For a turbo d16 , what flywheel ?
- urgent: brake problems
- what motor do i have? engine block says zc but it has vtec...
- SD peeps representin' Barona raceway...
- What do you guys think about venom injectors?
- How much Are ITR front & Back Seats Worth?
- how do i fix a code 8
- 6gen civic cluster swap into 5gen cluster housing... Who has the info required?
- 92 civic hatch
- 96-98 JDM EK4 bumpers
- Rear Disc Conversion
- HB rad support = 4dr???
- Sooo Hot. Need AC.
- quick question about starter
- IT'S HOT!!! I need my a/c...
- Crankshaft speed fluctuation sensor
- Intro & New EK9 owner... story here
- **Place Your Civic Pics Here**
- Help: Idle Trouble - GSR T-Body > D16Z6 Manifold
- RSX seats in a 1993 Civic Hatchback
- ill_take_one **PLEASE READ**
- cv joint question?
- What Kinda Lip Are On These EG's????????
- power steering pump removal
- Dissappointing day at the dyno. . . . ='(
- curb checked my rim!! need help!!
- What Year?
- does anyone trust an ebay turbo?
- 92 Si + GSR Block + ITR head + JDM 4-1 + RS*R = What length cat?
- Transmission differences between...
- Will this be ok?
- Which Del Sol?
- Blowing....FI E/M fuse...
- Del Sol Mods?
- Air Conditioning service, R12 vs. R134 retrofit, etc. HELP?? :)
- Eibach Pro-Kits and Bumpstop Cutting
- 94 Si How much???
- can you please post you times and horsepower, please......
- Rims?
- No more wheel hop!
- ::i hit a kid on a bike today::
- motor mount looks broken
- chipped p28
- something wrong with my bro's civic but dunno..
- I need a 92-00 Civic EX exhaust/axleback asap..
- helms manual
- Guages for my OBD2 Civic B20B
- dropping the steering column..
- intake on hybrid
- Trying to sell my tein suspension but dont' know......
- 2003 Civic Radio COde Help!!
- cruise and dimmer switch?
- Part #'s
- free honda engines in CA>
- removing wiring from climate control radio
- How to take out the heater control
- japan. vs. U.S.A. vs. Canada
- dohc decals
- my 96 hatch vs. 92-95 hatch
- Important Question, need your help!!!!
- Bad Idle and Funky Driving
- 94 integra cat back system fit 93 hatch?
- Okay to use aftermarket wheel lugs with stock wheels?
