View Full Version : Honda Civic / Del Sol (1992 - 2000)
- where can i get a downloadable basemaps at?
- How to stop camgear from moving?Quick question
- fuel problem please help!!!!!!!!!!!!!!!
- my spedo's gone crazy
- my new foglights and headlights
- Q about air conditioning install
- Silvestar Ultras
- doing a swap need some help!
- Press out Ball Joint or Hammer it out???
- ECU clip/wiring question
- injector ?
- b16a2 dyno chart
- Car Show (NJ)
- tbs callibration
- Ran into a snowbank and now my temp gauge doesnt work
- engine swap
- tanish color on plugs
- EP3 rear seats converstion????
- cracked manifold please help
- just got gsr swap
- boiling water in the overflow
- What Struts?
- climate control light bulbs
- cams and cam gears for b16a2
- INNOVATE MOUNTS vs HASPORT MOUNTS
- Who has the itr 5 lug w/ brakes conversion
- CPRs will the offset fit
- 94 si have power options ?
- TPS ???
- Buying a car that has been staying outside for 1 year
- HELP - Car wont start!!
- What is the size of the tweeters on the front door of a 95 Civic Coupe?
- cheapest place for oem o2 sensors?
- help... 1995 honda civic ex 1.6
- BDL fuel rail question!!
- Best headgasket to get?
- Electirc problem? help plz
- how to take off the signal and wiper switches
- Let the Pic do the Talking.
- 1999 ex flashing SRS
- eg tail question?
- Are all d series valve train the same?
- changed axles w/ out draining Tranny fluid?
- 92 Civic Cx/EX Alternator Difference?
- have a minor problem!!!
- Need help w/ power steering removal!!
- which ECU to use?
- D16Y8 Question
- Tire/Rim Questions?
- noob question
- MY 1994 SI CIVIC HATCH STOLEN GUNMETAL COLOR /W STEELIES Riverside"
- State Car Inspection Skid Pad Test Shows Passenger Side Rear Brake is NOT equal to the other??? Any
- Speedo
- My VTEC studders: I hit the 5200 rpms and then goes down to 4700 rpms then back up
- NEED HELP PLEASE!!!!!!
- 95 civic ex --> si conversion?
- Whats a good motor for a 93 4door eg9 thats automatic besides a d series
- Stalling out wile start up
- 2000 SiR seats
- 95 civic build
- blue smoke means>>???
- When i hit vtec my car smokes...
- how wire up o2 sensor from a cx????
- where i can i buy new tweeters?
- Any obd1 cars converted to obd2 for the BAR and passed?.. & some tech Q's.
- Turbo Kit For Everyday?
- Movin Up? O2 Help?
- To Turbo Or Not
- injectors
- password jdm fogs?
- yay i bought my 99 si.............
- need help,car wont run
- blown clutch
- ecu???
- vaccum help?
- head works
- Q?s about hx rims on a del sol si........
- will ep3 floor mats fit in my em1?????
- okay to drive without distributor leak cover?
- PM10 >>>>SEARCHED everywhere and need to know what car its for
- i got a 96 LS b18 on my Civic hatch..but i want More torque ANY IDEA'S ?
- help just finish my swap on my 99 ek no power to the ecu
- Boosting
- where to find an ammeter?
- cv-boot replacement
- Can I Use 1.5 JDM Vtec axle on a 1.6 SOHC Vtec spindle?
- 92-95 EG.. ZC or SOHC Vtec JDM Both??
- too good to be true?
- Tein HA suspension fitment
- D16Z6 question ...
- weird injector question
- Spoon Engines
- D16 BUILD
- Ok I was running my car fast (100 mph+) and my battery light come on and my idle went up
- head gasket question!!
- L bracket mount question
- will it mold?
- clutch pedal free play adjustment ( anyone know how? )
- MAIN BEARINGS AND CONNECTING ROD BEARINGS
- wheel lock lug nuts ... lost the key
- need help what goes hear????
- engine light
- Fuel Pressure?
- OBD2 motor in obd1 car...HELP!!
- intake filter
- Motor Mounts
- Speedometer reading
- Intakes
- skunk2 intake manifold question!!
- bad 3rd gear??
- Intakes
- will a/c from a ek work for a eg??? the lines match up?? if i have a y8 swap???
- 96-97 bumper ??
- *STOLEN* 1998 Honda Civic DX Stolen in Columbus, Ohio...please help.
- H-T OEM parts dealer
- ZipTech O2 sim wiring, help!
- b18c loom into b16a dizzy?
- o2 sensor
- passed bar today.
- headlamps
- overheating/heater doesn't blow hot air
- Transmission codes
- ECU JUMPING
- Wireing Help
- engine question
- D16y7 Exhaust manifold Q and A's
- need help
- ? about Del Sol OEM strut bar...
- engine making a weird sound.
- crank but wont start
- swap or boost help?
- d16y7
- brakes soft after 5lug itr brake swap HELP!
- quick question on a downpipe
- question for you ek's out there
- cylinder #1
- quick stupid question...
- 93civic....WONT START!
- d16y8 studdering
- eg power window conversion
- quick question
- For my LS- Vtec del Sol
- OBD1 p72 in my gsr swapped si..best ecu to run with?
- Radiator needs help!!
- Pics of EG Hatch w/F20c S2k Motor RWD!!
- Power window/lock conversion
- civic is not starting question?
- NGK LASER IRIDIUM plugs to fit my civic
- Factory Colors
- motor shaking
- Need Help QUICK!!!!
- New guy from Raleigh
- ecu code help
- What is this 92 Hatch Worth?
- Header for 6th gen DX? Cat?
- distributor help
- Harness keeps getting loose!
- Not much Heating
- questions for em1 civic with gsr
- no power from female plug to starter.
- b16a2 swap on 98' hatch with d16y2 I think.
- noob question
- another quick question
- 2 Questions / 1 Post
- 92 Civic DX Oil Pump Help
- o2 sensor and other questions
- Clueless
- del sol si d16z6 vtec not engaging
- KONI sport suspension
- crusie control
- h22 civic wont start
- Need Help With Removing Rear/Back Window in Del Sol
- EG Dash question.
- LS Turbo or GSR?
- Tail Light dosen't work and fuse is good???
- stock looking muffler
- questions about ex front brakes
- Interesting sound absorbing info...
- I need new OEM Front and Rear LCA's
- vtec solenoid cap
- HID kit for a 99 civic hatchback
- jdm fog lights
- where do you guys get your slicks?
- CYLINDER #4 MISFIRE!! HELP PLEASE!
- Which harness to use on a b20z
- eg and ek window motors question
- Integra Type R intake manifold on a OBD I B16 Head
- civic 99
- K20R, K20A or 18C1, 18C5
- p28 ecu ,will this work???????
- recommended shocks/springs
- d15Z1 vtec head
- help civic idle problem
- Electrical junkies please help...
- does intake manifold do anything for me
- Half-shaft Q's
- Quick Question??? Are 92-95 Civic LX ECU Interchangeable???
- boost d15b7
- Lowering Springs
- using wayy to much gas.
- ITR rear sway bar klunk noise
- So how bad is it really to push your cold when its cold??
- does this sound like a bad main relay problem ,help plz
- lean or rich??
- Want DelSol, none in town.
- Fluctuating Speedometer: Civic Si
- druM to disc upgrade..
- Got some sound clips from my RS*R GTII
- Hatch with factory cruise control?
- 1994 eg dash wiring harness question
- Car not starting, Alarm system problems....urgent!!!! Need help
- d15b7 IACV on d16z6?
- Can a bad ignition switch cause the fuel pump to not prime?
- header/exhaust work questions
- jdmsh!t -- "spoon style" mirrors...
- driver's side window problems
- red car what rims??
- aem tru power pulley's
- next mod?
- Short Shifter
- Carbon Hood
- BIN/ROM File Base Map for H22a
- Dumb question but I was wondering if anybody would have a good guess.
- distributor rotor: screw not sitting flush, taps surrounding pastic once every turn?
- How hard to Drill holes for 99-00 si wing onto virgin 99 ex trunk?
- code 36??? and 10
- H&R ultra low coilovers?
- HELP!!!!!!!!! H22 civic
- need help with jdm fog wiring
- Code 41--- 02 Sensor.?? HELP PLEASE!!!
- weird eg voltage problem?
- 95 Del Sol
- s20 synchro hub ?
- rear engine bracket...b18c5 swap into ek
- eg problem..
- Gas Tank Related
- Fan question??
- exhaust ?
- Need to find OEM SiR Lip Hardware
- Cage in a civic?
- where can i get my gsr insalled
- who's dc got stolen last night? cause i think i found it
- korbach frame locks for sale
- Depo Fog Relay Part #
- chipped crank pulley, question...
- Headlights?
- b16 and performance bolt-ons.
- counter shaft speed sensor
- need help with wing
- problems starting
