View Full Version : Honda Civic / Del Sol (1992 - 2000)
- steering wheel question
- good price for gsr head - ls/vtec?
- Thermostat Ground stripped
- superbrightleds.com bulb verification. Placing an order for License plate bulbs and.
- honda emblem question?
- 98 civic wiring harness Question
- Throttle bodys between engine series
- which cam is which
- Car pulling hard left? Help?
- My 1st World MB-EK Hibrid Civic
- b20 del sol
- Part number for ctr n1 crank pulley?
- how to tuck the wires inside the car
- 96-98 civic depo fog lights.
- Higher than usual at shifting
- Choppy Gas Pedal
- Smog help throwing codes
- my wiring harness
- B18C motor revs uncontrollably at start-up?
- D-Series vs B-Series Pressure Plate Thickness?
- axle help *tried searching*
- Help no dash (cluster) lights
- Build of ma civic (transformer)
- 2000 Civic Coupe/GSR swap Opinions....
- JDM Headlight Question. searched
- engine bay steam cleaning?
- cels causing vtec loop???
- car wont start
- Did you dissasemlbe your JDM mirrors before painting?
- What EK bumper do i have?
- help!! car jus dies! IAVC help!!
- 99-00 EM1 Civic Si BMC size
- ***The New Guy***
- Tranny Code Trouble
- cel codes
- d16y8 into 99dx
- Water Leak: 94 Civic EX coupe!
- 02 sensor help
- Engine isnt reving higher when a/c is on??
- B16 help?!
- gas problem
- No start, 1 click
- just a quick one
- Posibly Eltrical Short?
- Transmission Identification
- Engine number question (year of manufacture)
- My Neptune RTP and Tunerview 2 installation!
- 92 EG Hatch...bad idle after warm up/loss of power
- Del sol seat question
- Head Bolts Torque to yeild ( TTY ) what motors came with them?????
- Help with b18a swap.
- what kind of power can i get with b16a with type r pistons and cams
- 97 honda civic hatch dx smelling gas help
- What do you think? Window Issue on Del Sol
- Failed NOx but only at low speed
- gas pedel feels really loose
- converting to obd1 from obd2
- Transmission is GONE, helpful options??
- 00 civic si
- need help wit pwr doors
- need help wiring up my doors
- car wont start need help!!
- Civic swap motor mount help
- 93 1.5 soch ?????
- cheap ebay oem style foglight 99-00 civic wiring help
- seat base question
- z6 swap into a CRX whats involoved?
- Car Surges Up And Down At Steady Throttle
- Any one has a fuel pump wiring schematics
- jrsc help. just bought missing peices
- cooling fan wont work
- Best stuff to coat my (interior) floor with ?
- Just a tease
- 2nd gear popping out
- D16A6 into EG
- 97 civic problems
- Weatherstripping *PICS*
- advanced timing question
- a hopefully quick question about a swap
- what b-series power steering pump and bracket?
- Corner Ambers?
- Quick question about exhaust
- Fast brake kit
- 99-00 Civic Type R (Titanium) Headlights...Where to buy?
- Fuel leak please help!!
- [DIY] Interior Cabin Air (A/C) Filter retrofit for 5G 92-95 / delSol / 6G 96-00 Civic
- d15b Throttle body q... car runs weird?.
- em1 si hood?
- Check this Mugen Replica header
- where to buy pedals?
- Mini me or full swap..??
- throttle position sensor
- Fuel Leak around FPR and injectors/fuel rail
- car ran 5 minutes ago.. wont start now.
- b16 tranny
- Check Engine light
- Which d16 clutch did you go with?
- ***new to honda-tech>>showing my ek
- K24a1 block with k20a3 head
- Fuel gauge question
- Lower Ball joint will not release - Suspension Specialists, where you at?
- will header fit?
- Coolant Overflow Issues Anyone..??
- drive shaft possible problem on si?
- 5 lug on ek.. need axles?
- new to Honda-tech and Honda world
- Need help on choosing a tranny
- b16a tranny help
- D16z6 Price?
- Intake Mani+Throttle Body PERFORMANCE WISE???
- 00 civic si sunroof problem
- where and what type of cat
- clutch mc issues
- Intake mani
- ildling when at complete stop.. need help!!
- Need help ek climate
- 91 integra fuel line on eg/b18c?
- excessive blowby??
- New 95 Civic EJ1
- gsr engine ls internals
- GSR rebuild
- auto ecu in a 5-spped ek
- grant steering wheel adaptor for ek civic
- tapping starter?
- valve help
- will pm3s fit on eagle rods
- b-series half shaft seal
- loud thumping noise need help guys!
- junkyard questions
- D or B series alternator, OBD1 or 0? Need help immediately.
- HELP i need my car running again
- exhaust piping
- b-series flywheel
- coilovers help!
- Civic hubs fit on integra spindles?
- whinning noice coming from tranny???
- D16y8 Engine Coolant Temp Sensor broke off
- stock em1 head unit.
- gas leak need help...bad!
- Need some advice
- motor mount bracket ????
- Timing belt maintainence time...
- Motor identification question
- radiator help
- H22A vs B17
- new clutch
- Axle Nut Size To Remove Axle??
- eg will not start! Help installing turbo next week
- heater core and a/c control replacement help
- Cost estimate
- need help with apexi ws2 on a 94 hatch.
- LS Swap - No Start!!
- newbie
- anyone ever used these radiators?
- p/s pump
- ball joint question
- Need turbo help please
- No tranny fluid?!?!
- What is the use of "Flex Pipe" ?
- leaking fuel HELP! WOW
- identifying my motor - help
- code 10 IAT and lope at 1500rpm....
- Help wiring door poppers
- Replacing Alternator, Power Steering Belt, Etc?
- engine managment?
- Lost Motion Assembly (LMA) in 99-00 Civic Si
- 95 Civic Weight/Wheel Issue
- exhaust help 00 civic
- CYP CODE 9 nightmare help will be rewarded
- ***Turbo d16y8 project injector help***
- sedan rear speaker question
- difference between 96-98 and 99-00 front bumper
- d2 coilies
- motorsport engineer
- B16 head or gsr head for my b20z vtec??? opinions plz
- anyone ???????? pic request
- another stupid code 43 Q....
- what ls should i get for my hatch
- painted some stuff
- Removing rotor
- Red Rocket Revival
- helms?????
- G23?
- CF roof cap a good idea?
- Do coilovers off a 93-97 del dol fit a 98 Honda Civic Coupe??
- hello ... new here..
- key stuck in the ignition
- turn signals not working
- Rim integrity
- Help ASAP! Metallic noise when driving - brakes?
- converting D16Y8 Distributor to 0BD1
- HELP!!!Issue w/ Skunk 2 Rear Lower control arms
- New to the site - checkin' in
- HELP!!! brown liquid in overflow tank
- somethings wrong....
- 95 SI Hatch Part Out
- Clear lens EG head lamps anyone use these?
- 98 Civic Ex, suddenly died at 35mph ....???
- LS swap checklist help
- del sol owners in ct
- Can someone please confirm if there is only one size for d16z6 crank pulley
- knock sensor cel...from mounts? need help
- cant decide what to paint and what not too help!!!
- Radiator fan runs instead of starter when I try to start.
- Help: JDM sir cluster shows higher rpm than the orig how do I fix it?
- Is my transmission dented and wide open?
- HI6N on B series?
- 99-00 civic passenger door lock problem
- Turbo Help!!
- Timing belt still too loose
- is it my axle or my tranny?
- wat color?
- Cusco Front Strut Bar
- Replacing Heater Control & dash Bezel
- wtb vtec controler
- Car starting problem..i guess
- h22a (longblock) swap eg6 HELP
- help quick searched, 98 lx civic exhaust fit on a 95 civic lx?
- Can u use auto wire harness on manual swap
- A/C dash lights on EM1
- Burning engine oil B16A2
- rod knock or valve tapping..?
- 96-98 rear lip on 99-00 Civic?
- help
- 93 d16a vtec..? ( I did search )
- EM1 style carbon fiber front lip
- b series engine swap d series harness
- 97 Civic H22 swap questions
- GSR Rocker Shafts
- RPM idlleing issue in 98 ek with b16a swap..HELP!!
- motor problems, please help.....
- My 95 civic EJ2
- eg changes?
- Clutch Pedal Soft, Hold's High, Just replaced, didnt fix.
- mini me
- sway bar questions?
- Keep Spinning bearings on Dseries.
- put new batt. in n now car idles CRAZY LOW!
- D15B8 build 92 cx hatch
- Condenser fuse blown in fuse box under hood
- Problem with FPR (Fuel pressure regulator) bolt.
- B16 ?
- Getting another hatch WOOT
- Squeak from wheels! Rim or Tire? or somethingelse??
- What's consider high for fuel pressure?
- question about swap
- Exhaust help (EJ8)
- ek swap to ctr motor??
- Should i worry?
- Del Sol Bumper Question
