View Full Version : Honda Civic / Del Sol (1992 - 2000)
- motor mounts
- 1995 Civic HB need help or ideas on how to get better performance
- Anyone have similar problem? Random ignition failure?
- Has anyone ever BAR'd a ZCVTEC or D15B?????
- help with power locks (99 ex)
- Car becoming more and more difficult to start...
- MSD 6AL???
- B16A
- Anyone installed turbo on EG6 or EG2 with B16?
- which lowering springs front, or rear?
- next cheapest way to drop my 92 hatch without cutting springs
- gsr sputtering..help!!!
- For tubo...
- ls/vtec rev limit? (stock b18b1 block, b16 head ITR valvetrain)
- Stupid Question
- Hey need some more steering wheel help
- Pusling throttle
- No Vtec
- changing/flushing engine coolant
- What sway bar kit do I buy? Tried searching, but too much information = confusion.
- obd1 d15 into obd2 ek dx , dizzy question and other
- Will cable B series linkage work in a Del Sol?
- ek drum to disk
- Bushing for strut tower bar
- Radio issue
- What size bolts?
- Just a quick question about if I have an Ek9 or an EM1
- jdm b16 question?
- 2000 civic SOHC vtec...
- sun roof block off plare
- Will this Mugen Harness fit onto my USDM ITR seats (2000 Civic Si)
- sup guys iv got some msd questions
- Secondary butterflies wires
- b18c4 into ukdm ek
- hp
- Need help plz ...
- hp in my car
- incomplete disc conversion swap...need help...please
- electrical problem
- Just go into a accident.
- b16 lightend flywheel with AC any problems?
- 92 VX D15B timing belt vs D16Y8
- jdm itr 4-1 header on 94 ls.
- seized motor!!! help plz
- High RPM on all gears compare to other civics
- p28 ecu's
- my window only goes up with alwarm
- bleeding brakes....
- What A/C bracket do I need?
- hello all
- buying recaros, can i pick them up in my em1?
- How many AMPS does a stock civic radiator fan pull?
- DUDE!!!!
- hood steaming
- For those who dont know about G SPOT AUTOMOTIVE
- Just picked up my 93 Si hatch for $750.00. What do you guys think.
- Timing Belt Question for 1995 Civic Del Sol 1.6L VTEC
- Question about Transmission
- Power windows randomly went out
- so i want to upgrade my ignition system
- 96-00 Civic door handles
- car runnin on 3 cylinders just finished changing injectors HELP PLEASE
- ***Help with decision on head gasket problem***
- EK power steering rack thread??
- Codes 53 and 25?
- Engine swap
- idle control system malfunction?
- Wat kind of engine do i have?
- rear strut problem
- Clutch Issues...
- ***ANOTHER NEW RIDE*** WHAT A DEAL***
- type r headers ?
- ek cluster jumps
- Mini me swap
- Knock sensor
- 98 dx distributor q???
- Is this normal? Or is my fuel pump going out?
- Help new here !!!!
- Civic EX VSS Wire
- Its soooo cooolldd. Heater issues inside.
- spent and hour on google and yahoo and still no answer
- Right O-ring???
- what will switch from my 93 ex coupe to my 98 dx hatch
- ***pistons***
- MY HONDA!!!
- integra front knuckle/brake assembly question.
- what do you think?
- what kind of altenator to use for b16a 2gen sir?
- 95 civic air bags removed need srs light off
- CEL: Please help with diagnosis. 98 Civic LX CEL codes enclosed!
- Civic Ignition Question
- Dimensions of Rear Brace - EG
- TUNE
- Engine Stand + Z6 = Bolts?
- for those who have done the mini me swap or have an d16y7 head
- oil leaks
- What are the head torque specs
- how much hp can d16z6 rods handle?
- R seats in a EK
- mph/km?
- EK with 99-00 front end conversion
- Vtec Help????
- car troble
- where can i get some valves
- changing coolant..
- 96 hatch problem with my climate control doesn't blow in correct direction
- bent front subframe?
- quick hasport question
- anyone know a diy for fuel pressure gauge?
- Please Help Car died while driving
- Turbon install on delsol B16
- Rims what size or style?
- Speed Sensor Issues
- h22 hatch need advise?
- S2000 engine start button wiring
- d16y8 wont start!!! help, im going to miss a calculus mid-term
- new to vtec
- b16a2......
- seats
- Cannot set idle per FSM procedure - any ideas?
- Tensioner Bolt and crank bolt
- Complete A/C Unit
- Which Ecu?
- Honda Center Caps?
- How do I delete ABS?
- Broken ez out - valve cover bolt
- eg wont start.... BACKFIRES out of intake manifold
- breaking???
- 1999 civic dx hatch bseries swap.....need help.....
- ...Runnin rich...
- my japan version civic
- mighty 200whp mark..
- Where to buy parts in the PA??
- Question regarding swaps and legality
- camshaft postion
- quick question
- HELP!! EG wont start after swap! has spark and fuel priming. pls help!!
- Comptech Rear sway/tie combo PDF install File
- Motor rebuild write up for a B16A using B16B internals... HAVE SEARCHED
- Gas fumes in Cabin during idle
- Which mirrors to use?
- oem eg hatchback carpet
- cel 41 (yes i did search)
- 95 civic si.... crashed many parts available
- Little blue switch??
- finally pulling block
- what kind on engine??
- NEED PICS BAD !!! CABLE TRANNY EG!!! NEED INSTALL PICS!!!
- SOHC - Turbo Vs. N/A
- lighting issue
- simple question regarding rear bumper.
- Used Civic Info For Newbie
- what center caps will fit rota slipstreams?
- 1994 civic hatch exhaust ?
- Civic stock vinyl seats
- Alternator Question
- Burning a half quart every 1000 miles?
- i need help with my turbo please
- ideling problem.
- Should I Look for a new Tranny?
- motor swap
- My Honda Civic won't crank
- obd 1 and 2 questions?!!!
- stock pipe with aftermarket filter end?
- broke my hand brake
- D15b2 crx obd-0 in 93 bubble?
- oil in distributor
- eg6 rhd conversion question
- prelude rotor on civic??
- ek hatch w\ sir starting problems please help
- Throttle and O2 Sensor Low Voltage
- Quick question.
- Anyone use a transmission cooler? (auto slushboxes)
- What is an Intake Cam, and what does it do???
- HID Problem
- question TDC and Comp Cams #59300 timing issues
- 98 dx harness
- BOOST QUESTION need fast response..
- Looking for a specific civic coupe
- Please help, slight whine noise when adding throttle, but sounds differant in engine bay...
- stupid question
- normal idle for 97 ex coupe?
- is a 97 del sol obd2a or obd2b?
- d15b vtec 96+ into a HX??????? SEARCHED
- 93CX hatch... catback... do i need a test pipe?
- what is a PMR (Poor men Type R) set up?
- DIY on 99 si brake install on 99 ex?
- 97 honda civic ex
- put an ITR cluster into eg hatch
- Injector question
- P30 question
- Very simple questions I hope..
- Help Identify This Block Code
- Speedo / odometer accuracy for 92-00 Civic / 94-01 Integra owners...........
- Day-time Lights???
- Upgrade/rebuild b16a
- Vi-RS daily driver
- Front Bumpers
- d16z6 block with jdmd15 vtec head on boost
- AEM v2 civic 99/00 SI
- a/c
- can someone tell me what this part called???
- Piston to valve clearance with Type R Cams
- b16a sleeves
- ITR LSD into B16 Trans
- dx harness on a cx shell
- Peoples Opinion
- Exhaust System for EG6
- DC Sport Headers 95 hatch
- dose this look right?
- suspension question damper setting ???? help
- HP Question
- my boy having problems with H22 swap into his EK, HELP...
- need help.
- new to ht. hello people (:
- what happens if a resisitor box is not used?
- IAT SENSOR
- A/C INSTALL
- AUTO TO MANUAL CONVERSION ???
- Request: D15b vtec block picture
- replacing bearing
- Full Size Fluidyne Radiator into a 92-00 Civic Chassis, ANYBODY?
- ITR Rear Control Arms ST sway bar
- would a p28 work with a d16y8 head?
- master & slave cylinder. can't shift
- bad head gasket the only solution?
- need advice
- Auto to manual! anyone?
- euro hoods...
- tail lights wont work?
- Quick question about Ground control coilovers...
- Probbly at stupid question....but idk the answer
- coilover springs??
- Power to Manual Window Conversion
- cluster lighting
- roll cage good for 10s..
- juss dropped a OBD 2B GSR in My EG8 need a lil help
- Just cleaned EGR Port for 96 Civic HX - Pics included
- Question about GReddy Turbos
- DEL SOL IN WINTER????
- built sohc question.....
- Clutch Master Cylinder. . .
- autopower cage or cusco ?help
- B18B swap question please help
- Starting Problems I'm stumped
- jumper harness
- Civic vs S2000 vs Integra (Video)
- Looking for EG specific forums
- radiator fan issueeees
- mount issue
