View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Icv, ats wire colors!! Need help!!!
- '95 Civic DX won't start
- EJ1 Coupe Burning ECUs.?
- setting up dual alternators in 95 civic 1.5L
- 3rd Gear Whine, 5th gear sticks
- cut interior plugs
- 94 honda civic vx timing belt
- Fuel pump not getting power
- 99-00 civic si code 80
- help with axle!!
- Please look need help asap
- what is the first thing I should do?
- Fuel Injector
- help brake booster vacuum
- Ek Exhaust
- DC2 dash in EG
- HELP clutch problems
- what tire size to run?
- 4 dr and coupe differences
- b20 vtec
- y8 manifold swap on my y7, now idle surge
- what rims for my del sol
- will a exhaust system from an ek coupe fit in an ek hatchback???
- Quick ? for those with HIDs
- eg6 ROLL CAGE
- teaser of project
- ckf bypass trick
- Ek and EM1 exhaust question...
- d series head swap question
- does anyone keep the rubber thing on their hood?
- Loss of power!
- 92-95 type r side skirt fit ek hatch
- DC4 exhaust fit on 97 coupe?
- vtec hook!
- Steering problem in my EG
- Ek fogs on an EG bumper
- temp gauge on cluster not working?
- good set up?
- apxei N1 or Mugen twinloop exhaust??
- Winning sound/ sounding like a 4x4//!!? HELP?!
- got a d15 for free what can i do to it??
- also new to Honda tech **PICS**
- 11,000 rpm redline
- new to H-T. pics inside
- DAMN p0505 code!!!! HELP
- integra springs on EK
- HELP: installing shift light
- jdm itr header and cat
- ej6 d16y8 keeps dying after ignition repair
- Clutch Adjustment
- Thrown rod B18C1, fairwell GS-R :'(
- How to tell a good B16A2
- 92 iac valve question
- Weird idle help
- How to diagnose a busted distributor?
- Little advise please..Oil on 1 sparkplug!!
- APR studs Torque sequence for D series
- p1337,p1508,p0117
- Reliability/weekend track car Is it possible?
- No Throttle
- What does EM1 stands for?
- AEM fuel Rail Compatibility
- 300+whp Civic D Series Turbo Build
- Anyone running S100 on a setup like this one?
- Need help! stripped bolt. searched
- installed new headers 2000 civic ex
- b16 EG sounds like starter is just spinning HELP!!!!
- would 215/45/17 fit on 96 civic EX
- Ignition problems with a 92 dx
- San Diego Area? We need your '92 to 2000 Civic for Roll Bar and Roll Cage Fitment!
- Map Light Install: Popping Fuses?
- catalytic converter.
- What happens if i hook up plugs incorrectly
- New here
- What seats to put in 98' civic (need lower seats)?
- g1 b16 into 93 civic hb
- HELP, Civic SI ECU identifications
- what is a "clock spring" ?
- p28 jdm b16 (what could be wrong)
- is it safe to drive with cel 7 & 10
- BOUNCING RPMs???
- softer suspension!!!!NEED HELP BAD
- how to install rear lip ek?
- where can i get a vtec pressure switch?
- vtec not engaging: part 2, no cels
- Installing a drop
- Need help b16a2 idles bad in cold start
- major stuttering problem
- 1994 Civic EX coupe. What is it worth?
- H22 swap into 4 DR!!!!
- MAP Sensor position issue
- fuel problum
- Overheating headaches
- what tool for inner tie rod?
- Civic Misfiring! CANNOT FIGURE OUT...HELP!!!
- what exhaust is this?
- wire tuck & relocation
- D16Y8 Idling Help
- yes, I have searched!
- 92- 95 eg hatch owners need help...
- took my head off tiny spots on the cylinder wall
- HOW TO TUCK (SPORTMAX 002) on EG? HELP!
- Brake caliper rebuild question
- d15b & zex stage1_ camshafts the same??
- anyone have issues with there shift linkage's
- Skunk 2 Throttle Body
- d16a9 cam shaft help
- 97' cruise control HELP!!
- Do I need to replace my motor mounts, detailed symptoms inside
- 97' civic ex cruise control and horn aren't working.
- Need help with installing a Silencer
- right hand drive Conversion laws???
- Is the engine worth it?
- '99 Civic EX 5spd lacking torque - what to check?
- Everett Washington Area
- Cam Gear help please
- axel popped out of tranny maybe?
- Brake Lights don't work Please help
- eg6 ROLL CAGE
- 98 EK(EJ) NRG Quick Release Momo Tuner Horn Button Wiring Connection
- first time building. Question
- motor mount?
- rhd conversion? legal?????
- Need a Good Clutch for D16z6 Standard Tranny.
- Engine Swap - Locations and mechanic
- Headlight switch failure
- 92-95 steering rack??????
- ls non vtec to ls vtec
- Car died?? Distributor??
- coupe interior in a hatch?
- Ls vtec, oil pressure problems
- Searching for thread that involve fixing main relay. Help me find pls
- whats this noise (video)
- b18c5 swap quick q's?
- Whats the actual car name?
- CTR Cams bogging at low Idle??? HELP PLZ
- quick thermostat question
- Need info on the b16A1!!!!!!!!!
- need help with rotors!! please help
- wire tuck firewall grommets????
- Tranny makes nose in1st and 2nd gear
- Yowai-SS
- D15Z1 header
- b16 first start up rattle problem
- Motor debate LS or single slam ?
- EK drum to disk brake conversion
- Unorthodox Crank Pulley yes or no??
- 94 honda civic vx
- engine problem
- rhd clip where do i buy one?
- dynamat question(door specific)
- OBD2 to 0BD1 conversion info needed
- HELP>>>>>Ignition Prob
- civic dash
- will eg wiper assembly fit ek?
- B18c eg
- Damn!! Car pulled off road!!!
- need help finding oem si replica lip. Front and Rear
- rear disc brake conversion
- Theft in Palmdale area
- Jb weld radiator question!!!
- JDM GSR B18C OBDII emissions testing - Del Sol
- Used wrong Oil in my Civic
- ws 2 rattle
- 96-98 foglight bulb size??
- Radiator fan wont come on (searched)
- car color
- Master Cylinder/Slave? '93 Del Sol
- oil temp gauge water temp gauge
- **City Lights**
- Here's a good one (throttle body related)
- Better cup holder for 94 civic??
- what are you running for exhaust.....quiet exhaust
- What NOT TO DO....Honda N00Bs Bible...
- Prelude fuel pump in swapped civic?
- 1995 GS-R Powertrain into 1995 DX Coupe
- Brake Rotor Screws?
- where do you guys get
- Knock Knock Knocking DX
- hydrolock : (
- ecu problem!
- replacing the exhaust help please
- d15b8 vs d16y7
- 96 ek swap
- jdm singl wite stock air intake manifold?
- wipers completely dead
- D16y8 help please
- Can i use my old throttle cable for new swap?
- ignition problems
- Want to upgrade my stock 94 SI hatch
- southern pride eg build thread-continued!!
- 98 LX window will not roll up/down... Bad relay?
- EK auto tranny removal??????
- power steering fitment?
- Dip stick lengths
- Squeeling noise d16y8
- Can i use a car seat in a 93 Del sol?
- Will 16x8 +15 offset fit?
- Air box Question
- do i need the 2 motor mounts under the frame
- Code 16
- 00 civic feel and hear a click from clutch
- torq specs for tranny bracket bolts anyone?!
- turbo manifold fabbing
- EG hatch GOLD paint code
- what size injectors for my setup?
- high idel.
- D15Z1 3 cylinders at 1000-2500rpm electrical problem - any suggestions
- Need an idea JDM corner lamps and Headlights
- clutch slipping but have pedal
- WS2 Turbo Exhaust????
- Turbo Nitrous...
- that's really high mileage.
- ek hatch preference
- Will give away 94 nissan altima to anyone who gets my car running (south fl)
- Gsr and b16 Cam
- Rotten Eggs!!!!
- Need help with my 92 Del Sol
- how do i make my racing seats fit in my 95 civic????? help!!!!!
- Motor Mount Issue
- Just got a new DD.. **300WHP+**
- greddy sp2 or apexi ws2: performance
- Did I get everything for my Empty Shell? PLEASE LMK!
- the SI is Dead....or dieing
- need help removing/installing cam gear for b16
- Help with Headlights?
- daily flywheel
- header and hi flow cat question
- i have a really imp. question bout ek pwr
- need a good tunning shop in florida
- Question!!! about jdm itr steering wheel!!
- My 92 Eg Build Thread *56k warning*
- Transmission issue..
- Gsr cams on b16a?
- info about these EK SIR front bumper side lights?
- itr 98spec header fitment
- 00' civic Si cams
- Want to build my em1 For smog purpose ls-vtec or cr-vtec in
- Gsr & type r manifolds
- new fly/clutch options?
- k20/k24 swap ?ns 90 crx or 00 ex coupe
- 95 CX HB cluster Question, any answers?
- D16y8 spark plugs
- Difference between pre 99-00 bumpers??
- Vehicle Speed sensor
- **Honda-Tech Guru's only** B16a serious internal problem** Video**
- am I missing a plug or something here
- 96 civic HX with a ZC sohc vtec: what do i need to make it work?
- help: honda ek 96 code p0453 and p0505
