View Full Version : Honda Civic / Del Sol (1992 - 2000)
- whats wrong with my headlights?
- Fastest D15B8?
- wiring god/guru's needed!
- Looking for pics of a EK with 5 Zigen FC01R-C
- are the 97-99 sedan doors the same??
- EXEDY OR ACT
- car wont stay running
- PHILLY AREA ????? NEED HELP//
- springs
- Which AC Bracket? (Tried to search but AC can't be searched)
- WHAT IS WRONG WITH MY CIVIC?
- LSD or not?
- theft system
- How to install a steering column
- cluster lights
- Car making wierd noise!!
- Just got 92 Si hatch
- HOW TO: set readiness monitors for OBD 2
- What is the smallest rim size that can fit an EK (EJ8)?
- Help, Nut on Alternator Ground Just Spins. Can't get good ground!
- 95 ex electrical help
- need a quick answer about 99+ climate conversion
- Bad o2 Sensor= No Power????
- eg hatch si taillights
- Does DC2 axle back exhaust fit a 2000 Civic?
- Hatch problems
- Where can I find the bulbs for the gauge cluster?
- Two questions about valve cover leak
- d16 question please help
- 99 civic Si, with JDM D15 engine problem
- My 97 Civic's Windshield wipers are retarded! Help!
- vtec solenoid
- 92-95 front window ??
- 93 del sol turn signals stopped working
- anybody have a pic of a stock z6 cam gear?
- anyone seen/used this?
- Car hesitates in cold weather..
- really low idle
- H22 axle problem
- Help with gas mileage!
- HELP PLEASE!!!
- 1992 Honda civic FS
- NEW EJ1 OWNER!! ANYONE ELSE WITH A TEAL EJ1???POST PICS SPARK MY INTERESTS
- no spark, no fuel, engine just turning
- exhaust question (cx the same as dx?)
- tps sensor broke on delivery... help!
- CTR WING OR SPOON FOR HATCH
- good internals
- Door Help on EG rebuild
- Code 9 Cylinder sensor?
- 99 civic front lip...
- d16y8 head on a d16z6 block compression ratio?
- slave cylinder.. master cylinder..?? questions
- d15d ecu
- engine swap trouble deciding
- loss of compression create irratic idel??
- AUTOMATIC TO MANUAL CONVERSION ECU PROBLEM
- clutch flywheel and pressure plate problem
- Battery Not Holding Charge!! Replaced Alternator, Checked battery. HELP!
- Real quick engine question????
- someone please help asap!!
- INJECTORS
- 96 civic cx cold idle tick
- trying to make some money
- idling funny
- post your lowered 96-00 civic...
- Custom exhaust or buy one online
- b20 hesitation
- will a d16 tranny from 92-95 fit on a 96-00 civic d16y8?
- injectors
- JDM CTR EK9 pedals question
- b16 disaster
- eg cluster ?????
- d15?
- my b16 ek is dead - battery or alternator or starter or fuse problem?
- Quick valve lash question, clicking = too tight or too loose?
- GEARS KEEP LOCKING! PLEASE HELP
- swap question
- noob gear grinding question
- radiator overflow
- 00' Si fuel rail
- ef d series into my eg
- Hard to shift gears in heavy rain?
- cat back for sohc vtec
- how much HP does stage one hold..?
- Charcoal Can Bypass?
- exhaust manifold question
- Si cluster in ek hatch, speedometer off?
- Tie rod question
- shoft shifter kit HELP!!!!!
- distributor question
- motor swap help
- My tailight wont turn off! Help help help
- Bumper Removal 97 Civic
- swapped obd2 ls into 96 hatch ek !!!!!!!PLEASE HELP!!!!!!!
- brakes - are you able to make your brakes/tires skid on purpose?
- Dash removale and remote start install
- VIS or Seibon CF EG Hatch?
- NOt a tech topic but my philly people we are gonna become targets. RIGHT NOW
- 95 hatch blowing tail light fuse
- will the vss from a 94 civic work with my 94 civic with gsr tranny?
- Dash lights don't work
- is there a speed limiter in 00' SI
- 92-95 Civic Sohc clutch question...
- What radiator for 97 Civic EX shall I get?
- Club Honda....Italian style
- IACV question !!
- My turn signals dont work any help please?
- my whole gauge cluster doesnt work what should i do?
- del sol vtec rotor size?!
- 93 d15b8, 2 or 4 valve reliefs per piston?
- $50 to the person with the info to get my car started
- Problem with 92 EG w/ GSR
- HELP! Lights dim when at idle
- D series linkage on my B series?
- heater unit...
- Need help with my zc
- fuel injector o rings
- muffler question
- Del Sol CO2
- question
- Need some help with pricing
- i want buy this...but where??
- 98-01 ITR parts interchangeable with B16a2EG6?
- I AM IN DESPERATE NEED OF HELP!!!!!!!
- Went to the track! GSR EK, one good run, then grinding? HELP?
- whindsield wiper motor question
- authentic ek9 tailights v. are mine real?
- gsr swap rough idle
- 96-00 rear hatch leak
- Help me sand and paint this scratch!
- Hood dampers
- 99-00 civic abs system...
- Need Help with Brake Lights on 99 Civic EX
- back end problems
- what would cause this
- car backfire
- 94 civic speedometer not working and throwing a check engine light
- changing the light color of the climate control
- quick question...
- Trailing arm issues 93 ex
- Hood
- Help with D16Y7 into 93 EX
- Help me out car won't start
- Car Won't Start... Can you solve this one HT???
- how do i get the axel nut loose???
- 00 civic fuel help.
- H22 civic Question
- nOOb but I need Help plz reply ^^
- Chassis codes, anyone have a link?????
- Problems With Lights
- okay im new and need help and i dont have permision to do anything i need to do
- MAP sensor/ Rough idle questions
- Under dash fusebox diagram for 96 Civic anyone??
- I need help with my idle...
- oil seperator box (BLACK BOX ON BACK OF BLOCK)
- Custom Cutting EK Front Bumper?
- strange new motor noise - drivers side
- setting timing problems
- WHO's EG is this getting smashed by the truck?
- help...
- heater control unit.....
- Passing smog? obd1 b16a, obd2 vehicle.
- what would be the best mod for a 2000 si
- Mini me WONT START
- In - n - out
- stock z6 headgasket
- P28 or CTR ECU
- Rear body panel
- Apexi Turbo Timer 02 sensor OBD1 specific
- hf manifold...a/c compatible?
- What is this wing!
- HELP with pics
- HELP!!VTEC MALFUNCTION
- CAR DIED!!! Help! 96 ek civic hatchback (ej6)
- EG Fuse Box
- help me fix this plz!
- my shocking eg
- car seems to lose power in low RPM then at higher RPM the power kicks in
- alternator wire extending H22
- H22 Swap into '99 Civic *PICS*
- strut bar type R help
- Real friendly around here!!!!!
- Trying to sell my Si...please help
- ITR shift Linkage...1993 EG Civic...
- custom cluster for eg hand made thanks to kings idea!!!
- quick question bout b-series headers
- racespec catback
- rack and pinion removal ?
- quick nos q
- DEL SOL FRONT END. what is it worth?
- 1/4 miles time and setup
- tranny question
- Need Help with AC clutch issue
- Need some help..........friends gf car issues
- cam gears adjustment on a b18c5 with jun stage 4 cams
- Vtec issues
- handling issue
- DEPO/E-bay eg fogs
- Is It Actually Possible To Remove Alternator From Top Of Engine Bay???
- GSR Endlinks no no on ek
- SMOG REFF PROBLEM!!! NEED HELP
- What size resonator to run on a magnaflow exhaust setup?
- ek hatch springs and shocks question...
- no sound from my stereoo??
- Low Oil pressure??
- how much do regular side skirts cost?
- Tell tale signs of fake integra engines b18c
- i miss my low end torque help ?
- whats a good clutch
- clutch problem?
- pic request. rota group n's on eg hatch.
- ticket sign off question????
- most valuable small part on a 96-00 civic
- deal or no deal on cart repair
- h22 ecu in 92-95 hatch
- Can you tell if your car is misfiring without pulling any codes?
- any tricks to removing rear drums
- exhaust question.
- ex ecu plug and play with hx harness?
- b16a1 Motor Swap
- whats my redline??
- opinions on nitrous
- HELP!!!!!clutch fluid problem!!!
- Another honda stolen
- Bad axle???
- EG with JDM ITR hubs ect, probs
- Simple Turbo Question...
- axle prob..need help faast
- 00 d16y8 civic ex tranny 5 speed on 95 civic ex?
- 92 civic windshield seals
- Converting my EK3 ABS to rear disks
- can you hear sohc vtec?
- bad smell coming from the exsaust pipe
- sleeper foglights
- how can i fix this??
- CEL going on and off
- Manifold to head: what's the stud size? D16.
- I looked in the archive but nothing
- Del Sol bumper moldings
- 93 civic dx
- trap speeds?
- New SI Owner With A Couple Of Questions
- Diff. between 99 ex and 99 si springs
- What would fit onto my 99-00 Civic Hatchback?
- IM NEW PLANING TO GET A CAR NEXT MONTH
- Really need serious help!!!
- i have a huge problem!!!
- 95 civic coupe exhaust Question
- 92 hatch won't start.
