View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Very weird headlight problem
- I want to "de-badge" my civic...
- What Rear Leather Seat Did I Buy?
- HID's on my EG??
- y7 in a y8 head
- custom exhaust gaskets that i made seem to work
- new to the game
- VSS Problem
- Rear wheel wobbles...
- Timing Help
- convert an eg dash into dc dash parts need for convertion
- Will 96-98 spec bumpers fit on a 99 EM1?
- Low idle problem on a ej6 help!
- GSR block????
- How do I get rid of a shell???
- Are Sedan seat rails different then eg hatch?
- help with muffler and b-pipe
- FACTS, need to know DIFFERENCES between 99-00 DX & CX hatches!!!
- NRG HUBS
- pic request!!!
- smoke help!
- 5 gear pops out!!
- gauge cluster problem with a stock 94 LX
- where can i find this window spoiler!!!!!!!!!
- pls help.. bout idle!!
- question about clutch
- thin side molding
- How do I take a wiper arm off?
- Qeustion re '93 Civic DX
- offset 40, 45? spacers?
- Will DOHC ZC pistons fit in a b16a?
- no speedo after swap replaced vss!
- avid engine mounts
- d15b7 funny noise when accelerate help!
- need help installing power windows in a 98 civic hatch
- Is it the clutch or a cylinder problem, help...
- swap runs different
- jdm Ek fogs on Eg?
- type r rear suspension on Eg
- how do i
- gsr gauges into 98ex?
- what tire size for 15" volk te37's?
- Alternator making loud whining sound
- Hx wheels on em1?
- 96 Civic door lock control unit
- quick question about possible misfire
- Head lifting early??
- my parts pile for build
- B series shafts
- Serious Steering alignment issues.. Expert opinion required
- Piecing together an aftermarket A/C system
- Dont know if this is the right place or not
- EK Wiring/Timing belt Question
- clutch master cylinder
- Whats the diff between C/F hoods and OEM, aesthetically wise
- Messy / oily engine
- clutch question please look
- Car Stuttering Problem
- its smoking badis anyone willing to help me???
- No power brakes STUMPED!
- shock/strut?
- lookin for a b20 bottom end...
- Who makes this?
- can Vtec-E be changed to real Vtec
- A place that makes turbo downpipes.
- AEM short ram intake
- Auto to manual help
- IAC (EACV) - idle air control valve
- 06 Civic Fog Lights on CIVIC 93 EX
- compatabilty question - HeadLights Assemblies
- Need picture of 92+ EG interior under dash, without dash, need to see harness!
- Official EG/EK 'what rims you riding on' thread
- SRS Problem!!!!
- Swap question
- D16Z6
- Axles for auto and manual 99 ex civic coupe
- Question: Can you mix the New Blue Coolant with the Old Green Coolant?
- Tachometer for a 00 DX..
- HID Setup
- Password intake v.s. Short ram
- Quick question about my Radiator..
- car won't start... any ideas??
- Helms manual...
- brown wire in back of dash...where does it go?
- daytime running lights (DRL)
- no blinkers...
- P28 and P2P questions
- b series shift linkage del sol
- cars doing some weird shit after swap
- quick question
- del slow disc brakes on eg
- B16 Engine & Tach jump over bumps
- look out eg stolen 661 area code!!!!
- EK EX automatic cluster temp gauge acts funny in my hatch......HELP!!!!!!!!!!!!!!!!!!!!!!!
- Safe bulbs for OEM foggies?
- b16 with an ls tranny
- How much power is a retune worth on a mildly modded bolton d16y7?
- How easy are cam swaps and how much power do they give on the d16y7?
- Question
- were can i find srr lca's for ek9 hatch???
- obd2 to obd1 ecu pins question.
- Can i put an Ek Armrest in my EG?
- help-swap for my 94 civic coupe currently a zc motor but want integra motor
- no search results on how the Skunk 2 Racing mufflers sound? anybody know?
- Re: Mini Me Problem (Searched and Confused)
- Vtec oil pressure switch???
- is there any way that a 95 civic front bumper fit a 95 sedan?
- JDM GSR B18C LSD TRANNY
- sunroof problems.....where do I go?
- Just Installed 99 Civic Hatch seats into my 00 Coupe
- Few ??? Oil Temp Gauge, Trip Meter, and RSX Seat install
- H-T members of Australia, help me out, need details for civic models
- OEM Spoiler weight???
- Wheres the best place to get a Stage 3 Clutch
- dohc vtec sticker
- car cranks but it wont start
- OBD2 Dizzy question
- Which 5spd tranny would be the best for my d1577 '98 Civic?
- swapping a jdm d15b into a 97 civic dx
- Does cam-advance give much gain on the d16y7?
- Manual trans swapping D series
- itr gearbox onto ek4 % acceleration improvement ?
- 3rd BROKEN CAT! what should i check now
- coolant leak onto back of engine
- side marker placement??
- PCV valve issues..questions
- Problem with car starting
- Need your honest opinions of these products please
- Resurface or buy new flywheel?
- JDM power mirror pin-out
- B16 into a 97 Civic
- $600 exhaust manifold - '96 DX
- NEED HELP !!!
- computer problems (p28 chiped)
- Anyone know what these rims are called?
- ITB's?
- obd question
- Ignition coil?
- oem engine specs
- Dropzone lowering springs
- help me identify an ecu.
- help..just failed emissions state referee (CA)
- Check Engine Code 14 - Idle Air Control Valve?
- swapping suspension question
- will a D15b bottom end fit with a D16 Vtec head.
- parts list....someone help
- eg6 needs YOUR help..
- Big Brake upgrade for del Sol
- Steps to take after hydrolocking a motor???
- SKUNK2 Knob
- god speed project??
- will the EK4 earls brake lines fit 2 piston legend calipers?
- D15B swap to H22. Help Needed.
- Which manual shifter bushings are better for stock '99 EX sedan?
- OBD-2 conversion wiring for jdm b18c5 into 94 civic ex
- New to the Forums
- Another coolent ? Please advise
- How To: Quiet your car down....in the coming 2 weeks
- How Can You Fix B20Z Block Stripped Head Bolts????
- built b16 or poor mans type r?
- power folding mirror wire-up question
- buying a usdm ls b18b
- d15z1 exaust help
- 96 hatch, 01 LS swap Q
- How to take off upper side panel on interior?
- GC W/ Koni Yellows too lowW!
- Bogging VTEC...
- 99-00 front end coversion
- Question on pricing for del sol parts
- 96 JDM ITR BRAKE CONVERSION
- EG PIC THREAD
- 2 questions...hybrid clutch and smog
- Shifter help
- What hid bulbs to buy.
- FS: 1996 honda civic ex radio
- Jdm parts for ej7?
- energy suspension motor mount insert install
- ca smog testing
- - - - - - - - > Little problem here...
- quarter panel
- MPH gauge stop working
- 92 EG duckbill question
- new b....
- New to the site... & have a cold start question
- does anyone know how too.....
- 54 MPG, D15B8 or ???
- 1998 Civic 5 speed - what fluid to use in tranny?
- what should i do???
- body help!!!
- Help with Side Markers!!!!!!
- eg fogs work wit intercooler pipes?
- EK coupe vs hatch exhaust?
- Question about AXLE please help.
- Installing Stanley fogs
- TL Hid problem
- General Ground Control Spring Rates
- lip comparision
- dc cluster???
- buying D16z6 tranny
- SOHC Clutch on DOHC Car?
- Crossbar for a Del Sol
- recurring idle problem
- DIY Amber climate control with Real 99-00 civic si cluster?
- Grounding issues or ????
- zc pistons in y8
- D15B8 Strength? D15B8 Mods!
- Need some help on deciding some stuff..
- headers heating up??????????
- EMU SYSYEM
- Probem with my 92 eg hatch
- trouble running....fuel related
- oil in my coolant???
- how do you check for warpage on the head
- ek exhaust on del sol?
- jdmshit SiR lip same as password SiR lip?
- 97 civic keeps dying?
- need new head gasket for b16. what kind is best?
- ANOTHER SWAPPED EG....
- help head gasket question
- Some problems with my hatch
- Vacuum leak after warm up... now gone??
- obd-0 b16a into 93 del sol
- AC/Cabin Air Intake Location for the EK
- Smooth riding lowering springs? EK
- Woke up to a late christmas present........
- LS VTec tec
- DA integra seats into EK civic
- OEM Spoiler question....
- O2 and idle
- what size tires are you running on stocks
- h22 or b16?
- 92-95 civic axle question
- NEED HELP WITH MY CAR SHAKING???
- jdm gauge cluster
- h22 swap...
- turbo & air conditioning, what you know about it?
- My Exhaust started to rattle a Lot more Since i changed it to y8 exhaust mani.. HELP
- someone tried to steal my car last night !
- Swap ....help?
- will this work with my 92 hatch CX?
- I'm officially pissed off/stumped. v.tranny problems
- Speedo wont work
- VSS interchange question on my swap
- lookin to make the switch over to honda..
- What is this ORANGE plug for??????? *Help*
- all motor gsr???
- Bad CV joint???
- 99-01 P2P Civic EX ecu pinouts
- Stolen Hatch in Palm Springs, CA
