View Full Version : Honda Civic / Del Sol (1992 - 2000)
- fart can delete
- converter
- EF transmission on a d16y8?
- Quick Question! Can I temp use Manual Roof whilst Transtop not workin??
- My clean 93 dx..PURPLE
- EM1 dome light problem
- HID's
- GRRR code 21... b16a3 in eg coupe
- HELP! Motor started clicking.
- 98 civic no start..no accesories except headlights
- Heater in a RHD hatchback
- ok need help header question
- Wheel locks?
- 205/50 or 195/55 on si rims?
- RIP del sol
- Tie Rods????
- Braking Sounds Like Liquid(Not Crazy)
- 99 civic si ecu question
- Help, h22 eg
- painting various interior pieces need some input
- b18c build help
- d16a vtec (quesTionS)
- brake swap questions (93 DX hatch)
- Vehicle Registration/inspection
- Loose clutch
- Advice, Thoughts.
- Cam gear rotated during timing belt install
- D16y8 help
- One less EG on the street.. RIP
- 100-100-210-210 Compression H22a WHY?
- getting 10-12 mpg. stock GSR motor in eg
- what are the different trim levels for civics?
- EK manual steering rack?
- 98 Honda B swap need help!
- Won't Start,has spark, has fuel...ran well night before
- Fuel sending unit? quick question..
- help tryning to do a dash swap
- valves clicking/motor knocking, help!!!
- 2000 si tranny oil question
- are the 92-95 civic coupe and hatch carpet interchangable?
- Air Con. Removal.
- question regarding about interchangability ( EM1 Springs )
- Easy Question: EM1 steering rack on EG8?
- Ebay crank pulley good? Badd?
- EG STOLEN!!!! Keep you baby close!
- Need help quick
- Microfiche D16Z6 Distributor
- 94 b16 bore x stroke ???
- HELP! eg8 4 dr Front end conversion w/ eg6 hatch
- oo si problem
- check engine light/shift light
- how to wire vtec 92 eg
- spoon replica duckbill...
- idling problems
- opinion about pulling tranny
- If it aint a type R then in aint a tight car
- code 17 now vtec dont work
- ls vtec build question and rev limit?
- Replace Clutch?
- Is there a way to remove rust from bolts and screws?
- Distrbutor King
- BAD Axel?!?!?!? NEED HELP!!
- 96-00 civic spring on 92 - 95 shock?
- Ignition Timing Question...
- Timing issue, PLEASE HELP!!!
- How Do I Fix These CEL Codes?! DETAILS PLZ!!!
- Bad o2 sensor????
- what wheels are these?
- F2D....is it even possible?
- 1998 civic SOHC 1.6 Block Damage question
- 16"(front nsx wheels) on civic
- shifter question
- obd1 b20 in ek, no cruise control?
- Suspension question???
- Horn wire color on Cable Reel 98 Civic
- New Suspenison
- ls engine swap radiator hoses
- h22 swap in delsol
- D15 timing
- will 96+ struts fit a 93?
- Quick Shifter Question
- Need help guys
- Driving without o2sensor
- steering wheel install kit
- simple ECU questions
- i neeeed a del sol. wich is the best way to go about.
- sparco seats
- 96-00 civic front UCA, anyone have one to measure?
- can anyone help?
- b20 injectors fit integra fuel rail?
- This is gonna be a wierd question, but....
- 99 Civic Driver's side knuckle/hum assembly...
- MSD 2 step engagement
- anyone wanna see my video of me picking up a d16z6
- Rear Seats for a eg 4dr
- b17 ecu on single cam??????
- b18b2 with a b16a head?
- S2k cluster in em1
- vtec controller question
- crashed!!; wheel pushed back against fender
- OEM or Murdered Out?!?!??!
- Driver's side shock tower engine harness plug
- lack of heat in my 1992 SiR?
- I am pissed about my jdm foglights!!!!!
- Anyone ever have this problem with timing belt?
- WTB: Motivation (not REALLY a WTB/FS ad)
- hx rims on del sol?
- How to build a Engine B/D series?
- Battery Light Problem / Electronic Load Detector?
- Help - removing rear window box
- question about winshield washing
- Price quote: b16 cam gears
- Blue leather interior EG!
- replace ISB or get new trans
- GSR tranny question
- low gas mileage
- should i heat my springs
- HELP! Engine confusion
- y7 help... its gooone. ha
- What do these engine check codes mean?? HELP!
- Looped vs. Gutted Power Steering Rack
- b18b1 driver side axle part number?
- solid cel light searched but dont answer my question
- b16 tranny on highway
- which has better fitment and quality?
- HEY ?. mini me swap???'s D15&D16vtec
- Disc Brake Upgrade Question
- wiper smears del sol
- b16 tranny question
- nitrous question????
- new doors 4 the hatch
- Hidden Trunk subs in a Del sol??
- How to sell a salvage shell
- 5 speed transmission whinning noise
- horn does not work, clockspring has been replaced
- ? about transmissions
- skunk2 lowering ssprings need camber kit ?
- fully built b18c5?
- 92 integra pressure plate?
- Removing Gauge Cluster "Window"
- Coilover sleevs or lowering springs ???
- water temp issues
- i just got a eg ... loookin for a team
- No 2nd, 4th and Sometimes Reverse On Ocassion???
- b18a1? head to make it vtec?
- Where is cat converter in 99 Honda Civic?
- windshied wiper problems
- 2000 civic ex automatic fault code p1768 help.
- Weird knocking while shifting
- Very quick question, 00 Civic 3rd gear whine?
- del sol foglights help!!
- Tps problem
- Odd sound
- Transmission question
- Center Console Question?
- does any one have old capilers/Brakes
- can wiring harness connectors be purchased separately?
- civic ek mugen lip on 90 da....will it fit?
- 1.5 dizzy on 1.6vtec?/1.5 injectors on 1.6?
- what i need to built a b16a3 head
- water leak issue..
- Code 22 -- 22 VTEC pressure valve -- Pinout help? Anyone??
- what to do to a d16 del sol...ideas?
- HELP! Car turns over no spark!
- Trans swap.
- Wrecked Civic- Any hope?
- sea foam cleaner
- My seibon CF hood looking funny
- Does an DB8 axle back bolt onto a 96' ej7 Coupe?
- need opinions b16a3 or b18b1 swap for this price.
- problem with my ground contol coilovers
- where is em1 picture thread?
- Gas, and Parts...
- moving.. have some q's
- v tec problem HELP
- EG I just got
- Need help. car wont start and spark plugs wet
- Del sol Rear bumper removal!!
- gsr head problems need help
- Auto Tranny Help
- mini-me power!
- si or dx rear wiper blade question how to remove it help?
- B16A into EG CX, what length high flow cat do I need?
- suspension related
- JDM DC2 Recaros ... which rails should I go with ... ???
- problems
- Ok.....now I am angry
- fix it ticket
- LX to EX transmission differences
- alarm + coward thief = just a broken window.
- b16 auto swap.
- Shift linkage!!
- **The Official Civic si Picture Thread**
- jdm integra front on del sol
- 2000 si fog lights
- help! what would/did you do if your rear camber bolt holes are stripped?
- The Elusive Quick Steer Rack for 96-00 Civic
- Need Help choosing a Cold Air Intake
- QUESTION, what kind of bumper is this and where can i find it?
- Quick question for everyone about a new idea for a braking setup
- wips and horn wont work!!! help
- 2 door dash in a sedan?
- B Series Head Question!
- Throwout Bearing or Input Shaft Bearing or something else..?
- Help - how to remove window trim?
- LSD question
- H22a rpms bounce 100-1200 when warm ~ and stalls
- EM1 Si Grill
- What to buy to boost more on a JRSC for d16y7
- quick advice dx d16 manual transmission into a ex d16
- SIR wind deflectors
- Stupid Question about fender trim
- 99-00 Civic Headlight Help Needed
- civic si oil help!
- need to knopw what you guys think
- Turbo or Swap?
- B16 LSD Question
- mini me swap
- HELP: fixing front end
- anybody messed with TUNERVIEW II?
- Cruise Control Block Off
- EH2 and DC4 Knuckles
- Need a quick confirmation about a throwout bearing.
- Del Sol Door handle - broken
- y is my lsd stuck in positive traction??
- very unsteady throttle.... not tps
- lots of engine codes
- hx wheels on a si hatch
- whats wrong with HT
- No rear brake lights!
- Tune up time, need suggestions
- really really bad gas milage
- will a d16y8 trans fit a b18c1
- H22 cel #12 EGR ~ stalls a lot!
- Horrible Window Noise
- Lowering Springs Bad for Stock Struts
- oil leak
- new honda owner questions
- Car not moving!no its not the axles.
- 2000 Honda Civic found dead
- FAILED inspection - twice for same thing [OBD not ready]
- identify 3 wire plug on d16y8 harness
- Spark plug Question
- clutch making noise
- Removing headliner from EK
- stereo wiring problem
- fan doesn't turn on and gauge cluster doesn't read temp?
- 93 coupe hood problem?
- Replace Broken Lug Stud on USDM hatchy
