View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Ek9 Rear Sway Bar Issue
- Mini-Me timing issue
- No heat - hoses the issue?
- Does Anyone Have a Schley Tool To Replace Rear Trailing Arm Bushings I can Borrow?
- Vac line?
- Surface rust on d16y8 cylinder walls, HELP!
- 99 Civic Si Sunroof relay causing fuse 51 to blow
- Buy OEM or third party? 95 Civic Trailing Arm Bushings
- 1997 Del Sol Si Swap/Build Guide?
- Check Engine light problems
- air in cooling system
- 92 civic VX ECU
- 1999 civic ex brake lights not getting brighter
- HOW to fix timing on d15b7
- how do i unlock a transmission thats locked in park?
- 94 D15 Strange Radiator Fan Issue
- HELP ASAP!!!!!! 92 Honda civic dx
- 2000 SI rear seat question
- Fuse 43 blowing
- Honda civic 2000 lx Leak
- Suspension
- Acura to civic swap
- 2000 civic click when starting then shuts off
- D16y8 head swap p0132
- DevSport power steering delete kit experince
- Scraping/grinding noise coming from rear drum?
- quick question...about y8 into 96 dx
- Im a noob. Trying to do mini me swap
- Msd cap
- Overheating help! 1999 Civic LX
- Power window regulator replacement & sticky sunroof
- Skunk 2 coilovers
- Granada black pearl Help
- D16Z6 swap on 96 ek
- Del Sol VTEC syncros
- 96 honda auto transmission
- Vtec on non vtec valvetrain d16y8
- b16b obd2b green connetcor
- D15B7 wont spark
- D15b7 leaking oil HELP!!
- Z6 trans with broken housing. Can I used a nonz6 housing to replace it?
- B16A3/Y21 Second gear STRANGENESS
- AC coolant and oil amount after replacing condenser?
- Cam pulley and crank pulley not aligned?
- Anyone have any experience replacing trailing arm bushings?
- D16z6 swap on 97 ek NEED HELP
- How to disconnect horn harness under steering wheel?
- '92 Dx 1.5 automatic misfiring/sputtering
- 2000 Civic si b16a2 LMA issues on track?
- SRS flickers? Headlights/gauge lights flicker?
- Need help! Engine turns on randomly
- I need help saving my EM1 (engine head reassembly)
- clutch shudder
- 98 Civic rear disk conversion swap
- Is Bigger better
- Troubleshooting: D16Y7 Engine Misfire Issue
- B16type r
- 99-2000 civic brake setup vs 2000 Integra GSR brake setup
- No power thru the car
- My cluster in my eg ?
- Swap the throttle body D15B motor to D16y motor
- Engine question
- 1994 Civic EX sedan:mold and not starting, possibly due to water?
- Help finding a prop brake valve '93 Civic
- 96 EX coupe turn signal doesnt turn off after completing turn
- Stripped intake manifold nut how to remove ?
- B20 swap questions in EK
- 1993 civic ex
- manual of maintence civic si 95
- Are these authentic Function7?
- (Not important) dj27nitros EJ1 update
- HELP!! Idle bounces up and down rapidly
- Electrical issue?
- Rough idle blue smoke smooths out but spark knock?
- Do ebay head gaskets suck?
- honda civic 9
- Can't find the right wheel bearing. 99 Civic
- Window Regulator for a 98 Honda Civic DX?
- What’s wrong with my 94 civic lx sedan?
- Del Sol Glovebox with key or lock?
- Weird rusty metallic smell coming through my vents?
- Confirming Things about B16 Swap With Power Steering
- B18C5 obd2a swap into my EJ9 2000 chassis
- 93 civic with supercharged gsr
- 98 civic hx crank no start
- 98 Civic engine noise? Water pump/bearing failure? Valves? Video in thread.
- Motor Mounts
- 2000 Civic P1457 rust belt
- 1996 Honda Civic
- Trouble starting after just dting on road, but sound like it wants to
- Wont go into reverse after rebuild- until transmission cover installed
- adjusting/tightening the hand brake
- Auto to Manual + B20 conversions..Car Jerks Low Gear
- Del Sol radio backlight
- 98 civic b20b swap problems
- Integra bumper on ek!!!!
- Cheap but clean Wheels to buyyyy!!!
- Civic EX AT '98 - Injector not firing after engine rebuilt
- WHAT ECU for a B20 VTEC?
- ECU HELP FOR LS VTEC BUILD
- Rota Grid V > 282 Brake EJ8
- 95 Purple Coupe
- Losing coolant?
- 1992 Honda Civic wont start HELP!!!
- B20b (CRV) into 2000 Civic EX help!
- Civic GT Emblem: keep, or take off?
- 93 del sol - Rear and Passenger window stuck down
- Best bran turn signals for eg civic
- 98 civic ex code confusion
- D16Y8 question
- 5 spd swap??
- Heat or low heat?
- 96 EX Factory remote remote
- White smoke coming from radiator
- Axle seal leak
- D15b non vtec JDM
- Rocket Bunny K24 Turbo 4WD EG Build
- Subframe shims
- 2000 Honda Civic starter brand new but car won't start
- 1996 Honda Del Sol Door Won't shut
- 2000 y8 swap to z6 block and head PLZZZ HELP!!!!
- Ej1 headlight question
- Replacing LMAs B16a
- 98 Honda Civic temperature problems
- Do I need to worry about the timing when I replace my distributor?
- Idle surge on 2000 Civic
- HELP PLEASE IM GOING INSANE
- Driver side aftermarket door actuator
- Damper Forks Part number
- 1992 Honda Civic Idle issue
- Cooling fan turns on once ignition is off and stays on until battery dies
- Rear Drum Compatability
- Rebuild
- What ECU should i get?
- 1999 honda civic lx
- Should I buy this ej?
- Civic driver door
- 2000 Civic pulsating lights
- Complete Tubular AWD Conversion Kit for Civic
- Which sensors provide readings for IACV control?
- 1998 Honda Civic DX P0303, P0300, P1399 Please Help
- replaced distributor in 99 civic hx and now smokes runs bad
- Y8 alternator issues
- Removing srs light with resistor in a 95 civic
- ??? Strange rumbling, but only sometimes.???
- dashbord lights
- 1998si
- 92 Civic Fog Light
- VSS troublshooting
- I have a stock 1995 1.5 Del Sol with a blown HG no water in oil, but overheating?
- Me and The Silver Surfer
- Cold air intake temp sensor
- B20b in civic eg
- 92 Honda civic lx
- 3500 rev limiter please help
- Compression for supercharger
- 92 civic one injector not working
- idle jumps to 2500 even though it has warmed up / voltage drops on idling rpm
- I'm guessing its a bad headgasket
- b18c swap
- 1996 Honda Civic, speedometer and RPM’s not working
- 2000 Insight Brake Drums on a 95 Civic EX 2dr Coupe manual trans
- 98 Civic EX AT fuel economy
- 99 Civic Lx not starting
- ABS code 54 fail safe relay ?
- 1993 civic si heater core brand
- Need some quick help
- 2000 Civic DX temperature guage below C
- 1993 honda civic si heater core removal question
- Electric heat in an EG?
- 1995 Honda Civic Engine Cuts when clutch is depressed
- D16Y7none vtec swap out to a D16Y8 vtec
- civic 1995 power steering
- Honda civic
- Final drive swap
- 92-95 Door Switch, Replace/Repair?
- d15b valve cover torque specs
- D15B7 Burning Oil: Ideas?
- 1995 Delsol A/T - Key Getting Stuck
- 92 Hatch B16 Map Issue
- Any other h2b owner's
- EM1 obd1 and inspecton
- First time d16z6 builder
- 98 civic hatch racecar
- How bad is running 1 litre of oil short for 50,000 km?
- Honda Del Sol front fog light switch wiring. HELP!!!
- Can't figure out camshaft b16, b17?
- 97 Civic ex with 95 Jdm gsr swap. Cranks but will not start. Need help!
- 93 civic key triggers fan not starter
- My 1994 civic hatch and its challenges!
- Bought a cheap 1997 Civic, have a few questions.
- 2000 Civic si dead cylinder help!
- Swapping gsr rear discs on my ek dx hatch help
- missing 1 wire on 3 pin connector(dlc)
- Anyone have a pinout / illustration of...
- 00 EX Cruise Control Woes
- So how did I do on my Civic purchase?
- Possible to keep OEM seat belts with racing seat and harness install?
- '92 Civic Si - Dash light and head light stopped working
- Idle stuck at 3,4k rpm.
- Stumble/misfire/hesitation at 2k to 3k rpm
- P0730 Problem in Shift Control System
- Honda D16y8 engine rebuild
- B16A2 - Stalls when cold
- Why does my engine go up n down rpm’s when I give it gas? D16z6
- EG8 Brake Issues
- Removed alarm now car won't turn on
- 2000 Civic shuts off in the cold
- Help Climatronic EK9
- ek civic coupe and sedan windsheilds are the same ?
- Anyone know this ek9 tribute, dallas, k swap
- weird idle issues
- random misfires at low rpm, pls help!
- Christmas idle issues
- 98 Civic cx
- Clutch problem
- IACV problem
- Oil builds pressure at filter and then spews out
- Security system already ?
- U joint for manual rack
- car wont start after getting ditched
- compatable parts
- My 93 EG and ME
- Need Help Identifying THIS part (pictured in thread)
- b16 turbo need info
- Backfiring/Bogging Only In Gear and Under Load
- what is this hose a part of? 98 civic, See pic.
- New Civic Owner/ Suspension Swap Compatibility
- Cigarette lighter doesn't work in my 1995 del sol.
- HELP!! How to remove wire connectors from a plastic tab
- Honda Civic EG3 need information.
- Messed up drifting can’t figure out how to fix it
- Break issues need advice
- Wiring help please.......
- 1997 Del Sol SI Window/Door lock problems
- Can Rear Staging Brakes Work On a Daily Driver with Ugraded Front Brakes.
- VTEC
- 94 Del Sol Hard to Shift
- Skunk2 upper control arm ball joints
- 98 civic lx sedan noise from the back when accelerating
- Which axles for b series eg coupe
- srs light on
- Best replacement california-legal cat for a 2000 EX?
- New block, reuse internals?
- Bought a used Civic 1.4Lsi 1997 today
- Headliner - Chess Board Blue
- Dark Amethyst EK Hatchback Log *PICS!*
- Near supercar performance using a B-Series Engine
- 95' civic won't start after rebuild
- Power window adjustment 1996 civic coupe
