View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EG tb heater bypass
- Insurance for modified cars?
- Mod or sell?
- Opinions on new carpet
- eg roof spoiler?
- Just Swapped a b18C into my Civic VTEC?
- sway bar end links
- 1996 honda civic SI BUSHINGS and NOISES?
- what axle for h22a eg6
- which is real TDC
- Need some help.
- Quick Question
- 1995 CX Lightweight With D16y7
- Questions about which harness for B18B1 swap in an EG
- b16 swap questions
- EG Rear Disc Conversion - DA Integra parts
- 92 Civic intermittent starting
- AC Problem
- motor runs hot even with new head gasket
- asr brace with suspension technique sway bar???
- Retap condensor?
- cx, lx, and ex tranny question
- Will integra window regulator fit my civic?
- Del Sol brake help!!
- B20v Turbo Build.
- eg/ ek meet colrado springs co
- Sticky Clutch
- I dentify this plug
- MINI-ME SWAP HELLP VERY SIMPLE!!
- D16y7 Emissions problem!!Map sensor?!
- Why my car isn't a daily anymore (rusty bolts content)...
- Da u/control arm on a 94 Civic?
- Clutch squeaks -- WD-40?
- Weak Air Flow Through Vents
- BAD DAY FOR MY EG ALSO :(
- Yesterday Was A Bad Day For The Em1
- seafoam question
- 92-95 civic front lower control arms ??? help
- to buy or not to buy this rebuild steering/suspension kit from ebay ?
- Replacing motor mounts in my car
- Converting 92 Civic to SIR Front Brakes
- data link connector problem...already searched
- Cluster and corner lights wont work
- intake manifold gasket removal D-series
- b16a3 transmission and clutch problems
- Skunk2 Cams and GSR Cams
- turn signals and horn don't work on 1993 Civic SI
- JDM D15B running rough, need advice please
- 94 civic 2dr: right side front corner light won't work correctly
- 95 Civic Car cranks but won't start
- 99 Ex ob2b-obd1 distributor wiring
- NEED HELP PLZ What would cause these codes?
- AEM pulley belt sizes?
- [HELP] Specification Spoon N1 Muffler
- 95 coupe No Rear Drive lights !:!:!:
- Del Sol mirror replacements & one piece side windows?
- B18 to B16 Swappable parts...?
- Clutch kills my Car...any answers?
- will a stock si throttle body fit a skunk2 pro-series manifold
- 99-00 Taillights
- Depo fog light harness?
- obd2 ewh to obd1 gsr distributor
- car sounds like its spitting
- HELP: Replaced SPEED SENSOR but tranny shifting at HIGH rpm now? Any ideas? 95 civic
- 96-98 headlight buldge?
- B16 Valve seal replacement/Port/Polish Head?Performance Increase
- No vtec with mid grade gas
- vtec solenoid question
- I hate jdm motors.. please help me..
- DEPO fog lights killed my car!!
- 99 civic EX b18b1... no speedo, help...
- hesitating/lazy no cels 2000 civic lx 4dr si (with complete b16 si setup)
- I have a 95 cx non vtec i wanna vtec it. . .
- Oil Leak d16y7, Replaced rear main seal.
- JDM SIR lip vs the USDM EX lip is there a difference
- So let's talk about K23's in our 90's Honda.
- Shocks and Springs question....
- Help Identify Plug Damage w/ Pics
- 93 Coupe, Integra dash
- Anyone who knows mini-me swaps well..
- Wheres a good place to run a 10 gauge power wire on a civic?
- Cutting rear bumper for HKS Muffler?!?!
- Carpet cleaning out of car?
- car wont stay running help..
- Ignition coil
- battery problems
- wtf!!!!!! loose timing belt....HELP!!
- oil pan help
- which ebay clutch? (del sol)
- not sure whats wrong
- aftermarket oil temp & water temp gauge info needed
- 2000 Si & GSR power steering pump
- ripped hose
- 94 Civic V-Tec CEL Question
- Quick question, issue with starting car.
- Replacing my b16 with d16z6 having harness issues
- anyone have a distributor harness diagram ??
- EK JDM SiR
- My friend dident gap his rings
- Torque Specifications on Front suspension and steering components for EK
- Wiring up VTEC for my mini-me
- accel ignition coil
- A/C Pressure Switch Question
- sir cluster way dim...
- Radiator Fan wont turn on/overheating etc.
- Emmisions & Sparco Cap
- throttle body question???
- EM1 Daily driver coilover setup
- fresh swap and im shit out of luck...any help?
- Trouble starting the car?
- How does ur car drive with AC on????
- are these illegal??
- SRS Code 7-2
- 92-95 Civic - ABS brakes vs Non-ABS brakes
- Apexi WS2 vs. Tanabe Concept G
- B18 ITR Engine to B16A Civic Jordan HELP!!
- car starts then dies randomly
- question on civics
- distributerless system
- jdm bumper???
- B18C5 Ek9 idle issue..
- eg backseat in ek
- sohc rebuild????
- Fuel gauge problem and question,,,,help
- Is there a problem with my fuel gauge?
- Noob to the honda world
- how to remove a rear seat from a 94 civic coupe
- need help on mods
- Engine hoist to engine...problems.
- cluster ....light help...
- D-series head swap problems
- d16z6 into 93 civic cx
- HELP NO START
- JDm d15B
- ls with test pipe in civic do i need a custom catback
- 2000 em1 ?????
- New Here....Starting Project (B16 Turbo in EG hatch)
- Car keeps shutting off at idle.
- Car Acting Funny After New Swap....FRUSTRated
- How to check CEL (Complicated)
- insurance on a 99 civic
- are these quality window visors?
- Feel gouged by my machine shop on valve job.....
- brake pads?
- My Civic Si
- jdm d15 intake manifold on d16y7 motor?
- help! Hood Cable Broke!
- rough idle and stall. m i missing something?
- no start on cold engine!
- del sol with a b series swap
- EG Hatch Duckbill Questions
- Where do put transmission oil.
- Bad constant, which fuse is constant?
- adjusting depo headlights please help
- Question about OEM Carpet 93 Si Hatch!!
- My driver side mirror is FLOPPY!!!
- d15b7 cam timing marks
- B&M Fuel Pressure Regulator Problem
- 98 Honda Civic ceck engine light code 1382
- Valve spring compressor
- IACV question
- vtec wiring question
- problem with knock sensor code 23
- Stick on window visors? good/bad? install help?
- 1996 HONDA CIVIC EX - Weird sound..
- ITR cams in b16a head
- Is there a DIY for 99-00 JDM fog lights install?
- disconnecting key in ignition warning beep...
- Most rock solid engine
- installing my new {used} lip
- loud noise and loss of power under load
- i got some questions about the cooling system
- what wheels r these
- SRS Light
- New genuine honda keys
- help on how to adjust hand brake on 92 civic hatch
- 98-02 Accord OEM Foglights into a 96-98 Civic
- h22a eg hatch...need good clutch
- casper shield
- Will an SRS from a 93 fit my 94
- single cam achievments
- Eg Sidemarker
- how to test map sensor on 95 hatch
- broke ecu pin for o2 sensor help please
- differences in engine 96-98 ek and 99-00? swap help please..
- Rev limiter at 3500rpm
- "help" egine knock,code p1259(vtech malfunction)
- Help b16/b18 swap into my jdm vxi d15b7 sol!!
- engine problem
- diagnose this problem lol video inside
- Good brakes?
- tranny issue
- Need Help w/ 1998 Honda Civic LX speedometer
- b16 head!?!?
- Running Nitrous on high compression
- 1993 Civic DX Sedan 5 spd - Bump starts- not turning over.... No, Im not stupid.. ;)
- Rear disk HELP
- help b16a2 swap wont run!
- HELP! installing my DEPO fog lights
- Anyone Know The Name Of these Headlights?
- Roadtrips
- turbo kit fitment
- Changing my valve cover,all is gravy... until i see this!!! WTF!! Help me identify!!
- horn/hazard/srs lights won't work
- 99 Civic Radio Code, NO Serial # & NO Vin, What to do??
- APEXI VAFC 2 VTEC CONTROLLER KEEP OR SALE
- B series in EG hatch question
- What ECU is meant for a 96 b18b non vtec engine?
- '00 Si Muffler Tip
- ctr interior question
- "Snappy" shifting
- New EG hatch
- brake problem
- vtec sputter
- CTR 5 lug on d16y8 Possible?
- how do I clean out a/c drain line?
- 99 ex trailer hitch
- ABOUT B16A MODS
- jumper harness help??
- which are the best camshafts to my b16a2
- itr m/c on civic booster??
- 99 civic si stock motor overheating...help
- Del Sol window problem
- What throttle cable to use in a 93 cx with a 96 B18B swap?
- Need help taking sticker off tailight
- a/c help asap please
- cx hatch door onto a dx
- hid pnp
- Changed my iac valve on my y8
- civic w/b18 engine springs?
- jumpy idle after oil change.
- 94 Civic LX Engine and Trans - What CAN it go in?
- Crank Fluctuation Sensor (Error Code 54)
- Timing adjust on 99-00 Si?
- Best source for OEM headlights?
- B16A swap wont start, no cel light and no oil light
- B18B 99 EK clutch slave throttle cable Question
- Carbon Fiber Yellow Fog Lights For Em1
- Mud Guards (Flaps) For My Em1
- car rough idle need help please
- Bisimoto "typo" error on website... wtf?!
- hey whats up im new
- Plug help
- Greddy FPR.
- Cat-back exhaust advice (96-00 EK Civic)
- eg/ek a/c
- My P/S Delete experience.
- Have you guys ever seen this?
- Anyone know how to wire m3 side mirrors?
- Any recommendations for a good oil pressure gauge?
