View Full Version : Honda Civic / Del Sol (1992 - 2000)
- anyone have parts for d16y5 (civic hx)
- 00 Civic owners: How do i remove my door panel?
- how to: timing light
- 96-98 to 99-00 Civic HB conversion
- 97 civic.....problem in 1st gear
- Warrenty about to run out on my Si, what to check?
- ek exhaust (2dr and 4dr)
- line on crankshaft pulley
- ***High Flow CAT turns CHECK ENGINE LIGHT ON?***!!!
- Honda Oil Filter. Some questions.
- two problems---runnin hot, burning oil
- EK9 PARTS
- springs and bolts for ITR headers
- KYB AGX questions
- 96-00 civic sohc manifold
- type of honda/acura?
- I Need A B16 tRANNY !!!!!!!! sOMEONE sELL ME one
- Wheel Bearing Question
- Causes of overheating?
- D16Z6 SOHC VTEC
- ok guys i need some advise on some mods
- smog question
- 2001 Civic Fuel Pump
- 96-98 CIVIC EX HARNESS SAMETHING AS 99-2000 CIVIC EX HARNESS????
- Car and Bank account not cooperating! need your opinions.....
- 2000 Si Gauge cluster
- Orange Guage Cluster Needles...
- distributor?
- 7th Gen Civic, what are some first mod's?
- Anybody here running the DH-racing pulleys on there b series swaps???
- JDM D15B Clutch/Flywheel ?
- made the road trip, and then......
- Ebay exhaust
- what do i use to clean the flywheel and pressure plate?
- rca plugs?
- d16z6 parts on a B18A!
- Fuel Pressure Regulator
- Still having problem with idling
- how much oil should i put in?
- replaced alternator, replaced battery, car still won't start (del sol)
- Are my HX wheels clearcoated?
- Any pix of a total iner fiber glass honda EG?
- Hello im new...looking for a bumper...
- installing itr sway bar on eg ?
- camber kit
- Noob Q bout Oil Filter Install
- H-T should make a new rule: All questions asking or relating to a possilbe theift, that person shoul
- 98 honda civic coupe loud coils
- "smog question" for you californians
- anyone have a speed sensor?
- 98 honda civic dx dies when i slow down
- tranny removal, do you support the motor?
- p/s is leaking out my rack
- differences between 92-95 Si model's
- HX - D16Y5 true redline?
- Prelude rims on civic?
- Why does a d15b motor idle so high.
- whats the weight of a 92-95 ex with a b16 swap?
- Quick ? on IACV
- cracked stock header, what do to?
- 99 Civic Hatchback Project
- Bitch pin phun!
- Sick of your 92-95 cx-dx SEATS? I AM!
- where to buy a built D- series motor?
- Swap 4 my 93 Civic EX Coupe
- 1992 teal green civic hatchback, paintjob or no??
- Hit a deer this morning (pics)
- eg rear disc brake conversio
- LS motor swap in a hb
- Help..........obdo vs obd1 water temp sensors
- Disconnected knock sensor, Now car runs great!! What does this mean?
- B16 in EG, what non abs axles to use?
- jdm amber corners
- shaking
- '98 Honda Civic Problem.
- Four doors and best mileage
- questions about a d16z6
- HELP B16a swap
- ?'s for DropZone Struts/Shocks+Coilovers
- CEL 10 and no bottom end..
- Have you seen one of these before (56k die!)?
- Engine block drain plugs
- Timing questions
- Oil For My Civic and Break Problem
- 92-95 Civic Help
- Running Lean...easy fix?
- anyone selling a camber kit for a 97hx?
- ecu for k20a2 ek civic
- Exhaust Question
- Brake Master Cylinder Question
- is 94 integra axle back the same as eg axle back
- D16z6 N/A on EXTREME budget....!!
- Rear Disk Convertion
- Which Helms manual do I need?
- Alternator Pulley Question....
- difference between 92-93 and 94-95 EG AC
- How hard was it to install CTR 5 lug Suspension???
- need p2p wiring diagram d16y8
- help with removal of door handles
- '93 SI
- d16y8 field vtec safc setting
- obd2a obd2b
- B16 Tranny question
- sale question?
- what the hell is code 67 on a 00 si???
- switching the drivers side
- skunk 2 exhaust system
- question
- tranny grinds 3rd only above 3k
- Tranny wont go in 1st or 2nd!!!!
- Is this suspension good?
- 1992 Civic bubble hatch teal green
- JDM color codes...help!?!?!?
- HId wiring question?
- ELECTRICAL WIRING HELP
- vtec controler
- Del Sol Interior interchangability question
- would cutting and making the stock intake hole be dangerous?
- Help with my Setup
- EK or Integra rear lower control arms for GSR rear disc swap?
- Tranny is clicking?
- Help....Taking dash out of '96 civic
- 70 to replace drums.. or
- dohc or sohc?
- Will tire/wheel solutions fade the color of the rims?
- avg price for eg hatch?
- my 00 si b16a2 is thowing check engine light, how to find out what code???
- rear brake drum...
- Need help for brake conversion on 2000 Civic
- Cluster question--CX--Tach.
- d16y8 ek intake manifold
- How to keep tie end bolts from spinning???
- My Mini Me
- i killed my rims, but do i need an alignment?
- EK JDM Air Vent/Pocket Question......
- 96-00 civic ex tranny code
- HELP! need estimate on Head repair.
- 92-95 EG6 tansmission fluid leak HELP ME!
- wheres the fan switch
- blown fuse???
- hey quick SAFC Q
- new intake
- will an integra exhaust fit a civic hatchback 92-95??
- need help on fuel pump installation and removal?!
- Best Engine For 1993 Honda Del Sol?
- EGR lift valve solenoid
- F20B with F22 tranny?
- Anyone heard of carsponsorship.com?
- Help to identify wire????????
- emissions question (damn emissions!)
- 1997 civics hx code ????
- HELP MY WINDOW IS MESSED UP
- overheating troubles...
- EK front swaybar on EG?
- Burning oil like crazy...
- hookin up battery
- coilover question
- MAP Sensor
- rsx seats
- noticed small possible leak...is it my headgasket?
- quick ek question
- I have a quick ? about re-painting
- rear disc converison for my 97' hatch
- Stock swap times?
- LOTS OF MONEY, WHAT SHOULD I GET?
- Are Flywheels very effective?
- Del Sol Short Shifter
- Help... possible valve problems on new swap!!!
- what do u guys think this eh will run?
- Resetting SRS Light
- which shocks should i use?
- power mirrors
- squealling pig
- I need help in buying the best carbon fiber hood for my b/f..please help!!!
- Ex Tranny
- Child Safety Window Mod?
- looking for a motor
- New ECU = reflash the key?
- Invention by Korbach - On cover of Honda Tuning magazine - 6 page article
- GSR shifter into EG6
- *SOHC IAC 2000 dx need part number
- Looking for a gasket. Someone help.
- how do i take off a stock headunit off a 2003 civic?
- any tuners in west ohio, or east indiana?
- D16Z6 ???????
- Converting a KM Guage cluster to Miles
- Rear sway bar!!! Where the hell do i mount this?!?
- Complete Fuel System!!!!!! What should I go with?!!!
- Rolling chassis hatch
- ep3 exhaust on ek
- Help with CEL 3, map sensor
- What color combinations were available for the 5th Gen Civic Hatches?
- Aftermarket steering wheel + cruise control
- Cheap eBay stuff worth it?
- B18B problemss with hondata gasket and skunk2 IM
- map sensor trouble in ohio
- Whinning noise with PE belt! HELP!
- BACK TO SCHOOL, car is much more 'appealing' to thieves, please help with anti-theft
- b pillar bar eg6 eh2 civic hb
- question about gauge cluster
- 98 JDM ITR 5lug on EG Si - axle Q?
- Korbach Frame Locks "Brace Yourself" article in Honda Tuning
- meets from israel (pics inside)
- Sluggish B16a
- cam seals....are they the same?
- should I get new motor mounts?
- VSS questions...
- distributors, timing, and engine idle speed.....
- My jack clicks and squieks when used.
- APEX WS SPORT??
- D series clutch/flywheel bolts on B series?
- Where to Buy : 1992 - 1995 Glass Headlights
- Question about the price of Civic 97
- Question about my 96-98 Civic front end!!
- Convert ECU
- 99-00 or 92-95 lip fit better on del sol?
- BENEN QUESTION
- Tire offset questions
- I think my ignition is broke...
- Help with tuning my Si
- exhaust
- 2nd gear shifting, stalls when running RPMs at 3-4
- part number anyone?...engine mount
- Disconnecting the axels from the tranny
- Need help with firing order from replacing distributor on 92 si
- 98 EK hatch exhaust
- need a carfax
- how to clean the headliner...
- hard wire inverter
- Keeping a motor inside my apt? Good or bad?
- will a 97 hx distrib work on a 99 ex?
- REBUILD PROBLEM!!
- brake rotor problem
- Mixin and matchin trans parts.. "Poormans ITR trans"
- Weird problem with JDM EG city lights
- Where can I buy rotas with tires online?
- question about civic coupe ex weight
- Not Sure What To Name The Problem
- Will 99 Civic springs fit 92 civics?
- vtech?
- Help!!!!!
- brake booster install question(already did a search)
- 99 B16A in 93 Civic DX Vtec Question
- Axle nut loose?
- quick mount question
- vibration due to bump on a tire, bad strut?
- D16z6 vs. D16y8
- help me please
- What's the sympton of bad hub bearings on a 92-95 civic hatchback???
- What are the street prices for a 1992 Si hatch
