- How do you remove the EG steering wheel? Search turned up no results
- piping question
- Strait Pipes / Test Pipes
- Rev Limiter
- Turbo SI pics
- I need some real JDM headlight for a eg
- I got MONEy who has a turbo
- need an answer very VERY soon... before i buy something.
- Where to find cheap ACT and Exedy's
- 1.6 vtec headers?
- Pics of EK's
- is the USDM del sol B16 and the JDM sirII b16 the same???
- Looking for a part number (96-98 Civic interior components)
- wire harness?
- Requesting Pics...
- i got a zc
- ECT Switch Help!
- choosing new axels
- Good place to order a bov
- EG side markers measurements....
- very sad day 4 civic onwer....and onwers........
- speaker Infinity Perfects
- HID install
- input shaft bearings shot. could poor grounding be the culprit?
- HELP imma noob del sol lack of power when pushed pedal all the way down?? fixx??
- Tein coilover ??'s
- anyone know the COLOR CODE for 96-98 interior color Type F Lt.Grey
- if your engine bay is flat black....
- 1993 civic ex is it a vtec what engine code is it?
- Help.. del sol radiator problem
- where to buy front bumper cover (experiences)
- X- bar for eg
- JDM Fog Lights....
- ngO2 Sensor problem
- piston ring ?
- Help 98civic headlights front
- I HAVE SEARCHED!!! putting drag gen 3 kit on 95 EX coupe need specific answers!!
- Cat Interchangeable?
- coilovers + very strange suspension situation...
- OEM Foglight installation
- recommendation...
- Integra Rear Seats + 92-95 Civic Hatch Question
- ECU help
- question?
- what do you all use for front and rear strut bars??? ebay???
- turbo d15??
- Ball joint removal
- CTR headlights sold out
- AEBS or Skunk 2 IM on B16
- C2000 project goin underway ......need input and feedback
- how do i replace burned out bulb in fog?
- uhh... car sits higher after jacking it up?
- parting out engine
- noob question ..help
- automatic harness ls/vtec?
- What is this molding on my cx?
- vin # on tranny
- weight reduction ques.
- question on wich tranny i need?
- 92 civic headlight harness?
- looking for quality replacement carpet brands for 92 hatch
- 93 si axle nut ???
- Question for EG owners
- ecu for 1.6 ex vtec
- Fitment Question about Idle Air Control Valve
- timing specs on b16a
- installing new bearings.
- why did my exhaust spit out black stuff?
- Idling issues....Can timing contribute?
- Help: Civic has no power to starter or accessories.
- What does it do?
- SEARCHED shortest throw shifter
- Is this Turbo swap possible
- anyone know what wheel bearing i need?
- ABS vs Non ABS axles?
- WHAT SHOULD I DO TO MY CIVIC?
- IS THIS TRUE AND POSSIBLE
- I NEED HELP W/ A QUESTION
- K engine
- eg power folding mirrors
- h22a4 in an EG. wire questions.
- leaking plz help...
- What motor is in a 92 civic ex?
- D15B INTO A 92 VX ???? 5 Wire o2 to a 4 Wire?
- Smog/Ref question.
- racing heart knock off rims
- car stuttering
- Hydrolock survivor
- Ground Control coil question
- Wierd Noise at higher rpm's? Searched
- Integra GSR disc size
- Stutter/shake only during acceleration????
- another b20 in the making
- Coilover sleeves with yellow KONI...do they fit?
- whitecrow/j's racing eg front bumper?
- Do you think wetsanding can fix this?
- what suspension bars fit on which cars?
- New Timing Belt, loud noise now.
- Clicking noise when first moving my car in morning
- cleaning motor
- lights stays on
- Look what i found: TMRm'zine T-Shirts (brand new in the bag!)
- I HAVE A BROKEN INSTRUMENT BULB...WHAT NOW
- D16Y8 Heads
- fucked up idle
- Fujitsubo RM-01 and Sway bar clearance for EG HATCH
- drive or tralior to tune shop
- how much hp can a dx clutch hold??
- boosting
- Just got my sidemarker today HELP!!!!!!
- No Compression
- QUESTION ABOUT FAN
- QUESTION ABOUT INSTRUMENT LIGHT
- Best place to buy a d16z6 swap.
- D16 beatin a b16 wtf
- Surging/Dying/Bouncing idle... searched and pulled hair out.
- D16Y8 HELP
- Doors?
- Are 13" wheels ok for 2000 civic hatchback?
- type R short shifter
- Question about oil pan 98 civic
- Timing belt sizes
- b18b1--plugs wet.
- what shifter do i need
- Ebay Coilovers
- Hood doesn't want to close??
- LS/Vtec
- suspension question
- D16 Websites
- 1997 Honda Civic DX Mini-Swap
- Any idea where to get rear calipers at a good price?
- Broken A-Arm?
- Rear Brake Conversion
- QUICK RACING QUESTION
- HIDs for 94 Civic
- Bomex Kit for 92-95 EG
- Help!! what's needed for b-series swap in 95 Dx?
- I need a 99-00 si wheel!
- Is a 92-95 cx ECU the same as a 92-95 DX ECU???
- Anyone konw of DIY for Rear Drum Brakes?!?
- Name that sound
- will an OEM ITR strut bar fit my 94 EJ1?
- Why is it rubbing?!
- PLEASE HELP ASAP MY CAR BROKEN IN
- spring bolt question
- intake in eg
- SRS/Airbag Removal
- Cranck case breather
- How hard is it to fix a quarter sized rust spot?
- TRANNY COME IN ENGINES?
- fog light install?
- Honda Civic Hb Motor???
- Popping or backfiring sound under throttle lift???
- What's louder than this type of exhaust?
- ive got $2000 what should i build? HELP
- problems while driving
- SS Super tech valve springs?
- main relay.
- Are Hatchback & Sedan Emergency brake cables the same length?
- Best Aftermarket Headlight for an eg?
- swapable sensors?
- Motor wont rev past 4000 rpm
- Tanabe SMH exhaust into an EG
- Running 14" rims on an SI (winter set)
- 93 cx with d16z6
- Tried Searching.............What OBD is a 97 delsol?
- Rear carbon lip
- Help! Gauge lights don't work!
- stock civic hatchback weights??? doesnt seem right
- how to paint my valve cover shiny
- Transmission installation problem
- Where to buy 99-00 Si style bumper for eg?
- pic of a green or goldish del sol?
- ek oem foglights instalation?
- putting turbo on d16 I HAVE SEARCHED have some questions help please!!
- is it hard to put a sunroof glass in??
- ecu question need help!!!
- battery disconnect wiring?
- N/A JDM B18C OR TURBO H22A
- resealing a headlight
- 99' blue Honda Civic Si for sale!!!
- ls/vtec or gsr??
- What's up with these exhausts ?
- Need carfax fast!!!!
- How do i make a 4 wire o2 sensor engin work with a 5 wire o2 senor (civic VX)
- SOON TO B TURBO HATCH
- Sunroof cover out of place
- Show Your Civic / Del Sol ( Photo's plz )
- Best looking oEM's on a coupe
- front bumper only not sure what to do???
- Tunertoys I-Beam rods.
- Is this a good deal??
- POST ALL SEDAN(4DR) JDM ek9 PICS HERE(part 1)
- 3 rpm
- distributor proublem
- Key stuck in ignition
- muffler tips
- rimsandthings.com
- Worn keyway at end of crankshaft???
- D15 vs D16 vs B16a2/3 vs B16a vs B18c vs vs b18c1 vs B18c5 vs H22 vs k20 vs k24
- video host?
- 98 Civic.. new headers no air sensor
- Serious Weight Reduction.
- Need some help with hubs and driveshafts!
- HID. trouble. need help ASAP.
- S2k Cluster in an EG???
- Help...major nitrous damage!
- What is the fastest d series motor
- !!!HELP!!! WHATS THE BEST SWAP FOR A 98 CIVIC EX???POST INFO!! ASAP!!
- help me trouble shoot my windshield wipers
- del sol typeR, b16 turbo
- A few steering/brake/cooling problems?!! Suggestions/answers needed.
- honda tech windshield banner
- Help please..
- SI tranny conversion
- GSR door panel into eg hatch (search turned up nothing)
- Moderators: when can i post in the (No trial users section??)
- Pic of diagram for rear suspension 92-95 coupe
- B18b into an EG - Simple Questions Options
- slave cylinder!!
- think of doing a k swap!!!
- 94 Civic Ls/Vtec motor mount?
- Tire Replacement Help
- Quick question about Apexi N1 Catbacks
- Civic HX wiring harness
- 18 inch black rims and tires for sale
- will a eg hatch exhaust fit a ek hatch?
- Just a quick question about where to buy parts?
- B18b1 motor add-ons
- what kinda manifold is this?
- Stock z6 FPR on y7?
- Razo manual pedal installation?
- Selling my set up, gimme some ballpark prices...
- WOULD THIS GAUGE FIT IN MY CAR?
- GOOD NEWS !!!!!!!!!!!!!!!!!!!
- EK Hatch Rear Disc Swap....What E-Brake Cables????
- would my secondary butterfly open if i am running a p28 on h22a
- B16a vs B16a1 vs B16A2
- suspension question......
- What kind of shifter is this? **PIC**
- APEX'i n-1 exhaust into eg hatch question..
- dynoed my stock z6 4door@10psi today
- How do you get the door latch mechanism disconnected? I did a search...
- 94 integra ls intake fit a 00 civic si?
- fuel pump
- vtec-e question
- '97 CIVIC EX - AUTO TRANNY FLUID LEVELS?
- How do I tell what year my motor is?
- help on mi apexi VAFC
- Recently did swap, car is studdering
