View Full Version : Honda Civic / Del Sol (1992 - 2000)
- crankshaft maybe wrong one...help
- Transmission problem?
- Clutch hits the floor
- rear brake convertion question????
- Distributor installation
- 2000 honda civic lx code p0420
- Power Steering Pump Problem
- b series coolant leak
- bumper bolts
- quick d-series question.
- Engine VIN stamped on the engine??? Searched, please help.
- What Header is this, or what motor will it fit?
- any smoked taillights? on ek
- Just bought an intake and need some help
- 10mm bolt stripped on thermostat housing. HELP PLEASE
- intake manifold!!!! willl it workk
- what steps should i take in buying a swapped engine del sol?
- 5 lugs conversion: rear installed! Front bearing and questions!
- AC Prob please help
- cheapest place to buy a obd0 to obd2b harness ?
- help! wiring issues with a b18 swap
- What cluster should I use???
- H22 Swap on EK?....
- Drag helps
- k20 swap
- Idle surge at 1500 in d15b
- need help
- Got a CEl p0453 need help
- 2000 civic hatch cx.. no a/c.. help!!
- 93 civic stereo wiring
- flickering lights
- what is the best grease for bushing??
- B16 build need help!!!!!!!!!!!!!!
- Snapping Fuses...
- Rubber Trim around windows And Roof
- air condition
- What is the vtec pressure switch?
- losing power in em1..... :(
- need help locateing some items
- eg civic sedan 93.. please help!!!!!
- question 95 gsr hatch tach dont work LOOK!!!!!!!!
- Best place to shop for online honda performance in Canada
- Random misfire codes 0303 0304 1300
- quick q. gonna fix my window issues. anyone know if walmart has silicone spray?
- 92 Honda Civic Temperature Gauge Malfunction
- Short Shifter Problem
- quick battery question
- QUESTION ABOUT HONDATA
- lsvtec problem solved
- SOHC Performance help...
- SOHC Del Sol Flywheel bolt thread pattern
- FITV vacuum at operating temp
- Mounts installation
- engine swap and seats to fit into my 94' ex coupe
- Need help with the removal of an aftermarket head unit
- D-series Tranny?
- ICB Motorsports/JDM land.com ??????????
- ecu code 48
- k20 Swap into EK Cost?
- what type r back seats fit a 99-00 civic si
- alternator belt
- Door lock switch fully works, key doesnt unlock all doors
- b18a to b20 swap ?"s
- need help with overheating
- manual transmission
- Apexi V-afc2 questions....
- ej1 lip on a 92-95 del sol?
- ticking noise but isn't that loud.
- swap into a 95 civic not running right
- RHD eg6 tie rods same as LHD?
- Radiator fan relay keep going out...
- 96 ek coupe power window problem
- 98 integra type R cat or exhaust bolt up to a 00 honda civic ex
- Radiator stay removal advice?
- Ringing noise when step on gas pedal
- need help now
- D16 tranny problem
- Code 45 - Running rich/lean? HELP PLEASE!
- can i put a console in my dx?
- Rebuilding hy gsr.. Need some help answering my questions!
- Need help gettin an HMotors JDM ITR swap to idle and actually run
- Question about front and rear braided brake lines
- Broken wire in left door grommet for my left power window, how to fix?
- Del sol problem
- 12 Degrees HELP!
- what swap to do????
- Cold Air intake and header questions
- WHAT IS THE DIFFERENCE BETWEEN THE 96-98 CIVIC AND THE 99-00 CIVIC
- Help!!! MPG..... Good Deal? After market stuff
- Original Tein Struts & Springs!!!
- question on the new aem's engine position module???
- input shaft bearing
- Does lowering a Civic affect gas mileage?
- B18a Motor help
- Over Heating B16
- questions..need help asap
- code 71
- New guy here
- I am [freak]ed and need help please!!!!!!!!!!
- where do i find this part
- cd deck In original area 96 coupe
- Changed rear calipers now brakes don't stop right. HELP
- Horn!!! halllp
- Hello Ive been searching around the forums here in honda tech how to hook up v-tec on my car
- Looking for a good brake setup. (No rear disks!)
- Gas
- A/C problem Pleasew help!
- what is the correct name? please help
- Header problem (99 si swapped gsr)
- good setup?
- Jdm Side Moldings?
- transmission or engine noise?
- Quick HT. Im about to buy a car in 1 hour and I need last minute opinions!
- headers!!!
- upgrading suspension
- Will these springs fit my 98 Civic?
- new here
- stupid noob question about rear fold down seats - 2000 hx
- 92 Civic ECU/ECM
- honda part #'s wrong?? Cam cap bolts???
- EK's without AC
- NEED HELP ASAP!!! my brakes went out while i was driving. no pressure on pedal
- Possible to use stock B16a2 injectors in a B18B???
- eg shift linkage???
- Need help with timing/compression question
- **Safe having pictures of my SI on the web........??**
- si grille piece into a civic ex?
- HELP!!COOLING FAN AC FAN!!!
- civic suspension.
- will B20 pass state REF. on EK?
- b18b tranny swap
- Steering wheel / column quesion...........
- f'ed up idle!
- 94 Civic Hatchback--->Ratteling noise
- 98 Civic EX...need shock upgrade?
- 97 Honda civic dx trouble
- CIVIC EK9 spanks a Skyline GTR R35
- Core Support Replacement/Bumper
- Help! CEL 9
- 2 Loose Wires Hanging Dont Know Where They Go!!! HELP!!!
- B16 EM1 turbo questions.
- quick seat question
- timing belt is loose
- What causes my car to buzz?
- Which is better for the eyes...Amber or White guage cluster lighting?
- inlet size?
- big fire problem
- tranny swap
- boosting the SOL is finally underway....
- underdash fusebox..is JDM and USDM the same?
- need help identifying correct CV axles for a B16 swapped '94 Civic DX?
- 2 o2 sensor questions...
- Jdm EG6 SiR Cluster?
- Aem Wideband?
- eg6 headlight bulbs h4h 702k whats the best???
- Loud ticking from head!!
- What Headers is This?!
- Spark plug / Wire Recommendations for B18C.....
- exhaust set up on 95 hatch?
- b16a swap in a 94 civic dx
- Did a seafoam treatment, now I have bad valve noise...
- good del sol parts
- clutch break in
- CHICAGOLAND JUNK YARDS
- randomness.....makes me like having a 4 cly honda
- help with d16 swap!
- a/c work but isn't blowing or even with out a/c
- How to clean up purple blaster from aluminum radiator?
- Helping a friend. Car wont start. Good spark, Fuel, Grounds, Battery. Cranks but no Start ?? HELP!!
- noob swap question, your advice
- B20 VTEC KNOCK SENSOR
- My KeyBox - Honda Civic Key Mod - Slide Key - Also fit with Accord, Prelude Integra
- PO500 Code Wont Go Away Help Plz
- New member and proud new owner of a 96 Hatch!
- D16y8 drivetrain problems? need help!
- Differences between Type R motors
- Paint Code ? 5th gen Civic Purple
- 96-98 CTR Oem Replica Front Lip?
- b16 head
- Low idle need help
- si pistons
- CV drive axle install problem
- Help: Engine misfiring after rain
- HELP!! Blox intake Manifold install
- I like Honda!
- will a b16 manifold fit on a gsr head ????\
- ek hatchback sun roof
- o2 sensor testing
- suspension/lowering srpings
- what trans to use
- gsr hatch knock sensor question
- 00 civic 2dr auto perfomance upgrades
- CTR B16B SWAP IN EG CIVIC QUESTION.
- Replacing my ignition switch
- Exhaust ??
- water spots on the glass...
- 93 HONDA DEL SOL BOGGS!!!!!
- need help with h22 vtech swap
- o2 sensor problems any help appreciated
- HELP SMOG TECHS!! REFd But DIDNT PASS
- o2 sensor not working
- Lost my keys, where can I get one made?
- Question about obd2b and obd2a harness?
- spit and sputter in 1st gear help
- LSD Installation Write-Ups
- EG cluster on a 95 2 door coupe
- h22 in eg question
- Cranking amps
- ok got some issues....d15b swapFTL
- 99 civic si cams?
- Strange bell type sounds when acceling in 5th
- Any JRSC specialists in san Diego, CA? I need help!!!!
- Anybody make these aftermarket??
- Exhaust trade + cash
- recently moved to Richmond VA need to find
- nooob question.
- Poor Fuel Economy on Y8: Replace Oxygen Sensor?
- meanest b-16 cams
- eg6 original brochure request....
- 96 Civic Coupe outer door handle removal, HELP ASAP!!
- Kick Panel 00 civic
- LS engine harness question
- CP vs Wiesco for b16a2
- Help with Sunroof Headliner
- Strange idle problem.
- eletrical maybe
- any d series motor
- cable tranny in a hydrolic car
- Timing Belt Change / Charleston,SC
- overheating problem!!
- Whats the difference between an EK4 and an EK9?
- Vis Carbon Fiber Hood
- 2000 Civic SI Lower Ball Joint Replacement
- EJ8 with unknown b18b1, need help to pass emissions
- how to refresh/clean vtec solenoid
- resonator
- 92-95 ecu what ecu is this?
- HAVE EG PARTS
- MY CAR IS OVERHEATING!!!!
- CEL #41...Some ?'s.
- DB8 Seats in 96 civic hatch????
- Axle questions help!!
- !Help! P30 knock sensor ECU pinout
- idle prob
- wuts the biggest motor i can fit with a/c
- Recaro SRD in EK, need info
- d16y8
- New Del Sol Owner
- looking into buying this HB opinions please??
- Muffler Question
