View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Is there a write up on how to install an after market fuel rail?
- Wiring for Honda Cd Player
- How many lines to/from a/c condenser '00 Hatchie? gotta plug 'em...
- !!! Pronto! 4 door ej (99-00) headlights same as HB Stuck in dark hafta go 2 work !!!!!!
- speedo is going nuts "already searched "
- BAD COIL?
- Civic CX Head Issues
- When do you guys shift?
- Throttle Body Help!!!
- Normal to burn oil when VTEC kicks?
- HELP! question about brake master cylinders! searched but no answers! HELP!
- headers?
- Pics of my ride after the wreck
- which kind of timing belt do i use??NEED HELP PLEASE
- ANYONE RUNNING B20 TURBO?
- weak light in my reverse gauge...please help!
- FS: EK/Si parts
- light weight?
- fog lites on 96-98 pics?
- Attn: EK k kay Wanted: STOCK Exhaust Manifold-Catalytic Converter for 99 Civic Coupe DX-Southern Ca
- headers...
- coilover help!!
- Anybody using the JDMshit Hydro - cable kit?
- ticking sound when cold...rod knock? valves?
- stall 99 htchbk - relay, distr cap, or fuel ??????
- Compression and level of octane affect knock?
- engine Temp query
- OBD2?
- Factory Freak motor or Wrong motor sent to me!?
- b16 gear linkage
- Gas/Octane..
- ~~~~ECU guru's, problem with 4 wire 02 sensor conversion~~~~
- Short Shifter
- Need more power~!
- trouble with a 94 B16a3
- fog light bulb
- Where can i get the auto to manual mounth for 92-95 civic
- Good block cleaner
- D15B Swap
- transmission help
- best HID kit!
- Owning a $30K civic
- rear disc conversion on a del sol
- time to let her go...
- anybody know this...
- do hondas have shut off if the engines running with no oil?
- Does any Orlando EBP SI owners want a nice CF hood??
- HELP: Idle problems
- installing a slim fan...
- Guys Need Help Lookin For Apexi WS for my 95 Hatch(Specific website, cant find it)
- Mini me D16y7 to a y8 mini me, what kind of HP gain? (searched but no st8 answer)
- how 2 convert ek sideskirts to work on an eg??
- Removing paint from CF and clearcoating ??s
- quick question about exhaust system
- dc sports lower tie bar
- Question about the Optional Audio console for EG
- vafc install on 95 civic dx quick help
- all motor set up
- does the 01' type-r catback bolt up to the 00' civic si?
- Automatic p28 w/ manual trans CEL code 19
- Car idle control problems
- vacuum leak
- d16y7 and d15 vtec (jdm engine) whats best combination for more power?
- Door panel on del sols
- swap wont start - obd2 b18b > 92vx
- NA build questions-all motor forum gave me no response
- S2000 cockpit into civic 92-95
- B18C5, 18A crank, CTR pistons, B16A head, Help Again...torque settings?
- Which ECU would you use on a B18 TURBO'ed EK9! PLEASE HELP!
- 99 EM1 Civic IACV Wiring ... Help !
- power antenna on eg civic??
- will EF seats fit an Eg?
- swapping from manual to power mirrors???help
- again how to do the fast blinkers?
- crx seats in a del sol
- ***Looking for a 92-93 Cable Tranny***HELP***
- how do i get the dizzy off?
- FS JDM WORK WHEELS!!!
- Climate control temperatre wire
- SRS Removal question...
- Mini me runing a P13
- help i bought a 95 civic few probs.
- Hub adapter interchangeability
- tach wires behind my guage cluster?
- Doing tuneup, better to stick with OEM parts or will Bosch,Duralast etc... be ok?
- Wiper switch only works when holding it down?
- ls/vtec vs. gsr
- CEL goes on and off in '95 Civic, how do you diagnose?
- fuel hose question
- Looking for b18b1 LS swap for EK
- 99-00 SI gauge cluster
- EK seat in EG?
- wiring question? D15B into a non-vtec car.......
- question about rear disc brake upgrade!
- anyone know a place to find rolling chassis....
- HELP!! Guage cluster/deck wiring problem in EK
- anyone need a ek shell?
- lookin for turbo kit
- Factory EG Coupe Tire Diameter
- 97 ex leaking oil
- question on exedy clutch
- Civic si with VTEC CONTROLLER needs help!
- ecu help
- AEM short ram question
- GSR rotors and calipers fit on civic knuckles?
- te37 lug nuts
- tach problem HELP! PLEASE!
- b18c5 or b18c1 turbo
- question
- Gsr Brakes into Eks! someone do a writeup in here!
- Pads - AEM/Hawk...need opinion
- what the difference between jdm obd-1 p72 and usdm? and how much jdm one worth?
- project restore del slow
- Real quick question for my O2 sensor
- Painting headlights?
- 98 Civic EX- Wipers won't turn off!
- wtb urethane 00 civic si front bumper new..
- 96 sedan KEYLESS problem
- B16a3 problem
- Silverstar headlamps... :(
- Where did you get your front clip?
- little help on min-me? already searched & wrote into honda tuning
- Need helping finding a catback...
- charcoal canister removal...
- brakes on del sol
- HX wheels/ Wheel spacer
- Starting Issue
- Heater problems...
- idle problem Need HELP!!!!
- B18C EK exhaust INSTALL! NEED HELP?
- CrAzY Question. . . about the Bumper Pole. . .
- camber kit? washer trick for the rear??/
- Help?
- Wanted: STOCK Exhaust Manifold-Catalytic Converter for 99 Civic Coupe DX-Southern Calif
- fuel pump relay HeLppppppPPP
- 97 dx clutch problem
- core support
- where to get new wiring harness
- just bought coilovers.
- OBD1 to OBD2 PLASE HELP ANYONE!
- 96-98 lip??
- 2000 civic timing belt trouble
- Hood crunches?
- OBX manifolds Good?
- VAFC
- O2 Sencor Wiring
- JDM Integra seats into an EG?
- what wire is the d7 so i can hook up my air/fuel ratio
- 2000 sohc in my 96 sohc will it work
- turbo b16 not running right
- My new(to me) Aquisition
- H23 in a EG
- need help to upper the front hood
- Quater panels ?????????
- intake manifold, brake booster, vacuum questions... seafoam/cleaning
- Swap JDM Doors with power locks/mirrors/windows in an EJ2 non-power
- Boggy car, not drivable. Throws CEL bu it just blinks?
- bottom end build up on a d 15b vtec
- Is this a good deal
- 93 Del sol Si fuse box question
- a/c problem
- EG power mirrors
- are the d16y8 and d16z6 valve cover pretty much the same?
- QUICK! torque spec for knock sensor d16y8?
- whats better citr or itr trannys or are they the same ?
- Prefered place to have a cooling system flush done?
- cracked exhast manifold
- clutch for b16a2?
- 94 Si with JDM integra headlight conversion help....
- GSR brake swap, wheel clearance?
- b16 swap price
- about how long
- bad ground???
- Skookem is a scammer.. BEWARE!!!
- Need Coolant Line Diagram for d-series.
- 2000 civic si keyless remote question
- B18 Swap into EG Hatch Questions
- high flowing cat...
- limerock
- si intake manifold
- Electrical connections
- Hatchback with JDM integra headlight conversion
- vemom 400 performence controll module
- HX Shift Light
- Quick question about KYB's...
- jdm vin numbers on motor.
- 92-00 exhaust fitment
- anyone have problems with AEM pulley kit?
- b18 block compareison
- Angel eye head lights???
- first...braking, then...klunk Y?????
- Main Girdles
- It's Ricey McRicerton's 21st birthday today!
- Can't find knocking noise culprit up front (searched everything)
- b16 sputters starting off??
- o2 heater cel
- quick eg hatch
- hood pin scuff plate question..
- Split CV gaiter, How easy to replace?
- What is the size of the dx header?
- Need Help my 95 eg6 is idling rough.
- lower ball joint and tie rod need replacing, safe to drive?
- del sol auto??????????????
- H-T MEMBER SPECIALS
- has anyone used this seat bracket from memoryfab
- are del sol seats a direct bolt in to my 1993 eg?
- gsr ecu....b16... good idea?
- performance?
- How can you tell if your motor is JDM?
- Replacement A-pillar?
- defroster
- Pic Request: Rims on a black civic
- What to do with my SI???
- Wheel sizes with a drop
- paint code
- Del Sol needles in an EX/SI/VX cluster? + note on adjusting odometer reading
- Question about emission..
- Taking Off the cat will result in.....
- No Cat
- Civic si gauge cluster help needed!
- eg b series swap mounts ??
- need help identifying part on tranny
- FS: EK/civic Si parts
- how hard is it to remove/install a tranny?
- swapping obd1 d15b into a obd2 civic w/ y8... any heads up?
- 94 eg coupe Starter power wire grounded out.
- CRV Cluster in EG/EJ1
- Best Exhaust
- 5k running 12's ????
- Fuel pump relay gona bad?
- turbo kit ?
- 2 layer y8 headgaskets? honda or advance/auto zone?
- will prelude injectors fit on d16y8 fuel rail???
- Rack and Pinion diagram ??
- Whats the advantage of K series over B series ?
- PGM-FI main relay, how much does this part cost?
- HEad replacment?
- need help with offset..
- will it help
- need help bulding a turbo mini me
- S2000 cluster Pinout
- Help
- White smoke from intake...
- skunk or eldobrock
- where is the distributor
- Halfcut and Welded
- Replacing all parts of doors
- Blox stage 3+ cams !!!good cams!!!
- megan racing mufflers?
