View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 92 Si Hatch Sunroof Prob.
- SMOG, gross polluter-del sol?
- B20 Vtec shopping list. Tell me what you think.
- another newb here
- HID kit for my 95 civic ex?
- d16z6 arp studs and clutch
- Lower timing cover. A nessecity?
- Can u adjust timing belt without taking off mounts?
- Door lock won't unlock
- obd1 conversion on obd2 ls b18b1 motor pcv question
- Honda Civic dash swap.
- help quick question
- Best Way To Mount Her ?
- d16z6 crank the same??
- Transmission casing cracked?
- installing shift linkage
- Unknown Engine noises - 2000 Civic Si (Videos included)
- difference between jdm/usdm intake manifold
- Going to look at a 94 Civic HB Si as a daily..
- question about crvtec
- Car jumped a tooth
- 3 failed oil pumps and 3 sets of destroyed bearings on a rebuilt B16A
- motorola map sensors??
- drivers side window??
- 96 civic hatch???
- Engine Build !! OPINONS NEEDED!!
- 93 delsol si
- noob question about sohc oil pan
- trans problems help please!
- How much did you/would you pay for a midori hatch?
- 99-00 Si suspension the same as other trim Civics?
- Getting crank pulley off
- Dealership Sticker
- car will not rev
- Quote for a 1998 Civic Si 2 dr coupe
- Best Transmission for my d16y8
- vacuum question
- Headlights go out.
- **1st DIY Post** Rear Wiper Delete/Plug Install on EG Hatch
- 95 Fog light problem. Searched.
- SRS steering wheel with non SRS dash?
- differences from the 92-95 bubble
- idle drops when radiator fan kicks on?
- idle problems after cleaning IACV -HELP-
- head lights not working!!!!
- CTR carpet fit in a ITR?
- i dont know what my issue is...rings? valve seals?
- 255lph fuel pump surging when turn signal on
- Fel-Pro Permadry Oil Pan Gasket
- a/c belt noise or pulley?
- Im Stump Fuel Pump Not Priming Everything Good?
- type r intake manifold
- Have you ever raced against a scion?
- smog!!
- Ecu questions
- fuel injector wire power gets bat voltage help.
- Faster power windows?
- The evaporator of CRV 97-01 serves to a civic 97
- 2000 ex randomly dies. !HELP!
- illegal smog?
- Yet another n00b ?
- Lemme know if this is a good deal
- how many plugs do a OBD2B harness have? 3 or 4?
- Are obd1 and obd2 power steering pumps interchangeable?
- Anyone used diff flywheel weights?
- ek driver side axel problem...help
- what motor in 96 civic
- My Civic is Gone =( Take a look, i might have parts u want/need
- anyone?
- fuel injector wires only getting 3 volts 00 civic ex
- 99 Civic Muffler
- where to go for tunning between 3 shops.on a budget
- Just great....
- 95 DEL SOL 1.6 Sudden shut down
- Best Exhaust for $350!!
- 2000 Civic Si wiring tuck question
- 2000 Honda Civic Hatchback (EK9)
- 96 civic lowering springs
- V-TEC Cam Shafts
- B18 mount question
- head gasket help!!!!!!
- Clutch master Cylinder Reservoir...
- question: 92 civic ex front brakes
- need help gsr swap
- Honda del Sol rear fog light
- QUESTION ON CLEAN BAYS
- FOGLIGHT INSTALL HELP NEEDED**93 COUPE**ITS GOING TO RAIN SOON!!**
- JDM h22a fiacv
- Interchangeability of LCA stabilizer bracket????
- Guage install tips and tricks needed 94 del sol
- 96 ek questions about converting to power windows and power locks
- My 99 ek project.
- looking for aftermarket del sol mirrors
- b16 clutch - help
- changing the head on d15y5 !!!!
- need some help
- help: 1st clutch change scratching noise.
- ***WANT TO ADD A/C*** 92VX
- diagnose these noises (videos inside)
- dizzy help
- intermittent high temperature reading on B18C1
- Going to start K20 Swap on my EK3 98
- Bronze/Gold rims on Milano Red EG6
- braille. no weight racing battery have you used it
- 01-05 EM2 front and rear seats fit 99-00 Civic coupes?
- New To Civics, Got some questions Plz :)
- ecu ?
- Please someone hlep with an Ls swap
- 96-98 JDM CLOCK WIRING HELP
- Injectors fitment question, help!!!
- d to b swap
- 92-95 ex interior
- any body have any idea with this ac problem
- where can i find rare optional parts
- DIY JDM Cointray removal.
- what li is this?
- Coolant mixture problem...
- Who bought my car??? 3-4 years ago
- 5 speed AND Z6 swap
- Help with a speeding ticket
- wheel offset issues
- civic exhaust
- will an EK dash fit an EG hatch?
- Quick Noob Seat Belt Question
- jdm rear bumper fog light
- hydro 2 cable tranny
- b16a1 from an xsi
- will 205 55 16's fit?
- Should I remove my cat & a/c for more power??
- My new toy, well newer...
- secondary o2/catalytic check engine light every 100 miles or so...help!
- 96 civic B16 Auto swap prob.
- Keyless entry help
- B17A1 gaskets question.
- B16 Crank Possition Sensor?
- Harmonic Balancer??? Aftermarket Bad??
- ****B16 TRANNY PROBLEM****
- gas milage and oil problems
- hubs and studs
- Engine build issue
- 94 d15b7 extreme oil burning HELP!
- 95 Civic - Suspension Problem - Caster Troubleshooting
- custom civic grill
- a couple of header questions before in install...plz help
- Loose spring?
- Ebay fogs lights not turning on in 97 hatch
- a/c stopped blowing cold
- what are all the parts needed to install A/C on my EK hatch??
- 2000 honda civic si
- Power Steering Rack
- is this an easy fix?
- catback from EJ2 fit EJ6?
- papers needed for a swaped motor to prove its not stolen?
- coilovers or lowering springs
- B18B1 build
- quick steering question...
- Swap a d16a6 into a 94ex?????
- Dropping steering column?
- air fuel gauge.
- Annoying check engine issue
- how to see if motor is really built, cams valvetrain ect
- a/c gurus needed
- Slight sputter under backpressure?
- 96-00 Dash Removal
- removing heater componets
- What tire size on your 15x7 wheels? pic request!
- Cabin Air Filter 99 si
- car falls in and out of vtec
- speedometer not working
- What years body kit or bumper will fit 97 coupe
- My daily keeps dieing no cel
- No Start Situation-URGENT HELP!
- EP3 rear seats into EG hatch
- dizzy hybrid
- Question of the How Much would You Pay
- push button start on 2000 civic dx
- Vtec distributor question please help!
- 1997 Civic help about swap
- skunk 2 shift knob??
- Code 9 and 20
- building a jdm 98 spec type r head
- Opinion on ordering swap!
- 97 civic !!!OVERHEATING!!!!
- Car died when it get hot.....?
- ctr with slpitter lip?
- how much should it cost to install itr cams, itr dual valve springs, itr retainers???
- how much trouble is it
- b-series swap question..
- lookin for a place to.......
- question about an engine
- d16y8 finally gave out
- clutch line
- password:jdm j-spec fenders
- issues with ebrake cable (eg-del sol)
- Aftermarket springs on OEM shocks??
- 96-00 civic center ac unit swap
- side skirt
- duralast clutch almost new? or used stock clutch??
- Relocating O2 sensor
- what half shaft will fit my dame b16a
- B20 vtec not starting!
- Exhaust and Intake
- JDM b16a issues..
- Supra Pistons fo D16.. Anyone still have them?
- I CANT THIS OFF MY WHEEL! PICS INCLUDED
- engine stamp???
- z6 intake mani casting number
- Del Sol N00B Question - Roof Seals
- imma NooB /:
- How is my setup going to sound.2 different set ups
- A/C on LS swaped Ek.
- Dizzy question
- 93 del sol si swap questions
- d15b bogging out!!!!!!!!!please help
- 91 civic caliper , confused
- broke b18c
- 93 CIVIC DASH SWAP 99 SIR---B16A2
- Loud Rattling Noise?
- car keeps draining battery
- Lots of shifter movement - broken motor mount?
- Aloha J's socal meet
- Lsvtec burnig oil, oil change???
- door locks dont work...could it be a bad ground??
- Del Sol rear disk on EG
- K20/eg state ref ?
- Skunk2 fuel rail ANYONE TRY IT
- Swap Time and a few questions
- burnin up fuel injectors
- B and D series stuff, gotta sell fast!!!
- Hard to shift into 1st gear, HELP!!
- A/C problem
- 99-00 EX vs Si Rad specs
- DEL SOL DOHC RADIATOR SPECS?
- Some verifiable weights of Civics 92-00
- ek hatch spoiler
- Gear Ratios for '96-'00 Civics
- front towhook mounting place?
- b18c vtec engage
- 93 Civic Ex sunroof rubs on the roof, fresh paint! HELP!!
- Idle problems on mini me.
- Couple question about the b16a2
- 00 si interior illumination
- EG Civic No Fuel or Spark
- ECU pin connectors for OBD1?
- Help With Fixing a 2000 Honda Civic
- DC2 seats in EK?
- should the radiator fan always be running when you start the car?
- vacuum lines
- Where is?......
