View Full Version : Honda Civic / Del Sol (1992 - 2000)
- rear window on 1996-2000 coupe
- CTR in a EM1 Question
- b series pistons
- Gsr Swap reassurment questions.
- neo motor oil
- got question.....need help
- 96-00 civic suspension kit question
- sunroof stuck
- 93 Civic VX Tranny swap need help
- fan switches?
- 93 del sol sway bar link and rear trailing arm bushing question
- Hey.. RHD-EK
- DIY: 92-96 prelude seats into ej2
- Hatch/Coupe bumper on EG sedan??
- chip ECU
- socal good place to buy swaps
- Thing about gettin an SIR cluster worried about Speedo and Mile's driven???
- new injectors...swap
- is there a c pillar bar for the EM1/?
- IDLE raises in NEUTRAL
- A/C problem, help please
- P28 on the d16z6??
- Header with heat sheild mounts
- how many 02 sensor on a p28?
- Got new car. Had fog lights but the wires were cut off for show. Need help hooking it up?!
- help vtec problem help
- main relay!
- Swapping a EK?
- Does it have to be a certain temp for Vtec to activate??
- Car not cranking. Lots of help from electrical guru's needed, please!
- gutted interior paint help.
- how long until im a normal member?
- gas tank empty at 3/8
- AEM map sensor HELP!!!!!!!
- So tomm im taking out my AC is there anything i have to watch out for?
- bleeding brakes problem
- I NEED HELP WITH BATTERY NOT STAYING CHARGED!!!!!
- ECU choices........soooooo many i need a little guidance
- LS center console.
- DIY Headlight buzzer pics needed - searched, every link is old/down
- driver's door wont open....???
- Tranny noises? Y8
- Idle Problem...
- helicoil didnt fix my head stud
- O2 extender problem!
- rear outer tail light out, no turn signal, break lights...just running lights...
- D15B2 turbo need advice?
- honda civic 2000 ex problem help help plzzzz
- power issues
- idle jumping
- integra door panels into my eg? write up?
- Speedometer goin crazy?
- 06-08 Si seats in a 00 ek coupe
- Will 92-00 Ex exhaust fit a Del sol?
- RADIATOR help
- Stripped screw holding distributor rotor help
- Breaking hp point for d series stock axles?
- Headers & Cat problem
- B18C5 in EJ6
- does the 92-95 civic OEM airbag tray exist?????
- Camber adjusting?
- air/fuel gauge hook up
- Lucus oil additive? Anyone use it? Worth it or not..
- D16z6 head Y7 block Problems
- need "how to" on swaping SOHC non-vtec for vtec
- USDM itr cat back
- JDM B16 OBD0 Tach Wiring help!
- 98 civic a/c problem
- eg tranny/clutch problems
- Sensor Id and placement on this manifold..Please.
- Power locks issue on 1997 Acura 1.6 EL
- si strut bar?
- Civic EG8 music in the doors (6.5" midbass how made podiums for that)?
- rsx seats
- HONDATA TB GASKET QUESTION ?????
- Help! Transmission I.D question
- 93 civic cutting out (spark) ....car is all stock.
- flywheel and clutch question for b18
- Pic request,92-95 Civic with front nose mask.....
- m/t 24.5x8x15 slicks
- wiring toggel switch to cooling fan
- toggel switch to cooling fan
- Dual Core Radiator-got newbie interested
- Tranny problem: No 4th, 5th, or reverse...
- power steering help
- Traction bar question?
- Which Radiator? (URGENT)
- Two Problems: CEL and Speedo not working
- damn, what is the problem? (overheating situation)
- HONDA CIVIC EX
- Finally doing my rear conversion
- cold plugs
- Throttle Position Sensor Needed. 97 Sol D16Y8
- How to take front disk sheilds OFF!
- gsr block b16 head........
- d16y8? d16z6?
- quick cai question
- Gauge Cluster & Climate Control Bulb size??
- Hesitation only on partial throttle
- Old Gaskets
- just wondering
- idle problem
- Did Blox make a different style LCA for EK's?
- disadvantages and advantages of a non lsd tranny?
- ********CLUTCH PROBLEM NEED HELP CLUTCH SINKS TO THE FLOOR*********
- b20b Distributor $300?
- Timing adjustment
- LOST KEY TO MY EK..no spare..!!
- Cigarette Lighter Woes
- looking for help with tranny swap
- What can i use from a 4dr 95 integra onto 2dr 2000 hatch!
- Skunk2 intake manifold going in my eg6 with a 200 gsr...need advice
- HEADLIGHT PROBLEM!?!
- WHY DO PEOPLE DO THIS
- Need some wheel help?
- Just a quick one.
- delsol headlight problem
- skunk2 suspension
- What does the engine series mean?
- poor mans type r pistons
- jdm theory windshield banner
- cable tranny in eg???
- Strange 95 Civic AC problem
- Official Biggest Intake for Del Sol...I got it
- Coolant and vacuum hose diagram?
- problem with power steering
- Drive Belts Squeaking???
- WOW i just got 425 TO A TANK!!! 95 DX!!
- Over heating
- is it worth getting
- Gas question...
- D-series all share same ignition coil?
- '95 del sol uca's rubbing on wheelwell problem...
- Do I have a JDM OBD1 or 2 motor? How can I tell?
- I got a B18B1 setup but don't want to kill my mpg?
- temp guage not working
- Need help hood question...
- Si vs cx,dx,lx,ex fenders
- location of rear o2 sensor on 200 Civic EX
- EK GUYS OR MECHANICS I NEED SOME SERIOUS HELP THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!
- b16 and gsr dizzy. are they interchangeable.
- Spark issue I NEED HELP...
- ctr wing or cf spoon sports duckbill on a ek hatch
- Just bought some TEIN S TECH springs and i hate them.Do they fit 99-00??
- I dont think my Vtec pops...
- Where To Get Defi Replacement Parts ?
- will 88-91 EF civic springs fit on a 92-95 EG civic ?
- Noise from tire/wheel bearing/hub/axle? Help?
- Coolant
- P0A for what cars?
- Battery or wiring problem?
- Is the head gasket to blame?
- How do you remove that transaxle rod?? One with the pin??
- 92 Civic Lx getting a B18 non vtec swap... exhaust????
- Will CRX rear disc brakes fit my 99 ek?
- ECU for a Del sol
- starter question
- Do 92 SIs have a remindind bell when you leave the headlights on?
- a/c compressor noise under acceleration
- FOR ALL OBDII JDM ENGINE USERS, did your motor include,,,,
- cracked exhaust manifold
- D-series Build
- Is this my clutch? [EG Civic]
- Help with idle in h22 del sol
- MORE OIL LEAKS!! Engine code and high idle??
- Test Pipe ?
- floormats 4 Del sol
- tranny fluid
- A/C Problem
- Need Help Engine Missing at low throttle
- help to remove fading....
- WHat happens when you try and check a CEL code, and your CEL is not on?
- CEL #17- VSS- Vehicle Speed Sensor..light just came on, simple questions.
- The in-famous ek sideskirts on eg..
- <<<Need Serious Help!!!>>> :wave:
- tranny problems
- rmf headers on gsr
- is it my axles or tranny that's broken.....???
- What transmissions will work with a D16Y7?
- jdm b20b swap issue
- HELP PLEASE AC GOT NO POWER!!!!!
- sounds like wheel beering went out?
- Driveshaft Compatibility
- Did the D16Z6 came with two different intake manifolds/connecting pipe?
- sluggish vtec
- i need help ! how to built a ls vtec
- ECU question
- D series axles whats the breaking point
- Engine missing issue
- Replacing Rear Window In an Ek Hatchback.
- Cel #8 then car died
- b series tranny
- D series tranny from a 95 fit in a 98?
- Where can I buy a IAT sensor?
- AIMCO CLUTCH COMPANY
- need help no spark
- 95 civic EJ vs 96 civic EJ , GF wants to trade
- 94 HONDA CIVIC STOLEN in rancho cucamonga, please keep lookout
- JDM D15B VTEC fuel problem, will not accelerate fast! Miss wire?
- Windshield Leak, it's pissing me off really bad!
- What gauge wires are used for the diagnostic port?
- B16A2 N/A build question
- wiring....
- Second gear help
- 93 DEL SOL,REALLY NEED HELP FROM YOU GUYS!
- Hood spacers?
- Hondata Intake Manifold Gasket and FIA - D16Y8 >>
- code 22 problem
- 92 civic pcv valve?
- Camber Kit Needed? Recommendations on Tein/Tokico Setup EK Hatch + Tire Size?
- car wont start
- Problems with distributor king?
- arp rod bolts ???
- disc conversion
- diferences from a d16a6 and d16z6
- Maximum practical wheel/ tire width, for street.
- jg manifold Questions???
- vtec-e
- Loose A/C vents
- 92 civic d15 bleeding problem for the clutch
- Twin engine del sol, f22/h22!! BEWARE OF RICE!!
- ecu question?
- anyone have any pics of f22a swapped civic?
- Help System too rich P0172 *check engine light*
- Anyone know if Odyssey brakes fit onto a 99 Si
- check engine light
- remove vinyl?
- Idling Low?
- HELP! HELP!
- top hat,one nut is stuck
- Need some help with interior
- MAF Sensors
- b18c1 swap in 99 ek
- My b16a2 NA setup
- 02-03 si rear brakes onto ek4 ?
- HELP!!!!!!!!! i wrecked my car
- Distributor
- NEW TO SITE, 92 CIVIC HATCH SI
- Overtighten axel nut = half shaft is toast?
- what oil for 99 sohc
- common driver side lower than pass side problem
- Echaust problem, please help...
- need some exhaust advice
- back rotor question.
- [freak] theives
- 97 Civic 1.5 v-tec e ENGINE SWAPS
- Test Pipes
- d16y7 valve adjustment??????
- gsr cams in a b16 head
- steering rack boot
