View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Check engine/ rough idle help!
- DC2 cluster in EG (nothing to do with wiring)
- Front lip for EG6
- Car shakes at high rpm + light thump
- ECT question
- 19mm ST sway bar tearout?
- help please.
- o2 sensor wiring quesiton???????? to ecu??
- what engines would fit my 92 civic cx?
- curious about going NA with 2000 si
- Does anybody know the offical terms of hondas JDM names??
- I need a chip for crome!!!
- B18B Into 95 Dx
- Help!!!! Question about timing a B16a
- need help with horn
- Distributor and Top Dead Center? searched with no results....
- best why to get power but stay legal?
- Installing a horn/siren to a seperate button
- dizzy promblem
- gauge lights dead....?
- jdm map light
- b16a tapping noise
- Need Help... GSR brakes fit on 2000 civic hx ?
- Throttle cable bracket for B series swap? (B16A2 in EJ8)
- diy 92 civic heater core
- agx 8 ways on 96 hatch, any ideas
- surging question..
- b18b1 in ej2
- H&R OE sport springs
- Two mystery plugs on harness
- so my car gt stolen and recovered.
- EG QUESTION???
- Gas gauge way below E , won't move...
- voltage map for stock map sensor
- My Si Isn't Sparkin!! Need Help!!!
- what else will I have to convert for B16A2 swap?
- What kind of spark plugs to use for jdm B16A engine?
- sun roof
- fuel pump cut out switch??
- More Timing belt trouble!!
- installing turn signals in side mirrors
- DIY Valve lash adjustment tool, to save you money and time
- 00 si tranny issues.. need help
- Hard Cold Starts, maybe Cold Start Sensor/Temp sensor?
- Ignition Module Test >> 2000 Civic Si
- 2000 Civic HX. Gonna check the CEL
- Headers recommendations
- LCA? Camber kit required?
- !!!!!!! Click if you have EBAY EG fogs !!!!!!!
- how to wire secondary o2 sensor?
- OBX Ramhorn pictures
- Bought '95 Civic, need help to fix a few things
- Half Shaft...quick question
- Type R Rear Spoiler With Brake Light
- Stumped no fuel no spark (Searched for three days)
- Code 19
- Valve lash adjustment questions
- I have a new car... and a question!
- 99 ek auto to manual swap
- honda civic oil leak.
- BIG problem, need HELP!!!
- eg si gsr swap done getting code 22
- WIRING GURUS! OBD1 motor OBD2 harness (pic extensive)
- b18c5
- need help finding a clutser
- Need Help ASAP
- Thread pitch and size of a b16 header to block bolt?
- IAB
- how can this suspension be raised?
- 99 EM1 stolen
- Car Just died
- Help me out guys
- b16a oil pump compatibility
- Civic overheated and heat didn't work; thermostat?
- Wiring
- 94 Del sol engine problem
- BAD!!!
- H4 HID standard?
- Cylinder head torque settings for d14?
- NEED HELP With My CIVIC!!
- Fuse box question...need help, I'm in the dark
- 92-95 civic 96-00 front end?
- weird break light problem
- header + cat
- Ek Rhd conversion
- MOD OR ADMIN HELP PLEASE
- EGR valve?
- HELP!! fishing wires through the rear hatch
- obd1 b16 no rev limiter?
- B16 Swap NEED HELP
- Iacv: DIY testing
- Ride Height reallly weird....any suggestions???
- b18c1
- springs from a 91 sedan fit on a 92 sedan??
- Blox front camber kit
- fabric for arm rests
- Audio System EK9
- impatient n00b
- Any good meets in L.A
- looking for someone who has done h22 swap in ek and stayed obd2
- are 92-95 civic ex IACV interchangeable with 99 civic ex MT IACV
- What is the best gas for my 94 civic?
- D16Y8 pulleys?
- k20a2 swap
- Energy Suspension Rocks!!!
- Camber kit
- DC sports 4-2-1 headers
- Building A D16Z6 Turbo Engine
- Lots of Work done...Now Needles Don't Work??
- EK to Type-R conversion
- my di6z6 is idle hunting i cant figure it out any advise?
- ALARM OR ALTERNATOR KILLING MY BATTERY? Help asap.
- Civic RHD doors on a USDM Civic
- project eg?
- dash fuse blowing
- vtec light CEL
- Boring Brake light question
- 00 ek/ 95 eg ?
- oil leak
- OBD2 CODE 67!!! HELP!!
- Help! Alternator Installation
- CX and VX Tranny the Same?
- Need Help...91 Crx with D16y7, pm6 ecu obd0
- espelir jgt500
- NEED HELP code 20 CEL
- Help please, Running an Idle Air Valave without the Manifold!
- does anyone else change there oil filter from the top?
- I Don't Know whats going on!! HELP
- 99 civic converted to obd1, can you still check code?
- 2000 Civic SI Tranny Question
- 3'' exhaust on civic
- Are all 92-95 civic injectors the same?
- Some Problems....Need Input
- gsr dual stage intake manifold vs single runner
- I hate Wisconsin
- Spoiler and Mud Flaps for a 2000 Civic SI!!
- Del Sol Body Part Question
- ???????Who makes a cat-back exhaust for 99-00 Hatches?????????
- stock eg coilovers on ek
- can someone tell me why these 2 d16y8's are different?
- doughnuts
- > 250whp ... advice?
- Password JDM CF/Kevlar Airbag Tray
- monza exhaust?
- obd1 cel ??
- 13 inch wheels
- speedo/VSS question after z6 swap
- JDM B16A4
- wat should i do 2 my b18b1(ls) to make it just a lil bit faster?
- changing pulley belt.
- Anyone with Spoon style wing come in...
- B16 cams
- did search: cel light hard start
- EARLS INLINE FUEL FILTER???
- DX Auto - B18C Swap / manual + Si Cluster - help
- Aftermarket radio, wanting to retain dome light and keyless
- Brake Booster ???
- ECU
- How The Hell Do You IM On Here?????
- Stripped SOHC bolt
- D15b not going into vtec, no engine codes.....
- engine swap
- Speedometer went crazy - Odometer works fine
- CIVIC DASH!!!!!
- motor problems
- accord 2.2 injectors??
- Cost for dealer to change timing belt?
- d16y7 piston vs d16y8 pistons
- what cams on ITB?!
- HELP MY VX HATCH HAS A CODE 48 (o2 sensor) PROBLEM!!!
- Erratic Idle???
- everyone help me plz
- Will EK's stock intake work with EG body?
- just finshed a swap, i have a few problems
- Lil help plzzz?
- Any performance if i just swap a ITR inake came n ITR intake valve?
- QUICK QUESTION
- RHD conversion Question????
- Inconsistent prime
- HELP: installed new spark plug/wires and idles low once warm
- New B16A Internals- N/A Build
- HELP! HELP! HELP! - Do I have a blown headgasket? Is this normal? HELP! HELP! HELP!
- Need your opinions about my del aol
- Sanden Ac compressor the same between eg/ek???
- need 92-95 ex door harnesses/switches/power window relay
- VIN Question, am I retarded, or did I get ripped off?
- correct torque for head?
- Plug harness questions, pls help
- quik question
- Can this part be bought? SRS/Cruise Control unit
- EK Hatch GSR swap
- Sohc motor Questions
- carbon fiber si wing
- Windshield wiper motor going out?
- ok I started my car yesterday and then it shut off and I keep cranking but it won't start
- Audio Console
- 99-00 coupe/hatchback exhaust differences?
- will corbreu trs seats fit.......
- Just got this ek hear a poping noise from rear coilovers and look what i find!
- p06 to stock p28, all i need is the vtec conversion?
- Are EG's injector clip same as EK's?
- J's Racing fender flares
- Ls turbo???
- free carfax
- my MPH is jumping from 60-80-60-80-70-90 and so on.......
- Need Some Help!!!
- need ur help h-t members
- ek d16y7 oil pump onto d15b7??
- Automatic engine question
- Someone help me out
- CTR MIRROR QUESTION / CLARIFICATION ......I SEARCHED
- GSR problem!!!! help anyone
- fuel pump blowing fuses
- pump
- EJ6 Seats
- gas pedal question?
- axel grease
- Looking for air filter location
- speedometer is off
- Mechanical water temp
- Muffler Silencer
- Need FSM for 95 civic
- JDM front bumper
- d15 backfires/hesitates/stuggles (umm...gargling engine)
- Belt tensioner
- 99 EK HATCH STOKEN IN HOUSTON!
- o2 sensor hook up?? 96 b18c1 w/ chipped p28 in 99 hatch
- help..!!!!! civic help..!!!
- ctr shift boot and knob...
- 99 ex cluster or vss
- My gas mileage went off after new plugs and such
- idle surge
- K&N 57i Intake Kit?
- quick question on y7 tb on y8
- 1998 Honda Civic aut. transmission low clutch drum.
- my obd2 gsr vs homeboys type r
- Stolen '98 Honda Civic *North New Jersey
- Coolant level in reservior keeps on changing..
- oem parts!!!!
- HONDA brake rotor sizes????
- H23A1 in a 92 civic Hatchback?
- RACE BEARINGS / HONDA BEARINGS
- gettin a tach
- TACHOMETER PROBLEM
- HELP
- Has anyone ever tried these?
- THANKS HONDA TECH
- Tapping underneath valve cover
- B16 OEM injector cracked, would 310 cc injectors make the car run rich?
- Password Carbon Airbag Delete Tray
