View Full Version : Honda Civic / Del Sol (1992 - 2000)
- real deal ctr rear lip?
- offical real rota slipstreams?
- CX question
- max hp on a stock h22 tranny
- h22 wiring harness
- Will your brakes break?
- can a 96-98 civic carbon fiber hood fit on my 2000 civic??
- Tire rubbing question!
- my 00 si stolen in orange county
- Exhaust fitment question
- OBDI B16 going into a 98 Civic EX
- switching h22 integra axel inner hubs
- I ripped my SRS reel off accidentally, now what?
- what was wrong with my 93 dx
- What motor is in there?
- Up shift light.. eer i thought so...
- DIY how to install hub/steeringwheel?
- difference between eg6 sir and eg6 vti??
- Question about 99Civic EX - replaced distributor - check engine light
- oem vs aftermarket o2 sensors
- 1999 Civic LX Rear Disc Brake Conversion ? Sedan 4door
- Wings West Civic Type R rear lip
- Code 36, JDM P30 ECU?????
- 92 civic overheating.
- OBD1 gsr into 00 Civic EX
- cant pass 4k rpms help!
- I need a clutch
- Differences between the Transmission on DX, LX, EX civics?
- Rear fog light
- Is the 99-00 ex front end same as a 99-00 si front end??
- BRILLIANT RED EK COUPE STOLEN.
- seat brackets
- did a y8 intake mani swap on a y7...confused on these hoses..
- ELD code: Swapped ECUs and EEPROMS
- Folding Tow Hook????
- Turbo plans!
- intake mani question
- help don't know what could be the problem
- traction bar question
- Errr no CEL???
- B16 Running rich. intermitent problem. But mostly a problem.
- GSR CAMS QUESTIONS
- eg6 sir II full rhd swap in 93 civic ex coupe egt light is on
- D series axles
- Stupid wiring burned
- SOHC tranny question
- alignment questions???????????
- ek b series avid mounts fitment
- A little turbo help ASAP
- Seafoam: 50 mile drive, is this safe?
- Speedo problem
- Type r spark plugs
- ENDless Brake Fitment
- 94 Civic Alternator Belt
- need help converting civic manual to power steering
- iac
- i installed integra sunroof! yea thats right!
- muffler piping ???? helpp
- Brightest headlight for 92 civic
- 99-00 Civic Tailights Q
- jdm fog light switch......help
- finally moved up to B-series
- S2000/ Del Sol Mirror swap
- reverse light question????
- Running insanely rich. JDM D15B
- my cluster light works but the needles ones dont
- Swapped B16A2 in EK, often struggles to start or idle properly
- 2 Heads of Bolts Broken off..
- correct fog light adjustment
- Please help!! Pics inside
- Please Look... Engine swap questions
- Question about changing brake pads.
- DEL SOL SHIFT LINKAGE PROBLEMS PLEASE HELP!!!
- Could it be a timing belt thing?!?
- EK9 Civic Type R Shocks and Springs
- gear issues
- WTB CV axles
- MSD Ignition Distributor question
- 99 Civic AC Problem?
- cam shaft problem?
- how much is it worth? $$ Sir
- quick paint question
- Idle Screw
- honda civic si need help
- turbo eg, d16y7
- headlight
- Spark plug gap - GSR motor, ITR pistons
- D16Y8 OBD2b ECU pinouts for the primary O2 sensor?
- 1994 civic Si problem plsed help ......theres no check engine light
- Non-SR glovebox in SR chassie
- Fuel Injection Air (FIA) Control Valve
- Timing Belt Check up
- Distributor oil seal
- club eg
- NOOB question
- two o2 sensors on 98 civic dx........
- '94 Civic LX Power Loss
- car won't start?
- Civic Rear Spindle
- 94 civic ex coolant reservoir
- converting 94 civic front end to 97???
- EG sunroof on EK
- Z6 Build questions
- '96 civic hx to d16z6. What Intake Manifold?
- Cleaning the engine up
- installed valve springs now car wont start
- Quick Shifter Question
- [HELP]Water entering sunroof JDM EG6 stock sunroof
- refereee tickit what to do help please
- 1996 honda civic leaking oil
- header cat exhaust question
- New Wheel = Hoovering Sound?
- h22 engine
- When buying a ram air intake....
- junk yard find: rear disk conversion
- del sol exhaust
- re95 Civic DX taking forever to start....
- Cat. Converter gone bad
- FINAL DRIVE???
- 2 quick questions: short shifter and hg
- 92-95 civic catback exhaust
- Quick spark plug wire question
- skunk2 stage 2 cams?
- gsr alternator b16?
- auto to manual
- I need Vtec connection help
- tranny just went out...
- B18C1 Axel Question
- How do wheel diameters affect your gas mileage
- will y8 dizzy fit on z6 head
- need help passenger window problem
- Just sprayed my 2nd layer clearcoat, need help (it's dull)
- Auto to manual on 97 civic hx?
- DA parts onto a EJ1??
- B16A Spark Plug Wire Order on Distributor Cap
- CTR Transmission
- Fuel Gauge
- S2000 muffler on an 96 Civic Ek hatchback....questions, please look
- Honda Civic CX Hatchback and A/C System
- new to site
- lengthing o2 sensor cable?
- question (excuse my english)
- What do you think is better built?? 92-95 or 96-00 Honda Civic??
- why would a 5 speed civic start with out pushing in the clutch?!
- will wheels fit gsr brakes????
- Cleaning a junkyard Brake Master Cylinder.
- replacing the whole suspension.
- rs*r exmag pics on EK hatch? or even apexi WS.
- Stock intake vs no intake vs after market cold air
- STEERING FEELS LOOSE
- b16a3 to a 99 si
- Ignition Wiring question
- Distributor wiring ?
- JDM P72 basemap??
- over heating problem please help?
- b18b1 vs. d16z6
- Crower Stage 3 Cam
- 92 body molding
- 92 Honda Civic A/C comes ON/OFF
- 93 eg hatch key troube
- Grinding 2nd to 3rd gear 2000 civic dx hatch
- 1992 CIVIC SEDAN ? ABOUT GSR EXHAUST
- What should I get to install cruise control on '97 del sol s?
- 92 Civic CX Hatch Exhaust Dilemma
- Timing Question
- rack and pinion question
- stoptech vendors ?
- looking for a good service manual
- type-r cams...
- Bump stop questions
- gsr cams
- Del Sol won't start
- Fuel Pump Relay Location???
- Fog Light Wiring Question
- EK vs EG physical size comparison
- AEM cold air intake for 92-95 civic Does it fit a DEL SOL??
- vtec not engaging...HELP
- Check enine light blinking slowly but throwing no codes?? WTF
- Tranny making noise when downshifting
- d16 bore
- '96 civic hx to d16z6. What ECU?
- Rear Wiper Shave for EK. Instructions with Pics
- H22a swap into EG sedan whislt retaing P/S & A/C.
- Using water intstead of coolant...?
- Rear Disk
- Engine Rebuild guide
- Front shock fork?
- help here
- heating up 96 ek hatch issue
- Head stud torque specs with cometic 81mm head gasket
- vtec pressure valve? code 22
- Tire/rim size recommendations
- Little Help!! Oil Filter adapter and radiator hose
- bogging problem?
- EG A/C question
- Bad MPG - Del Sol Si *D16Z6*
- HELP: 96-00 front windshield rubber trim question
- question about wiring harness d16y8
- RUSTED BREMBO ROTORS!
- HKS Carbon Ti Turbo Muffler PIC REQUEST PLEASE
- 95 civic jerks horribly under acceleration
- Car Started Smoking!!! Help!!
- need serious help?
- Help me pick out the right engine combination
- Throttle bodies from other D-series motors not compatible with D15B7?
- Skunk2 Cams
- Carnk seal
- Test pipe
- B20b P8R Head Questions...
- Virginia Safety Inspection
- vtec pressure switch on then off
- Help: Radiator choice need help
- Want eg sedan pictures
- Help me
- my ITR build.... cant stop
- Woul'd like to do a few things to my 2000 Civic HX 5 speed with 176k miles. Few Q's for yall
- my car got stolen!!!!!
- Does front coilovers fit in the rear???
- quick question
- B Series tranny question, YSK-1 Tranny stamp
- help on Ek 98 Hatch Suspension
- Building a D16Y8 what pistons do you guys prefer?
- engine knocking
- h22 eg swap problems
- Will an apexi exhaust off a hatch fir a coupe?
- Clutch/shift-linkage problem? PLEASE HELP!
- What is the best daily driver? (Poll)
- Axle back exhaust?
- wiper blades
- First timer needs some help!
- JDM Amber Radios?
- rhd sol
- breaking bolts.......
- 94 civic body
- stupid window cranks
- Problems at 5000 rpms. Need some troubleshooting help.
- Three cylinders
- netami or obx twin loop?
- What sway bar?!
- Weird Problem
- Seat and Brackets didn't come wif bolts
- 93 civic ex head
- mounts for auto to manual conversion
- How rare is at to find a 94-95 civic EX with ABS and rear disk brake's??
- A/C Condenser problem.
- High Energy Ignition Systems
- EG or EF ???? Which one do you like BEST ???
- Projectors for EG8. Help!!
- Can someone take a look at this please
- Power window chaos
