View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Is this a good deal.
- speedo MPH off
- Question ( a newbie on honda's)
- Oil problem
- 99 White Civic SI?
- Engine block heater
- erratic idle
- What is the BEST performance equipment for B16A2! Sugest here!!!
- cf hatch on an ek
- ECU/Swap Question
- steering lock
- Comptech rear sway from integra fit 96+ civic??
- b-16 c2 11w 11d
- Removing an OBDII SRS Airbag Steering Wheel.
- swapping over integra brakes to ek hatch couple of questions
- where is the D series sticky thread
- Difference in front rotor size?
- Help!! Wont stopped blowing!!!Cant warn traffic
- em1 idling problem, did a searh already
- Individual throttle bodies Question
- Engine trouble
- My brake lights will not turn off ??
- 99 SI uberdata / ecu
- OBX cams worth a crap?
- GSR brakes on 97 DX?
- Del sol bumper idea
- aftermarket brake shoes for 97 Civic HX?
- How long does factory radiator last?
- Code 20, electric load detector, my 92 Si doesn't seem to have one
- What size tires?
- Which tires are batter Falken Ziex Ze-512 vs. fuzion ZRi? for summer daily drive
- Mugen Chip wont work on sohc?
- sohc axles
- What's a better form of forced induction?
- just installed megan exhaust, highly hightly recommended
- Help!! Someone please identify this ECU for me.
- annoying rattles?
- What is an electric load detector?
- couple of intake questions
- I konw there is a topic on this but it dont answer my question
- My Car was Stolen
- 99-00 Type R fog lights with ion lens???
- can u test a ecu w/o being in a car?
- D15B Torque Monster Possibilities....
- 94 Ej1 braking at stop sign rpms drop to almost 0?
- d15b7 head gasket
- Car Hesitant to Crank. Relay?
- LS MOTOR IN 94 CIVIC HATCH QUESTION
- help with wire colors
- eg and ek hatchie rear seats
- Starting problems 92 cx
- Problems with the window rolling up correctly.
- Drop Zone Gas Shock/Struts?
- Jumpy idle. but don't have a FITV
- Are obd0, obd1, obd2 knock sensors the same?
- What else to mod on a 94 vtec coupe
- Car wont go into gear when running.
- quick intake question
- Wire PINOUT ON 92 CX FOR THE 4 WIRE o2 Sensor!!! HELP
- b16 swap help
- b16 question
- Momo Shift Boot
- rims or system
- 94-01 integra seat bracket/slider fit in a 92 eg?
- Did they make a white civic SI in America in 1999?
- Problems with the CEL on a B18b
- Question on shift linkage
- Won't freak'n go into gear. Hard to shift
- ecu problems?
- 94hatch w/ h22 need some assistance
- PS? 95 civic EX coupe with a b16a3
- d16y7 head gasket problem please respond.
- Cusco Lower Tie Bar Rear??
- carbon fiber fuel tank cover
- Car too rich
- d16y7 dizzy question
- '96 Civic Coupe b20z swap?
- north east
- aB16a1-2 compression test
- No more AC=HP???? Is this true?
- Good Shops on the East Coast
- Gasket for Type R swap??? HELP!
- EG jdm climate control
- help on headlights
- Honda sites?
- CYP sensor?? Important or can i leave it for a while
- fuel injector
- uneven power
- rear disc?
- WTB: stock parts for 93 eg hatch in MN
- Does anyone know which fuse is the cig lighter?
- interior dye for crappy interior
- Connecting Rod Problem!!!!
- 2000 Civic Idle Problem NEED HELP PLEASE!!!
- Air Conditioning not working - 2002 Civic Lx
- Weird noise
- jdm tow hook
- question about cat. converter
- D15 vs. D16 pistons
- Car purchase advice
- will 89crxsi head bolt right up to 94civic dx?
- Driver Side torque mount
- Intake manifold fitment problems...
- what timing belt
- what do RS badges mean?
- b16 usdm in to a honda civic 97 HELP HELP HELP HELP???????????
- DEAL ON EBAY...................................Bilstein SHOCKS/Strut & Ground control COilover Combo
- Integra Type R armrest in EG
- B16 OR B18
- Chance ?
- question bout buyin a 99 si already modified
- Question: 99-00 Front Conversion on a 97 Hatch...
- i fear that horrible grinding noise when shifting
- TYPE R HEADER AND CAT FITMENT QUESTION.
- Over-heating Help ASAP --> Searched
- cluster stopped working (searched)
- identify flywheel help!
- I have an ecu Question?????
- >>>>>>---OBD1 to OBD2 Question----<<<<<<<
- heeeeelp me...suspension
- info on retro fitting hid projectors in EK
- Head Gasket Leak
- 97-01 Prelude cd deck into a 92-95 Civic?
- mini-me cam/ignition timing problems
- Question about engine and mileage?
- d16y8 and turbo question
- annoying squeaks !!!!! power steering ?
- shift linkage question...
- non vtec to vtec? single cam
- what color dash in 1997 civic hatch?
- Lowering my car 2 inches...is a chamber kit suggested?
- Auto Meter Temp Gauge???
- ricer stickers on car
- 99-00 fogs on an eg
- ECU wiring question?
- eg exhaust advice
- Bottoming-out (or something) after lowering springs installed...
- Can I rewire injector plugs to match up to other injectors?
- DEL SOL SWAP
- Mini Me what drivers side munt to use. Please Help
- OEM SPOILER ?'s
- Help! Spiders have taken over my Del Sol
- Question about rear hubs....
- really quick header/exuast question for a ls/vtec...
- removing paint from moldings?
- help identifying sensor. 1995 honda civic ex
- Rear mudflap fitment...
- Wing Fitment....
- SARD fuel regulator, english instructions?
- Removing fuel line help
- looking for a reliable balancing/alignment shop in ROCHESTER area?
- Horn Replacement - Need help
- Need some help 02 problems
- Damn Emissions
- S2k steering wheel question
- start up/timing issues help please.
- HELP....my car is acting weird
- Engine Knock = Check engine light?
- auto wont shift to 3rd till warm
- wtb: eg audio console in black
- i am so lost please help me
- swap for 00 ex auto?
- Missing part w/ AEM fuel rail
- Civic Door Question
- selling the baby girl
- axle question
- Not FS thread ... market value assesment 93 civic lx sedan
- changing head gasket.
- your .02
- Any good Long Island Shops?
- Buying a Motor
- Rumpkin Responds to 600lbs in back of Hatchback
- oem style front end replacement parts
- Center console question
- Codes being thrown at me.
- b20 vtec help!!!
- differnt types of Civic Climate control
- Mangaflow Exhaust? Is it good?
- Who sells the cheapest Honda parts?
- ls intake manifold on sohc?
- once and for all (oil pressure sensor socket size)
- lighter eg6
- pinging..need help!!!!
- 96-00 Headlights (i have a question)
- grinding noise coming from engine!!!???
- Transmission whining and metal-to-metal sounds?
- what is the best turbo for the street
- VTEC engagment depends on what?
- Have a ? about my Guage Cluster...Please Help.
- Lights get brighter after 4500 RPM?
- smoke at high RPM, bad oil? *searched
- Piston to Deck Height for D16Z6 with PM6 Pistons...
- how hard would this be?
- Quick motor mount question.
- Adding Short Shifter= Harder Shifting?
- ITR springs
- auto to manual
- 96 engine
- Can anybody tell me what this is ??
- Upper control arm question
- what trans for jdm d15b
- Bar Sticker Question
- 4x114.3 mafia..what you guys do about abs?
- my civic hatchback project
- new battery/alternator,but car wont keep a charge????
- HELP! Code 10, swapp problems
- People With B18b swap into EG need your help with mine.
- Will a 94-01 front swaybar fit on my car?
- obd1 motor wit obd2 ecu??
- Vtec Controller on 94 sohc vtec
- 96 to 99 climate control conversion (no light!!!)
- Nitrous Questions?
- clutch break in
- tire bubble .. ?
- Pulley holder tool use
- Need 2000 civic si specifications
- EG fuse box layout.
- Code 16, help me out suckas
- Just about Done!!
- zc questions
- Climate Control Relocation/Swap
- ECU trouble CODE 9 CYP sensor....need help
- d16y8 head on a d16y7 bottom end! Need HELP! All help needed. Advice welcome too!
- really low idle
- Radiator hose, which one to use??
- gas tank on 94 civic
- Motor mount problem
- Question about part URGENT
- What throttle cable???
- car runs like sh!t
- Del Sol Upgrades
- idle problems
- HELP
- Frustrated: Please read.. Caster Prob
- 94 civic will not start...... help
- what header has best performance???
- Are USDM and JDM EG hatch mudflaps the same?
- any way to get factory keyless to work with an aftermarket radio?
- SkyeC's Garage Sale! (B-series, EG, SRR, Goodridge, misc)
- EKcivic Handling
- VIN decoding
- What to do about the vin on a dash swap?
- Jdm d15b rods
- hairdryer on spraypaint?
- ls motor??
- blown tie rod boot?
- need help removing auto tranny from 2000 civic
- Where to buy Brembo Rotors?
