View Full Version : Honda Civic / Del Sol (1992 - 2000)
- FAQ: Changing light bulbs in 1992-1995 Rear defrost/cruise/foglight switches
- del sol wing?
- Mount mount w/ PICS
- p28 on GSR
- All the haters, I DID get a check from that dudes insurance.
- 95 eg w/ obd1 b16.. wut engine harness do i use?
- d16z6 lil idle problem (need help)
- integra coupe interior parts in EG hatch
- got rear ended - here are some pics..
- je pistons good to ?? horsepower
- lol....what happened to my clutch/tranny?
- Vibration!
- Motor Smoking
- catalytic converter question
- CEL, when @ 5200-5600 RPMS
- help please!
- D16Z6- Anyone use Skunk2Cams an Diff ECU?
- Brembo Slotted & Drilled Rotors
- What distributor for my OBD2B B16A2?
- cf duckbill help!
- after market pistons
- -ej8- no power from 1-3 thousand rpm's??? HELP!
- Could OEM actually have a ground loop?? fixin up a fix
- b16 idle
- 2000 Radiator question?
- better transmission
- Clutch feels bumpy..?
- Buddy Club Spec II Exhaust?
- 99 Civic EX Throwing Code 67. What to replace???
- question bout 100+ octane ......
- Noise in or around cylinder head (B16a2)
- Not starting
- car threw cel tonight
- help taking out dash in 92 civic hatch
- Filter Question
- Help! Need instructions on how to put on cf duckbill
- check out what haters did to my car
- SPRINT SPRINGS??
- black housing headlights on a purple EK hb. yes or no?
- Ground
- Cleaning my 96-98 headlights
- my new eg6 help...
- help
- TPS issues...
- help!! need a tip
- where do I buy paint for my valve cover ?
- what do you think of this time
- Coolant always low and murky
- What kind of rims for red 92 hatch.
- What mods should i get for my D16
- Better engine!!!!!!
- Exhaust!!!!!!!!!!!!! Question?
- d16y8 ?s
- H22 Swap in del Sol
- color problem righ now!!!!!!!!!
- Civic king!
- 1996-1998 Honda civic ex or 1992-1995 honda civic dx!
- JDM DEL SOL FOGS????
- Should I build up my D16 in my 92 hatch or do engine swap
- D16z6 and D15b
- cars acting weird any ideas
- does check engine light mest up my performance?
- d15 block/ d16 head
- my car stalls out after it starts
- del sol mugen replica spoiler installation advice
- who makes these skirts/lips
- cat delete question
- need a eg civic..i got 8000 any help
- h22 in a eg times...
- Squirrelly steering
- YS1 Final drive.. Are the final drives interchangeable with S80 trannys
- noob on Motor Swap advice
- what is the best setup for a type r engine
- which is better? b16 head or gsr head?
- Car was Impounded on the 9/30..
- PROBLEMS AFTER MINI ME!!!!!!PLEASE HELP ASAP!!!!!!!
- engine setting
- did the mini me ...car runs rich aand idles rough...and vtec malfunctin mil code is give,...please h
- OBD2 to OBD1...?
- searched... sohc v-tec dizzy on a non v-tec head
- 93 hatch
- radiator leak
- APEXI N1
- I there a actual part number? ITR shift boot...
- ITR cd player in EG
- auto gauge work on manual gauge?
- cold weather+94 civic ex= bad news bears
- Disc Change
- bouncing tach, sputters, please help.
- Rolling Fenders??
- GSR swap into 93 ex 4dr
- wood grain steering wheel
- Need some help with my shocks!
- need info o top mount kits for an ek
- si cluster
- what Muffler is to big?
- Where is my coolant going?
- Anybody with a good stock D16Y7 ex manifold downpipe wanna trade for Megan header
- Help window replacement!!!!!!!!!!!!!!!!!!!!
- Del Sol Coilovers????
- cx brakes...
- Brake light problem!!!!!!!!!
- Need a shop or some one good with crom asap...
- b16 breather chamber ?
- n00b question! Fuel rails and injectors?
- Brake booster check valve
- gsr swap pass emissions??
- Power loss on half a tank of gas? normal
- 2000 ex alternator problem?? help!!
- I NEED A LS CRANK....
- EG HATCH OR DA TEG??? DIDNT KNO WHERE TO POST
- What would you swap into a 99 si
- what can a b16a do?
- Converting OBD-2 Ecu's....
- eg hatch n del sol charge pipes
- Is this a good deal??
- Underdrive and lightened pullies -- pros/cons?
- is EK centre console can fit on EG?
- ran out of gas and will not start
- b16 timing belt teeth count
- hey im sorta new
- Is this a deal to you guys?
- From out of town... need to BAR and SMOG in CA HELP!!
- Where to get SIR headlights
- Horse Power Chips off of eBay???
- idle surges with clutch pedal pressed in??
- idle fluctuates when i turn off my lights...very strange...please help!
- symptoms for smoke
- Will the coupes side skirts fit the hatchback?
- crank key d series b series
- Bad Distributor?!?!
- I GOT A FIX IT TICKET!
- Can a 98 SI coupe front passenger door fit on a 98 sedan front door?
- Socketing an Ecu
- knock sensor??
- KONI YELLOW shocks question
- rear defrost switch
- locked
- how do i take out the gauge cluster? help plz
- JDM ? about the actual EG6
- odb2 harness help
- car rev's during warm up.
- eg ac belt
- Civic caliper Integra brakes
- Buddy club Spec 3 question.
- 99 - 00 head lights and tail lights
- two question?
- USDM P07 car, JDM p08 ECU.....O2 sensor question
- Post Your SIR EK's!
- Installed si cluster now got check engine light
- whats good to use w/o damaging my paint?
- Launch problems?
- choosing the right engine
- OBD1 to OBD2 plug swap - need diagram please help get my car done.
- what first
- can a gas tank rust?
- auto start (expert please)
- coolant??
- Avg. price for WS2 catback exhaust??
- 2000 with swap
- does anyone have a pic or a diagram for a p30 ecu for a 94 honda del sol?
- Horn Problems... current draw?
- y7?z6 mini me. NEED some Info
- LOCking Lug nuts.
- paint help
- Altrnator issues
- Fujita CAI
- Motor is finally in. Here is some pictures with it washed. LMK what you think..
- are these around accurate for a usdm b16 compression test results
- Clutch sensors?? (searched)
- SRS on dash after installing aftrmrkt wheel
- Possibe Alternator Problem?
- CA state ref question
- Setting my VTEC AFC
- 1993 del sol with d16z6 keeps throwing code 10 IAT
- Bored and stroked
- S2000 Steering Wheel in a 92-95 EG Civic?
- 99 SI Gauge Cluster
- Can it be done?
- help my civic wont start at all
- question about thermostat temp?
- GSR front/rear discs on my 92 dx hatch, brake booster, master cylinder, which fits?
- b series headers
- 93 del sol with a 93 b18 swap wont start but cranks over
- question about ride height and shipping
- EK with B series with no header bracket on header
- Transmission Fluid
- Water injection on an N/A motor
- On my way to be a future civic owner and...
- noise in manual tranny
- MINI ME HELP AGAIN PLLZLZLLZ
- does a 97" civic stock motor have a FITV?
- D16z6 valvetrain knocking... HELP!!!
- i want to up grade cams on my gsr not sure wat to use
- Automatic Transmission issues
- WTB 92-95 Coupe LEFT FENDER BLACK
- Civic GSR Swap Stolen...10/7
- 93 HB FOR SALE NEAR LOS ANGELES
- Planning Exaust -- Header Back
- horn wire?
- Engine swap
- Question about checking toe
- where can i get this piece?
- What should i do?
- Greddy SP2 plus 4-2-1 header?
- WHY IS MY CAR RUNNING LIKE SHIT?
- Broken timing belt, I need help setting timing on Skunk2 cam gears??!?!?
- OVERHEATING PROBLEM!!
- 96-00 Power mirror pigtail
- :( i got rear ended today
- swapping a d16y8 into a cx
- is there any difference between TD-41U and TD-31U dizzy's ?
- muffler choices...
- ITR lower control arms
- need a motor 94 civic ex need motor eather ls or singal cam
- Honda conversion...
- Cams
- 99 civic w/98 gsr motor.... cat and o2 ?s...
- wheel fitment?
- suggestions on internals
- Zex Stage-2 Cam Just Installed --- Help
- low fuel light not working
- Anyone near Bronx check out car? Will pay.
- how much for this repair?
- Max Horse Power
- Cannot stop this leak, what should i do
- Cheapest place to buy Sash Trims
- wont pass 3k rpm when cold?
- are the d16z6 manual and automatic 92-95 ex/si engine harnesses different??
- Amber Cluster?
- power gone and back and gone
- noob intake manifold question
- Major problems with a simple swap...please help!!!
- Need Honda or Acura cd din cable extension. part # , please help*****
- 97 auto trans in 92 civic **PLEASE HELP ASAP**
- installation of lip
- Mounts?
- Spindle question :?
- 98 civic wont start
- Wiring battery straight to head unit.
- Do they make rear brakes?
- upgrade brake booster & MC for wilwood brake?
- A'pexi 3" World Sport II Universal Muffler fitment on 96-00 Hatch
- 100k miles what to do?
- wiring help please.
- tranny question
- HELP tranny problem in first gear. tranny skips
- suspension techniques sway bar...
- does any one know
- lowering springs...
