View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Spark plug, distributor or both?
- D15B7 surging idle
- CAM TIMING
- Changing starter in B16?
- wreck eg hatch!!!!!!!
- korbach frame locks
- Wanted: Mini-Me Swap parts
- wanted carbon intake
- My engine fell and snapped my cv axel!!!!!
- ek civic turkey
- Resonator Help!
- Climate Control Fuse?
- High RPM Whine..
- car tends to over heat every other time i drive it
- glovebox andbracket help
- How Do You BAR A B16 In A 94 EG?
- please help: 98' civic alarm does not stop
- Question About Canadian SIR Prop Valve
- 81.5mm or 84mm for sleeving for turbo?
- 2000 civic factory security
- any aftermarket slave cylinder line out there?
- Vss cel, don't understand it.
- Need some help is it worth it?
- CTR Lma's purchase???
- A/c Question/Help
- cup holder and ashtray ideas for 2000 civic lx?
- I'm about to break down,em1 cooling/fan problem....
- 92-00 civic speedometer fix
- will a 91 Accord Fuel pump work in a del Sol?
- High pitch noise coming from engine.
- Has anyone try the TRI-Y style stainless header on ebay?
- 95 civic hatch won't crank
- del sol best place for gauges
- Anyone Know where to get Interior door locks?
- Throttle Cable
- Interior Door Locks Need Some Help
- 98 Hatch w/illuminas...What springs?
- I need Help with the vacuum lines on my 94 civic
- need help im buying a motor its already out.
- 99 to 00 civic si wire harness
- Help!!! Engine wont start.
- UNBAN RICK RABIES!!!
- Questions about s2000 cluster in 96 civic
- Leather E-Brake Handle?
- idk what to swap in my ek4 hatch plz help!!
- how to find out which t-bracket i have
- i need some fuel pump help..
- Think I'm going to replace the IACV
- d16z6
- Thinking of repainting
- Eg light help
- New Project / need input
- 95 swapped del sol wont start on its own
- ex doors on a dx
- help with rewire turn signal...
- ridiculous question on intake manifolds..
- 92 hatch Overheating
- D16y7 rough idle sounds like a miss fire/subaru HELP
- Help with dash lights please!!
- d15b7 with greddy turbo kit help??no full boost till 5k
- Slim Fans Worth it?
- Radio Problem.
- B16a Motor tick?
- del sol and drag radial question
- 94 civic D16Z6 cutting off at 6800 or 7000
- tell me what you guys think about this setup
- cranking issues on civic B swap
- How the F do I get this out?
- Bumper swap questionable?
- Roll cage for ITR fit eg hatch?
- Rust hood help
- Power window binds after reg/motor/glass replacement
- Who has password jdm rotors?
- GSR Rear LCA on EG?
- Viper 350plus starter kill relay wiring problems help
- 1999 Integra GSR Brakes onto 1993 Civic EX Coupe I HAVE QUESTIONS!!! HELP PLEASE!
- my parts list what would you do?
- White smoke comes out of the exhaust after driving stopping. Help!!
- h22 swap
- Rear disc conversion
- Got a REF ticket, Which engine can i put in for cali inspection LS?
- my car stereo speakers arent
- Need help finding the ecu ground
- what engine should i use??
- VALVE SPRINGS
- Does this mean the motor is rebuild??
- Booster/Master/Prop valve upgrades
- VALVE SPRINGS
- Ac Problem: Charge system and Freon shoots out AC pressure release valve.
- dashboard vin #????
- Lowering springs being a pain
- Question about apexi vafc2?
- Finding the correct starter, 91 JDM b16
- What seat rails fit buckets in an eg2?
- no brake pressure/ brake feel when car is on- after replacing spindles
- need help on build
- I really need help with the injectors on my civic
- ej8 exhaust recomendations
- 98 civic hatch break problem!
- Sway Bars fit for Autocross
- Is this a good deal??
- Fire wall plugs?
- idle problems please help
- B16a running rich and tying to die
- B series flywheel bolts
- NEED HELP: How to Spot a real CTR Axleback
- what to swap?
- GSR in EG, AIT sensor problems.
- b16 clutch on b20 motor with b16 tranny
- Window fitment
- S2000 shock install on my EM1
- 3" exhaust loud w/ res & WS2??
- d15b7 to d16z6 what is needed?
- what muffler?
- JDM unlimited
- brake backing plate on rear conversion.
- dx to vx wiring helpp!
- B16a swap into a 97 dx coupe**help**
- 99 civic si power lock problems.
- Cant get D15B7 out of limp-mode
- VSS cel won't go away, need some help this time.
- Whats this hole for?
- B16a iacv question
- window tint
- question regarding power door conversion
- Exhaust question/ recommendation
- d16z6 into a VX, turns over WONT FIRE!?! Help??
- Replacing climate control unit?
- Weak engine start up 2000 ex coupe - help
- 97 civic dx intake manifold question
- 94 civic ex wont turn over
- b16 tranny wont go into 5th gear (help!)
- upper ball joint problem
- Replacing ECU Harness
- Photos Of Bad Magnaflow Carsound Catalytic Converter
- Anyone know how to replace the fuel gauge in an EG
- for sale or for parts ek y7 motor
- Another no vtec thread
- OEM or aftermarket shock absorbers?
- eagle talon tsi turbo in civic ?!?!?!
- Doors unlocking themselves????
- Random Check engine light
- LS swap into 2000 DX Hatch exhaust/cat
- swapping engine. need to do the tranny too.
- another obd1 gsr motor in a 97 coupe wiring problem...
- Oil Leak
- Engine lagging... PLEASE HELP
- timing belt change intervals - getting mixed answers
- anyone had good luck from dropzone coilovers?
- broken exhaust bolts
- My EK9 Type Rx Build
- just did distributor seal and not starting?
- Spark Plugs Indicate Lean Condition Help Me Troubleshoot
- new guy with a k swap
- d16b2 replacements?
- $800 TO REPLACE A POWESTEERING LINE!?!
- 1994 honda civic swap
- da springs on ej6
- Has my ECU been chipped?
- Help with new build and cam gear install
- Where to buy a 2.5 Cat for 92 Hatch?
- Automatic engine harness in a manual car?
- Help!!! H22 euro-r manifold in 96 ek hatch.
- does 94 usdm del sol vtec have abs?
- Dead shocks
- VHT Flameproof coating - cure time?
- interior questions
- how low can i go with stock shocks and 205/50 15's?
- overheated, broken timing belt!
- My car dies out and why
- What are the valve clearance for a d15b7. Help!
- is their a company that i can buy......
- Clutch pedal vibration
- 1998 dx hatch b16a Vtec help
- turbo spinning at idle but no boost at all!! im scared as h***
- Radiator Fan Not working.
- searched. Inner tie rod replacement
- Type R cams in B16A2, need timing help
- My car is lowered can i get a alinement?
- 'Stripped In Seconds'
- quick d-series mount question
- Cruise Control not working
- d16z6 wont rev over 2500, tried everything HELP!!!
- 96 civic.. Car was in a crash a minor crash now front end doesnt line up right need..
- I have a CAI but want to switch back to OEM, Help please!
- b16a2 advice.
- Ground locations for EJ2 B18C Coupe..
- fog lights
- ej1 sohc turbo need smog test for registration
- Flywheel cover bolt sizes?
- Who has run a D16Z6 head witha D16Y8 block?
- Help!!
- seals not the ball balancing kind.
- totally baffled - d15 won't run without open throttle, runs like shit
- Clutch switch or interlock switch question
- center console holes?
- T-Belt tensioner how long do they last ?
- my ek3 has a dead spot. Why?
- EK Hood Clearance with a GSR.. WTF.
- Help with del sol mounts!!!!!!
- air conditioning AC *evaporator* bad? (2000 EM1)
- Oil pressure port! SOME ONE HELP please!
- High idle at startup. Gone after restart
- What size RPF1's are these?
- EF-EG Alternator adjusting bracket the same?
- Need Suspension Help
- Tail light work
- Civic conversion
- Need help identifying a part on my engine
- starting problems!! please help asap
- Quick front brake swap question, 92 Civic Si
- H22 swap, need help
- Front End Conversion Question
- Lugging motor at part throttle
- Help needed with part number
- parting out crashed ej1
- 95 civic eg cx hatch turbo build 350-400whp
- Function Form Type 1
- quick release/lock help!
- Removing turbo kit off D16A
- gsr swap rough idle
- A/C leak / to much pressure
- golden eagle vacuum box
- Civic rear disc conversion
- AC into my 96 dx coupe?? need clarification
- Can 94-01 integra sterring wheel be used on a eg sedan!!
- will itr rear sway bar fit on my 2000 honda civic si em1
- 98 civic EX no start. Replaced several parts. INPUT NEEDED
- coilover good or bad?
- 98 dx radiator fan does'nt work
- What is this plug for beside passenger headlight?
- Rear lower control arm shock bolt broke.
- Removing exterior door handle...
- Lol Question!!!
- 96 Civic Window Situation
- Cant Stay Away.
- mini me question
- swap oil flow???
- B16A2 into EJ6 - What ecu?
- confused as balls about wiring auto to manual
- del sol door belt molding
- del sol question
- idleing then stalling issues on my 96 del sol
- 101 cel count?
- Intake leak after putting new gasket in.
- h22a1 swap into civic eg8
- Difficulty with slave cylinder replacement
- D15B7 to D15b Swap
- suspension pros and cons?
- ls motor into eg 4 door rear mount question
