View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 92-95 2 door side window removal and replacement
- 1/4 help
- b16 hatch vs lincon?
- Oil Filter Question
- my Eg h22 turbo against vette c5
- EK front subframe tech question
- shipping
- ********** SEARCH ********
- WRECKED CIVIC!!!
- Hood Latch
- EK Suspension
- dyno results
- Got my Audi A4 HID retrofit in :) pics and vid
- My friend wants to trade suspensions...
- QUicky: Car sputters up until about 2000 rpms. What is it?
- quick question
- zc in to 92 si
- help on cd player for 99 civic hatch.
- Fuel Pump?
- putting a dash back in a eg
- Finally...
- obd1 alternative?
- just back from first weekend at etown :-)
- how soon should i purchase a walbro fuel pump?
- plug wires Question bout fitment
- RSX coin holder in civic???
- Timing belt install problems? Car studders?
- intake maifold
- Exhaust help?
- quick Question..YEs or No
- ? about transfer of suspenion
- Sohc vtec kick over????
- Just got back from the track and...
- girls girls girls!!
- Comptech Rear sway/tie bar combo in a 5th gen
- question
- can anyone tell me if black RSR springs for a civic is any good?
- ek9 b-series swap, I need help!!
- Check engine light problem
- taking out stereo in 99 civic
- 98 civic hatch front clip? Cost?
- I installed a rear disc setup and Specialty products control arms
- Can I fit a rear sway bar on my EK hatch???
- assorted rear disk swap questions...
- DC2 Integra rear swaybar on 96-00 EK civic
- i got an idea
- Widest Width Tire on Stock Rim
- VERY VERY VERY Minor rust problem
- Vtec Solenoid! Help!
- I think I need a new water pump... (pic) and questions.
- not a broken mount, but a broken something!
- Tein Basics
- How to adjust handbrake?
- Can Someone Post my Pics? PLEASE!!
- what exhausts are made for 92-95 civic 4 door??
- goodridge stainless front brake lines too long?!!!
- What timing belt, headgasket and head studs for B7 head on Z6 block?
- 15"s SSR Wheels want them?
- Quick! Oil pressure sensor socket size!
- In-car Fuse Box
- louder horn?
- Looking for some feedback on my new EK!!
- N00b question...changing to synthetic?
- Upgraded brakes Question? Do they make a 4 piston setup that can fit under 15"s?
- My EK Sedan Project
- Fitment issues with gsr cluster into the eg dash HELP!!!!
- Who sells spark plug o-rings (lower ones)
- What oem head units fit into an eg hatch?
- I shall shoot people: Distributor people please look here... final call before suicide.
- i have strange alignment numbers after my rear disc conversion / SPC lower control arm install
- OT- Need Denji glass headlight housing for EG
- Honda Civic JDM Ek4 Navigation?
- anyone knows the part # for a del sol dohc ac bracket
- 3-4 B-D syncros interchangability
- 98 civic hatch type r?
- D-Series header...
- Tokiko Shocks - Adjusting Tool Missing
- is there a such thing as a
- ground control mounts
- Intermittant CEL D16Z6
- Traction with t25 on d16z6
- Aren't 92-95 eg tails the same as coupe ???
- B18B vs B18c turbo
- What's the funniest/stupidest comment you've had on your civic?
- Need the trunk cover for my hatch...Please help!
- Eg rear disk brake swap into a Ek?
- tranny wont go into 4th or 5th gear
- installing a/f and oil pressure guages in 94 DX hatch????
- what could be the problem?
- Need Some Help!
- something unfortunate - wrecked silver EK hatch
- Window Help
- Finally got to put some time in on teh Civic!
- Tapping damage
- issues with 00 h22 engine in 92 hatch..need help quick!
- wheel locks
- Please help this noob out; I am very stuck
- I have come to a decision
- carbon fiber intake arm....
- quick DX tranny question
- Help with dizzy question!!! d16y8 vs. y7!!! SOMEONE LOOK !!!
- sway bar for 95 HB, (car has no swaybar)
- Crankshaft pulley bolt removal
- Electrical problem
- Guys help please!: I need an obd1 -> Obd2 dizzy repin diagram!!
- apexi n1 N/A universal: what piping size? 2.36" or 2.5"
- What headlights do you best recomend for my 94 civic ???
- Are Acell wires worth buying
- d16y7 Dizzy on a d16y5/y8: How to make it work ASAP!!!
- 99SI 300whp possible with jrsc?
- HELP!!! NEED A MODIFIED HARNESS TO PUT A B SERIES MOTOR IN A 96-98 civic
- F/S: Turbo piping for your EG
- Could my lca's be bent?
- Just did h22 swap and wont go in gear with motor on!?
- who has thier factory exhaust laying around
- Painted Valve Cover (easy DIY)
- Injector O Ring installation
- ZC cam in D16Y8?
- Resistor box
- First time at the track. Tell me what you think of my times.
- Whats the difference in exhausts between the 92-95's and 96-02.
- cold air inatke with a swap
- Clicking from driver's side when releasing clutch pedal....
- jdm type r conversion on ek hatch????
- anyone change the colors of there speedometer lights
- anyone remove their exhaust heat shield?
- Need help with engine noise in 99 civic
- anybody have Apexi N-1 UNIV with costumed piping?
- My horn doesn't work how do i fix it
- Another vid of my RSR GII w/o silencer
- EG hatch exhaust fit a Ej coupe?
- powerslot rotors on rear of 99-00 si question
- depinning at ecu?
- Wiring Diagram for 94 Del Sol SI cluster?
- anyone done nsx brake conversion on their 99-00 si ?
- obd 0 to obd 1
- Y8 Intake manifold on Z6 head
- Clutch Recomendations :-)
- Cheapest Place to get WHOLE Gsr Swap for a 96+ Civic?
- Need Help with a Distributor Code...
- Can someone explain offsets?
- Will 96-02 axle back fit a 92-95?
- Need help with ls swap
- potential 93 EX civic purchase
- how do i remove the rotor?
- B20 Swap into 97 EK Hatch mounts?
- :: 94' Sol Type S :: Does it come with powersteering ::
- help fast searched and couldnt find tourqe specs on y7 clutch
- oil on spark plugs..... whats wrong...
- rear LCA bolt broken off... Please HELP Me..!!!!!
- Please Help!!! Car idles weird then dies!
- Help, need some experienced advice
- CARFAX...plz enyone
- Need advice on increasing HP - 95 Civic
- 99-00 OEM foglight install problem
- Headlight ram air
- Catch can oil= really thin + smells like gas
- Proportioning valve, EG rear disc conversion help please.
- vtec engagment
- what is the stock ecu for a 95 del sol w/ d16z6?
- Well, new heart is almost ready!!!(pic)
- intake?
- What would you choose personally B16 or B18 block
- r what?What timing belt did u use on ur mini me??
- ACG fuse keeps blowing
- JDM SPEC b16a2 MAP Sensor where the heck?
- civic si rear pad install help
- WTF my clutch pedal fell to the floor.
- Wiring Harness
- Yeah haw!
- Need help, what flow are h22 injectors and will they work in a b18c
- What is easier to maintain a turbo or juice
- unhow do you lift up your car??? help now please!!
- d16y8
- y8 swap throwing missfire/knock codes
- camber kit ques?
- b16a2 trannie ??
- type r engine swap into a 92-95 hatch?
- Fuel pump control light problem
- 1st post....and a warranty question?
- 99 Civic DX/HB Suspension twerks and errrts
- what you guys think of those headlight?
- suggestions in cornering mod?
- why larger wheels?
- FS J's racing Carbon Air duct (link)
- few questions about d15b7
- just picked up a new toys
- my eg/ek
- Is this all i need to instal a RECARO Speed into my eg............
- 99-00 si front and rear bumper on a 97 dx coupe???
- HX Rims
- For the dragstrip: Comptech Icebox setup, remove intake or ?
- failed emissions, high THC and NOx - analysis please?
- Does anyone know what these are??
- Who wants to make $20 bucks? (tried everything and still no spark from dizzy)
- Type R exhaust fit EG???
- 00 civic bumper fitment HELP!!
- Do the Brand of any front/rear strut bar, tie bar, and sway bar matters?
- 1994 civc dx stock 0-60 time
- ACT flywheel
- SOHC turbo motor build up...?'s
- '94 civic Si cable or hydraulic clutch?
- Red Line fore 94 civic dx
- what is the difference between apexi universal N-1 and just apexi N-1??
- del sol passenger side airbag
- Best adjustable STRUTS?????
- shock install help
- 94 Civic EX 0-60 time
- Brakes?
- ek hatch -sound like a good deal?
- p30 Or p28 chipped ecu for b16a2 swap....?????
- Civic RS
- Skunk 2 coil overs all around.
- D16Z6 ITB's...
- Easy Ball Joint Question
- 195 width tires to big for 13" vx wheels??
- pressure plate bolts have no extra???
- hayne's lied, chilton's lied
- overheating and surging idle problem
- engine help
- what would yo do? and or buy ?
- Felpro Intake Manifold gasket, one question
- is there any way i can change air/fuel raito without messing with the ecu
- o2 censor location
- Draft:Why does this keep happening to me? 2nd clutch in 2,000 miles
- anyone put sway bars in a 95 civic ex coupe?
- gsr cluster install
- D15B7...good motor?
- vibrant performance's universal dashboard
- DOHC vs SOHC
- 94 Civic 02 RSX dash conversion
- radiator support removal?
- hey whats up guys? i just bought a 93 civic h22a have to rebuild
- HEEELLLPPPP!!!! firing order
- loud noise coming from car when driving
- why does my air/fuel ratio gauge tell me i run rich when the cars idle is dying
- 93civic headlight housing removal??
- hp racing coil overs
- damn nice eg for sale on ebay
- i need HELP timing belt!
- Pics and vid of my RSR GTII exhaust :P
- gas mileage?
- burning oil
- the do it yourself "amber corner lights"? where it b at?
- Chassis codes?
- Jumping ECU's
- should i buy this turbo? advice please!
- today is slowww
- skunk2 coilovers
- DOH! Rear bumper support for an EM1 Coupe......
