View Full Version : Honda Civic / Del Sol (1992 - 2000)
- where can i get a new final drive?
- B20 Boost in Ek Sedan Weight Questions
- Depo Foglight relay problem.
- cam gears for boost?
- What is this plug for on the back of a b18b?
- Primering side moldings.
- my crank pulley came loose while driving home
- need help plzplzplz
- 6G Civic - ITR 22mm Rear Swaybar and ASR Subframe Brace Install
- crank seal help!!
- LS VTEC set up. opinions wellcome
- Quick Question
- 98 hatch...fuse for cig. lighter
- Multimeter tests...What settings?
- Problem on my 96 Civic. PLEASE HELP!!!!!!!
- civic oem mudguard over rear lip?
- how do i start my car???? igniton fed up
- head swap
- I need someone to check their EG for me...
- Fog light switch question>!??!?!?!
- A quick look at GSR Seats in an EK Hatchie
- ex and si difference
- just replaced right axle shaft... pulls to right... need alignment?
- Lets compare short shifters... SHALL WE?!
- wiring help with civic D16Z6
- Fuel system problems 93 sol
- losing oil, no visible leaks!
- remote start, bypassing the clutch.
- My Civic is idling funny.. need some suggestions/help
- need help
- WHat do you guys think
- tuning questions
- Brake Rotor Screws..Need help ASAP.
- quick question~ for hub kits
- ctr pistons on stock valvetrain?
- need fuse diagram for 97civic
- Will this work 97 hatch o2 sensor on a 99 civic ex? if i splice wires will it work
- Need quick answer. SRS related
- MY BOOT IS BUSTED ON MY DR. SIDE AXLE PLEASE HELP!!!
- d16a6 piston d17 rod
- SRS light on: S2K steering wheel in 00 hatch
- d16z6 overheating bad
- Where to buy a tranny
- SImple Problem, need help...searched applied, denied
- 92-95 Civic Brake upgrade
- What to do after perchasing ITR cams?
- tranny shudders
- Weird noise
- d16y8 distributor work on a VX motor??
- CRV A/c Bracket, B18C Swap
- advise on buying ls swapped coupe. tranny question
- d15b water pump, what ones will work?
- Need Help Fast Pls Concerning Stock Shocks Ek Onto Eg!!!!!
- Pad/Rotor help !!!!!!!!!!
- d16z6 to b16c1 is it do-able?
- wtb
- Q about 4x114 typr conversion.. Parts specifically..
- What header to use on gsr ek?
- oil plug bolt size for 98 civic
- how can a ball joint brake?
- Rear alignment problem
- Limp mode or fucked ECU ?
- All Running Light's Not Workin.....
- Bad intermediate shaft?
- Leaking coolant?? 93 civic,
- EK JDM FOLDING MIRRORS
- how do i change my check engine light bulb 96civic dx
- Car runs COLD!
- high idle after hard run
- 97 civic ex (canada style) i need parts
- Got a ???????????????????????? For You
- del sol starting problem? help
- Roof spoiler on a Coupe??????
- Proper procedure in Pulling off a B series VTEC head
- Question about blocks
- problem tonight
- HELP!! - 2000 Honda Civic - d15y7
- civic VX Vtec
- Exhaust Problem
- car theft in fort worth tx...
- HELP: supporting the middle of a rear type r lip
- HELP: Clicking/Rattling annoying sound
- It's not so bad...
- the h4h bulbs will fit my 92-95 jdm eg6 headlights?
- feeler gauge questions for valve adjustment
- Flip over your JDM b-series valve cover
- HELP need to identify this hid kit i have hid +
- damn.. hit rev limiter
- srs blinking..
- Adjust stock tps help?
- d16z6 fit in a 91 civic hatch?
- cold air intake **searched my ass off**
- b16a
- b16 + greddy turbo kit road racing?
- Can someone tell me what this is?
- Installing distributor tomorrow, had no idea timing light would be needed.
- where do i start to strip my rear?
- hondata s100
- green gsr rims for sale.?
- turbo d questions
- Pulling my motor, need a quick answer
- Some pics of my hatch nothin special just some pics.!
- Anybody know any good step by step B series swap DVD's??
- brake swap?
- check engine light tonight, but fixed after resetting ecu... cause?
- WOuld it look weird??
- alternator problem
- JDM EF/EG/EK/BB/CB Side Marker Measurements
- have anyone make a eg to 4wd !!!!!
- i would like to put more torque to my soch v tech. but i do not want to waste alot of money.
- CX to VX gauge cluster works fine but 1 thing CX and VX ppl help
- Hazards not working
- gsr 5 speed tranny onto d block.
- Stuck PCV valve
- Swap Question
- Fuel system on a d15b7!! trouble shooting HMM?
- Swap done Thank God....
- wont rev over 2000 rpms need help
- 93 Del Sol Si Suspension Question....
- crx del sol fenders in usdm spec... wiring quickie??
- My radiator smokes but the temp doesn't go up
- i have a problem
- d16 Question
- to those of you that have c pillar bars for your ek
- EG front lower tranny mount problem...
- type r grill
- Screw on rotor wheel in Distributor...
- quick..question
- Car stolen in colorado
- H22 EK what should I look for!!
- weird squeal...
- difference between single and dual short shifter
- Any aftermarket lug nuts w/locks for stock Honda/Acura wheels
- need wire diagram for my powerfolds
- z6 head on b7 block , can i use b7 timing belt?
- Whats with the idle!!
- ? about GSR brake swap on a EK
- Best clutch..GSR turbo
- sway bars
- So I picked up a '00 Civic Ex Coupe & wanted to upgrade the radio....
- bypassing my IAC.
- anyone see this car around? the philly area
- code 38?
- wireing up vtec??
- Oil Control Jet???
- Question about AEM v2 intakes....
- which header?
- Pin out for a p30 vtec solinoid and pressure switch
- What happened to my clutch?
- Outside door handle broke off??
- B series axle compatability
- looking to purchase helms manual...
- del sol S vs SI transmission.
- lost my 5th gear
- Question about removing spindles
- Does a just odometer guage exist?
- HELP WITH MY REAR DISC CONVERSION!!
- headers?
- HELP HELP HELP mee
- ( code 14 wont go away.
- Leak into door panel
- r-sr exhaust---opinions plz
- hey panda
- help cars sputterin and idles bouncing
- 94-01 integra type r 4door rear seats into a 94 civic 4door
- oem ball joint
- Tire's performance
- Question on hondata
- EG (maybe other H4 civics too) headlight question
- b18b swap
- New to site, Just picked up my new project "EG6 daily driver"
- 92 civic not starting.. help!
- My car is a total loss! anyone need 1993 del sol si parts.
- who is this guy?
- mini me wiring 2000 civic DX
- its getting cold.....
- code 1 oxygen content....how can it be fixed???
- Trouble Starting?!
- EG Hatch stolen!!!!!!!! SLO Ca
- quick question
- Difference between D16Z6 and D16Y8 Pistons
- 93 AUTO 2 MANUAL SWAP
- turbo help
- 96-98 Power window
- d16z6 in a 1993 honda civic cx hatchback o2 sensor question
- GSR front and rear or GSR fronts and....................................
- stroker kit and turbo question
- HELP: 5000rpm problems
- Changing moonroof glass, already searched!!
- installed new tranny now car is bogging and backfiring
- Window Trim problem
- Just put in B16 and front end seems a little rough, is this normal
- SOHC VTEC ?'s
- civic headlights - brightness changes as I drive
- ground noise
- JUSTICE!! **lil shunshine on a stolen EM1**
- Drag racing Civic
- 93 rs tranny
- switching cluster
- Knocking noise. running out of solutions.
- OK i NEED HELP PLZ I HAVE A Chaeck engine light that wont go off
- Shift linkage or tranny problem?
- B20 Vtec (Juiced) Eg,Thinkin Bout Boostin?
- 92-00 Coupe suspension fit 92-95 hatch back?
- What size bulbs goes in climate control?
- Will a 92-95 B16A2 pass NY emissions installed in a 2000 Si?
- del sol k20.
- Fuel Cell For High boost/low boost setup...Daily Driven...Questions!!!!
- cel code 7 Throttle position sensor...does it affect VTEC at all????!?!!?
- hot wire cars
- ls/vtec swap, how much should i be paying?
- Temp guage goes staight to "H" problem
- Concerned buyer of a 95 SI hatch
- Need Sunroof/Moonroof info
- dash-gauges-gs-r
- look what happened to my brake pads........
- fuses
- 1999 civic hx oil capacity
- I need a pic of eg SiR cluster at night
- Wobbly front end under heavy acceleration???
- will this accelerater cable work?
- What seats can I replace my 97 Civic 4-door rears with?
- buying new car.
- 93 Civic...
- Clean cut for FMI?
- PIC request! PY EK9 hatchback with USDM ITR Wheels....????
- Help with mini me swap.
- B16 swap into 94 hatch, all parts needed,, still won't start?????
- fender flares
- what dis to use in z6
- Is there a tutorial showing how to install a stock dizzy in a D16Z?
- SOL 1/4MILE TIME
- Stock EG Cd player
- Everyone With Power Windows on DX/CX
- s2000 / ek exhaust fabrication
- Need Some help guys 95/96 Civic
- Humming sound coming from around intake mani...
- squzzing noise from right left.. timing belt?? or tranny?
- distributor problem ???
- Wiring Issue help : update.
- will d16a1 pistons fit in an d16z6?
- pics needed!!!!
- 99-00 civic climate control swap <HELP PLEASE>
- How to Hook up the Horn with a Nrg Quick Release and momo corse wheel?!?!
- password JDM question
- Engine install trouble with main relay!
- Trip to get oil changed at Jiffy Lube, blew engine 30 mins afterwards
- civic ek sedan taillight question
- Starting Problem
- having engine trouble with a new D15B7 motor
