View Full Version : Honda Civic / Del Sol (1992 - 2000)
- On the side of the road with my iPhone! Help. Car won't start
- Help with a Civic build
- Delete plugs for wire tuck
- stage 3 clutch installed, dont feel like its engaging.
- transaxel question
- wire tuck questions
- 1999 civic ex turn signals
- Need Help Installing Bike Rack On My 95 Hatchback.
- What tranny do i have?
- **Carbon Fiber Doors**
- EDITED: dash plugs inquiry, help
- 1995 civic 4 door
- Umm my civic dose'nt drive straight?
- H22 in EJ1 linkage
- Oxygen Sensors...
- How hard is it to swap over to 5 lug itr?
- How Reliable Is This Timing Belt Kit?
- Need some help pricing my hybrid hatch
- h22 on a EK hatch?!?!?!!
- 95 Civic LX Auto - Engine hiccup with tink ONLY above 2500rpm
- what size are 96-00 hx injectors
- Conversion Possibilities...?.
- What front brakes fit no-mods?
- oil inside distributor cap
- friends 94 civic wont start
- new shocks
- Replaced CV Axle, cars making noises now...
- Help with eg ignition?
- best way to flare/roll arches?
- Which site do you guys buy stuff on?
- Which brake should i get
- eg stanley foglights.
- 93 eg hatch brake light problem
- obd0 b16a
- help! b16 swap still not running right!
- knock sensor help?
- d16z6 block & b16a head
- eg media???
- ?'s on my all motor build
- Help! Car randomly shuts off then starts right back up while driving
- 400whp vitara build clutch help
- Cel p1162/ gas milaege drop
- Parking brake stopped working!!
- Saying hi from UK EK4 Vti-s
- Interior WIring Help??
- Swapping B-series -w- 2-wire IACV into '96 DX-w- 3-wire IACV plug
- Eg hatchback sideskirt removal. Help
- Map problems
- obd2 to obd1 conversion
- e-brake light comes on when i stomp on it
- ej8 lip help!
- shift linkage question
- D16y8 swap with d16a6??? Need help fast!
- Nevada to BOSSTON
- d16y8 Turbo or b16a2
- 99/00 civic si pics & video thread
- Tranny whine
- just put on my turbo kit now im having problems PLEASE HELP
- Help, honda civic after swap engine problem
- wat rpms should i be shiftin at?
- 93 Del Sol Si leaking oil from the distributor housing
- Air Filter Question
- 93 del sol ign switch help!!
- 93 Del Sol Si passenger light stopped blinking
- Del Sol wiring problems
- OBDI vs OBDII question
- H23 vtec build starting today 9-5-09
- gas pedal cable
- Exhaust creek is driving me insane
- 1998 civic ex with 95 civic ex tranny
- d16y8 wiring harness problems
- D16Y7 auto to 5 speed question?
- questions!
- ecu repair gurus
- Blowing FI E/M Fuses! Please help!
- Boost setup suggestions
- waterpump woes - p72/p75/p30
- pr3 wiring diagram
- ebay turbo kit
- Werid noise coming from clutch
- pin for ecu connector wont stay in?
- can i still use this?
- crVTEC bottom end question
- gsr into 95dx..wiring needed
- Missing/Stumbling issue
- speedometer problem
- DC Header Quick Q
- how much will you pay for ctr lip?
- da9 seats in ek?
- jdm type r swap in ek misses BAD
- antifreeze problem.......
- STOLEN: 92 WHITE CIVIC HATCH!!!!
- Valve cover removal
- Rear disc brake pad replacement issues
- Constant Throttle Rev Bouncing 98 Automatic
- car just shuts off.
- trouble code p 1337 ignition system. or misfire.
- Grinding sound on decel??
- speedo problem plz help
- mystery idle problem...
- 95 sol s wont start
- SIR front
- Temperature goes up when driving uphill
- need help on my civic
- Coilover Help Please
- Changed out fuel injector wires, Only firing on 3 now.
- Need a non japanese fuse diagram
- 95 civic windows
- mugen intake on an EG?
- exhaust leak or oil weight?
- DIY chip kit launch control question... anybody know the awnser?
- 99 civic dx problem
- SOHC distributor! placed wrongly?
- 1996 honda civic si climate control lights?
- starts and stallsi
- D16Y8 valve cover stud problem
- PURE STOCK 97 EK, should i trade for a integra?
- under hood ignition wires
- WOT BOX install on 92 hatch type R
- header heat shield help
- what motor oil to use, mobil1 or vtec oil?
- Can someone help out with my car? It keeps dying out of no where! fuuuuuuuuuuuuuuuuuu
- Adjustable cam gear size? Its different than stock!?!
- need help with last sensor
- torque converter problem?
- Chipped ECU Problem.. CODE 24????
- D16Y8 oil pump
- D16Y8 Baffled oil pan
- Alternator from Autozone, Oreillys or Advance reliable?
- does mazda speed 6 intake fit in 92 civics
- Need Help..suspension setup
- Tach and Speedometer dont work
- High Comp. Z6 ?s
- D16z6 swap into 1998 Civic hatch
- Post D15b Questions
- CEL P1162
- Help with LS/VTEC
- what engine to put in??
- Stupid leaky oil pan gasket
- '95 Civic - Can I use a junkyard crankshaft?
- will a motor fit?
- Oil Pan Fitment.
- Gauge pod top mount or cluster mount?
- can i use my stock mounts
- EG Cluster interchangables and ideas.
- Fuel Pump Wiring on Civic Dx 92
- question about wheel offset
- hard to go into second gear?
- Auto shifting ?
- Performance chip in 00 civic
- '94 Civic Vtec Issue
- flywheel / clutch interchangibility
- D16Z6 PCV Valve Question
- sonoma red eg ferio.
- Painting Exhaust System
- Can old exhaust hangers make noise?
- 97 civic cd player
- wiring issues.
- ls in a 99 coupe, need help please
- b20vtec or ls-v need help
- (US) 99-00 SI brakes/sway bars on (US) 96 EX?
- wtf happened?? car wont start!
- Ok, next step after CEL
- white smoke and ...
- help on d series???
- do i keep this car or not? what would you guys do
- Battery removal on a 94 Si EG Hatch?
- 98 hatch A/C problems please help !!!!
- Brake problem when idle goes up.
- pilot bearring question
- problems with ecu and wiring up vtec
- d15b idle stuck at 900 rpm
- immobilizer?!
- DC4 front seats to an EJ8
- start up help
- 2000 civic lx a/c wont turn on please help!
- 97 d16y5 into 93 si
- Ef Coils on an j1
- 97 civic cluster needle issue
- Gauge Cluster Tach Problem
- RSX seats into EJ8 (with pics)
- Bogging Problem
- 93 Si tranny issues
- Specific Wire Removal/Install for Alternator?
- EG/DC and EK seat rail question
- Slave cylinder bleed bolt size?
- FS: FS: BNIB Eibach Pro Springs (92-95 hatch)
- 99 CTR lca's on EG8?
- Ek (s2k gsr leathers)
- EG SWAP
- d15z1 vs. d16z6
- torque on crankshaft pulley
- ej1 wont rev past 4k rpm!?
- Oil cooler?
- Light bulb code
- Shaved engine bay...what to do with brake lines?
- What do you think...
- Some Problems on my EJ1 94 Civic EX Coupe
- obd 1 distributor keeps blowin out!! help please
- Honda will not start
- need help!! how to replace rear door handles civic 92
- NEED HELP ASAP, QUESTIONS ON TIMMING
- Hmm which engine?
- Ex Sunroof Question
- Rear door/rocker rust - repair and prevention
- brian crower HP?????
- '95 Civic - How do you replace a crankshaft in an old engine?
- ignition problem? car dont start.. please help
- Eg firewall heater/coolant hose prob NEED HELP PLZ
- EG4 D15B2 - alternator bearings.
- Another d16 thread
- home-made intake heat shield
- ASS smell and spark
- quick question
- es tuning oval smog?
- Auto Shippers
- H22 In Hatch no start
- DIY Cupholder and Coin Tray in Single Din Slots
- b16a or boosted d15b
- Skunk2 Lowering Springs Question?
- Need HELP! code p0505 & p1456 civic with b18c2
- H22 civ4dr project
- D16z6 trans problem help
- HID kit help
- Need Help with GSR to EM1 swap
- Bought a car and have some qestions about it?
- B20 Vtec or Boost???
- 92-95 civic power steering question
- takata harness short/long
- Motor bogs with throttle and backfires alot
- '95 Civic Engine Mechanic Question, need help!
- impossible idle problem is back
- Del Sol exhaust on my civic?
- wont rev past 5k
- HELP ME FIND WHAT RAILS THESE ARE?DID I GET RIPPED?
- 93 del sol si engine swap
- Update
- qouple quick questions
- My Civic won't Start. HELP
- d15b2 into 92 Hatch
- Mystery fusebox plug?
- radio and climate control flip?
- 1992 Eg Civic HB with 03 RSX Type S swap?
- f20b
- Recommended B16A2 Oil & Coolant
- Turbo???
- warning to all honda drivers!!!
- FogLight Question
- Quick Seatbelt Question
