- Building my daily sedan
- Problems with D15b
- Blower motor problems
- D15b2 Block D16y8 Head
- B20 VTEC ecu issue, pls help
- 1997 Honda Civic CX Gas Gauge
- Interchangable honda parts for Del Sol
- Hondata S300 errorcode 16
- New Engine? 95 Del Sol head gasket blown :(
- High oil pressure
- 2000 EX civic cranking but wont start
- clutch for future turbo
- Oem vs aftermarket
- Inline AC Pressure Switch
- Alternator mounting bracket stripped help?
- EG Stereo Connector Pin Female
- 99 SI FACTORY KEYLESS ALARM AND PROGRAMMING
- Gauge cluster problems
- 1998 Honda Civic Ex; No compression on #3
- D16y8
- What lip to use for ek sedan with Domani front end
- Raybrig Fogllight cracked lens
- SS brake lines compability between 5th and 6th gen (ABS vs no ABS)
- 15inch max tire size question on EG9
- Gave out
- Seized tie rod set nut
- Skunk2 ultra street manifold on d16
- Transmission swap
- 215/45r17 on 2000 4dr Civic
- hi guys i need help
- 94 Del Sol Speedometer stopped working
- 12.5:1 compression pistons for a b16a
- What are the first things to look at in a 1998 Civic Ex Sedan?
- Steering issues
- '93 Del Sol washer fluid pump wiring
- 98 Civic ex Manual. Has CEL, and shudders around 2k rims after warm up.
- Help to repair 95 Del Sol
- Best suspension compenents?
- Problem with oxygen sensor
- 94 civic won’t start please help!!
- Honda Civic B18C1
- NRG Hub adapter question
- chipped p28 solid cel
- Do 5th gen civics need a "Line output converter"?
- HELP! DIY OMP bucket seat mountings for civic ek
- Wire mess Civic 99 b16
- Civic EK Intersection lights
- Larger battery that can fit in 5th gen civic
- Rough engine after washing
- Honda Civic ek 1 1999 cxi
- DIY flycutting valve reliefs
- Honda civic b16a2 not starting plz plz plz help
- 1995 Civic ex <f20b swapped > need help with dizzy
- Civic 2000 trunk drain plug installation
- 96 Civic Hatch Clutch Fork
- 93 del sol
- Del sol vin locations
- d16y8 cranks but no start
- Check engine light stays on - no spark HELP!!!
- D16z6 intake on y8 head
- DX auto trans in a EX
- Honda civic 95 turn signals
- DRIVESHAFTS AXLES for Honda Civic EK Coupe with H22A swap
- Really Confusing Electrical Issue Please Help
- 5th gen civic stereo not working
- Disc brake swap 96 civic hx
- Eg weird noise when slowly taking off
- d15/d16 turbo build
- Boosted D16y8 Intermittently Dies and No Start
- Wiring inner tail lights on EJ6 Civic
- Please help! Alternator issue on Civic 6th gen
- Outer tie rod compatibility
- Which of the civic em1 wing mirrors are closeable?
- Need help with ignition ACC wiring issue
- 99-00 EX doors with a 96-98 floor harness?
- B18B1 Swapped into 96 Civic EX - Low Idle Problem
- K series Supercharged awd
- No fuel to engine
- O2 sensor and ecu problem
- Stock 98 e.x crank, no start
- Won't Start
- Adding Variable Intermittent Wipers to 6th gen Civic
- 6th gen HF engine and transmission swap into an EG VX
- Welding a Y8 knock sensor bung on an older block
- Civic EK4 EUDM Keyless Entry System
- Where do I plum this coolent jack too (b18)
- Sputters then straightens out, seems based on temperature gauge. It's
- I need some help because I'm kinda confused
- 99 Driver side window issue
- No battery power 80 amp fuse bad?
- 96-00 M/T ebay idle air control valve
- Coolant leaking from radiator cap. 98 dx
- NEED HELP PLEASE/ Motor swap 92 LX d16y7
- Are EG awd conversions easier with K series engines?
- How can I get rid of rear windshield squeak in 5th gen hatch?
- Tie rod boot ripped off the end
- D16y8 engine timing 😁
- How to rewire my DLR for new headlights
- 1993 Honda del sol wiring help
- 92 del sol b20 swap , trying to wire up 😩😩
- oil question in a d15b HELP
- First post guys. Need help.
- Eg b16a cv axel replacement
- 94 dx d15b7 rev limit
- B16a2 idle problems
- OEM Air Intake Tube Question
- Stereo has no power
- i swapped my 1996 honda civic to a b18a1 and the fuel isn't coming at all
- 92-95 EG Honda Civic Power Steering Retrofit using Toyota Prius EPAS/EPS
- Idle fluctiations only in park and neutral. Need help
- Quick question about wheel hub/bearing (tried search)
- What generation is my b16a
- 1998 Honda Civic ex 2dr
- Axel support bearing assembly?
- 3 to 2 Wire IACV
- Skunk 2 manifold on D16Y7 Help!
- EG Cargo Cover
- Ejaculated oil into intake
- Pocket for usdm double din center console
- K24 eg header hitting subframe
- B series T bracket regonition
- Which swap is the ideal for more power without terrible mileage?
- D16Y7 transmission swap
- My civic losing power while driving🤦🏽
- How do you calibrate a 95 del sol speedometer needle?
- Engine swap on 93 civic 1.5B7
- Climate Control not functioning
- 1998 civic overheating
- 2000 Civic Headlight connector full of crud
- 97 Honda civic struts
- 99 civic EX rebuild- is it worth it?
- Tacho signal
- D16z6 in 93 honda civic
- Breather Chamber Joint
- Weird noise only when I slowly take off 95 civic
- 92 Civice Oil Leak from back of engine
- Rough idle (only in park)
- Request Help with Narrowing Down the Knocking Noise Problem
- leaking oil pressure sender
- losing break fluid - getting frustrated
- 92 EG Fuel Pump Mystery!
- Congradulations Honda.. drum brakes suck!!
- ANYBODY GOT A D16y8 Short block or engine ??
- Trunk latch (sedan)
- K24a4 swap questions
- 1997 hatchback 5 speed p2p-335 D16Y8
- 15 short shifter work on B series?
- B18c1 rebuilt vs built new engine price.
- 96 Honda Civic EX Coupe EK Chassis B18B Swap
- What weight oil in a 95 5sp del sol trans
- Del Sol Auto Center Console,
- JDM D15B(d15z7) RPM fluctuation while cruising in neutral
- Looking for some fuel line help please
- Unknown harness wire and P0325 / P0330 codes
- Help Low voltage on tps
- Will the oem rotor work with the msd pro cap?
- D15 mini me build
- 96 lx civic trans change
- 98 civic lx backup lights
- 1993 Si crank no start help sought
- Automatic crankshaft vs manual?
- Driver Side Suspension WTF
- Steering/Suspension problems
- B series Charcoal canister
- What crank pulley for h2b Ek?
- Del sol seats width? differences between the seats for different trims?
- B20 power steering pump on B18?
- d15b7 idle problem? aka question
- Fuel line questions 94 civic hatch
- SRP pistons and Probe Industries rods
- Can a L15b7 be swapped into a EG civic?
- Eg passenger air bag removal
- 92-95 EX tranny with 92-95 DX/LX final drive? Is it possible?
- 5th gen weight reduction, more important in front or rear?
- Fuel trim is negative and random misfire. No code. 2000 Civic HX manual
- Cylinder 2 and 3 not firing at all
- d15 turbo vs B18 price
- 1998 honda accord acg fuse blowing
- 99 ex spoiler bolt size?
- Car wont turn over and have no idea how to trace it
- 1995 Honda Del Sol 1.6 A/T wont start
- 92 Eg best upgrades?
- Is there enough room in a hatchback to fit a spare door?
- 92 Eg vx interior upgrades
- Speedometer Cross Reference
- Delsol/Civic pedal question
- Delayed fuel pump relay start after ignition turn on on rainy days
- 92 Civic EG - Best AC Option
- 1998 honda civic clutch/ transmission problems.
- Del Sol Engine Mountings
- EG and EK Trans torque mounts?
- D16y8 thermostat housing
- Bouncing Idle
- D15B 3 stage vtec cold start issue
- 94 b18b tps?
- Power steering in EM1. I'VE SEARCHED LIKE CRAZY.
- Speedometer acting weird.
- OBD1 Code 43
- 1998 Honda civic
- Weird starting problem
- White smoke from exhaust while going downhill
- D15Z3 head
- D16Y7 Block with Y8 Head any different than a D16Y8 block and head?
- CEL on Then Off
- distributor installation
- Weird cold start issue 94 EJ2 DX
- 1998 civic dx no spark after valve replacement
- 1993 Del Sol Auto to Manual conversion issues
- 95 civic b16a motor car won't go into gear when turned on
- Ls 93 civic hatch failed smog!!! Help!!!
- Speedo and Tach Quit Working
- b16a oil leak , vtec solenoid?
- em1 idle rpm’s bouncing
- WHITE SMOKE FROM O2 SENSOR help
- Main relay no power
- D15b7 Breather chamber thingy
- Quick Timing Question 1.5 Stock del sol
- Overheating/Potential Cooling System Leak
- Heat(er) problem 97 civic d16y7
- em1 aftermarket brand recommendations
- 93 civic possible electrical issues
- Car won't stay running when the CEL is on.
- Identifying Wires Under Dash
- Where to apply assembly lube, if it's needed after resurfaced and cleaned head
- Need to confirm
- Remote Tuning
- Idle surge
- HELP// Rebuilding D15Z7
- How does ECU calculate mixture from start up
- D16y8 swap electrical connectors
- 2000 Civic/D16Y8 head machining risk
- Clicking noise after changing shifter bushings
- Help my cars filling with water
- Will the D16Y7 6th gen civic manual transmission mounts fit a 97 del sol?
- Help with auto tranny weirdness on daily
- 95 civic b16a what does this hose do
- Help! LS timing
- Car won’t start
- Heater 95 civic
- HELP: Mystery Idle Problem
- Broken distributor ear piece
- Civic Sun visors
- Delsol A/T Speedo Gear Selector Position bulb
- del sol auto to manual '97
- No Spark. Please help.
- 2000 civic ex oil leak need help
- 2000 civic ex Unknown oil leak
- 96 Honda civic delsol
- EM1 stalling
