View Full Version : Honda Civic / Del Sol (1992 - 2000)
- stupid question pls help if u can
- building a ls motor
- Changing 98 civic ignition coil...anyone know where I can get info on bolt sizes???
- acrua tl 2004+ calipers..
- optima batteries suck
- Vtec not engaging idealing high? please help
- B17 swap is a bitch!!! what PS pump am i supposed to use?
- "turbo" blinker
- broken connector
- Six point roll cage in an EG hatch W/DC2 dash?
- spider crack
- quick ecu question
- 94-01 integra gauge cluster
- ecu pin connectors
- Please someone go look at their headlight harness for me
- knocking noises not CV joint. driving me nuts!
- Next Miracle X Bar with EDFC?
- rear disc conversion
- what is needed to put a del sol radiator into an eg chasis?
- is it ok to mix up these bolts?? please help now
- damn it happened...i got into a car accident
- 96-98 civic, bseries motor swap questions.
- how much for AC
- hey im having trouble making a decision
- Check Engine Light turns on when...
- Has Anyone Put 2004 Honda Civic hatchback seats in a EG Hatch.
- header and gas mileage
- D16Y7 Airbox blues
- Drum to Disc conversion : Keeping ABS?
- super d series trans
- Ran my D15, did I do ok?
- 95 Civic q's????
- Does MAACO do body work?! Or Just repaint?
- Oil leak
- rpm gauge onto 94 hatch dx
- auto-rx ANyone try it?
- Smokin?
- WHOS AT FAULT?
- hx head swap to cx?
- beginner questions
- a/c overcharge civic 97
- Rear Window Defroster ???'s
- timing belt parts
- Need Some SERIOUS Help with my list of problems
- APexi ws2 vs greddy evo2
- NEED HELP ON SPOILERS!
- cx tach and wiring question
- 12v ignition for ek
- Car overheating due to A/C?
- Stock headlights a little dull. Need help replacing them...
- Q: changing the cx cluster to sir cluster with rpm guage
- K Swap Dyno Results
- skunk 2?
- Does anyone have the part number?
- 92 Civic Hatchback - starting problems
- Hmotorsonline.com offers an eg6 to an eg9 front end conversion?
- WANTED! Complete Swap. B16a2, B18C, along these lines!!
- What rear mount do I need for YS1 Cable into EG
- question about a d16 and a b16 head???
- do a civic 94 2dr front bumper fit a 95 4dr ??
- 00 si side skirt fit hatch?
- how to tell difference between P28 auto and P28 Manaul???
- Konig Helium's info #2
- How to fit S2000 seat into a 1998 civic ??
- Nippon Racing F-2 wheels???
- why wont my radio work?
- cams Itr (98) or skunk2 stage one
- d-series appreciation post
- WILL DEL SOL SEATS BOLD RIGHT ON TO EG
- Is there an air filter for the A/C vents in 92 EG?
- Blew head gasket and fixed now it won't start!!!!
- STOLEN EG! Want to give the cops my engine #
- quick question about smog....
- idle
- Headlight Connector for 2000 Honda Civic
- Quick 92-95 Civic color question...
- Speedometer is PMS'n
- CEL Code 90 Evaporative Emission Control System.....could this be the problem???
- teg rear breaks on eg???
- D15B over B16A?
- problem with gauage cluster
- dont buy gas sunday
- Del Sol b16 Skunk2 IM ???
- >> How do I take apart this piece on the Front Brake.. look plz <<
- HELP !!!! CAR SHUTS OFF RANDOMLY !!!!
- will a obd1 ex auto tranny fit a obd2 ex auto engine??????
- Axles -> Stock or not???
- new guy
- Question about Y8 intake mani and gas mileage
- b16 hydro transmission
- is there a torque spec thread anywhere?
- 96 EK is it OBDI or II?
- CODE PO170 ????
- 99-2000 Civic Fog Lights On 92-95 Honda Civic?
- ball joint
- Stolen Civic in the NorthWest
- 97 civic header question
- Knocking noise coming from front left side?
- WOW...amazingly NICE!!!
- suspension question for a wondering mind....
- Wilwood aluminum master cylinders
- How difficult is it swaping the wiring harness
- will stock ek oem CD player fit into eg console?
- Integra Clutch MC / Civic Clutch MC. Differences? :Throws hail mary to B18C5-EH2:
- B18A into my OBD1 car
- PICS REQUEST: del sol roll cages
- b18 into a ej8 (97 coupe)
- integra brakes
- Custom piping Question, Need help!
- 98 EK HATCHY AIR BOX...
- Gas?
- Exhaust
- whats going on?
- chipping a turbo...diesel
- 1999-2000 si wheels on a '93 DX
- H23 in a Hatch, need help
- 96 civic cx boggs when starting
- too tucked in?
- 94 dx white smoke and bogging
- How to i mount an ITR air box in an 1993 EG
- Anyone heard of DH racing for hondas.(Dave Hickmane racing)
- H22A OR H22A4
- D15b Vtec Tranny Info???? HMO Tranny
- fule problem
- clutch
- what is this noise??!?!?
- rust on ek
- ahh yess another "car wont start" thread
- check engine light was the starter
- will eg seat rails fit onto delsol seats?
- WTF psychotic steering WTF
- rubbing noise from rear drums before and after changing shoes......help!
- Intake manifold on B16a swap in Del Sol
- Custom Exhaust vs. name brand?
- broke axle need help as to which one to get
- Skunk2 intake mani vs. stock for b18c
- cel rob power?
- Some simple upgrade. choice of spark wiresand plugs.
- coilover help pleeeeeasse...
- How can u tell if its a 92-95 SI if the car is stripped?
- [wanted] SOHC exhaust sound clips / vids?
- motor sensors
- Wiring VTEC solenoids
- help with compression ratio... searched...
- How to install Fuel Injector ?
- Axles in.. But not really. QUICK HELP PLEASE
- rate my ride
- hesitation at 3.5k rpm
- rs*r header rare?
- Wussup people... I need some Professional Advice...
- Top Fuel
- Engine Heat Problem
- Idle problems???
- wiring experts
- Engine just shuts off while driving
- ok... search has confused me.
- Whats the best civic to buy?
- New , looking for minor mod suggestions.
- car wont start..(gettin ready 2 lose my mind)
- taillights light up on when lights on- only 3rd brake light turns on when brakes engage.... HELP
- need help quick
- Can I swap a 2000 civic si or integra b18c1 into my 1993 civic si even thogh it is obd1
- help...
- ordering a high flow cat
- plx install having cel prob
- universal oxygen snesor bosch
- Whats the differance between a p28 & p08 ecu
- blue gauges?
- HAs anyones rust came back after welding it?
- noob got a new car, are the parts any good?
- i wonder if any one has done a Ferio swap to their EG8?
- Where is the burnt oil coming from?
- some real questions
- Part # for a plug on an eg firewall for integra
- Compression tested my D16Y7 today
- stock engine in 97 ex coupe?
- Code P-0420 is driving me crazy...Please Help
- new honda sub-compact to replace the civic?
- Y8 Tranny Swap
- Continuous Clutch Problems. Experts Needed. Lots of Symptoms.
- can some 1 give me a link on how to change an ep3 (ctr) s brake pads
- B18c1 Cams
- Problem with acceleration
- >> So what happends when my car doesn't even crank, what the! <<
- where is this part?
- Car wont start Need help. (searched)
- car not starting pls help
- Anybody gotta write up on how to make one of them T adapters for water temp gauge
- Anyone ever relocate their climate control? (EG)
- My speedometer on my 93 civic ex keeps reading then disconnects back and forth
- which tires????
- Exhaust Manifold
- No clutch pressure, pedal stays on the floor
- Tach is jumping like crazy!!!
- my turn signals dont work?
- NEED MODERATOR HELP
- Ls mounts into a EG coupe they fit?
- GSR trottle body holes? Answer to my high idle?
- Cheap Oxygen Sensors for 95 Civic
- Engine Shut Off!!
- What's the best wax?
- 99 Civic Si
- removing my headlights
- LS dizzy on an SI?
- How do you know you have a OEM front 96-98 front bumper?
- I need a stock catback for my 95 dx hatch
- Questions about IM/TB bore on a 2000 si
- Autolock does not work, car just got stolen
- 97 Civic EX stumbling/loss of power in low RPM's.. help.. tried everything
- can i refill my tranny with tranny fluid by removing the spped sensor?
- Newbie on the block...
- exhaust mani question.....What will fit my car?
- Want to swap form eg to ek
- What kind of head are these??
- auto to manual -- piecing together
- 37 MPG?!?! Is my formula correct?
- anyone have a write up for a headgasket change?
- Need your honest opinion. * Thinking about selling the car, but not sure*
- u wouldnt believe what i found stuck in my throttle body
- skunk 2 pro series intake manifold....is it good
- Switch problem ?
- Have questions about 94/with B16A?
- Painting interior vinyl.. yes or no?
- stolen 98 red ex chicago
- did anyone?
- Why you shouldn't drive a lowered civic on a camping trip.
- Utah Honda-Techer's quick question regarding safety inspection
- some pivs of my VTI
- i need someone who know thier hks exhausts!
- Adding airconditioning...?
- Cluster question
- changing input shaft bearing... what else should i get done?
- Problem with Cx motor into crx swap, need help.
- stock axles
- CEL Code 65 "Secondary oxygen sensor heater" '00 Civic DX / SI
- 98 Civic Coupe lip kit
- Swapping ECUs! *Easy quick question*
- whirling sound...need your best guest.
- 92-95 Honda civic Throw out Bearing ??? 5 speed
- Circuit Suspension
- losing oil every 2,500 km's or so..
- Wheel locks with no KEY! How to get them off?
- Can't find radio screws in 98 civic
- Where is the IAT plug on a 97 Civic Harness?
- B18B auto swap into EG
- Cheapest place to buy a intake filter??
- code 41 oygen sensor on my poor mans type r motor turns on and shuts right off.\?
- h22 in an ek
