View Full Version : Honda Civic / Del Sol (1992 - 2000)
- torque mount
- Hey Im New
- Would Volk GT series center caps fit 15" volk TE-37 rims?
- d16z6 timing belt, anyone know how many teeth?
- Replacing Rear Speakers
- a/c condensor cover/blocker
- For those who have slammed EGs
- cam question for 99ex
- wtf is going on!!!!!
- Megan Racing header review
- clutch problems *noise*
- Toda piston kit
- Trying to eliminate unwanted sounds.
- Fog light Question
- tein
- S2000 steering wheel in 92-95 civic?
- OIL PRESSURE GAUGE SENDING UNIT ?
- Need EG climate control help!! Getting cold!! lol
- damn thieves
- recommend me a shifter
- buying a 95 obd1 gsr swap tonight anything i should look for?
- ek motor mounts
- Anyone have clear pics of a GSR IAB system?
- ECU Upgrade
- sputtering engine
- how you do you know if you have a quaife LSD in the tranny with out taking it apart
- Real quick spring question
- Can I fit my Quaife from a z6 tranny in a y8 tranny ???
- NEED ECU PINOUT!
- bad tire?
- Intake manifold hoses help!
- new motor questions
- Z6 Y8 top half .....
- H-T SWAP GURU'S, I NEED YOUR HELP!
- Wiring Diagram 99 Civic
- Rim Wheel Assist
- Advise; purchasing head gasket parts
- Failed Ref Station Again: Anyone know if OBDII Carsound can pass?
- B16A1
- NEED HELP ON COLD START CONCERN
- My new import website
- EK Trunk Light
- EG6 Gathers head unit into a EG9? Already searched.
- whas C laccin
- How to install air/fuel gauge in hatch back vx?
- Is this a D16Y8 IM?
- Cooling fan???
- 3" clearence, I want to keep it that way...
- rod cap doesnt want to come off
- Motor work? who would you perfer to do it?
- 2000 civic si b16a2
- Need to identify different sensors
- what kind of oil pressure should i be getting
- header wrap
- PICTURES OF YOUR FIXED UP EK THE BAY AREA!!
- K series Swap question (did a search)
- Ignition is dead? ...
- Question about b20 short & long blocks ...
- Question regarding axles?
- Need help. Car won't start after B18b swap.
- Limp Mode, IACV, Idle!?!?! (Searched!)
- Rear toe.....
- CEL Code on 2000 SI
- Will this Fit?
- This might sound stupid but how do i make my EG sound system sound like my old Preludes system?
- compression checked my b16
- Help me find my door locks
- Extracting An ECU Pin
- will an ek coupe exhaust manifold, mid/b-pipe and cat work on an ek hatch?
- rattling cant figure out where?
- 99-00 lip
- putting a SI tranny on a VX Q:
- My 93 Del Sol Si
- where is a good place to..........................
- grounding kit diagrams.... anyone have them???
- need help with a 88 civic hatch
- wheeel locks.....help!
- HELP!!! Front OBX Lower Brace...
- Sparco Seat Question
- Hesitation and Fluctuating Idle Problem
- bleeding breaks
- Shifting Wheel Jump
- HID question
- EK foglights
- weird idle and occasional CEL
- OEM CTR ECU and passing emissions
- d15b8 head on d16z6 block
- quick question on k&n filter for my b16a
- jdm itr header into 2.25" piping?
- intermitten wipers
- d16y8 to d16z6
- DIY cheap, temporary starter kit
- WTB Honda civic in chicagoland area
- any one paint cars??? in cali???
- Integra back seat in 92-95 coupe?
- Adv. and Disadv. of a Gsr Motor.
- Window squirters?
- Anyone have a J's racing intake on their Sol, will it fit?
- Big problem with B16A2!!!!
- need help??
- Noob question but i did search. brake light bulbs
- question
- Just got my car back tonight, new ZC engine installed!!!!
- seat covers don't fit???
- backyard special bumper
- sarting... all i get is clicks 00'Si
- h22 swap into 2000 civic
- ulev bypass mod for 2004 civic vp, any help?
- stocked 94 dx civic shakin
- Brake Swap?
- Del sol seats
- Swap!! b16A2 OR H22A
- give me your thoughts...
- del sol leather seats
- HFP Civic Sedan?
- d16y8
- e-brake
- fuel upgrade?
- How does this happen? Cracked Air conditioning compressor
- 2001 civic coupe
- idiots back.
- I am a NEW PROUD owner of a California Bar Sticker!!!
- how to pu a 99 si strut bar onto an eg coupe
- fluidyne or koyo?
- When I drive I fell like something........
- Can a floor mat be painted?
- 98 Civic - what's wrong?
- How to recognize the bad tranny?
- P72 or Chipped P28
- what gauge is stock harness?
- i have a bad clutch
- 99 Si H.I.D. HELP!
- ?Price for Pr3 pistons
- Is there a JDM SOHC 1.6l vtec or just the 1.5l?
- open hood other way
- burning oil
- Help diagnose ticking and smoking issue....
- Civic stock 14" steel steelies wheel offset (searched already)
- ep3 airbag rewire for ek
- Bigger brakes for my CX?
- HELP 2000 SI makes noise
- h22 hatchback
- will buy hondas 4-sale
- STOLEN!!!!!!: 00 Civic Si Electron Blue in Baltimore, MD............
- H22 Idle Problem
- car shakes under braking. (searched already)
- 94 Civic EX-NYC
- LSD - It will fit?
- Question about with turbo to use on my B20
- b16 cold startup gives clunk sound!!
- right spark plugs for a mini-me
- ABS Light Problem w/GSR Cluster in EK
- JDM EG6 side mirrors
- Transmission Problems
- Wiring diagram
- LS motor swap in a DelSol
- del Sol Sweatshirts
- oem style koyo from radiator.com or a two row all metal from radiatorbarn.com?????
- Speed Sensor Issues. Replacment, care, and problems.
- Failed emmission in NJ today. A few questions.
- 1.5 lt non-vtec distributor vs. 1.6 vtec distributor
- FREE Vtec BOOSTER!
- Enclosed Intakes or Regular CAI's
- 94 Civic EX oil leak - from distributor shaft or cam seal???
- What types of OEM seats have you put into your EG?
- does itr axle back fit eg6
- GRINDING NOISE FROM TRANSMISSION.
- black smoke when i go above 5500 rpms
- Apexi SAFC
- How to stop the rattling interior noise ?
- Honda-tech Dictionary?
- Need help on valve adjustment
- Carbon Fiber Overlay Complete Interior!?!?!?
- 95 Eg Si ABS???
- Difference between Civic and Integra Rear Defrost?
- 92-95 white coupe red gt3's
- Question about steering wheel and HID
- help on srs light?
- Fog lights for EVO3 body kit???
- Tokico blues
- My Del Sol sounds like an aquarium
- exhaust for my EK
- Quick easy Question do struts made for 94-00 integra work in 96-00 civics?
- fog lights?
- h&r cup kit question
- OWNERS of Ground Controls! Part numbers? Please HELP!!!
- Small Photoshoot of my buddie's EG
- Any advice before Timing Belt install/insection?
- Swap Question...
- Major Suspension Problems, Need a Quick Fix
- ACT Clutch
- CTR cluster wont dim
- Need Fuse block pin outs for CX civic (92-95)
- need info to convert 96htch from auto to 5 spd
- tokico illuminas
- Intake Mani-Tech
- oil light, could be knock...
- is vtec bad?????????/
- FS: Maxima HID Kit 01-03 O.E
- Just fab'd up a strut/trunk/cross & lower tie bar...
- head gasket
- HELP: Swap problem....
- Max power on stock engine
- h23a vtec JDM blue top problems
- gsr lca's
- tranny problems
- looking for a FAQ
- $5 well spent :-D
- tilted engine?
- B18c5 swap into EK 98 need help
- *Official 2004 Winterizing your EG+Civic/Del Sol Thread*
- CLIMATE CONTROL light out??? HELP! I tried everything! PLEASE
- just gota new tranny...
- Weight of 99 stock hood?
- WHy is my car shaking when i gas?
- what clutch to get?!?
- i need a valve spring compressor asap
- Quick question?
- Looking for someone in San Diego that can build my B18C..
- do I need a new head or what???
- what are the basics for a 97 civic ex coupe?
- master clutch cylnd replaced, now having problems
- D17 Engine Build
- which motor performs better? H22 vs B16 ... or B16 vs B18?
- EG rear disc conversion?
- Advice On Engine Swap For 92-95 Civic Coupe
- Need b16 head torque specs. Please.
- anyone know where i can get some parts?
- does prelude 5 lug fit in my eg hatch?
- Lighting for Civic
- Car still overheating
- civic ex and gsr fuel pumps same?
- Input Shaft Bearing?
- need info on b20 swap into a 99 civic si
- bad suspension?
- quick engine harness question
- Dumb question about cat
- Filling the gap
- Rant from a Trial user :(
- eg hatch exhaust fit on a coupe?
- Anyone know anything about Edelbrock headers?
- how much should these go for????
- need list for H22 swap in 99si
- Sport springs or Racing springs?
- How to install throttle cable (searched)
- k20 swap into eg
- H&R or Eibach
- Bad wheel bearing?
- will a 89 crx si header fit a 92 civic ex?
- how much for new clutch and flywheel
