View Full Version : Honda Civic / Del Sol (1992 - 2000)
- i give it gas but it wont go plzz help ..........
- need a head
- Any A/C Specialist??? Need some help???
- Tein vs. Skunk2
- B18c1 into 97 ek hatch....wich throttle cable?
- 92 ls swap to 94 coupe trouble
- heater core>
- Anyone here ever order a brand new b16a?
- turbo quick question
- power door lock question
- ek power folding mirror question.....
- HONDA DEL SOL FOR SALE
- steering wheel vibration
- hey i got a
- Bypass fan switch
- mount help!!!!!!
- M11-1.25 bolt? where can i find them?
- b series shift linkage
- dyno before turbo
- Mini me gone bad...need advice
- lights diming
- Help with transmission
- speedo guage problems
- single or double bend?
- need help with b20 vtec
- Brake problem...
- service manuals
- EK mid wing mounting, how to?
- HELP! window!
- Question about tranny on 97 Civic HX!!!!!!!!!!!!!!!!!!
- window lube?
- D16 Turbo
- auto tranny woes?
- whats next???
- intake issue
- URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF
- tach not working???
- Thermoswitch size (MM)
- Engine oil overflow.
- are 15in' ctr wheels the same as 15in' teg 98 spec itr wheels
- D16y7 Intake Manifold Nipple!!! what is it?
- Obd1 GSR into 99 cx hatch... HELP PLEASE!!!!!
- DIY - Rear Sub-Frame Brace
- OEM Exhaust Replacement (Civic)
- HELP! What Main/Rod bearings do I need??
- car trouble need help quick!
- 96+ sohc swap into 92-95
- radiator?
- Tsudo Catback
- z6 head
- Idle problems
- gauge cluster stopped working!!!!
- what exuast fits my sol
- Help / Troubleshooting Advise needed!!! Thanks!!!
- Exhaust for 2000 Si Comptech v. Exmag
- my window
- Ebay trbo kits???
- Exhaust Systems???? Anyone Help Me Please
- another boring car wont start thread
- will SRD recaro seats fit in eg?
- CMC problems
- simple question, has anyone used the 3" apexi ws2 turbo muffler on a eg hatch
- Does Integra's Mirrors Fit in Eks?
- Engine smoked when using seafoam. Question about it?
- mysterious electrical issue?
- Rear Main Seal bracket..??
- Battery tie down measurement?
- eg door swap
- Need some help on replacing bad piston rings!!!
- cracked axle?
- 99 EX - LS/Vtec
- anyone else have this problem
- Bad c/v axle seal on tranny??
- Ok, more proportional valve problems! Which one IS IT for an EJ6 ITR5 Lug conversion!?
- Wiring question
- high idle, help b16a3 eg...
- Hood and fender question
- General Exhaust Question
- srs light. already searched.
- SeaFoam done...emissions passed..
- Window problem
- d series block
- Good Vibrations (sort of) and Breathing Easy
- 2.25 piping to magnaflow muffler vs 2.25 piping w/ resonator to MF muffler----sound?
- worth it? 93 turbo coupe
- jumpy idle when engine is warm
- code 9 cyp CEL
- Jackson Racing B16a/B18c5
- is there a diff between a SOHC catalytic and a DOHC cat?
- Help On Exhausts
- 5-speed D16Y7 to D17A1/D17A2 swap.. has anyone done this?
- Water Wetter
- civic launching problem..need help..
- Apexi WS muffler
- idle isues surge between 1000 and 1200
- my Ek Has wierd stuff in radiator!!! LOOK
- pic request: 96-00 civic with 13" steelies
- need help????
- b18a what can i take?
- del sol with h22
- Hotspots on flywheel possibly??
- MY CEL is gone??
- I NEED HELP
- sensor questions
- yes look heree, im debating :-D
- CEL 99 civic si
- brake swap, want input
- SUSPENSIONN springs
- parking lights and city lights on all the time like day time driving lights...
- 95 civic ex motor
- Replacing main and rod beaings, need help!!
- d16y7 ac compressor?
- b18a head
- Shaved Door kit
- cel gett5ng code 6 car is lagging
- Car Surges at 25mph 2nd gear maybe 3rd too... wtf?
- Automatic transmission lockup control valve
- Twin Turbo Kit
- Check Engine Light Comes on
- Update on my braking problems
- crower stage 2 cam d16y8, boost?
- Primary and Secondary O2 Sensor same part?
- sunroof adjustment
- z6 turbo vs b16 swap?
- Throttle body noise
- VW seats?
- Question about 96-98 ek bumper
- Hey engine D15B is What kind of parts!?
- Hey
- What WHP for a Street Ride.
- PIC Performance LCA vs. Koni Yellows
- Clutch pressure
- d16y8
- The never ending transmission leak
- camber kit
- 99 si boosted?
- Help Boosted H22 EK hatch wont start...
- Hondata Gasket
- Mother of all throttle response issues.
- installing brake pads
- Power steering hose question
- To take or no?
- SI Check Engine Light
- Radiator fan wiring?
- any good close up pics of the mounting points on the seatbelts?
- 1992 honda civic dx
- Where is the IAT sensor located on a 99 Civic?
- OBD II Codes!
- need exhaust for 96 hatch with bseries
- eg valves question
- turbo pistons 8.3 compression ratio?
- 92 w/h22...good deal?...
- Front & rear bumper reinforcement
- d15b7 mini me swap
- code 41 help.
- 93 si hatch with b16. alternator ?
- Why is there a state sign
- 97 to 00 civic front end conversion?
- mishimoto radiator for single cam..
- 100% stock d16y7 throws cel "Lean"
- asking price
- Z6 motor into a 96-98 civic
- 00 si muffler
- Any advantage with polyurethane bushings in Camber Kits?
- idle randomly dropping below 700RPM
- jdm ecu vs gsr ecu
- anyone know if the h22 skunk2 pro series manifold would fit inside an ek chasis.
- ECU question
- Caliper seal...
- need help to put my spoon lip on my EK
- What to do with my breaks!!
- 02 sensor
- anyone know where can i buy nrg frogeye gauge pod?
- DA seats into EG?
- B16 block price?
- Is the b16 and b18 timing belt the same?
- Grinding going into 3rd.
- 99 tail lights on 97
- 99 headlights on 97
- knock sensor
- Do I have top hats (Upper mounts on my suspension) ???
- Honda Civic 95 sedan problem and need help please A.S.A.P
- rings
- leaking near passenger glove compartment. Heater core?
- can the b16b throttle fit b16a1?
- quick question..........
- WTF TPS only sold as part of throttle body for B16(a2)
- Feels like clutch is slipping but its not??
- Changing Drivers Side Axle....w/pic for refererance
- blower for turbo?
- TDC on Crank Pulley keep jumping
- d15z7 fuel pump on b16a2 will be OK ?
- whats break boost
- Need Help - Low Idle (only when hot outside)
- Battery Pooched? Has 12.7V but wont start car
- motor mount question
- Accelerator slipping, transmission problem?
- how much would you pay?
- oil leak!!! dont know where from!!
- popping sound???
- Any Dseries Motor Available?
- Blox D-series intake manifold ?
- itr inake manifold on a b16
- h22 into ek
- CEL above 3000RPM?!?!?!?!?! HELP!!! (yes i already searched)
- main relay location for 99 civic hatch?
- Emissions problem with H22 (Chicago)
- bleeding brakes?
- brake pads
- question about vibration for my 97 civic, help
- wont change gear! NEED HELP!!!
- Question: Coilovers vs shocks and springs
- Any advantages with going stock EK over stock EG?
- Where do I feed SEAFOAM in from?
- USA Ferio VI/RS- could u get these state side??
- Flywheel question... Need answer PRONTO
- No crank, no fuel
- Need some help
- Alternator problem or bad ground?
- Help me to make my car safe... Please.
- Should i purchase this h22 civic ?
- my cluster blinks
- d16 y7 with a b16 ecu
- Why do some people leave their Honda? (trying to scope whether or not to buy my first)
- eg9 cluster speedo problem pls help
- do i need new doors?
- changing transmission oil
- Only charging at 12.6 volts... is this normal?
- ecu
- ecu auto to manual- searched
- preparing for EJ8 (96-98 civic) B-series swap, help needed
- Evap question (searched)
- Rear brake conversion, need help??
- rev limiter to early
- 1998 Acura Integra LS V-TEC for sale in NEW JERSEY area!!!!!
- Replacing Airbags and Fixing SRS Light
- A/C in EG with B18C swap
- vtec pressure solenoid problem
- grounding kit
- tricks on sliding on a tranny?
- JDM Cluster Needles on My USDM Cluster???
- si's for sale
- Any EJ or EK pics with honda fit rims?
- oil pressure
- problem solvers..click here...help on d16z6 turbo
- TPS problem
- anyone know the stock honda throttle body bores?
- Who has a D16 Y7 motor? Need you to tell me the colors of your primary O2 wires
- VIN.
- Will a autopower DC2 roll cage fit EG6?
